timeouts and failure
Joel Sherrill
joel at rtems.org
Sat Mar 18 14:00:52 UTC 2017
These are all long running tests. Gedare is on a new computer which I
assume is quite fast. So he has fewer timeouts.
I am out of town but can try to remember to use tsim to get the running
time for some of these in real CPU time. My recollection is that crypt01
takes a long time compared to other tests.
--Joel
On Mar 18, 2017 4:55 AM, "Tanu Hari Dixit" <tokencolour at gmail.com> wrote:
Gedare,
By erc32 under gdb do you mean using --debug-trace=gdb option with
rtems-test ?
I ran a normal
./rtems-test --log=log_erc32_run_alltest_new --rtems-bsp=erc32-run
--rtems-tools=$HOME/development/rtems/4.12
/home/thd/development/rtems/src/builds/b-erc32_allt/sparc-
rtems4.12/c/erc32/testsuites
without the debug trace option and got the following results:
Passed: 543
Failed: 6
Timeouts: 12
Invalid: 0
Total: 561
Failures:
mdosfs_fsscandir01.exe
spcontext01.exe
jffs2_fsscandir01.exe
mrfs_fsscandir01.exe
imfs_fsscandir01.exe
mimfs_fsscandir01.exe
Timeouts:
mdosfs_fsrdwr.exe
mimfs_fserror.exe
fsdosfsname01.exe
mimfs_fspatheval.exe
mouse01.exe
fsdosfswrite01.exe
malloctest.exe
math.exe
crypt01.exe
fsdosfsformat01.exe
mdosfs_fstime.exe
mimfs_fsrdwr.exe
Regards,
Tanu Hari Dixit.
On Sat, Mar 18, 2017 at 11:47 AM, Chris Johns <chrisj at rtems.org> wrote:
> On 18/3/17 11:46 am, Gedare Bloom wrote:
>> I just ran tests and observe the following on erc32 under gdb, can
>> anyone confirm/replicate the timeouts and failure, and know why this
>> is happening?
> How many cores are you using with rtems-test and so how many tests are
> running in parallel? This can effect the time per test and it is
> difficult to know the effect this has on the timeout per host machine
> being used.
> Chris
>> Passed: 554
>> Failed: 1
>> Timeouts: 6
>> Invalid: 0
>> Total: 561
>> Result: timeout Time: 0:03:00.219154 fsdosfsformat01.exe
>> Result: timeout Time: 0:03:00.228353 fsdosfsname01.exe
>> Result: timeout Time: 0:03:00.217955 fsdosfsname02.exe
>> Result: timeout Time: 0:03:00.189769 fsrfsbitmap01.exe
>> Result: timeout Time: 0:03:00.203202 imfs_fserror.exe
>> Result: timeout Time: 0:03:00.207983 crypt01.exe
>> Result: failed Time: 0:00:02.056732 spcontext01.exe
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
devel mailing list
devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170318/1682a499/attachment.html>
