Large number of failures on leon3
Jiri Gaisler
jiri at gaisler.se
Mon Mar 20 11:00:02 UTC 2017
This seems to be a problem with the leon3 bsp, most of the failing tests
work fine on erc32 and leon2. This is regardless of which simulator is
used. Maybe the SMP additions to leon3 breaks something when SMP is
disabled ...? It also goes back in time - I am using git master from
early December 2016 and I see these failures there already ...
Jiri.
On 03/19/2017 02:32 PM, Joel Sherrill wrote:
> Hi
> I was following up on Gedare's testing and tried leon3. There
> were a surprising number of failures there with SMP disabled.
> This is testing with gdb. Does anyone else get the same
> results with qemu or tsim? Any idea what's broken?
> Passed: 458
> Failed: 20
> Timeouts: 73
> Invalid: 3
> Total: 554
> Failures:
> cdtest.exe
> spintrcritical20.exe
> dl05.exe
> spintrcritical01.exe
> spintrcritical04.exe
> spintrcritical10.exe
> spintrcritical22.exe
> sp69.exe
> spintrcritical21.exe
> sp11.exe
> spintrcritical16.exe
> spintrcritical23.exe
> psxfile01.exe
> spintrcritical05.exe
> spintrcritical02.exe
> spintrcritical08.exe
> psxgetrusage01.exe
> spcpucounter01.exe
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170320/893c3b57/attachment.html>
