RTEMS 4.11.2 milestone date
Tue Mar 21 01:19:44 UTC 2017
On 17/03/2017 12:34, Chris Johns wrote:
> On 17/03/2017 10:58, Gedare Bloom wrote:
>> On Thu, Mar 16, 2017 at 7:52 PM, Joel Sherrill <joel at rtems.org> wrote:
>>> You couldn't build powerpc gdb because of the error symbol. There was
>>> something
> Ah yes something in the simulator is referencing a C symbol when it will
> now be a C++ symbol, ie missing include somewhere. I wonder if this is a
> clang vs gcc issue. This was using the latest gdb so I will see if it is
> a problem with the 4.11 gdb.
This does not happen building the 4.11 tools on FreeBSD 11.0.
>>> with max_align_t but I think that got resolved.
>> https://sourceware.org/bugzilla/show_bug.cgi?id=21206
> Yes, and this is fixed on 4.12 (master). I may need to backport the fix.
> It is isolated to FreeBSD hosts so a low impact fix.
This issue does not appear on the 4.11 branch on FreeBSD 11.0.
