答复: [PATCH] modify punitvara's works on BBB i2c, and now can read the eeprom info.
赵 思晨
zsc19940506 at outlook.com
Tue Mar 21 05:21:15 UTC 2017
Hi all:
I think it can use in i2c devices, but i don't test it.
and the read_eeprom is using reading the eeprom. and i will modify it in the future, conform my code to the RTEMS code specification.
Best regrads
Sichen Zhao
发自 Outlook<http://aka.ms/weboutlook>
________________________________
发件人: devel <devel-bounces at rtems.org> 代表 Ben Gras <beng at shrike-systems.com>
发送时间: 2017年3月21日 12:12:42
收件人: devel at rtems.org; 1473996754 at qq.com
主题: Re: [PATCH] modify punitvara's works on BBB i2c, and now can read the eeprom info.
Dear all,
SZ, great initiative. Gedare and Sebastian have commented.
For my part, can I just check - the implementation is supposed to be
generic to i2c devices, correct?
If so, can you explain what read_eeprom is for? Is it just as demo? Is
the code generic otherwise?
Cheers,
Ben
On 03/14/2017 10:05 AM, Sichen Zhao wrote:
> c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c | 684 ++++++++++++++++++++++++++++--
> c/src/lib/libbsp/arm/beagle/include/i2c.h | 18 +-
> cpukit/dev/i2c/eeprom.c | 24 +-
> testsuites/samples/i2c0/init.c | 98 ++++-
> 4 files changed, 777 insertions(+), 47 deletions(-)
> diff --git a/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c b/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
> index 6b790e5..6a22125 100644
> --- a/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
> +++ b/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
> @@ -21,11 +21,23 @@
> #include <bsp/bbb-gpio.h>
> #include <rtems/score/assert.h>
> +#define u16 unsigned int
> +static int am335x_i2c_set_clock(i2c_bus *base, unsigned long clock);
> +static void omap24_i2c_init(i2c_bus *base);
> +static void flush_fifo(i2c_bus *base);
> +static int wait_for_bb(i2c_bus *base);
> +static int omap24_i2c_probe(i2c_bus *base);
> +static u16 wait_for_event(i2c_bus *base);
> +static int am335x_i2c_read(i2c_bus *base, unsigned char chip, uint addr, int alen, unsigned char *buffer,
> + int len);
> +static int read_eeprom(i2c_bus *base,struct am335x_baseboard_id *header);
> +static int am335x_i2c_write(i2c_bus *base, unsigned char chip, uint addr,int alen, unsigned char *buffer,
> + int len);
> static bool am335x_i2c_pinmux(bbb_i2c_bus *bus)
> bool status =true;
> // We will check i2c_bus_id in am335x_i2c_bus_register
> // Apart from mode and pull_up register what about SCREWCTRL & RXACTIVE ??
> if (bus->i2c_bus_id == I2C1) {
> @@ -48,9 +60,7 @@ static bool am335x_i2c_pinmux(bbb_i2c_bus *bus)
> /* ref. Table 21-4 I2C Clock Signals */
> For I2C1/2
> Interface clock - 100MHz - CORE_LKOUTM4 / 2 - pd_per_l4ls_gclk
> Functional clock - 48MHz - PER_CLKOUTM2 / 4 - pd_per_ic2_fclk
> @@ -74,7 +84,6 @@ state. Functional clocks are guarantied to stay present. As long as in
> this configuration, power domain sleep transition cannot happen.*/
> /* REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKCTRL) |=
> AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE;
> while((REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKCTRL) &
> AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE) != AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE);
> @@ -86,30 +95,29 @@ this configuration, power domain sleep transition cannot happen.*/
> REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C1_CLKCTRL) |=
> AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE_ENABLE;
> while(REG((AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C1_CLKCTRL) &
> AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE) != AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE_ENABLE);
> } else if (bus->i2c_bus_id == I2C2) {
> REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C2_CLKCTRL) |=
> AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE_ENABLE;
> while(REG((AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C2_CLKCTRL) &
> AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE) != AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE_ENABLE);
> while(!(REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKSTCTRL) &
> (AM335X_CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_L4LS_GCLK |
> AM335X_CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_I2C_FCLK)));
> static void am335x_i2c0_pinmux(bbb_i2c_bus *bus)
> - REG(bus->regs + AM335X_CONF_I2C0_SDA) =
> + printf("0x44e10000 + AM335X_CONF_I2C0_SDA:%x\n",0x44e10000 + AM335X_CONF_I2C0_SDA);
> + printf("bus->regs:%x\n", bus->regs);
> + REG(0x44e10000 + AM335X_CONF_I2C0_SDA) =
> (BBB_RXACTIVE | BBB_SLEWCTRL | BBB_PU_EN);
> - REG(bus->regs + AM335X_CONF_I2C0_SCL) =
> + REG(0x44e10000 + AM335X_CONF_I2C0_SCL) =
> @@ -314,14 +322,29 @@ void am335x_i2c_init(bbb_i2c_bus *bus, uint32_t input_clock)
> static bool am335x_i2c_busbusy(volatile bbb_i2c_regs *regs)
> bool status;
> - if (REG(®s->BBB_I2C_IRQSTATUS_RAW) & AM335X_I2C_IRQSTATUS_RAW_BB)
> + unsigned short stat;
> + int timeout = I2C_TIMEOUT;
> + REG(®s->BBB_I2C_IRQSTATUS)=0xffff;
> + printf("REG(®s->BBB_I2C_IRQSTATUS_RAW):%x\n",REG(®s->BBB_I2C_IRQSTATUS_RAW) );
> + // printf("%x\n",0x1400 & 0x1000 );
> + printf("REG(®s->BBB_I2C_IRQSTATUS_RAW) & AM335X_I2C_IRQSTATUS_RAW_BB:%x\n",(REG(®s->BBB_I2C_IRQSTATUS_RAW) & AM335X_I2C_IRQSTATUS_RAW_BB));
> +while(stat =( REG(®s->BBB_I2C_IRQSTATUS_RAW) & AM335X_I2C_IRQSTATUS_RAW_BB) && timeout--)
> - status = true;
> - } else {
> - status = false;
> +REG(®s->BBB_I2C_IRQSTATUS)=stat;
> + udelay(20);
> + if (timeout <= 0) {
> + printf("Timed out in wait_for_bb: status=%04x\n",
> + stat);
> + return 1;
> - return status;
> + REG(®s->BBB_I2C_IRQSTATUS)=0xffff; /* clear delayed stuff*/
> + return 0;
> static void am335x_i2c_reset(bbb_i2c_bus *bus)
> @@ -330,9 +353,27 @@ static void am335x_i2c_reset(bbb_i2c_bus *bus)
> printk("reset bus->reg is %x \n",bus->regs);
> /* Disable I2C module at the time of initialization*/
> /*Should I use write32 ?? I guess mmio_clear is correct choice here*/
> + REG(®s->BBB_I2C_CON)=0x00;
> printk("inside BBB_I2C_CON value is %x \n",®s->BBB_I2C_CON);
> - mmio_clear((®s->BBB_I2C_CON),AM335X_I2C_CON_I2C_EN);
> - mmio_clear((®s->BBB_I2C_SYSC),AM335X_I2C_SYSC_AUTOIDLE);
> + REG(®s->BBB_I2C_SYSC)= 0x2;
> +// mmio_clear((®s->BBB_I2C_CON),AM335X_I2C_CON_I2C_EN);
> + REG(®s->BBB_I2C_CON)= AM335X_I2C_CON_I2C_EN;
> + while((REG(®s->BBB_I2C_SYSS) &I2C_SYSS_RDONE)==0) //wait reset done
> + udelay(100);
> + am335x_i2c_set_clock(&bus->base, I2C_BUS_CLOCK_DEFAULT);
> + REG(®s->BBB_I2C_CON)= AM335X_I2C_CON_MST | AM335X_I2C_CON_I2C_EN;
> +// mmio_clear((®s->BBB_I2C_SYSC),AM335X_I2C_SYSC_AUTOIDLE);
> //REG(bus->regs + AM335X_I2C_CON) &= ~(AM335X_I2C_CON_I2C_EN);
> //REG(bus->regs + AM335X_I2C_SYSC) &= ~(AM335X_I2C_SYSC_AUTOIDLE);
> @@ -385,6 +426,7 @@ static unsigned int am335x_i2c_intrawstatus(volatile bbb_i2c_regs *regs)
> static void am335x_i2c_masterint_enable(volatile bbb_i2c_regs *regs, unsigned int flag)
> + printf("am335x_i2c_masterint_enable func\n");
> REG(®s->BBB_I2C_IRQENABLE_SET) |= flag;
> @@ -401,6 +443,7 @@ static void am335x_int_clear(volatile bbb_i2c_regs *regs, unsigned int flag)
> static void am335x_clean_interrupts(volatile bbb_i2c_regs *regs)
> + printf("am335x_clean_interrupts func\n");
> am335x_i2c_masterint_enable(regs,0x7FFF);
> am335x_int_clear(regs,0x7FFF);
> am335x_i2c_masterint_disable(regs,0x7FFF);
> @@ -412,30 +455,69 @@ static void am335x_i2c_setup_read_transfer(bbb_i2c_bus *bus, volatile bbb_i2c_re
> volatile unsigned int no_bytes;
> //am335x_i2c_masterint_enable(regs, AM335X_I2C_INT_RECV_READY);
> // No of data to be transmitted at a time
> +//bbb_i2c_bus *bus = (bbb_i2c_bus *) base;
> +// volatile bbb_i2c_regs *regs = bus->regs;
> + struct am335x_baseboard_id header;
> + omap24_i2c_probe(&bus->base);
> + read_eeprom(&bus->base,&header);
> REG(®s->BBB_I2C_CNT) = 0x02;
> no_bytes = REG(®s->BBB_I2C_CNT);
> + // Set Slave address & Master enable, bring out of reset
> + REG(®s->BBB_I2C_SA) = msgs->addr;
> + printf("slave address : %x\n",REG(®s->BBB_I2C_SA));
> // I2C Controller in Master Mode
> - REG(®s->BBB_I2C_CON) = AM335X_I2C_CFG_MST_TX | AM335X_I2C_CON_I2C_EN | AM335X_I2C_CON_START | AM335X_I2C_CON_MST;
> + REG(®s->BBB_I2C_CON) = AM335X_I2C_CFG_MST_TX | AM335X_I2C_CON_MST | AM335X_I2C_CON_START | AM335X_I2C_CON_I2C_EN | AM335X_I2C_CON_STOP;
> printk("set master in transmission mode %x \n",REG(®s->BBB_I2C_CON));
> - // Set Slave address & Master enable, bring out of reset
> - REG(®s->BBB_I2C_SA) = msgs->addr;
> - printf("slave address : %x\n",REG(®s->BBB_I2C_SA));
> +while(am335x_i2c_busbusy(regs) != 0);
> + printk("bus is free \n");
> // clear status of all interrupts
> am335x_clean_interrupts(regs);
> printk("\n set memory address to read\n");
> // transmit interrupt is enabled
> am335x_i2c_masterint_enable(regs,AM335X_I2C_IRQSTATUS_XRDY);
> printk("Enable transmit interrupt \n");
> //start condition
> - REG(®s->BBB_I2C_CON) |= AM335X_I2C_CON_START;
> + REG(®s->BBB_I2C_CON) |= AM335X_I2C_CON_START | AM335X_I2C_CON_I2C_EN;
> printk("start transmission \n");
> - while(am335x_i2c_busbusy(regs) == 0);
> - printk("bus is free \n");
> printk("CNT : %x\n", no_bytes);
> + printf("BBB_I2C_DATA:%x\n", readb(®s->BBB_I2C_DATA));
> +writeb(0x5,®s->BBB_I2C_DATA);
> +printf("(0x50 >> 8)& 0xff:%x\n",(0x50 >> 8)& 0xff);
> +printf("REG(®s->BBB_I2C_DATA):%x\n",readb(®s->BBB_I2C_DATA) );
> +printf("®s->BBB_I2C_DATA:%x\n",®s->BBB_I2C_DATA);
> +//REG(®s->BBB_I2C_IRQSTATUS)=AM335X_I2C_IRQSTATUS_XRDY;
> +udelay(10);
> +writeb(0x0,®s->BBB_I2C_DATA);
> +//REG(®s->BBB_I2C_DATA)= ( (0x50 >> 0)& 0xff);
> +printf("(0x50 >> 0)& 0xff:%x\n",(0x50 >> 0)& 0xff);
> +REG(®s->BBB_I2C_IRQSTATUS)=AM335X_I2C_IRQSTATUS_XRDY;
> + // no_bytes = REG(®s->BBB_I2C_CNT);
> while(0 != no_bytes);
> printk("total msg count for tranmission is zero \n");
> while( !(am335x_i2c_intrawstatus(regs) & (AM335X_I2C_IRQSTATUS_ARDY)));
> @@ -464,6 +546,7 @@ static void am335x_i2c_setup_read_transfer(bbb_i2c_bus *bus, volatile bbb_i2c_re
> printk("Exit read transfer\n");
> @@ -570,11 +653,16 @@ static void am335x_i2c_setup_transfer(bbb_i2c_bus *bus, volatile bbb_i2c_regs *r
> regs = bus->regs;
> - REG(&bus->regs->BBB_I2C_BUF) |= AM335X_I2C_BUF_TXFIFO_CLR;
> - REG(&bus->regs->BBB_I2C_BUF) |= AM335X_I2C_BUF_RXFIFO_CLR;
> - am335x_i2c_set_address_size(msgs,regs);
> - bus->read = ((bus->read == true) ? 0:1);
> + printf("REG(®s->BBB_I2C_DATA):%x\n",REG(®s->BBB_I2C_DATA) );
> + // REG(&bus->regs->BBB_I2C_BUF) |= AM335X_I2C_BUF_TXFIFO_CLR;
> + // REG(&bus->regs->BBB_I2C_BUF) |= AM335X_I2C_BUF_RXFIFO_CLR;
> +printf("REG(®s->BBB_I2C_DATA):%x\n",REG(®s->BBB_I2C_DATA) );
> + // am335x_i2c_set_address_size(msgs,regs);
> +bus->read = (msgs->flags & I2C_M_RD) != 0;
> +printf("bus->read:%d\n",bus->read );
> + //bus->read = ((bus->read == true) ? 0:1);
> bus->already_transferred = (bus->read == true) ? 0 : 1;
> if (bus->read) {
> @@ -652,7 +740,7 @@ static int am335x_i2c_transfer(i2c_bus *base, i2c_msg *msgs, uint32_t msg_count)
> bbb_i2c_bus *bus = (bbb_i2c_bus *)base;
> volatile bbb_i2c_regs *regs;
> uint32_t i;
> - printk("\n enter transfer ");
> + printk("\n enter transfer\n ");
> rtems_task_wake_after(1);
> @@ -665,20 +753,23 @@ static int am335x_i2c_transfer(i2c_bus *base, i2c_msg *msgs, uint32_t msg_count)
> return -EINVAL;
> + printf("bus->regs:%x\n",bus->regs );
> bus->msgs = &msgs[0];
> bus->msg_todo = msg_count;
> printk("total msg = msg_count : %x \n",bus->msg_todo);
> bus->current_msg_todo = msgs[0].len;// current data size
> - bus->current_msg_byte = msgs[0].buf;// current data
> + //bus->current_msg_byte = msgs[0].buf;// current data
> printk("\n current_msg_todo %x \n ",msgs[0].len);
> printk("\n current_msg_byte %x \n ",msgs[0].buf);
> + //printf("8011A5CC:%x\n", *(unsigned int *)(0x8011A5CC) );
> bus->task_id = rtems_task_self();
> regs = bus->regs;
> - am335x_i2c_setup_transfer(bus,regs);
> - REG(®s->BBB_I2C_IRQENABLE_SET) = BBB_I2C_IRQ_USED;
> + // REG(®s->BBB_I2C_IRQENABLE_SET) = BBB_I2C_IRQ_USED;
> + am335x_i2c_setup_transfer(bus,regs);
> sc = rtems_event_transient_receive(RTEMS_WAIT, bus->base.timeout);
> // If timeout then return timeout error
> if (sc != RTEMS_SUCCESSFUL) {
> @@ -688,7 +779,9 @@ static int am335x_i2c_transfer(i2c_bus *base, i2c_msg *msgs, uint32_t msg_count)
> return -ETIMEDOUT;
> printk("exit transfer\n");
> // return bus->regs->BBB_I2C_IRQSTATUS == 0 ? 0 : -EIO;
> return 0;
> @@ -700,19 +793,28 @@ static int am335x_i2c_set_clock(i2c_bus *base, unsigned long clock)
> uint32_t prescaler,divider;
> printk("set clock start\n");
> + REG(®s->BBB_I2C_CON)=0;
> prescaler = (BBB_I2C_SYSCLK / BBB_I2C_INTERNAL_CLK) -1;
> + printf("prescaler:%d\n",prescaler );
> printk("PSC offset %x \n ",®s->BBB_I2C_PSC);
> printk("PSC offset %x \n", &bus->regs->BBB_I2C_PSC);
> //mmio_write((®s->BBB_I2C_PSC), prescaler);
> REG(&bus->regs->BBB_I2C_PSC) = prescaler;
> divider = BBB_I2C_INTERNAL_CLK/(2*clock);
> + printf("divider:%d\n", divider);
> printk("SCLL offset %x \n",&bus->regs->BBB_I2C_SCLL);
> //mmio_write((®s->BBB_I2C_SCLL), (divider - 7));
> REG(&bus->regs->BBB_I2C_SCLL) = (divider - 7);
> //mmio_write((®s->BBB_I2C_SCLH), (divider - 5));
> printk("SCHL offset %x\n",&bus->regs->BBB_I2C_SCLH);
> REG(&bus->regs->BBB_I2C_SCLH) = (divider - 5);
> + REG(®s->BBB_I2C_CON)=I2C_CON_EN;
> +writew(0xFFFF, &bus->regs->BBB_I2C_IRQSTATUS); /* clear all pending status */
> printk("set clock end \n");
> return 0;
> @@ -729,6 +831,8 @@ static void am335x_i2c_destroy(i2c_bus *base)
> i2c_bus_destroy_and_free(&bus->base);
> int am335x_i2c_bus_register(
> const char *bus_path,
> uintptr_t register_base,
> @@ -751,14 +855,15 @@ int am335x_i2c_bus_register(
> bus->regs = (volatile bbb_i2c_regs *) register_base;
> // 1. Enable clock for I2CX
> - I2C0ModuleClkConfig();
> + I2C0ModuleClkConfig();
> // 2. pinmux setup
> am335x_i2c0_pinmux(bus);
> // 3. RESET : Disable Master, autoideal
> - am335x_i2c_reset(bus);
> + // am335x_i2c_reset(bus);
> // 4. configure bus speed
> bus->input_clock = input_clock; // By default 100KHz. Normally pass 100KHz as argument
> printk("Before set clock \n");
> err = am335x_i2c_set_clock(&bus->base, I2C_BUS_CLOCK_DEFAULT);
> @@ -768,12 +873,16 @@ int am335x_i2c_bus_register(
> rtems_set_errno_and_return_minus_one(-err);
> bus->irq = irq;
> +omap24_i2c_init(&bus->base);
> //bring I2C out of reset
> - REG(&bus->regs->BBB_I2C_CON) |= AM335X_I2C_CON_I2C_EN;
> +//printf("REG(®s->BBB_I2C_IRQSTATUS):%x\n",REG(&bus->regs->BBB_I2C_IRQSTATUS));
> + // REG(&bus->regs->BBB_I2C_CON) |= AM335X_I2C_CON_I2C_EN;
> // 5. Start interrupt service routine & one interrupt at a time
> sc = rtems_interrupt_handler_install(
> irq,
> "BBB I2C",
> @@ -787,6 +896,7 @@ int am335x_i2c_bus_register(
> rtems_set_errno_and_return_minus_one(EIO);
> // 6. start transfer for reading and writing
> bus->base.transfer = am335x_i2c_transfer;
> bus->base.set_clock = am335x_i2c_set_clock;
> @@ -794,3 +904,499 @@ int am335x_i2c_bus_register(
> printk("exit register\n");
> return i2c_bus_register(&bus->base,bus_path);
> + bbb_i2c_bus *bus = (bbb_i2c_bus *) base;
> + volatile bbb_i2c_regs *regs = bus->regs;
> + int deblock = 1;
> +printf("omap24_i2c_init func!!!!!!\n");
> +retry:
> + if (readw(&bus->regs->BBB_I2C_CON) & I2C_CON_EN) {
> + writew(0, &bus->regs->BBB_I2C_CON);
> + udelay(50000);
> + writew(0x2, &bus->regs->BBB_I2C_SYSC); /* for ES2 after soft reset */
> + udelay(1000);
> + writew(I2C_CON_EN, &bus->regs->BBB_I2C_CON);
> + while (!(readw(&bus->regs->BBB_I2C_SYSS) & I2C_SYSS_RDONE) && timeout--) {
> + puts("ERROR: Timeout in soft-reset\n");
> + return;
> + udelay(1000);
> +am335x_i2c_set_clock(&bus->base, I2C_BUS_CLOCK_DEFAULT);
> + /* own address */
> + writew(1, &bus->regs->BBB_I2C_OA);
> +//#if defined(CONFIG_OMAP243X) || defined(CONFIG_OMAP34XX)
> + * Have to enable interrupts for OMAP2/3, these IPs don't have
> + * an 'irqstatus_raw' register and we shall have to poll 'stat'
> + // writew(I2C_IE_XRDY_IE | I2C_IE_RRDY_IE | I2C_IE_ARDY_IE | I2C_IE_NACK_IE | I2C_IE_AL_IE, &i2c_base->ie);
> +//#endif
> + udelay(1000);
> + flush_fifo(&bus->base);
> + writew(0xFFFF, &bus->regs->BBB_I2C_IRQSTATUS);
> + /* Handle possible failed I2C state */
> + if (wait_for_bb(&bus->base))
> + if (deblock == 1) {
> + //omap24_i2c_deblock(&bus->base);
> + printf("deblock\n");
> + deblock = 0;
> + goto retry;
> + // omap24_i2c_probe(&bus->base);
> + // read_eeprom(&bus->base,&header);
> + u16 stat;
> +printf("flush_fifo\n");
> + * note: if you try and read data when its not there or ready
> + * you get a bus error
> + while (1) {
> + stat = readw(&bus->regs->BBB_I2C_IRQSTATUS);
> + if (stat == I2C_STAT_RRDY) {
> + readb(&bus->regs->BBB_I2C_DATA);
> + writew(I2C_STAT_RRDY, &bus->regs->BBB_I2C_IRQSTATUS);
> + udelay(1000);
> + } else
> + break;
> + u16 stat;
> +printf("wait_for_bb\n");
> + writew(0xFFFF, &bus->regs->BBB_I2C_IRQSTATUS); /* clear current interrupts...*/
> +//printf("test1\n");
> + /* Read RAW status */
> +//printf("%x\n", readw(&bus->regs->BBB_I2C_IRQSTATUS_RAW) & I2C_STAT_BB);
> + while ((stat = readw(&bus->regs->BBB_I2C_IRQSTATUS_RAW) &
> + I2C_STAT_BB) && timeout--) {
> + writew(stat, &bus->regs->BBB_I2C_IRQSTATUS);
> + udelay(200);
> + stat);
> + return 1;
> + writew(0xFFFF, &bus->regs->BBB_I2C_IRQSTATUS); /* clear delayed stuff*/
> + return 0;
> + unsigned char chip = 0x50;
> + u16 status;
> + int res = 1; /* default = fail */
> +printf("omap24_i2c_probe\n");
> + if (chip == readw(&bus->regs->BBB_I2C_OA))
> + return res;
> + /* Wait until bus is free */
> + return res;
> + /* No data transfer, slave addr only */
> + writew(chip, &bus->regs->BBB_I2C_SA);
> + /* Stop bit needed here */
> + writew(I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_TRX |
> + I2C_CON_STP, &bus->regs->BBB_I2C_CON);
> + status = wait_for_event(&bus->base);
> + if ((status & ~I2C_STAT_XRDY) == 0 || (status & I2C_STAT_AL)) {
> + * With current high-level command implementation, notifying
> + * the user shall flood the console with 127 messages. If
> + * silent exit is desired upon unconfigured bus, remove the
> + * following 'if' section:
> + if (status == I2C_STAT_XRDY)
> + printf("i2c_probe: pads on bus probably not configured (status=0x%x)\n",status);
> + goto pr_exit;
> + /* Check for ACK (!NAK) */
> + if (!(status & I2C_STAT_NACK)) {
> + printf("Device found\n");
> + res = 0; /* Device found */
> + udelay(200);/* Required by AM335X in SPL */
> + /* Abort transfer (force idle state) */
> + writew(I2C_CON_MST | I2C_CON_TRX, &bus->regs->BBB_I2C_CON); /* Reset */
> + udelay(1000);
> + writew(I2C_CON_EN | I2C_CON_MST | I2C_CON_TRX |
> + I2C_CON_STP, &bus->regs->BBB_I2C_CON); /* STP */
> +pr_exit:
> + return res;
> + u16 status;
> +//printf("wait_for_event \n");
> + do {
> + udelay(200);
> + status = readw(&bus->regs->BBB_I2C_IRQSTATUS_RAW);
> + } while (!(status &
> + (I2C_STAT_ROVR | I2C_STAT_XUDF | I2C_STAT_XRDY |
> + I2C_STAT_RRDY | I2C_STAT_ARDY | I2C_STAT_NACK |
> + I2C_STAT_AL)) && timeout--);
> + printf("Timed out in wait_for_event: status=%04x\n",
> + status);
> + * If status is still 0 here, probably the bus pads have
> + * not been configured for I2C, and/or pull-ups are missing.
> + printf("Check if pads/pull-ups of bus are properly configured\n");
> + status = 0;
> + return status;
> + int len)
> + int i2c_error = 0;
> + int i=0;
> + u16 status;
> +printf("am335x_i2c_read\n");
> + if (alen < 0) {
> + puts("I2C read: addr len < 0\n");
> + return 1;
> + if (len < 0) {
> + puts("I2C read: data len < 0\n");
> + return 1;
> + if (buffer == NULL) {
> + puts("I2C read: NULL pointer passed\n");
> + return 1;
> + if (alen > 2) {
> + printf("I2C read: addr len %d not supported\n", alen);
> + return 1;
> + if (addr + len > (1 << 16)) {
> + puts("I2C read: address out of range\n");
> + return 1;
> + /* Wait until bus not busy */
> + return 1;
> +//printf("test2\n");
> + /* Zero, one or two bytes reg address (offset) */
> + writew(alen, &bus->regs->BBB_I2C_CNT);
> + /* Set slave address */
> +//printf("test3\n");
> + if (alen) {
> + /* Must write reg offset first */
> + /* Stop - Start (P-S) */
> + writew(I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_STP |
> + I2C_CON_TRX, &bus->regs->BBB_I2C_CON);
> + /* Send register offset */
> + while (1) {
> + printf("status:%x\n",status );
> + /* Try to identify bus that is not padconf'd for I2C */
> + if (status == I2C_STAT_XRDY) {
> + i2c_error = 2;
> + printf("i2c_read (addr phase): pads on bus probably not configured (status=0x%x)\n",
> + status);
> + goto rd_exit;
> + if (status == 0 || (status & I2C_STAT_NACK)) {
> + i2c_error = 1;
> + printf("i2c_read: error waiting for addr ACK (status=0x%x)\n",
> + status);
> + goto rd_exit;
> + if (alen) {
> + if (status & I2C_STAT_XRDY) {
> + // printf("alen:%d\n",alen );
> + alen--;
> + // printf("addr:%x\n",addr );
> + // printf("(addr >> (8 * alen)) & 0xff:%x\n",(addr >> (8 * alen)) & 0xff );
> + /* Do we have to use byte access? */
> + writeb((addr >> (8 * alen)) & 0xff,
> + &bus->regs->BBB_I2C_DATA);
> + writew(I2C_STAT_XRDY, &bus->regs->BBB_I2C_IRQSTATUS);
> + if (status & I2C_STAT_ARDY) {
> + writew(I2C_STAT_ARDY, &bus->regs->BBB_I2C_IRQSTATUS);
> + break;
> + /* Read len bytes from slave */
> + writew(len, &bus->regs->BBB_I2C_CNT);
> + /* Need stop bit here */
> + I2C_CON_STT | I2C_CON_STP,
> + &bus->regs->BBB_I2C_CON);
> +//printf("test4\n");
> + /* Receive data */
> + while (1) {
> + // printf("test 5\n");
> + * Try to identify bus that is not padconf'd for I2C. This
> + * state could be left over from previous transactions if
> + * the address phase is skipped due to alen=0.
> + i2c_error = 2;
> + printf("i2c_read (data phase): pads on bus probably not configured (status=0x%x)\n",
> + status);
> + goto rd_exit;
> + // printf("i2c_error = 1\n");
> + i2c_error = 1;
> + goto rd_exit;
> + if (status & I2C_STAT_RRDY) {
> + char temp;
> + temp=readb(&bus->regs->BBB_I2C_DATA);
> + *buffer++ =temp;
> + *bus->msgs[0].buf++=temp;
> + // (*(uint8_t *) bus->current_msg_byte[0]) = readb(&bus->regs->BBB_I2C_DATA) & 0xFF;
> + i++;
> + break;
> +rd_exit:
> +//printf("rd_exit\n");
> +//printf("i2c_error:%d\n",i2c_error);
> + return i2c_error;
> +bbb_i2c_bus *bus = (bbb_i2c_bus *) base;
> +printf("sizeof(struct am335x_baseboard_id):%d\n",sizeof(struct am335x_baseboard_id) );
> +//printf("sizeof(struct am335x_baseboard_id):%d\n",sizeof(unsigned int) );
> + am335x_i2c_read(&bus->base,0x50,0,2,(unsigned char *)header,sizeof(struct am335x_baseboard_id));
> +printf("am335x_i2c_read end\n");
> + printf("header->magic:%x\n", header->magic);
> + printf("header->name[0]:%x\n", header->name[0]);
> + printf("header->name[1]:%x\n", header->name[1]);
> + printf("header->name[2]:%x\n", header->name[2]);
> + printf("header->name[3]:%x\n", header->name[3]);
> + printf("header->name[4]:%x\n", header->name[4]);
> + printf("header->name[5]:%x\n", header->name[5]);
> + printf("header->name[6]:%x\n", header->name[6]);
> + printf("header->name[7]:%x\n", header->name[7]);
> + int len)
> + int i;
> + u16 status;
> + if (alen < 0) {
> + puts("I2C write: addr len < 0\n");
> + return 1;
> + if (len < 0) {
> + puts("I2C write: data len < 0\n");
> + return 1;
> + puts("I2C write: NULL pointer passed\n");
> + return 1;
> + if (alen > 2) {
> + printf("I2C write: addr len %d not supported\n", alen);
> + return 1;
> + printf("I2C write: address 0x%x + 0x%x out of range\n",
> + addr, len);
> + return 1;
> + return 1;
> + /* Start address phase - will write regoffset + len bytes data */
> + writew(alen + len, &bus->regs->BBB_I2C_CNT);
> + writew(chip,&bus->regs->BBB_I2C_SA);
> + I2C_CON_STP,&bus->regs->BBB_I2C_CON);
> + while (alen) {
> + /* Must write reg offset (one or two bytes) */
> + i2c_error = 2;
> + printf("i2c_write: pads on bus probably not configured (status=0x%x)\n",status);
> + goto wr_exit;
> + i2c_error = 1;
> + printf("i2c_write: error waiting for addr ACK (status=0x%x)\n",
> + status);
> + goto wr_exit;
> + alen--;
> + writeb((addr >> (8 * alen)) & 0xff, &bus->regs->BBB_I2C_DATA);
> + } else {
> + i2c_error = 1;
> + printf("i2c_write: bus not ready for addr Tx (status=0x%x)\n",
> + status);
> + goto wr_exit;
> + /* Address phase is over, now write data */
> + for (i = 0; i < len; i++) {
> + i2c_error = 1;
> + printf("i2c_write: error waiting for data ACK (status=0x%x)\n",
> + status);
> + goto wr_exit;
> + writeb(buffer[i], &bus->regs->BBB_I2C_DATA);
> + } else {
> + i2c_error = 1;
> + printf("i2c_write: bus not ready for data Tx (i=%d)\n",
> + i);
> + goto wr_exit;
> + * poll ARDY bit for making sure that last byte really has been
> + * transferred on the bus.
> + do {
> + } while (!(status & I2C_STAT_ARDY) && timeout--);
> + if (timeout <= 0)
> + printf("i2c_write: timed out writig last byte!\n");
> +wr_exit:
> + return i2c_error;
> diff --git a/c/src/lib/libbsp/arm/beagle/include/i2c.h b/c/src/lib/libbsp/arm/beagle/include/i2c.h
> index d4a9e32..6c924ee 100644
> --- a/c/src/lib/libbsp/arm/beagle/include/i2c.h
> +++ b/c/src/lib/libbsp/arm/beagle/include/i2c.h
> @@ -132,11 +132,11 @@ extern "C" {
> #define DISP_LINE_LEN 128
> -#define I2C_TIMEOUT 1000
> +#define I2C_TIMEOUT 1001
> #define I2C_BUS_MAX 3
> -#define I2C_BASE1 (OMAP34XX_CORE_L4_IO_BASE + 0x070000)
> +#define I2C_BASE1 (OMAP34XX_CORE_L4_IO_BASE + 0x070000) //0x48000000+0x070000
> #define I2C_DEFAULT_BASE I2C_BASE1
> @@ -356,7 +356,7 @@ static inline rtems_status_code beagle_i2c_read(
> | AM335X_I2C_IRQSTATUS_ARDY \
> | AM335X_I2C_IRQSTATUS_RRDY \
> | AM335X_I2C_IRQSTATUS_XRDY \
> - | AM335X_I2C_IRQSTATUS_XUDF)
> + | AM335X_I2C_IRQSTATUS_XUDF )
> #define BBB_I2C_IRQ_USED \
> ( BBB_I2C_IRQ_ERROR \
> @@ -478,6 +478,18 @@ static inline int bbb_register_i2c_2(void)
> +struct am335x_baseboard_id {
> + unsigned int magic;
> + char name[8];
> + char version[4];
> + char serial[12];
> + char config[32];
> + char mac_addr[3][6];
> #ifdef __cplusplus
> #endif /* __cplusplus */
> diff --git a/cpukit/dev/i2c/eeprom.c b/cpukit/dev/i2c/eeprom.c
> index 39cff95..15040af 100644
> --- a/cpukit/dev/i2c/eeprom.c
> +++ b/cpukit/dev/i2c/eeprom.c
> @@ -55,6 +55,7 @@ static ssize_t eeprom_read(
> off_t offset
> eeprom *dev = (eeprom *) base;
> off_t avail = dev->size - offset;
> uint32_t off = (uint32_t) offset;
> @@ -86,6 +87,17 @@ static ssize_t eeprom_read(
> (uint8_t) (off >> 16),
> (uint8_t) (off >> 24)
> + i2c_msg msgs[1] = {
> + .addr = i2c_addr,
> + .flags = I2C_M_RD,
> + .buf = in,
> + .len = cur
> i2c_msg msgs[2] = {
> .addr = i2c_addr,
> @@ -99,14 +111,22 @@ static ssize_t eeprom_read(
> .len = cur
> int err;
> err = i2c_bus_transfer(dev->base.bus, &msgs[0], RTEMS_ARRAY_SIZE(msgs));
> if (err != 0) {
> return err;
> todo -= cur;
> off += cur;
> in += cur;
> @@ -236,7 +256,7 @@ int i2c_dev_register_eeprom(
> if (program_timeout_in_ms == 0) {
> - program_timeout_in_ms = 1000;
> + program_timeout_in_ms = 5000;
> dev = (eeprom *)
> diff --git a/testsuites/samples/i2c0/init.c b/testsuites/samples/i2c0/init.c
> index b428216..70bbe12 100644
> --- a/testsuites/samples/i2c0/init.c
> +++ b/testsuites/samples/i2c0/init.c
> @@ -23,10 +23,62 @@
> #include <dev/i2c/eeprom.h>
> +#include <rtems/shell.h>
> +#include <stdio.h>
> +#include <stdarg.h>
> +#include <stdlib.h>
> +#include <string.h>
> +#include <errno.h>
> +#include <rtems/userenv.h>
> +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> +#define CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
> +#define CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER
> +#define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
> +#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
> +#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 32
> +#define CONFIGURE_MAXIMUM_USER_EXTENSIONS 1
> +#define CONFIGURE_UNLIMITED_ALLOCATION_SIZE 32
> +#define CONFIGURE_UNLIMITED_OBJECTS
> +#define CONFIGURE_UNIFIED_WORK_AREAS
> +#define CONFIGURE_STACK_CHECKER_ENABLED
> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> +#define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_DEFAULT_MODES
> +#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
> +#include <rtems/confdefs.h>
> +#define CONFIGURE_SHELL_COMMAND_CP
> +#define CONFIGURE_SHELL_COMMAND_PWD
> +#define CONFIGURE_SHELL_COMMAND_LS
> +#define CONFIGURE_SHELL_COMMAND_LN
> +#define CONFIGURE_SHELL_COMMAND_LSOF
> +#define CONFIGURE_SHELL_COMMAND_CHDIR
> +#define CONFIGURE_SHELL_COMMAND_CD
> +#define CONFIGURE_SHELL_COMMAND_MKDIR
> +#define CONFIGURE_SHELL_COMMAND_RMDIR
> +#define CONFIGURE_SHELL_COMMAND_CAT
> +#define CONFIGURE_SHELL_COMMAND_MV
> +#define CONFIGURE_SHELL_COMMAND_MALLOC_INFO
> +#include <rtems/shellconfig.h>
> /* I2C address of CAT24C256 eeprom
> EEPROM SIZE 32 KB Ref: BBB SRM */
> #define I2C_SLAVE_ADDR (0x50)
> -#define EEPROM_SIZE 256
> +#define EEPROM_SIZE 78
> #define EEPROM_PATH "/dev/i2c-0.eeprom"
> /* forward declarations to avoid warnings */
> @@ -35,16 +87,23 @@ rtems_task Init(rtems_task_argument argument);
> const char rtems_test_name[] = "GSOC 2016 I2C TESTING";
> rtems_printer rtems_test_printer;
> rtems_task Init(
> rtems_task_argument ignored
> rtems_test_begin();
> int i;
> int rv,fd_bus,fd_in_dev;
> uint8_t in[EEPROM_SIZE];
> struct stat st;
> off_t off;
> + ssize_t n;
> + rtems_shell_env_t env;
> /*bus registration */
> rv = bbb_register_i2c_0();
> @@ -64,23 +123,56 @@ rtems_task Init(
> 256, // size_in_bytes
> 0 // program time out in ms
> + _Assert(rv == 0);
> +// exit( 0 );
> printf("register EEPROM \n");
> fd_in_dev = open(EEPROM_PATH, O_RDWR);
> + printf("fd_in_dev:%d\n", fd_in_dev);
> _Assert(fd_in_dev >=0);
> printf("open eeprom \n");
> rv = fstat(fd_in_dev, &st);
> _Assert(rv == 0);
> _Assert(st.st_blksize == 8);
> _Assert(st.st_size == sizeof(in));
> +printf("read func\n");
> + n = read(fd_in_dev, &in[0], sizeof(in));
> + printf("n:%d\n",n );
> + printf("0:%x, ",in[0]);
> + printf("1:%x, ",in[1]);
> + for(i=0;i<sizeof(in);++i)
> +printf("%x\n",in[i]);
> + printf("sizeof(in):%d\n", sizeof(in));
> + // _Assert(n == -1);
> +printf("test\n");
> for ( i = 0; i < sizeof(in); ++i) {
> + printf("i:%d\n",i);
> off = lseek(fd_in_dev, 0, SEEK_SET);
> + printf("lseek func done!\n");
> rv = read(fd_in_dev,&in[0], sizeof(in));
> - printf("\n %s \n ",in[i]);
> + // printf("\n %s \n ",in[i]);
> printf("EXIT from test case");
> close(fd_bus);
> - unlink(BBB_I2C_2_BUS_PATH);
> + unlink(BBB_I2C_2_BUS_PATH);
> rtems_test_end();
devel mailing list
devel at rtems.org
http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170321/4aa0968c/attachment-0001.html>
