timeouts and failure
Tanu Hari Dixit tokencolour at gmail.com
Tue Mar 21 07:06:11 UTC 2017
> I noticed you have 17 tests more than I do enabled. How did you configure?
../../rtems/configure --target=sparc-rtems4.12 --enable-tests
--enable-rtemsbsp=erc32
--prefix=/home/thd/development/rtems/install_path_erc32_alltest_new
I used Joel's configuration, that is:
../../rtems/configure --target=sparc-rtems4.12 --enable-rtemsbsp=erc32
--prefix=/home/thd/development/rtems/install_path_erc32_js
--disable-networking --enable-posix --disable-multiprocessing
--disable-smp --enable-tests --enable-cxx --enable-maintainer-mode
I got the following results:
Passed:   540
Failed:     6
Timeouts:   9
Invalid:    0
Total:    555
Failures:
 spcontext01.exe
 mdosfs_fsscandir01.exe
 jffs2_fsscandir01.exe
 imfs_fsscandir01.exe
 mimfs_fsscandir01.exe
 mrfs_fsscandir01.exe
Timeouts:
 fsdosfsname01.exe
 fsdosfswrite01.exe
 fsimfsconfig02.exe
 fsimfsgeneric01.exe
 fsjffs2gc01.exe
 fsdosfsformat01.exe
 fsrfsbitmap01.exe
 imfs_fserror.exe
 crypt01.exe
Average test time: 0:00:01.434556
Testing time     : 0:13:16.178701
This is still one more test than Joel's total. I understand
spcontext01.exe is expected to fail. But I can't figure out why the
rest fail on my host. (My rtems source tree is updated.)
Also, how can we change the number of cores operational? I found the
--timeout option but none regarding the cores.
Can the devs please help me with this?
Thanking you,
Tanu Hari Dixit.
On Tue, Mar 21, 2017 at 5:55 AM, Chris Johns <chrisj at rtems.org> wrote:
> On 20/03/2017 17:20, Sebastian Huber wrote:
>> On 18/03/17 21:52, Joel Sherrill wrote:
>>> FWIW here are my results for sparc/erc32:
>>> Passed:   548
>>> Failed:     1
>>> Timeouts:   5
>>> Invalid:    0
>>> Total:    554
>>> Failures:
>>>  spcontext01.exe
>> Yes, this is expected.
>>> Timeouts:
>>>  fileio.exe
>>>  top.exe
>>>  termios.exe
>>>  capture.exe
>>>  monitor.exe
>> These tests should terminate after 20 seconds or so without input. A
>> timeout should therefore not occur.
> That is 20 seconds of target time and not real-time if running on a heavily
> loaded machine running simulators in parallel. The test tool's timeout is
> real time.
> I have created https://devel.rtems.org/ticket/2946 to look into this.
> Chris
