Re: 答复: 回复: GSOC 2017 Beagleboard BSP projects
Tue Mar 21 17:35:08 UTC 2017
On Tue, Mar 21, 2017 at 9:51 AM, 赵 思晨 <zsc19940506 at outlook.com> wrote:
> Hello Christian Mauderer:
> I think there are still some misunderstanding:
> I want to add the hardware independent parts of WLAN (IEEE802.11 standard),
> cause i think the USB driver and WLAN protocol is necessary for the USB
> wireless network card. And i think you mean i only wanna add the USB driver,
> right?
It sounds like the hardware-independent parts of WLAN are expected to
be already completed and merged by the folks at Embedded Brains. So,
you can focus instead on the driver specific to your dongle.
> Best Regards
> Sichen Zhao
> 发自 Outlook
> ________________________________
> 发件人: devel <devel-bounces at rtems.org> 代表 Christian Mauderer
> <christian.mauderer at embedded-brains.de>
> 发送时间: 2017年3月21日 21:21:44
> 收件人: 赵思晨
> 抄送: devel
> 主题: Re: 回复: GSOC 2017 Beagleboard BSP projects
> Hello Sichen Zhao,
> Am 21.03.2017 um 12:22 schrieb 赵思晨:
>> Hi Christian Mauderer:
>> 1.There is no WLAN chip on BBB, so my need USB dongle. So the USB driver
>> is important and is my main goal of GOSC BBB BSP project.
> OK. It's fine if that is your focus.
>> 2.I don't think there is a potential conflict: I think Project
>> Deliverables is a deadline to check , and the work adding the 802.11
>> protocol should be check at the deadline August 29-September 5.    June
>> 27 - August 23 (Second Half) is what i need to do during the two month.
>> and the work i did will be check at the Project Deliverables time. So
>> it's not conflict.
> So if I understand you correctly, this parts have to do with the
> hardware dependent driver (depending on your USB dongle) and getting one
> example with an USB-WLAN dongle to run? Eventually you should try to
> rephrase that. I read the "adding the 802.11 protocol" in a way that you
> want to add the hardware independent parts of WLAN (IEEE802.11 standard).
> Kind regards
> Christian Mauderer
>> ------------------ 原始邮件 ------------------
>> *发件人:* "Christian Mauderer";<christian.mauderer at embedded-brains.de>;
>> *发送时间:* 2017年3月21日(星期二) 下午4:33
>> *收件人:* "joel"<joel at rtems.org>;
>> *抄送:* "RTEMS"<devel at rtems.org>;
>> *主题:* Re: GSOC 2017 Beagleboard BSP projects
>> Am 21.03.2017 um 00:45 schrieb Joel Sherrill:
>>> On Sun, Mar 19, 2017 at 4:38 PM, Christian Mauderer
>>> <mailto:christian.mauderer at embedded-brains.de>> wrote:
>>>     ----- Ursprüngliche Mail -----
>>>     > Von: "赵 思晨" <zsc19940506 at outlook.com
>>>     <mailto:zsc19940506 at outlook.com>>
>>>     > An: "RTEMS" <devel at rtems.org <mailto:devel at rtems.org>>
>>>     > Gesendet: Sonntag, 19. März 2017 15:29:03
>>>     > Betreff: GSOC 2017 Beagleboard BSP projects
>>>     > Hi all:
>>>     > I am interested in the ticket #2819 Beagleboard BSP projects
>>>     > And i have a idea about the project: add the USB and wireless
>>>     network card
>>>     > driver to RTEMS. So RTEMS can apply on many scene applications
>>>     such as the UAV.
>>>     > And for now, i am working on transplant the USB driver from
>>>     FreeBSD to RTEMS.
>>>     > I am a master student from China NanJing University. and i am
>>>     interested in
>>>     > applying for GSoC 2017 under RTEMS.
>>>     > I have develop project on RTEMS for almost a year, so i am very
>>>     familiar with
>>>     > RTEMS development.
>>>     > For now, i have done these works on RTEMS:
>>>     > 1.Porting the ethernet driver from FreeBSD to RTEMS on BBB bsp.
>>>     > 2.Transplant the ION-DTN protocol stack on RTEMS.
>>>     > 3.Took over Punitvara's(GSOC 2016 student) unfinished work on BBB
>>>     i2c driver,
>>>     > and can use i2c read the EEPROM info..(already send PV my pull
>>>     request)
>>>     > 4.Porting  the ethernet driver from UBoot to RTEMS on BBB bsp.
>>>     > Best Regrads
>>>     > Sichen Zhao
>>>     > 发自 Outlook<http://aka.ms/weboutlook <http://aka.ms/weboutlook>>
>>>     > _______________________________________________
>>>     > devel mailing list
>>>     > http://lists.rtems.org/mailman/listinfo/devel
>>>     <http://lists.rtems.org/mailman/listinfo/devel>
>>>     Hello Sichen Zhao,
>>>     just a note regarding the WLAN support in rtems-libbsd: I have just
>>>     recently ported a lot of the necessary kernel modules for
>>>     unencrypted WLAN. Depending on the projects progress, It's quite
>>>     possible that we (embedded brains) will work on encrypted WLAN too
>>>     in the near future. So this might could collide with the goals in
>>>     your proposal that relate to the hardware independent parts of the
>>>     network stack.
>>> Christian.. I appreciate you giving a heads up but isn't the work of
>>> USB support for a BB and a specific WLAN driver for a USB WLAN stick
>>> rather independent of adding encryption support? It would seem they
>>> are in different areas of the tree.
>>> I can see where he could focus on unencrypted support and then
>>> if things work out, take advantage of the encrypted support later.
>>> I thought the tree was already up to date so there wouldn't be any
>>> massive updates of code.
>>> What conflicts do you foresee? And can you work with the student
>>> to avoid or minimize them.
>>> Working in the open and coordinating efforts is critical in any open
>>> source project. This seems like one which can be managed. Especially
>>> if you help out on this project so you can help avoid the issues.
>>> Thanks.
>>> --joel
>> Hello Joel, Hello Sichen Zhao,
>> I agree, that most of the proposal won't be touched by the WLAN part
>> that is already done or will be (hopefully) done in the near future. I'm
>> not sure what WLAN chip set is used on the BB (or on the intended USB
>> dongle) so currently I can't say for sure whether it is already build
>> with the rest of the drivers or not. Sichen Zhao: Do you have any
>> information on that?
>> A potential conflict in the proposal is in the "Project Deliverables"
>> the part "August 29-September 5 (Final Evaluation) - Add the wireless
>> protocol such as 802.11". That is also mentioned in "June 27 - August 23
>> (Second Half)" under the point "5.Adding the wireless protocol 802.11 on
>> RTEMS."
>> But to be honest: It might anyhow would have been a quite big workpiece
>> if it would have been only a part of a GSoC project. The unencrypted
>> WLAN port has been quite some effort and there is a big part necessary
>> for the encrypted WLAN user space (the wpa supplicant). So it quite
>> likely is better to concentrate on the device specific driver and try to
>> get it running with unencrypted WLAN. If that works, it shouldn't be a
>> big problem to get the encrypted one running.
>> If there is time left for any work: For the encrypted WLAN, it is always
>> interesting if there is any hardware encryption support. If the WLAN
>> chip doesn't have it itself (not all USB chips have it), a hardware
>> encryption of the host processor might be useful. So if the processor on
>> the BB has a hardware encryption module, it could be nice to have it
>> supported by the rtems-libbsd. But I'm not sure whether we already have
>> any encryption on other platforms and I'm also not sure how much work
>> that would be.
>> Please note that I don't really have any experience what the usual scope
>> is for a GSoC project. So I'm not sure whether that would be possible or
>> realistic in the given time.
>> Kind regards
>> Christian Mauderer
>> embedded brains GmbH
>> Christian Mauderer
>> Dornierstr. 4
>> D-82178 Puchheim
>> Germany
>> email: christian.mauderer at embedded-brains.de
>> Phone: +49-89-18 94 741 - 18
>> Fax:   +49-89-18 94 741 - 08
>> PGP: Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> devel mailing list
>> devel at rtems.org
> Christian Mauderer
> Dornierstr. 4
> D-82178 Puchheim
> Germany
> devel mailing list
> devel at rtems.org
> devel mailing list
> devel at rtems.org
