[PATCH] modify punitvara's works on BBB i2c, and now can read the eeprom info.
Tue Mar 21 17:36:13 UTC 2017
On Tue, Mar 21, 2017 at 12:12 AM, Ben Gras <beng at shrike-systems.com> wrote:
> Dear all,
> SZ, great initiative. Gedare and Sebastian have commented.
> For my part, can I just check - the implementation is supposed to be
> generic to i2c devices, correct?
> If so, can you explain what read_eeprom is for? Is it just as demo? Is
> the code generic otherwise?
I believe PV used EEPROM to test his i2c implementation.
> Cheers,
> Ben
> On 03/14/2017 10:05 AM, Sichen Zhao wrote:
>>  c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c | 684 ++++++++++++++++++++++++++++--
>>  c/src/lib/libbsp/arm/beagle/include/i2c.h |  18 +-
>>  cpukit/dev/i2c/eeprom.c                   |  24 +-
>>  testsuites/samples/i2c0/init.c            |  98 ++++-
>>  4 files changed, 777 insertions(+), 47 deletions(-)
>> diff --git a/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c b/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
>> index 6b790e5..6a22125 100644
>> --- a/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
>> +++ b/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
>> @@ -21,11 +21,23 @@
>>  #include <bsp/bbb-gpio.h>
>>  #include <rtems/score/assert.h>
>> +#define u16 unsigned int
>> +static int am335x_i2c_set_clock(i2c_bus *base, unsigned long clock);
>> +static void omap24_i2c_init(i2c_bus *base);
>> +static void flush_fifo(i2c_bus *base);
>> +static int wait_for_bb(i2c_bus *base);
>> +static int omap24_i2c_probe(i2c_bus *base);
>> +static u16 wait_for_event(i2c_bus *base);
>> +static int am335x_i2c_read(i2c_bus *base, unsigned char chip, uint addr, int alen, unsigned char *buffer,
>> +                           int len);
>> +static int read_eeprom(i2c_bus *base,struct am335x_baseboard_id *header);
>> +static int am335x_i2c_write(i2c_bus *base, unsigned char chip, uint addr,int alen, unsigned char *buffer,
>> +                            int len);
>>  static bool am335x_i2c_pinmux(bbb_i2c_bus *bus)
>>    bool status =true;
>>      // We will check i2c_bus_id in am335x_i2c_bus_register
>>      // Apart from mode and pull_up register what about SCREWCTRL & RXACTIVE ??
>>    if (bus->i2c_bus_id == I2C1) {
>> @@ -48,9 +60,7 @@ static bool am335x_i2c_pinmux(bbb_i2c_bus *bus)
>>  /* ref. Table 21-4 I2C Clock Signals */
>>   For I2C1/2
>>   Interface clock - 100MHz - CORE_LKOUTM4 / 2 - pd_per_l4ls_gclk
>>   Functional clock - 48MHz - PER_CLKOUTM2 / 4 - pd_per_ic2_fclk
>> @@ -74,7 +84,6 @@ state. Functional clocks are guarantied to stay present. As long as in
>>  this configuration, power domain sleep transition cannot happen.*/
>>   /* REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKCTRL) |=
>>                          AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE;
>>    while((REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKCTRL) &
>>        AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE) != AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE);
>> @@ -86,30 +95,29 @@ this configuration, power domain sleep transition cannot happen.*/
>>    REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C1_CLKCTRL) |=
>>                               AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE_ENABLE;
>>    while(REG((AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C1_CLKCTRL) &
>>       AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE) != AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE_ENABLE);
>>    } else if (bus->i2c_bus_id == I2C2) {
>>    REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C2_CLKCTRL) |=
>>                               AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE_ENABLE;
>>    while(REG((AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C2_CLKCTRL) &
>>       AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE) != AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE_ENABLE);
>>    while(!(REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKSTCTRL) &
>>             (AM335X_CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_L4LS_GCLK |
>>              AM335X_CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_I2C_FCLK)));
>>  static void am335x_i2c0_pinmux(bbb_i2c_bus *bus)
>> -  REG(bus->regs + AM335X_CONF_I2C0_SDA) =
>> +  printf("0x44e10000 + AM335X_CONF_I2C0_SDA:%x\n",0x44e10000 + AM335X_CONF_I2C0_SDA);
>> +  printf("bus->regs:%x\n", bus->regs);
>> +  REG(0x44e10000 + AM335X_CONF_I2C0_SDA) =
>>    (BBB_RXACTIVE | BBB_SLEWCTRL | BBB_PU_EN);
>> -  REG(bus->regs + AM335X_CONF_I2C0_SCL) =
>> +  REG(0x44e10000 + AM335X_CONF_I2C0_SCL) =
>> @@ -314,14 +322,29 @@ void am335x_i2c_init(bbb_i2c_bus *bus, uint32_t input_clock)
>>  static bool am335x_i2c_busbusy(volatile bbb_i2c_regs *regs)
>>    bool status;
>> -  if (REG(&regs->BBB_I2C_IRQSTATUS_RAW) & AM335X_I2C_IRQSTATUS_RAW_BB)
>> +  unsigned short stat;
>> +  int timeout = I2C_TIMEOUT;
>> +  REG(&regs->BBB_I2C_IRQSTATUS)=0xffff;
>> +  printf("REG(&regs->BBB_I2C_IRQSTATUS_RAW):%x\n",REG(&regs->BBB_I2C_IRQSTATUS_RAW) );
>> + // printf("%x\n",0x1400 & 0x1000 );
>> + printf("REG(&regs->BBB_I2C_IRQSTATUS_RAW) & AM335X_I2C_IRQSTATUS_RAW_BB:%x\n",(REG(&regs->BBB_I2C_IRQSTATUS_RAW) & AM335X_I2C_IRQSTATUS_RAW_BB));
>> +while(stat =( REG(&regs->BBB_I2C_IRQSTATUS_RAW) & AM335X_I2C_IRQSTATUS_RAW_BB) && timeout--)
>> -    status = true;
>> -  } else {
>> -    status = false;
>> +REG(&regs->BBB_I2C_IRQSTATUS)=stat;
>> +    udelay(20);
>> +  if (timeout <= 0) {
>> +    printf("Timed out in wait_for_bb: status=%04x\n",
>> +           stat);
>> +    return 1;
>> -  return status;
>> +  REG(&regs->BBB_I2C_IRQSTATUS)=0xffff;   /* clear delayed stuff*/
>> +  return 0;
>>  static void am335x_i2c_reset(bbb_i2c_bus *bus)
>> @@ -330,9 +353,27 @@ static void am335x_i2c_reset(bbb_i2c_bus *bus)
>>    printk("reset bus->reg is %x \n",bus->regs);
>>    /* Disable I2C module at the time of initialization*/
>>    /*Should I use write32 ?? I guess mmio_clear is correct choice here*/
>> +  REG(&regs->BBB_I2C_CON)=0x00;
>>    printk("inside BBB_I2C_CON value is %x \n",&regs->BBB_I2C_CON);
>> -  mmio_clear((&regs->BBB_I2C_CON),AM335X_I2C_CON_I2C_EN);
>> -  mmio_clear((&regs->BBB_I2C_SYSC),AM335X_I2C_SYSC_AUTOIDLE);
>> +   REG(&regs->BBB_I2C_SYSC)= 0x2;
>> +//  mmio_clear((&regs->BBB_I2C_CON),AM335X_I2C_CON_I2C_EN);
>> +   REG(&regs->BBB_I2C_CON)= AM335X_I2C_CON_I2C_EN;
>> +   while((REG(&regs->BBB_I2C_SYSS) &I2C_SYSS_RDONE)==0)  //wait reset done
>> +    udelay(100);
>> +   am335x_i2c_set_clock(&bus->base, I2C_BUS_CLOCK_DEFAULT);
>> +   REG(&regs->BBB_I2C_CON)= AM335X_I2C_CON_MST | AM335X_I2C_CON_I2C_EN;
>> +//  mmio_clear((&regs->BBB_I2C_SYSC),AM335X_I2C_SYSC_AUTOIDLE);
>>    //REG(bus->regs + AM335X_I2C_CON) &= ~(AM335X_I2C_CON_I2C_EN);
>>    //REG(bus->regs + AM335X_I2C_SYSC) &= ~(AM335X_I2C_SYSC_AUTOIDLE);
>> @@ -385,6 +426,7 @@ static unsigned int am335x_i2c_intrawstatus(volatile bbb_i2c_regs *regs)
>>  static void am335x_i2c_masterint_enable(volatile bbb_i2c_regs *regs, unsigned int flag)
>> +  printf("am335x_i2c_masterint_enable func\n");
>>    REG(&regs->BBB_I2C_IRQENABLE_SET) |= flag;
>> @@ -401,6 +443,7 @@ static void am335x_int_clear(volatile bbb_i2c_regs *regs, unsigned int flag)
>>  static void am335x_clean_interrupts(volatile bbb_i2c_regs *regs)
>> +  printf("am335x_clean_interrupts func\n");
>>    am335x_i2c_masterint_enable(regs,0x7FFF);
>>    am335x_int_clear(regs,0x7FFF);
>>    am335x_i2c_masterint_disable(regs,0x7FFF);
>> @@ -412,30 +455,69 @@ static void am335x_i2c_setup_read_transfer(bbb_i2c_bus *bus, volatile bbb_i2c_re
>>    volatile unsigned int no_bytes;
>>    //am335x_i2c_masterint_enable(regs, AM335X_I2C_INT_RECV_READY);
>>     // No of data to be transmitted at a time
>> +//bbb_i2c_bus *bus = (bbb_i2c_bus *) base;
>> +//  volatile bbb_i2c_regs *regs = bus->regs;
>> +  struct am335x_baseboard_id header;
>> +  omap24_i2c_probe(&bus->base);
>> +   read_eeprom(&bus->base,&header);
>>    REG(&regs->BBB_I2C_CNT) = 0x02;
>>    no_bytes = REG(&regs->BBB_I2C_CNT);
>> + // Set Slave address & Master enable, bring out of reset
>> +  REG(&regs->BBB_I2C_SA) = msgs->addr;
>> +  printf("slave address : %x\n",REG(&regs->BBB_I2C_SA));
>>    // I2C Controller in Master Mode
>> -  REG(&regs->BBB_I2C_CON) = AM335X_I2C_CFG_MST_TX | AM335X_I2C_CON_I2C_EN | AM335X_I2C_CON_START | AM335X_I2C_CON_MST;
>> +  REG(&regs->BBB_I2C_CON) = AM335X_I2C_CFG_MST_TX  | AM335X_I2C_CON_MST | AM335X_I2C_CON_START | AM335X_I2C_CON_I2C_EN | AM335X_I2C_CON_STOP;
>>    printk("set master in transmission mode %x \n",REG(&regs->BBB_I2C_CON));
>> -  // Set Slave address & Master enable, bring out of reset
>> -  REG(&regs->BBB_I2C_SA) = msgs->addr;
>> -  printf("slave address : %x\n",REG(&regs->BBB_I2C_SA));
>> +while(am335x_i2c_busbusy(regs) != 0);
>> +  printk("bus is free \n");
>>    // clear status of all interrupts
>>    am335x_clean_interrupts(regs);
>>    printk("\n set memory address to read\n");
>>    // transmit interrupt is enabled
>>    am335x_i2c_masterint_enable(regs,AM335X_I2C_IRQSTATUS_XRDY);
>>    printk("Enable transmit interrupt \n");
>>    //start condition
>> -  REG(&regs->BBB_I2C_CON) |= AM335X_I2C_CON_START;
>> +  REG(&regs->BBB_I2C_CON) |= AM335X_I2C_CON_START | AM335X_I2C_CON_I2C_EN;
>>    printk("start transmission \n");
>> -  while(am335x_i2c_busbusy(regs) == 0);
>> -  printk("bus is free \n");
>>    printk("CNT : %x\n", no_bytes);
>> +  printf("BBB_I2C_DATA:%x\n", readb(&regs->BBB_I2C_DATA));
>> +writeb(0x5,&regs->BBB_I2C_DATA);
>> +printf("(0x50 >> 8)& 0xff:%x\n",(0x50 >> 8)& 0xff);
>> +printf("REG(&regs->BBB_I2C_DATA):%x\n",readb(&regs->BBB_I2C_DATA) );
>> +printf("&regs->BBB_I2C_DATA:%x\n",&regs->BBB_I2C_DATA);
>> +//REG(&regs->BBB_I2C_IRQSTATUS)=AM335X_I2C_IRQSTATUS_XRDY;
>> +udelay(10);
>> +writeb(0x0,&regs->BBB_I2C_DATA);
>> +//REG(&regs->BBB_I2C_DATA)= ( (0x50 >> 0)& 0xff);
>> +printf("(0x50 >> 0)& 0xff:%x\n",(0x50 >> 0)& 0xff);
>> +REG(&regs->BBB_I2C_IRQSTATUS)=AM335X_I2C_IRQSTATUS_XRDY;
>> + // no_bytes = REG(&regs->BBB_I2C_CNT);
>>    while(0 != no_bytes);
>>    printk("total msg count for tranmission is zero \n");
>>    while( !(am335x_i2c_intrawstatus(regs) & (AM335X_I2C_IRQSTATUS_ARDY)));
>> @@ -464,6 +546,7 @@ static void am335x_i2c_setup_read_transfer(bbb_i2c_bus *bus, volatile bbb_i2c_re
>>    printk("Exit read transfer\n");
>> @@ -570,11 +653,16 @@ static void am335x_i2c_setup_transfer(bbb_i2c_bus *bus, volatile bbb_i2c_regs *r
>>    regs = bus->regs;
>> -  REG(&bus->regs->BBB_I2C_BUF) |= AM335X_I2C_BUF_TXFIFO_CLR;
>> -  REG(&bus->regs->BBB_I2C_BUF) |= AM335X_I2C_BUF_RXFIFO_CLR;
>> -  am335x_i2c_set_address_size(msgs,regs);
>> -  bus->read = ((bus->read == true) ? 0:1);
>> +  printf("REG(&regs->BBB_I2C_DATA):%x\n",REG(&regs->BBB_I2C_DATA) );
>> + // REG(&bus->regs->BBB_I2C_BUF) |= AM335X_I2C_BUF_TXFIFO_CLR;
>> + // REG(&bus->regs->BBB_I2C_BUF) |= AM335X_I2C_BUF_RXFIFO_CLR;
>> +printf("REG(&regs->BBB_I2C_DATA):%x\n",REG(&regs->BBB_I2C_DATA) );
>> + // am335x_i2c_set_address_size(msgs,regs);
>> +bus->read = (msgs->flags & I2C_M_RD) != 0;
>> +printf("bus->read:%d\n",bus->read );
>> +  //bus->read = ((bus->read == true) ? 0:1);
>>    bus->already_transferred = (bus->read == true) ? 0 : 1;
>>    if (bus->read) {
>> @@ -652,7 +740,7 @@ static int am335x_i2c_transfer(i2c_bus *base, i2c_msg *msgs, uint32_t msg_count)
>>    bbb_i2c_bus *bus = (bbb_i2c_bus *)base;
>>    volatile bbb_i2c_regs *regs;
>>    uint32_t i;
>> - printk("\n enter transfer ");
>> + printk("\n enter transfer\n ");
>>    rtems_task_wake_after(1);
>> @@ -665,20 +753,23 @@ static int am335x_i2c_transfer(i2c_bus *base, i2c_msg *msgs, uint32_t msg_count)
>>          return -EINVAL;
>> +  printf("bus->regs:%x\n",bus->regs );
>>    bus->msgs = &msgs[0];
>>    bus->msg_todo = msg_count;
>>    printk("total msg = msg_count : %x \n",bus->msg_todo);
>>    bus->current_msg_todo = msgs[0].len;// current data size
>> -  bus->current_msg_byte = msgs[0].buf;// current data
>> +  //bus->current_msg_byte = msgs[0].buf;// current data
>>    printk("\n current_msg_todo %x \n ",msgs[0].len);
>>    printk("\n current_msg_byte %x \n ",msgs[0].buf);
>> +  //printf("8011A5CC:%x\n",  *(unsigned int *)(0x8011A5CC) );
>>    bus->task_id = rtems_task_self();
>>    regs = bus->regs;
>> -  am335x_i2c_setup_transfer(bus,regs);
>> -  REG(&regs->BBB_I2C_IRQENABLE_SET) = BBB_I2C_IRQ_USED;
>> + // REG(&regs->BBB_I2C_IRQENABLE_SET) = BBB_I2C_IRQ_USED;
>> +  am335x_i2c_setup_transfer(bus,regs);
>>    sc = rtems_event_transient_receive(RTEMS_WAIT, bus->base.timeout);
>>    // If timeout then return timeout error
>>    if (sc != RTEMS_SUCCESSFUL) {
>> @@ -688,7 +779,9 @@ static int am335x_i2c_transfer(i2c_bus *base, i2c_msg *msgs, uint32_t msg_count)
>>      return -ETIMEDOUT;
>>    printk("exit transfer\n");
>>    // return bus->regs->BBB_I2C_IRQSTATUS == 0 ? 0 : -EIO;
>>    return 0;
>> @@ -700,19 +793,28 @@ static int am335x_i2c_set_clock(i2c_bus *base, unsigned long clock)
>>    uint32_t prescaler,divider;
>>    printk("set clock start\n");
>> +  REG(&regs->BBB_I2C_CON)=0;
>>    prescaler = (BBB_I2C_SYSCLK / BBB_I2C_INTERNAL_CLK) -1;
>> +  printf("prescaler:%d\n",prescaler );
>>    printk("PSC offset %x \n ",&regs->BBB_I2C_PSC);
>>    printk("PSC offset %x \n", &bus->regs->BBB_I2C_PSC);
>>    //mmio_write((&regs->BBB_I2C_PSC), prescaler);
>>    REG(&bus->regs->BBB_I2C_PSC) = prescaler;
>>    divider = BBB_I2C_INTERNAL_CLK/(2*clock);
>> +  printf("divider:%d\n", divider);
>>    printk("SCLL offset %x \n",&bus->regs->BBB_I2C_SCLL);
>>    //mmio_write((&regs->BBB_I2C_SCLL), (divider - 7));
>>    REG(&bus->regs->BBB_I2C_SCLL) = (divider - 7);
>>    //mmio_write((&regs->BBB_I2C_SCLH), (divider - 5));
>>    printk("SCHL offset %x\n",&bus->regs->BBB_I2C_SCLH);
>>    REG(&bus->regs->BBB_I2C_SCLH) = (divider - 5);
>> + REG(&regs->BBB_I2C_CON)=I2C_CON_EN;
>> +writew(0xFFFF, &bus->regs->BBB_I2C_IRQSTATUS);  /* clear all pending status */
>>    printk("set clock end \n");
>>    return 0;
>> @@ -729,6 +831,8 @@ static void am335x_i2c_destroy(i2c_bus *base)
>>    i2c_bus_destroy_and_free(&bus->base);
>>  int am335x_i2c_bus_register(
>>    const char *bus_path,
>>    uintptr_t register_base,
>> @@ -751,14 +855,15 @@ int am335x_i2c_bus_register(
>>    bus->regs = (volatile bbb_i2c_regs *) register_base;
>>  // 1. Enable clock for I2CX
>> -  I2C0ModuleClkConfig();
>> + I2C0ModuleClkConfig();
>>  // 2. pinmux setup
>>    am335x_i2c0_pinmux(bus);
>>  // 3. RESET : Disable Master, autoideal
>> -  am335x_i2c_reset(bus);
>> + // am335x_i2c_reset(bus);
>>  // 4. configure bus speed
>>    bus->input_clock = input_clock; // By default 100KHz. Normally pass 100KHz as argument
>>    printk("Before set clock \n");
>>    err = am335x_i2c_set_clock(&bus->base, I2C_BUS_CLOCK_DEFAULT);
>> @@ -768,12 +873,16 @@ int am335x_i2c_bus_register(
>>      rtems_set_errno_and_return_minus_one(-err);
>>     bus->irq = irq;
>> +omap24_i2c_init(&bus->base);
>>    //bring I2C out of reset
>> -   REG(&bus->regs->BBB_I2C_CON) |= AM335X_I2C_CON_I2C_EN;
>> +//printf("REG(&regs->BBB_I2C_IRQSTATUS):%x\n",REG(&bus->regs->BBB_I2C_IRQSTATUS));
>> +  // REG(&bus->regs->BBB_I2C_CON) |= AM335X_I2C_CON_I2C_EN;
>>    // 5. Start interrupt service routine & one interrupt at a time
>>    sc  = rtems_interrupt_handler_install(
>>      irq,
>>      "BBB I2C",
>> @@ -787,6 +896,7 @@ int am335x_i2c_bus_register(
>>      rtems_set_errno_and_return_minus_one(EIO);
>>    // 6. start transfer for reading and writing
>>    bus->base.transfer = am335x_i2c_transfer;
>>    bus->base.set_clock = am335x_i2c_set_clock;
>> @@ -794,3 +904,499 @@ int am335x_i2c_bus_register(
>>    printk("exit register\n");
>>    return i2c_bus_register(&bus->base,bus_path);
>> +   bbb_i2c_bus *bus = (bbb_i2c_bus *) base;
>> +  volatile bbb_i2c_regs *regs = bus->regs;
>> +  int deblock = 1;
>> +printf("omap24_i2c_init func!!!!!!\n");
>> +retry:
>> +  if (readw(&bus->regs->BBB_I2C_CON) & I2C_CON_EN) {
>> +    writew(0, &bus->regs->BBB_I2C_CON);
>> +    udelay(50000);
>> +  writew(0x2, &bus->regs->BBB_I2C_SYSC); /* for ES2 after soft reset */
>> +  udelay(1000);
>> +  writew(I2C_CON_EN, &bus->regs->BBB_I2C_CON);
>> +  while (!(readw(&bus->regs->BBB_I2C_SYSS) & I2C_SYSS_RDONE) && timeout--) {
>> +      puts("ERROR: Timeout in soft-reset\n");
>> +      return;
>> +    udelay(1000);
>> +am335x_i2c_set_clock(&bus->base, I2C_BUS_CLOCK_DEFAULT);
>> +  /* own address */
>> +  writew(1, &bus->regs->BBB_I2C_OA);
>> +//#if defined(CONFIG_OMAP243X) || defined(CONFIG_OMAP34XX)
>> +   * Have to enable interrupts for OMAP2/3, these IPs don't have
>> +   * an 'irqstatus_raw' register and we shall have to poll 'stat'
>> + // writew(I2C_IE_XRDY_IE | I2C_IE_RRDY_IE | I2C_IE_ARDY_IE | I2C_IE_NACK_IE | I2C_IE_AL_IE, &i2c_base->ie);
>> +//#endif
>> +  udelay(1000);
>> +  flush_fifo(&bus->base);
>> +  writew(0xFFFF, &bus->regs->BBB_I2C_IRQSTATUS);
>> +  /* Handle possible failed I2C state */
>> +  if (wait_for_bb(&bus->base))
>> +    if (deblock == 1) {
>> +      //omap24_i2c_deblock(&bus->base);
>> +      printf("deblock\n");
>> +      deblock = 0;
>> +      goto retry;
>> +  //  omap24_i2c_probe(&bus->base);
>> + //  read_eeprom(&bus->base,&header);
>> +  u16 stat;
>> +printf("flush_fifo\n");
>> +   * note: if you try and read data when its not there or ready
>> +   * you get a bus error
>> +  while (1) {
>> +    stat = readw(&bus->regs->BBB_I2C_IRQSTATUS);
>> +    if (stat == I2C_STAT_RRDY) {
>> +      readb(&bus->regs->BBB_I2C_DATA);
>> +      writew(I2C_STAT_RRDY, &bus->regs->BBB_I2C_IRQSTATUS);
>> +      udelay(1000);
>> +    } else
>> +      break;
>> +  u16 stat;
>> +printf("wait_for_bb\n");
>> +  writew(0xFFFF, &bus->regs->BBB_I2C_IRQSTATUS);  /* clear current interrupts...*/
>> +//printf("test1\n");
>> +  /* Read RAW status */
>> +//printf("%x\n", readw(&bus->regs->BBB_I2C_IRQSTATUS_RAW) & I2C_STAT_BB);
>> +  while ((stat = readw(&bus->regs->BBB_I2C_IRQSTATUS_RAW) &
>> +    I2C_STAT_BB) && timeout--) {
>> +    writew(stat, &bus->regs->BBB_I2C_IRQSTATUS);
>> +    udelay(200);
>> +           stat);
>> +    return 1;
>> +  writew(0xFFFF, &bus->regs->BBB_I2C_IRQSTATUS);   /* clear delayed stuff*/
>> +  return 0;
>> +  unsigned char chip = 0x50;
>> +  u16 status;
>> +  int res = 1; /* default = fail */
>> +printf("omap24_i2c_probe\n");
>> +  if (chip == readw(&bus->regs->BBB_I2C_OA))
>> +    return res;
>> +  /* Wait until bus is free */
>> +    return res;
>> +  /* No data transfer, slave addr only */
>> +  writew(chip, &bus->regs->BBB_I2C_SA);
>> +  /* Stop bit needed here */
>> +  writew(I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_TRX |
>> +         I2C_CON_STP, &bus->regs->BBB_I2C_CON);
>> +  status = wait_for_event(&bus->base);
>> +  if ((status & ~I2C_STAT_XRDY) == 0 || (status & I2C_STAT_AL)) {
>> +     * With current high-level command implementation, notifying
>> +     * the user shall flood the console with 127 messages. If
>> +     * silent exit is desired upon unconfigured bus, remove the
>> +     * following 'if' section:
>> +    if (status == I2C_STAT_XRDY)
>> +      printf("i2c_probe: pads on bus probably not configured (status=0x%x)\n",status);
>> +    goto pr_exit;
>> +  /* Check for ACK (!NAK) */
>> +  if (!(status & I2C_STAT_NACK)) {
>> +    printf("Device found\n");
>> +    res = 0;        /* Device found */
>> +    udelay(200);/* Required by AM335X in SPL */
>> +    /* Abort transfer (force idle state) */
>> +    writew(I2C_CON_MST | I2C_CON_TRX, &bus->regs->BBB_I2C_CON); /* Reset */
>> +    udelay(1000);
>> +    writew(I2C_CON_EN | I2C_CON_MST | I2C_CON_TRX |
>> +           I2C_CON_STP, &bus->regs->BBB_I2C_CON);    /* STP */
>> +pr_exit:
>> +  return res;
>> +  u16 status;
>> +//printf("wait_for_event \n");
>> +  do {
>> +    udelay(200);
>> +    status = readw(&bus->regs->BBB_I2C_IRQSTATUS_RAW);
>> +  } while (!(status &
>> +       (I2C_STAT_ROVR | I2C_STAT_XUDF | I2C_STAT_XRDY |
>> +        I2C_STAT_RRDY | I2C_STAT_ARDY | I2C_STAT_NACK |
>> +        I2C_STAT_AL)) && timeout--);
>> +    printf("Timed out in wait_for_event: status=%04x\n",
>> +           status);
>> +     * If status is still 0 here, probably the bus pads have
>> +     * not been configured for I2C, and/or pull-ups are missing.
>> +    printf("Check if pads/pull-ups of bus are properly configured\n");
>> +    status = 0;
>> +  return status;
>> +                           int len)
>> +  int i2c_error = 0;
>> +  int i=0;
>> +  u16 status;
>> +printf("am335x_i2c_read\n");
>> +  if (alen < 0) {
>> +    puts("I2C read: addr len < 0\n");
>> +    return 1;
>> +  if (len < 0) {
>> +    puts("I2C read: data len < 0\n");
>> +    return 1;
>> +  if (buffer == NULL) {
>> +    puts("I2C read: NULL pointer passed\n");
>> +    return 1;
>> +  if (alen > 2) {
>> +    printf("I2C read: addr len %d not supported\n", alen);
>> +    return 1;
>> +  if (addr + len > (1 << 16)) {
>> +    puts("I2C read: address out of range\n");
>> +    return 1;
>> +  /* Wait until bus not busy */
>> +    return 1;
>> +//printf("test2\n");
>> +  /* Zero, one or two bytes reg address (offset) */
>> +  writew(alen, &bus->regs->BBB_I2C_CNT);
>> +  /* Set slave address */
>> +//printf("test3\n");
>> +  if (alen) {
>> +    /* Must write reg offset first */
>> +    /* Stop - Start (P-S) */
>> +    writew(I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_STP |
>> +           I2C_CON_TRX, &bus->regs->BBB_I2C_CON);
>> +    /* Send register offset */
>> +    while (1) {
>> +      printf("status:%x\n",status );
>> +      /* Try to identify bus that is not padconf'd for I2C */
>> +      if (status == I2C_STAT_XRDY) {
>> +        i2c_error = 2;
>> +        printf("i2c_read (addr phase): pads on bus probably not configured (status=0x%x)\n",
>> +              status);
>> +        goto rd_exit;
>> +      if (status == 0 || (status & I2C_STAT_NACK)) {
>> +        i2c_error = 1;
>> +        printf("i2c_read: error waiting for addr ACK (status=0x%x)\n",
>> +               status);
>> +        goto rd_exit;
>> +      if (alen) {
>> +        if (status & I2C_STAT_XRDY) {
>> +      //    printf("alen:%d\n",alen );
>> +          alen--;
>> +      //    printf("addr:%x\n",addr );
>> +      //    printf("(addr >> (8 * alen)) & 0xff:%x\n",(addr >> (8 * alen)) & 0xff );
>> +          /* Do we have to use byte access? */
>> +          writeb((addr >> (8 * alen)) & 0xff,
>> +                 &bus->regs->BBB_I2C_DATA);
>> +          writew(I2C_STAT_XRDY, &bus->regs->BBB_I2C_IRQSTATUS);
>> +      if (status & I2C_STAT_ARDY) {
>> +        writew(I2C_STAT_ARDY, &bus->regs->BBB_I2C_IRQSTATUS);
>> +        break;
>> +  /* Read len bytes from slave */
>> +  writew(len, &bus->regs->BBB_I2C_CNT);
>> +  /* Need stop bit here */
>> +         I2C_CON_STT | I2C_CON_STP,
>> +         &bus->regs->BBB_I2C_CON);
>> +//printf("test4\n");
>> +  /* Receive data */
>> +  while (1) {
>> + //   printf("test 5\n");
>> +     * Try to identify bus that is not padconf'd for I2C. This
>> +     * state could be left over from previous transactions if
>> +     * the address phase is skipped due to alen=0.
>> +      i2c_error = 2;
>> +      printf("i2c_read (data phase): pads on bus probably not configured (status=0x%x)\n",
>> +              status);
>> +      goto rd_exit;
>> +     // printf("i2c_error = 1\n");
>> +      i2c_error = 1;
>> +      goto rd_exit;
>> +    if (status & I2C_STAT_RRDY) {
>> +      char temp;
>> +      temp=readb(&bus->regs->BBB_I2C_DATA);
>> +      *buffer++ =temp;
>> +     *bus->msgs[0].buf++=temp;
>> +  //   (*(uint8_t *) bus->current_msg_byte[0]) = readb(&bus->regs->BBB_I2C_DATA) & 0xFF;
>> +      i++;
>> +      break;
>> +rd_exit:
>> +//printf("rd_exit\n");
>> +//printf("i2c_error:%d\n",i2c_error);
>> +  return i2c_error;
>> +bbb_i2c_bus *bus = (bbb_i2c_bus *) base;
>> +printf("sizeof(struct am335x_baseboard_id):%d\n",sizeof(struct am335x_baseboard_id) );
>> +//printf("sizeof(struct am335x_baseboard_id):%d\n",sizeof(unsigned int) );
>> + am335x_i2c_read(&bus->base,0x50,0,2,(unsigned char *)header,sizeof(struct am335x_baseboard_id));
>> +printf("am335x_i2c_read end\n");
>> +    printf("header->magic:%x\n", header->magic);
>> +     printf("header->name[0]:%x\n", header->name[0]);
>> +      printf("header->name[1]:%x\n", header->name[1]);
>> +     printf("header->name[2]:%x\n", header->name[2]);
>> +      printf("header->name[3]:%x\n", header->name[3]);
>> +       printf("header->name[4]:%x\n", header->name[4]);
>> +        printf("header->name[5]:%x\n", header->name[5]);
>> +         printf("header->name[6]:%x\n", header->name[6]);
>> +          printf("header->name[7]:%x\n", header->name[7]);
>> +                            int len)
>> +  int i;
>> +  u16 status;
>> +  if (alen < 0) {
>> +    puts("I2C write: addr len < 0\n");
>> +    return 1;
>> +  if (len < 0) {
>> +    puts("I2C write: data len < 0\n");
>> +    return 1;
>> +    puts("I2C write: NULL pointer passed\n");
>> +    return 1;
>> +  if (alen > 2) {
>> +    printf("I2C write: addr len %d not supported\n", alen);
>> +    return 1;
>> +    printf("I2C write: address 0x%x + 0x%x out of range\n",
>> +           addr, len);
>> +    return 1;
>> +    return 1;
>> +  /* Start address phase - will write regoffset + len bytes data */
>> +  writew(alen + len, &bus->regs->BBB_I2C_CNT);
>> +  writew(chip,&bus->regs->BBB_I2C_SA);
>> +         I2C_CON_STP,&bus->regs->BBB_I2C_CON);
>> +  while (alen) {
>> +    /* Must write reg offset (one or two bytes) */
>> +      i2c_error = 2;
>> +      printf("i2c_write: pads on bus probably not configured (status=0x%x)\n",status);
>> +      goto wr_exit;
>> +      i2c_error = 1;
>> +      printf("i2c_write: error waiting for addr ACK (status=0x%x)\n",
>> +             status);
>> +      goto wr_exit;
>> +      alen--;
>> +      writeb((addr >> (8 * alen)) & 0xff, &bus->regs->BBB_I2C_DATA);
>> +    } else {
>> +      i2c_error = 1;
>> +      printf("i2c_write: bus not ready for addr Tx (status=0x%x)\n",
>> +             status);
>> +      goto wr_exit;
>> +  /* Address phase is over, now write data */
>> +  for (i = 0; i < len; i++) {
>> +      i2c_error = 1;
>> +      printf("i2c_write: error waiting for data ACK (status=0x%x)\n",
>> +             status);
>> +      goto wr_exit;
>> +      writeb(buffer[i], &bus->regs->BBB_I2C_DATA);
>> +    } else {
>> +      i2c_error = 1;
>> +      printf("i2c_write: bus not ready for data Tx (i=%d)\n",
>> +             i);
>> +      goto wr_exit;
>> +   * poll ARDY bit for making sure that last byte really has been
>> +   * transferred on the bus.
>> +  do {
>> +  } while (!(status & I2C_STAT_ARDY) && timeout--);
>> +  if (timeout <= 0)
>> +    printf("i2c_write: timed out writig last byte!\n");
>> +wr_exit:
>> +  return i2c_error;
>> diff --git a/c/src/lib/libbsp/arm/beagle/include/i2c.h b/c/src/lib/libbsp/arm/beagle/include/i2c.h
>> index d4a9e32..6c924ee 100644
>> --- a/c/src/lib/libbsp/arm/beagle/include/i2c.h
>> +++ b/c/src/lib/libbsp/arm/beagle/include/i2c.h
>> @@ -132,11 +132,11 @@ extern "C" {
>>  #define DISP_LINE_LEN 128
>> -#define I2C_TIMEOUT 1000
>> +#define I2C_TIMEOUT 1001
>>  #define I2C_BUS_MAX 3
>> -#define I2C_BASE1         (OMAP34XX_CORE_L4_IO_BASE + 0x070000)
>> +#define I2C_BASE1         (OMAP34XX_CORE_L4_IO_BASE + 0x070000) //0x48000000+0x070000
>>  #define I2C_DEFAULT_BASE      I2C_BASE1
>> @@ -356,7 +356,7 @@ static inline rtems_status_code beagle_i2c_read(
>>      | AM335X_I2C_IRQSTATUS_ARDY \
>>      | AM335X_I2C_IRQSTATUS_RRDY \
>>      | AM335X_I2C_IRQSTATUS_XRDY \
>> -    | AM335X_I2C_IRQSTATUS_XUDF)
>> +    | AM335X_I2C_IRQSTATUS_XUDF )
>>  #define BBB_I2C_IRQ_USED \
>>    ( BBB_I2C_IRQ_ERROR \
>> @@ -478,6 +478,18 @@ static inline int bbb_register_i2c_2(void)
>> +struct am335x_baseboard_id {
>> +     unsigned int  magic;
>> +     char name[8];
>> +     char version[4];
>> +     char serial[12];
>> +     char config[32];
>> +     char mac_addr[3][6];
>>  #ifdef __cplusplus
>>  #endif /* __cplusplus */
>> diff --git a/cpukit/dev/i2c/eeprom.c b/cpukit/dev/i2c/eeprom.c
>> index 39cff95..15040af 100644
>> --- a/cpukit/dev/i2c/eeprom.c
>> +++ b/cpukit/dev/i2c/eeprom.c
>> @@ -55,6 +55,7 @@ static ssize_t eeprom_read(
>>    off_t offset
>>    eeprom *dev = (eeprom *) base;
>>    off_t avail = dev->size - offset;
>>    uint32_t off = (uint32_t) offset;
>> @@ -86,6 +87,17 @@ static ssize_t eeprom_read(
>>        (uint8_t) (off >> 16),
>>        (uint8_t) (off >> 24)
>> +    i2c_msg msgs[1] = {
>> +        .addr = i2c_addr,
>> +        .flags = I2C_M_RD,
>> +        .buf = in,
>> +        .len = cur
>>      i2c_msg msgs[2] = {
>>          .addr = i2c_addr,
>> @@ -99,14 +111,22 @@ static ssize_t eeprom_read(
>>          .len = cur
>>      int err;
>>      err = i2c_bus_transfer(dev->base.bus, &msgs[0], RTEMS_ARRAY_SIZE(msgs));
>>      if (err != 0) {
>>        return err;
>>      todo -= cur;
>>      off += cur;
>>      in += cur;
>> @@ -236,7 +256,7 @@ int i2c_dev_register_eeprom(
>>    if (program_timeout_in_ms == 0) {
>> -    program_timeout_in_ms = 1000;
>> +    program_timeout_in_ms = 5000;
>>    dev = (eeprom *)
>> diff --git a/testsuites/samples/i2c0/init.c b/testsuites/samples/i2c0/init.c
>> index b428216..70bbe12 100644
>> --- a/testsuites/samples/i2c0/init.c
>> +++ b/testsuites/samples/i2c0/init.c
>> @@ -23,10 +23,62 @@
>>  #include <dev/i2c/eeprom.h>
>> +#include <rtems/shell.h>
>> +#include <stdio.h>
>> +#include <stdarg.h>
>> +#include <stdlib.h>
>> +#include <string.h>
>> +#include <errno.h>
>> +#include <rtems/userenv.h>
>> +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
>> +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>> +#define CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
>> +#define CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER
>> +#define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
>> +#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
>> +#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 32
>> +#define CONFIGURE_MAXIMUM_USER_EXTENSIONS 1
>> +#define CONFIGURE_UNLIMITED_ALLOCATION_SIZE 32
>> +#define CONFIGURE_UNLIMITED_OBJECTS
>> +#define CONFIGURE_UNIFIED_WORK_AREAS
>> +#define CONFIGURE_STACK_CHECKER_ENABLED
>> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>> +#define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_DEFAULT_MODES
>> +#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
>> +#include <rtems/confdefs.h>
>> +#define CONFIGURE_SHELL_COMMAND_CP
>> +#define CONFIGURE_SHELL_COMMAND_PWD
>> +#define CONFIGURE_SHELL_COMMAND_LS
>> +#define CONFIGURE_SHELL_COMMAND_LN
>> +#define CONFIGURE_SHELL_COMMAND_LSOF
>> +#define CONFIGURE_SHELL_COMMAND_CHDIR
>> +#define CONFIGURE_SHELL_COMMAND_CD
>> +#define CONFIGURE_SHELL_COMMAND_MKDIR
>> +#define CONFIGURE_SHELL_COMMAND_RMDIR
>> +#define CONFIGURE_SHELL_COMMAND_CAT
>> +#define CONFIGURE_SHELL_COMMAND_MV
>> +#define CONFIGURE_SHELL_COMMAND_MALLOC_INFO
>> +#include <rtems/shellconfig.h>
>>  /* I2C address of CAT24C256 eeprom
>>     EEPROM SIZE 32 KB Ref: BBB SRM */
>>  #define I2C_SLAVE_ADDR         (0x50)
>> -#define EEPROM_SIZE 256
>> +#define EEPROM_SIZE 78
>>  #define EEPROM_PATH "/dev/i2c-0.eeprom"
>>  /* forward declarations to avoid warnings */
>> @@ -35,16 +87,23 @@ rtems_task Init(rtems_task_argument argument);
>>  const char rtems_test_name[] = "GSOC 2016 I2C TESTING";
>>  rtems_printer rtems_test_printer;
>>  rtems_task Init(
>>    rtems_task_argument ignored
>>    rtems_test_begin();
>>    int i;
>>    int rv,fd_bus,fd_in_dev;
>>    uint8_t in[EEPROM_SIZE];
>>    struct stat st;
>>    off_t off;
>> +  ssize_t n;
>> +  rtems_shell_env_t env;
>>    /*bus registration */
>>    rv = bbb_register_i2c_0();
>> @@ -64,23 +123,56 @@ rtems_task Init(
>>        256, // size_in_bytes
>>        0 // program time out in ms
>> + _Assert(rv == 0);
>> +// exit( 0 );
>>    printf("register EEPROM \n");
>>    fd_in_dev = open(EEPROM_PATH, O_RDWR);
>> +  printf("fd_in_dev:%d\n", fd_in_dev);
>>    _Assert(fd_in_dev >=0);
>>    printf("open eeprom \n");
>>    rv = fstat(fd_in_dev, &st);
>>    _Assert(rv == 0);
>>    _Assert(st.st_blksize == 8);
>>    _Assert(st.st_size == sizeof(in));
>> +printf("read func\n");
>> +  n = read(fd_in_dev, &in[0], sizeof(in));
>> +   printf("n:%d\n",n );
>> +    printf("0:%x, ",in[0]);
>> +   printf("1:%x, ",in[1]);
>> + for(i=0;i<sizeof(in);++i)
>> +printf("%x\n",in[i]);
>> +   printf("sizeof(in):%d\n", sizeof(in));
>> +   // _Assert(n == -1);
>> +printf("test\n");
>>    for ( i = 0; i < sizeof(in); ++i) {
>> +    printf("i:%d\n",i);
>>      off = lseek(fd_in_dev, 0, SEEK_SET);
>> +    printf("lseek func done!\n");
>>      rv = read(fd_in_dev,&in[0], sizeof(in));
>> -    printf("\n %s \n ",in[i]);
>> +   // printf("\n %s \n ",in[i]);
>>    printf("EXIT from test case");
>>    close(fd_bus);
>> -  unlink(BBB_I2C_2_BUS_PATH);
>> + unlink(BBB_I2C_2_BUS_PATH);
>>    rtems_test_end();
> devel mailing list
> devel at rtems.org
