[PATCH 1/5] Adding modified FREEBSD headers to sync RTEMS termios with FREEBSD
Kirspel, Kevin Kevin-Kirspel at idexx.com
Tue Mar 21 18:02:33 UTC 2017
I have compiled all BSPs for the following toolsets:
arm, bfin, sh, i386, m68k, lm32, powerpc, and sparc
All BSPs for these toolsets build without error.  I had to fix some arm and sh code so I will send version 3 of the patch soon.  These toolsets were chosen due to the fact that a BSP within the toolset was updated to accommodate the termios changes.
Kevin Kirspel
Electrical Engineer - Sr. Staff
Idexx Roswell
235 Hembree Park Drive
Roswell GA 30076
Tel: (770)-510-4444 ext. 81642
Direct: (770)-688-1642
Fax: (770)-510-4445
-----Original Message-----
From: devel [mailto:devel-bounces at rtems.org] On Behalf Of Sebastian Huber
Sent: Tuesday, March 21, 2017 2:35 AM
To: devel at rtems.org
Subject: Re: [PATCH 1/5] Adding modified FREEBSD headers to sync RTEMS termios with FREEBSD
On 21/03/17 00:25, Joel Sherrill wrote:
> Agreed a BSP or user space code should not use the same name as
> anything that is included in POSIX. :)
> How did my build sweep miss this?
You didn't apply Kevin's patches?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
devel mailing list
devel at rtems.org
https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.rtems.org_mailman_listinfo_devel&d=DwIF-g&c=2do6VJGs3LvEOe4OFFM1bA&r=dbavT-WIJ4nBfQFKYnKdAD52Vyq3ZXSzrL9TAm21lZI&m=gviw10QRteGCnfEYiKuWi1Y2f1ukuTJ7WvP9wjxNeXQ&s=HvhAZ_Ioa2oUSpcVqSrkqer5oyBw1CQys4XBb7XcgOg&e=
