[PATCH v3 5/5] Updated termios testsuites to use dedicated input and output baud rates in termios structure
Kevin Kirspel
kevin-kirspel at idexx.com
Tue Mar 21 19:39:52 UTC 2017
testsuites/libtests/termios/init.c | 341 +++++++++++++--------
testsuites/libtests/termios01/init.c | 143 +++++++--
testsuites/libtests/termios01/termios01.scn | 270 ++++++++++++----
testsuites/libtests/termios01/termios_testdriver.c | 6 +-
testsuites/libtests/termios02/termios02.scn | 4 +-
testsuites/libtests/termios03/termios03.scn | 6 +-
testsuites/libtests/termios04/termios04.scn | 8 +-
testsuites/libtests/termios05/termios05.scn | 8 +-
testsuites/libtests/termios06/init.c | 2 +-
testsuites/libtests/termios06/termios06.scn | 20 +-
testsuites/libtests/termios07/termios07.scn | 21 +-
testsuites/libtests/termios08/termios08.scn | 19 +-
12 files changed, 592 insertions(+), 256 deletions(-)
diff --git a/testsuites/libtests/termios/init.c b/testsuites/libtests/termios/init.c
index fcb586b..d8ac60a 100644
--- a/testsuites/libtests/termios/init.c
+++ b/testsuites/libtests/termios/init.c
@@ -46,6 +46,7 @@ void print_c_oflag(struct termios * tp);
void print_c_lflag(struct termios * tp);
void print_c_cflag(struct termios * tp);
void print_c_cc(struct termios * tp);
+void print_baud(const char* name, speed_t spd);
void print_termios(struct termios *tp);
unsigned long get_baud_rate(void);
unsigned long get_parity(void);
@@ -118,6 +119,9 @@ void print_c_oflag( struct termios * tp )
if( tp->c_oflag & ONLCR )
printf( "ONLCR " );
+ if( tp->c_oflag & ONOEOT )
+ printf( "ONOEOT " );
if( tp->c_oflag & OCRNL )
printf( "OCRNL " );
@@ -215,27 +219,38 @@ void print_c_oflag( struct termios * tp )
void print_c_lflag( struct termios * tp )
char * c_lflag_bits [] = {
- "ISIG", /* 0000001 */
- "ICANON", /* 0000002 */
- "XCASE", /* 0000004 */
- "ECHO", /* 0000010 */
- "ECHOE", /* 0000020 */
- "ECHOK", /* 0000040 */
- "ECHONL", /* 0000100 */
- "NOFLSH", /* 0000200 */
- "TOSTOP", /* 0000400 */
- "ECHOCTL", /* 0001000 */
- "ECHOPRT", /* 0002000 */
- "ECHOKE", /* 0004000 */
- "FLUSHO", /* 0010000 */
- "unknown", /* 0020000 */
- "PENDIN", /* 0040000 */
- "IEXTEN", /* 0100000 */
- "unknown", /* 0200000 */
- "unknown", /* 0400000 */
- "unknown", /* 1000000 */
- "unknown", /* 2000000 */
- "unknown", /* 4000000 */
+ "ECHOKE", /* 0x00000001 */
+ "ECHOE", /* 0x00000002 */
+ "ECHOK", /* 0x00000004 */
+ "ECHO", /* 0x00000008 */
+ "ECHONL", /* 0x00000010 */
+ "ECHOPRT", /* 0x00000020 */
+ "ECHOCTL", /* 0x00000040 */
+ "ISIG", /* 0x00000080 */
+ "ICANON", /* 0x00000100 */
+ "ALTWERASE", /* 0x00000200 */
+ "IEXTEN", /* 0x00000400 */
+ "EXTPROC", /* 0x00000800 */
+ "XCASE", /* 0x00001000 */
+ "unknown", /* 0x00002000 */
+ "unknown", /* 0x00004000 */
+ "unknown", /* 0x00008000 */
+ "unknown", /* 0x00010000 */
+ "unknown", /* 0x00020000 */
+ "unknown", /* 0x00040000 */
+ "unknown", /* 0x00080000 */
+ "unknown", /* 0x00100000 */
+ "unknown", /* 0x00200000 */
+ "TOSTOP", /* 0x00400000 */
+ "FLUSHO", /* 0x00800000 */
+ "unknown", /* 0x01000000 */
+ "NOKERNINFO", /* 0x02000000 */
+ "unknown", /* 0x04000000 */
+ "unknown", /* 0x08000000 */
+ "unknown", /* 0x10000000 */
+ "PENDIN", /* 0x20000000 */
+ "unknown", /* 0x40000000 */
+ "NOFLSH", /* 0x80000000 */
printf( "c_lflag = 0x%08x\n\t", tp->c_lflag );
@@ -246,98 +261,8 @@ void print_c_lflag( struct termios * tp )
void print_c_cflag( struct termios * tp )
- unsigned int baud;
printf( "c_cflag = 0x%08x\n", tp->c_cflag );
- baud = (tp->c_cflag & CBAUD) ;
- if ( tp->c_cflag & CBAUDEX )
- switch( baud ) {
- case B0:
- printf( "\tCBAUD =\tB0\n" );
- break;
- case B50:
- printf( "\tCBAUD =\tB50\n" );
- break;
- case B75:
- printf( "\tCBAUD =\tB75\n" );
- break;
- case B110:
- printf( "\tCBAUD =\tB110\n" );
- break;
- case B134:
- printf( "\tCBAUD =\tB134\n" );
- break;
- case B150:
- printf( "\tCBAUD =\tB150\n" );
- break;
- case B200:
- printf( "\tCBAUD =\tB200\n" );
- break;
- case B300:
- printf( "\tCBAUD =\tB300\n" );
- break;
- case B600:
- printf( "\tCBAUD =\tB600\n" );
- break;
- case B1200:
- printf( "\tCBAUD =\tB1200\n" );
- break;
- case B1800:
- printf( "\tCBAUD =\tB1800\n" );
- break;
- case B2400:
- printf( "\tCBAUD =\tB2400\n" );
- break;
- case B4800:
- printf( "\tCBAUD =\tB4800\n" );
- break;
- case B9600:
- printf( "\tCBAUD =\tB9600\n" );
- break;
- case B19200:
- printf( "\tCBAUD =\tB19200\n" );
- break;
- case B38400:
- printf( "\tCBAUD =\tB38400\n" );
- break;
- case B57600:
- printf( "\tCBAUD =\tB57600\n" );
- break;
- case B115200:
- printf( "\tCBAUD =\tB115200\n" );
- break;
- case B230400:
- printf( "\tCBAUD =\tB230400\n" );
- break;
- case B460800:
- printf( "\tCBAUD =\tB460800\n" );
- break;
- default:
- printf( "\tCBAUD =\tunknown (0x%08x)\n", baud );
- break;
switch( tp->c_cflag & CSIZE ) {
case CS5:
printf( "\tCSIZE =\tCS5\n" );
@@ -356,6 +281,11 @@ void print_c_cflag( struct termios * tp )
break;
+ if( tp->c_cflag & CIGNORE )
+ printf( "\tCIGNORE set: iqnore c_cflags enabled\n" );
+ else
+ printf( "\tCIGNORE clear: iqnore c_cflags disabled\n" );
if( tp->c_cflag & CSTOPB )
printf( "\tCSTOPB set: send 2 stop bits\n" );
else
@@ -386,17 +316,35 @@ void print_c_cflag( struct termios * tp )
else
printf( "\tCLOCAL clear: don't ignore modem lines\n" );
-#if defined(CBAUDEX)
- if( tp->c_cflag & CBAUDEX )
- printf( "\tCBAUDEX set: What does this do?\n" );
+ if( tp->c_cflag & CCTS_OFLOW )
+ printf( "\tCCTS_OFLOW: hardware CTS output flow control enabled\n" );
else
- printf( "\tCBAUDEX clear: What does this do?\n" );
-#endif
+ printf( "\tCCTS_OFLOW: hardware CTS output flow control disabled\n" );
+ if( tp->c_cflag & CRTS_IFLOW )
+ printf( "\tCRTS_IFLOW: hardware RTS input flow control enabled\n" );
+ else
+ printf( "\tCRTS_IFLOW: hardware RTS input flow control disabled\n" );
if( tp->c_cflag & CRTSCTS )
printf( "\tCRTSCTS: harware flow control enabled?\n" );
else
printf( "\tCRTSCTS: hardware flow control disabled?\n" );
+ if( tp->c_cflag & CDSR_OFLOW )
+ printf( "\tCDSR_OFLOW: hardware DSR output flow control enabled\n" );
+ else
+ printf( "\tCDSR_OFLOW: hardware DSR output flow control disabled\n" );
+ if( tp->c_cflag & CDTR_IFLOW )
+ printf( "\tCDTR_IFLOW: hardware DTR input flow control enabled\n" );
+ else
+ printf( "\tCDTR_IFLOW: hardware DTR input flow control disabled\n" );
+ if( tp->c_cflag & CCAR_OFLOW )
+ printf( "\tCCAR_OFLOW: hardware CD output flow control enabled\n" );
+ else
+ printf( "\tCCAR_OFLOW: hardware CD output flow control disabled\n" );
@@ -404,25 +352,26 @@ void print_c_cc( struct termios * tp )
size_t i;
char * cc_index_names [ /* NCCS */ ] = {
- "[VINTR] ", /* 0 */
- "[VQUIT] ", /* 1 */
- "[VERASE] ", /* 2 */
- "[VKILL] ", /* 3 */
- "[VEOF] ", /* 4 */
- "[VTIME] ", /* 5 */
- "[VMIN] ", /* 6 */
- "[VSWTC ", /* 7 */
- "[VSTART] ", /* 8 */
- "[VSTOP] ", /* 9 */
+ "[VEOF] ", /* 0 */
+ "[VEOL] ", /* 1 */
+ "[VEOL2] ", /* 2 */
+ "[VERASE] ", /* 3 */
+ "[VWERASE] ", /* 4 */
+ "[VKILL] ", /* 5 */
+ "[VREPRINT]", /* 6 */
+ "[VERASE2] ", /* 7 */
+ "[VINTR] ", /* 8 */
+ "[VQUIT] ", /* 9 */
"[VSUSP] ", /* 10 */
- "[VEOL] ", /* 11 */
- "[VREPRINT]", /* 12 */
- "[VDISCARD]", /* 13 */
- "[VWERASE] ", /* 14 */
- "[VLNEXT ", /* 15 */
- "[VEOL2] ", /* 16 */
- "unknown ", /* 17 */
- "unknown ", /* 18 */
+ "[VDSUSP] ", /* 11 */
+ "[VSTART] ", /* 12 */
+ "[VSTOP] ", /* 13 */
+ "[VLNEXT] ", /* 14 */
+ "[VDISCARD]", /* 15 */
+ "[VMIN] ", /* 16 */
+ "[VTIME] ", /* 17 */
+ "[VSTATUS] ", /* 18 */
+ "unknown ", /* 19 */
for( i = 0; i < sizeof(cc_index_names)/sizeof(char*) ; i++ ) {
@@ -431,6 +380,116 @@ void print_c_cc( struct termios * tp )
+void print_baud( const char* name, speed_t spd )
+ switch( spd ) {
+ case B0:
+ printf( "%s = B0\n", name );
+ break;
+ case B50:
+ printf( "%s = B50\n", name );
+ break;
+ case B75:
+ printf( "%s = B75\n", name );
+ break;
+ case B110:
+ printf( "%s = B110\n", name );
+ break;
+ case B134:
+ printf( "%s = B134\n", name );
+ break;
+ case B150:
+ printf( "%s = B150\n", name );
+ break;
+ case B200:
+ printf( "%s = B200\n", name );
+ break;
+ case B300:
+ printf( "%s = B300\n", name );
+ break;
+ case B600:
+ printf( "%s = B600\n", name );
+ break;
+ case B1200:
+ printf( "%s = B1200\n", name );
+ break;
+ case B1800:
+ printf( "%s = B1800\n", name );
+ break;
+ case B2400:
+ printf( "%s = B2400\n", name );
+ break;
+ case B4800:
+ printf( "%s = B4800\n", name );
+ break;
+ case B9600:
+ printf( "%s = B9600\n", name );
+ break;
+ case B19200:
+ printf( "%s = B19200\n", name );
+ break;
+ case B38400:
+ printf( "%s = B38400\n", name );
+ break;
+ case B7200:
+ printf( "%s = B7200\n", name );
+ break;
+ case B14400:
+ printf( "%s = B14400\n", name );
+ break;
+ case B28800:
+ printf( "%s = B28800\n", name );
+ break;
+ case B57600:
+ printf( "%s = B57600\n", name );
+ break;
+ case B76800:
+ printf( "%s = B76800\n", name );
+ break;
+ case B115200:
+ printf( "%s = B115200\n", name );
+ break;
+ case B230400:
+ printf( "%s = B230400\n", name );
+ break;
+ case B460800:
+ printf( "%s = B460800\n", name );
+ break;
+ case B921600:
+ printf( "%s = B921600\n", name );
+ break;
+ default:
+ printf( "%s = unknown (0x%08x)\n", name, (unsigned int)spd );
+ break;
void print_termios( struct termios *tp )
printf( "\nLooking at the current termios settings:\n\n" );
@@ -439,6 +498,8 @@ void print_termios( struct termios *tp )
print_c_cflag( tp );
print_c_lflag( tp );
print_c_cc( tp );
+ print_baud( "c_ispeed", tp->c_ispeed );
+ print_baud( "c_ospeed", tp->c_ospeed );
printf( "\n" );
@@ -450,7 +511,8 @@ unsigned long get_baud_rate(void)
while( 1 ) {
printf( "Enter the numerical value for the new baud rate.\n" );
printf( "Choices are: 50, 75, 110, 134, 150, 200, 300, 600, 1200, 1800\n" );
- printf( "2400, 4800, 9600, 19200, 38400, 57600, 115200, 230400, 460800\n" );
+ printf( "2400, 4800, 9600, 19200, 38400, 7200, 14400, 28800, 57600, 76800\n" );
+ printf( "115200, 230400, 460800, 921600\n" );
printf( "\nYour choice: " );
scanf( "%lu", &baud_rate );
printf( "\n" );
@@ -470,10 +532,15 @@ unsigned long get_baud_rate(void)
case 9600: return B9600;
case 19200: return B19200;
case 38400: return B38400;
+ case 7200: return B7200;
+ case 14400: return B14400;
+ case 28800: return B28800;
case 57600: return B57600;
+ case 76800: return B76800;
case 115200: return B115200;
case 230400: return B230400;
case 460800: return B460800;
+ case 921600: return B921600;
default:
printf( "%lu is not a valid choice. Try again.\n\n", baud_rate );
@@ -589,7 +656,9 @@ void change_line_settings( struct termios *tp )
sleep( sleep_time );
- tp->c_cflag = CLOCAL | CREAD | parity | stop_bits | data_bits | baud_rate;
+ tp->c_cflag = CLOCAL | CREAD | parity | stop_bits | data_bits;
+ tp->c_ispeed = baud_rate;
+ tp->c_ospeed = baud_rate;
if( tcsetattr( fileno( stdin ), TCSADRAIN, tp ) < 0 ) {
perror( "change_line_settings(): tcsetattr() failed" );
rtems_test_exit( 1 );
diff --git a/testsuites/libtests/termios01/init.c b/testsuites/libtests/termios01/init.c
index 64c3bb2..562b252 100644
--- a/testsuites/libtests/termios01/init.c
+++ b/testsuites/libtests/termios01/init.c
@@ -12,6 +12,7 @@
#endif
#include "tmacros.h"
+#define TTYDEFCHARS
#include <termios.h>
#include <rtems/libcsupport.h>
#include <rtems/malloc.h>
@@ -66,10 +67,15 @@ static const termios_baud_test_r baud_table[] = {
{ B9600, 9600 },
{ B19200, 19200 },
{ B38400, 38400 },
+ { B7200, 7200 },
+ { B14400, 14400 },
+ { B28800, 28800 },
{ B57600, 57600 },
+ { B76800, 76800 },
{ B115200, 115200 },
{ B230400, 230400 },
{ B460800, 460800 },
+ { B921600, 921600 },
{ INVALID_CONSTANT, INVALID_BAUD }
@@ -233,16 +239,14 @@ static void test_termios_set_baud(
puts( "Test termios setting device baud rate..." );
for (i=0 ; baud_table[i].constant != INVALID_CONSTANT ; i++ ) {
- tcflag_t cbaud = CBAUD;
sc = tcgetattr( test, &attr );
if ( sc != 0 ) {
printf( "ERROR - return %d\n", sc );
rtems_test_exit(0);
- attr.c_cflag &= ~cbaud;
- attr.c_cflag |= baud_table[i].constant;
+ attr.c_ispeed = baud_table[i].constant;
+ attr.c_ospeed = baud_table[i].constant;
printf(
"tcsetattr(TCSANOW, B%" PRIdrtems_termios_baud_t ") - OK\n",
@@ -258,7 +262,17 @@ static void test_termios_set_baud(
"tcsetattr(TCSADRAIN, B%" PRIdrtems_termios_baud_t ") - OK\n",
baud_table[i].baud
- sc = tcsetattr( test, TCSANOW, &attr );
+ sc = tcsetattr( test, TCSADRAIN, &attr );
+ if ( sc != 0 ) {
+ printf( "ERROR - return %d\n", sc );
+ rtems_test_exit(0);
+ printf(
+ "tcsetattr(TCSAFLUSH, B%" PRIdrtems_termios_baud_t ") - OK\n",
+ baud_table[i].baud
+ sc = tcsetattr( test, TCSAFLUSH, &attr );
if ( sc != 0 ) {
rtems_test_exit(0);
@@ -301,7 +315,21 @@ static void test_termios_set_charsize(
printf( "tcsetattr(TCSADRAIN, CS%d) - OK\n", char_size_table[i].bits );
+ if ( sc != 0 ) {
+ printf( "tcsetattr(TCSAFLUSH, CS%d) - OK\n", char_size_table[i].bits );
+ if ( sc != 0 ) {
+ printf( "tcsetattr(TCSASOFT, CS%d) - OK\n", char_size_table[i].bits );
+ sc = tcsetattr( test, TCSASOFT, &attr );
if ( sc != 0 ) {
rtems_test_exit(0);
@@ -344,7 +372,21 @@ static void test_termios_set_parity(
printf( "tcsetattr(TCSADRAIN, %s) - OK\n", parity_table[i].parity );
+ if ( sc != 0 ) {
+ printf( "tcsetattr(TCSAFLUSH, %s) - OK\n", parity_table[i].parity );
+ if ( sc != 0 ) {
+ printf( "tcsetattr(TCSASOFT, %s) - OK\n", parity_table[i].parity );
if ( sc != 0 ) {
rtems_test_exit(0);
@@ -390,7 +432,21 @@ static void test_termios_set_stop_bits(
printf( "tcsetattr(TCSADRAIN, %d bits) - OK\n", stop_bits_table[i].stop );
+ if ( sc != 0 ) {
+ printf( "tcsetattr(TCSAFLUSH, %d bits) - OK\n", stop_bits_table[i].stop );
+ if ( sc != 0 ) {
+ printf( "tcsetattr(TCSASOFT, %d bits) - OK\n", stop_bits_table[i].stop );
if ( sc != 0 ) {
rtems_test_exit(0);
@@ -404,9 +460,9 @@ static void test_termios_cfoutspeed(void)
int sc;
speed_t speed;
struct termios term;
- tcflag_t bad;
+ speed_t bad;
- bad = CBAUD << 1;
+ bad = B921600 << 1;
memset( &term, '\0', sizeof(term) );
puts( "cfsetospeed(BAD BAUD) - EINVAL" );
sc = cfsetospeed( &term, bad );
@@ -436,9 +492,9 @@ static void test_termios_cfinspeed(void)
int sc;
speed_t speed;
- tcflag_t bad;
+ speed_t bad;
- bad = CBAUD << 1;
puts( "cfsetispeed(BAD BAUD) - EINVAL" );
sc = cfsetispeed( &term, bad );
@@ -469,9 +525,9 @@ static void test_termios_cfsetspeed(void)
int status;
speed_t speed;
- tcflag_t bad;
+ speed_t bad;
- bad = CBAUD << 1;
puts( "cfsetspeed(BAD BAUD) - EINVAL" );
status = cfsetspeed( &term, bad );
@@ -508,15 +564,45 @@ static void test_termios_cfmakeraw(void)
puts( "cfmakeraw - OK" );
/* Check that all of the flags were set correctly */
- rtems_test_assert( ~(term.c_iflag & (IMAXBEL|IGNBRK|BRKINT|PARMRK|ISTRIP|INLCR|IGNCR|ICRNL|IXON)) );
+ rtems_test_assert( ~(term.c_iflag & (IMAXBEL|IXOFF|INPCK|BRKINT|PARMRK|ISTRIP|INLCR|IGNCR|ICRNL|IXON|IGNPAR)) );
+ rtems_test_assert( term.c_iflag & (IGNBRK) );
rtems_test_assert( ~(term.c_oflag & OPOST) );
- rtems_test_assert( ~(term.c_lflag & (ECHO|ECHONL|ICANON|ISIG|IEXTEN)) );
+ rtems_test_assert( ~(term.c_lflag & (ECHO|ECHOE|ECHOK|ECHONL|ICANON|ISIG|IEXTEN|NOFLSH|TOSTOP|PENDIN)) );
rtems_test_assert( ~(term.c_cflag & (CSIZE|PARENB)) );
- rtems_test_assert( term.c_cflag & CS8 );
+ rtems_test_assert( term.c_cflag & (CS8|CREAD) );
+ rtems_test_assert( term.c_cc[VMIN] == 1 );
+ rtems_test_assert( term.c_cc[VTIME] == 0 );
+static void test_termios_cfmakesane(void)
+ struct termios term;
+ memset( &term, '\0', sizeof(term) );
+ cfmakesane( &term );
+ puts( "cfmakesane - OK" );
+ /* Check that all of the flags were set correctly */
+ rtems_test_assert( term.c_iflag == TTYDEF_IFLAG );
+ rtems_test_assert( term.c_oflag == TTYDEF_OFLAG );
+ rtems_test_assert( term.c_lflag == TTYDEF_LFLAG );
+ rtems_test_assert( term.c_cflag == TTYDEF_CFLAG );
+ rtems_test_assert( term.c_ispeed == TTYDEF_SPEED );
+ rtems_test_assert( term.c_ospeed == TTYDEF_SPEED );
+ rtems_test_assert( memcmp(&term.c_cc, ttydefchars, sizeof(term.c_cc)) == 0 );
typedef struct {
@@ -684,7 +770,7 @@ static void test_set_attributes_error(void)
rtems_test_assert( !ctx.done );
errno = 0;
- rv = ioctl( fd, RTEMS_IO_SET_ATTRIBUTES, &term );
+ rv = ioctl( fd, TIOCSETA, &term );
rtems_test_assert( rv == -1 );
rtems_test_assert( errno == EIO );
rtems_test_assert( ctx.done );
@@ -702,8 +788,8 @@ static void test_set_best_baud(void)
static const struct {
uint32_t baud;
- tcflag_t cflag;
- } baud_to_cflag_table[] = {
+ speed_t speed;
+ } baud_to_speed_table[] = {
{ 0, B0 },
{ 25, B0 },
{ 26, B50 },
@@ -731,19 +817,17 @@ static void test_set_best_baud(void)
{ 0xffffffff, B460800 }
- size_t n = RTEMS_ARRAY_SIZE(baud_to_cflag_table);
+ size_t n = RTEMS_ARRAY_SIZE(baud_to_speed_table);
size_t i;
for ( i = 0; i < n; ++i ) {
- tcflag_t cbaud_mask = CBAUD;
memset( &term, 0xff, sizeof( term ) );
- rtems_termios_set_best_baud( &term, baud_to_cflag_table[ i ].baud );
+ rtems_termios_set_best_baud( &term, baud_to_speed_table[ i ].baud );
- (term.c_cflag & cbaud_mask) == baud_to_cflag_table[ i ].cflag
+ rtems_test_assert( term.c_ispeed == baud_to_speed_table[ i ].speed );
+ rtems_test_assert( term.c_ospeed == baud_to_speed_table[ i ].speed );
@@ -791,13 +875,14 @@ static rtems_task Init(
* tcsetattr - ERROR invalid operation
- puts( "tcsetattr - invalid operation - ENOTSUP" );
+ puts( "tcsetattr - invalid operation - EINVAL" );
rc = tcsetattr( test, INT_MAX, &t );
rtems_test_assert( rc == -1 );
- rtems_test_assert( errno == ENOTSUP );
+ rtems_test_assert( errno == EINVAL );
test_termios_cfmakeraw();
+ test_termios_cfmakesane();
* tcsetattr - TCSADRAIN
diff --git a/testsuites/libtests/termios01/termios01.scn b/testsuites/libtests/termios01/termios01.scn
index c1c5470..36f1b8e 100644
--- a/testsuites/libtests/termios01/termios01.scn
+++ b/testsuites/libtests/termios01/termios01.scn
@@ -1,4 +1,4 @@
-*** TEST TERMIOS 01 ***
+*** BEGIN OF TEST TERMIOS 1 ***
Test termios_baud2index...
termios_baud_to_index(-2) - NOT OK
termios_baud_to_index(B0) - OK
@@ -17,10 +17,15 @@ termios_baud_to_index(B4800) - OK
termios_baud_to_index(B9600) - OK
termios_baud_to_index(B19200) - OK
termios_baud_to_index(B38400) - OK
+termios_baud_to_index(B7200) - OK
+termios_baud_to_index(B14400) - OK
+termios_baud_to_index(B28800) - OK
termios_baud_to_index(B57600) - OK
+termios_baud_to_index(B76800) - OK
termios_baud_to_index(B115200) - OK
termios_baud_to_index(B230400) - OK
termios_baud_to_index(B460800) - OK
+termios_baud_to_index(B921600) - OK
Test termios_baud2number...
termios_baud_to_number(-2) - NOT OK
@@ -40,10 +45,15 @@ termios_baud_to_number(B4800) - OK
termios_baud_to_number(B9600) - OK
termios_baud_to_number(B19200) - OK
termios_baud_to_number(B38400) - OK
+termios_baud_to_number(B7200) - OK
+termios_baud_to_number(B14400) - OK
+termios_baud_to_number(B28800) - OK
termios_baud_to_number(B57600) - OK
+termios_baud_to_number(B76800) - OK
termios_baud_to_number(B115200) - OK
termios_baud_to_number(B230400) - OK
termios_baud_to_number(B460800) - OK
+termios_baud_to_number(B921600) - OK
Test termios_number_to_baud...
termios_number_to_baud(-2) - NOT OK
@@ -63,103 +73,179 @@ termios_number_to_baud(B4800) - OK
termios_number_to_baud(B9600) - OK
termios_number_to_baud(B19200) - OK
termios_number_to_baud(B38400) - OK
+termios_number_to_baud(B7200) - OK
+termios_number_to_baud(B14400) - OK
+termios_number_to_baud(B28800) - OK
termios_number_to_baud(B57600) - OK
+termios_number_to_baud(B76800) - OK
termios_number_to_baud(B115200) - OK
termios_number_to_baud(B230400) - OK
termios_number_to_baud(B460800) - OK
+termios_number_to_baud(B921600) - OK
Init - rtems_io_register_driver - Termios Test Driver - OK
Termios_test_driver - rtems_io_register /dev/test - OK
-Init - Major slot returned = 2
+Init - Major slot returned = 3
Init - open - /dev/test - OK
Termios_test_driver - rtems_set_initial_baud - bad baud - OK
Termios_test_driver - rtems_set_initial_baud - 38400 - OK
-tcsetattr - invalid operation - ENOTSUP
+tcsetattr - invalid operation - EINVAL
cfmakeraw - OK
+cfmakesane - OK
tcsetattr - drain - OK
-set_attributes - B0 5-NONE-1
+set_attributes - B0 8-NONE-2
tcsetattr(TCSANOW, B0) - OK
tcsetattr(TCSADRAIN, B0) - OK
+tcsetattr(TCSAFLUSH, B0) - OK
tcsetattr(TCSANOW, B50) - OK
-set_attributes - B50 5-NONE-1
+set_attributes - B50 8-NONE-2
tcsetattr(TCSADRAIN, B50) - OK
+tcsetattr(TCSAFLUSH, B50) - OK
tcsetattr(TCSANOW, B75) - OK
-set_attributes - B75 5-NONE-1
+set_attributes - B75 8-NONE-2
tcsetattr(TCSADRAIN, B75) - OK
+tcsetattr(TCSAFLUSH, B75) - OK
tcsetattr(TCSANOW, B110) - OK
-set_attributes - B110 5-NONE-1
+set_attributes - B110 8-NONE-2
tcsetattr(TCSADRAIN, B110) - OK
+tcsetattr(TCSAFLUSH, B110) - OK
tcsetattr(TCSANOW, B134) - OK
-set_attributes - B134 5-NONE-1
+set_attributes - B134 8-NONE-2
tcsetattr(TCSADRAIN, B134) - OK
+tcsetattr(TCSAFLUSH, B134) - OK
tcsetattr(TCSANOW, B150) - OK
-set_attributes - B150 5-NONE-1
+set_attributes - B150 8-NONE-2
tcsetattr(TCSADRAIN, B150) - OK
+tcsetattr(TCSAFLUSH, B150) - OK
tcsetattr(TCSANOW, B200) - OK
-set_attributes - B200 5-NONE-1
+set_attributes - B200 8-NONE-2
tcsetattr(TCSADRAIN, B200) - OK
+tcsetattr(TCSAFLUSH, B200) - OK
tcsetattr(TCSANOW, B300) - OK
-set_attributes - B300 5-NONE-1
+set_attributes - B300 8-NONE-2
tcsetattr(TCSADRAIN, B300) - OK
+tcsetattr(TCSAFLUSH, B300) - OK
tcsetattr(TCSANOW, B600) - OK
-set_attributes - B600 5-NONE-1
+set_attributes - B600 8-NONE-2
tcsetattr(TCSADRAIN, B600) - OK
+tcsetattr(TCSAFLUSH, B600) - OK
tcsetattr(TCSANOW, B1200) - OK
-set_attributes - B1200 5-NONE-1
+set_attributes - B1200 8-NONE-2
tcsetattr(TCSADRAIN, B1200) - OK
+tcsetattr(TCSAFLUSH, B1200) - OK
tcsetattr(TCSANOW, B1800) - OK
-set_attributes - B1800 5-NONE-1
+set_attributes - B1800 8-NONE-2
tcsetattr(TCSADRAIN, B1800) - OK
+tcsetattr(TCSAFLUSH, B1800) - OK
tcsetattr(TCSANOW, B2400) - OK
-set_attributes - B2400 5-NONE-1
+set_attributes - B2400 8-NONE-2
tcsetattr(TCSADRAIN, B2400) - OK
+tcsetattr(TCSAFLUSH, B2400) - OK
tcsetattr(TCSANOW, B4800) - OK
-set_attributes - B4800 5-NONE-1
+set_attributes - B4800 8-NONE-2
tcsetattr(TCSADRAIN, B4800) - OK
+tcsetattr(TCSAFLUSH, B4800) - OK
tcsetattr(TCSANOW, B9600) - OK
-set_attributes - B9600 5-NONE-1
+set_attributes - B9600 8-NONE-2
tcsetattr(TCSADRAIN, B9600) - OK
+tcsetattr(TCSAFLUSH, B9600) - OK
tcsetattr(TCSANOW, B19200) - OK
-set_attributes - B19200 5-NONE-1
+set_attributes - B19200 8-NONE-2
tcsetattr(TCSADRAIN, B19200) - OK
+tcsetattr(TCSAFLUSH, B19200) - OK
tcsetattr(TCSANOW, B38400) - OK
-set_attributes - B38400 5-NONE-1
+set_attributes - B38400 8-NONE-2
tcsetattr(TCSADRAIN, B38400) - OK
+tcsetattr(TCSAFLUSH, B38400) - OK
+tcsetattr(TCSANOW, B7200) - OK
+set_attributes - B7200 8-NONE-2
+tcsetattr(TCSADRAIN, B7200) - OK
+tcsetattr(TCSAFLUSH, B7200) - OK
+tcsetattr(TCSANOW, B14400) - OK
+set_attributes - B14400 8-NONE-2
+tcsetattr(TCSADRAIN, B14400) - OK
+tcsetattr(TCSAFLUSH, B14400) - OK
+tcsetattr(TCSANOW, B28800) - OK
+set_attributes - B28800 8-NONE-2
+tcsetattr(TCSADRAIN, B28800) - OK
+tcsetattr(TCSAFLUSH, B28800) - OK
tcsetattr(TCSANOW, B57600) - OK
-set_attributes - B57600 5-NONE-1
+set_attributes - B57600 8-NONE-2
tcsetattr(TCSADRAIN, B57600) - OK
+tcsetattr(TCSAFLUSH, B57600) - OK
+tcsetattr(TCSANOW, B76800) - OK
+set_attributes - B76800 8-NONE-2
+tcsetattr(TCSADRAIN, B76800) - OK
+tcsetattr(TCSAFLUSH, B76800) - OK
tcsetattr(TCSANOW, B115200) - OK
-set_attributes - B115200 5-NONE-1
+set_attributes - B115200 8-NONE-2
tcsetattr(TCSADRAIN, B115200) - OK
+tcsetattr(TCSAFLUSH, B115200) - OK
tcsetattr(TCSANOW, B230400) - OK
-set_attributes - B230400 5-NONE-1
+set_attributes - B230400 8-NONE-2
tcsetattr(TCSADRAIN, B230400) - OK
+tcsetattr(TCSAFLUSH, B230400) - OK
tcsetattr(TCSANOW, B460800) - OK
-set_attributes - B460800 5-NONE-1
+set_attributes - B460800 8-NONE-2
tcsetattr(TCSADRAIN, B460800) - OK
+tcsetattr(TCSAFLUSH, B460800) - OK
+tcsetattr(TCSANOW, B921600) - OK
+set_attributes - B921600 8-NONE-2
+tcsetattr(TCSADRAIN, B921600) - OK
+tcsetattr(TCSAFLUSH, B921600) - OK
Init - close - /dev/test - OK
@@ -168,21 +254,37 @@ Termios_test_driver - rtems_set_initial_baud - 38400 - OK
Test termios setting device character size ...
tcsetattr(TCSANOW, CS5) - OK
+set_attributes - B38400 5-NONE-2
tcsetattr(TCSADRAIN, CS5) - OK
+tcsetattr(TCSAFLUSH, CS5) - OK
+tcsetattr(TCSASOFT, CS5) - OK
tcsetattr(TCSANOW, CS6) - OK
-set_attributes - B38400 6-NONE-1
+set_attributes - B38400 6-NONE-2
tcsetattr(TCSADRAIN, CS6) - OK
+tcsetattr(TCSAFLUSH, CS6) - OK
+tcsetattr(TCSASOFT, CS6) - OK
tcsetattr(TCSANOW, CS7) - OK
-set_attributes - B38400 7-NONE-1
+set_attributes - B38400 7-NONE-2
tcsetattr(TCSADRAIN, CS7) - OK
+tcsetattr(TCSAFLUSH, CS7) - OK
+tcsetattr(TCSASOFT, CS7) - OK
tcsetattr(TCSANOW, CS8) - OK
-set_attributes - B38400 8-NONE-1
tcsetattr(TCSADRAIN, CS8) - OK
+tcsetattr(TCSAFLUSH, CS8) - OK
+tcsetattr(TCSASOFT, CS8) - OK
@@ -191,17 +293,29 @@ Termios_test_driver - rtems_set_initial_baud - 38400 - OK
Test termios setting device parity ...
tcsetattr(TCSANOW, none) - OK
tcsetattr(TCSADRAIN, none) - OK
+tcsetattr(TCSAFLUSH, none) - OK
+tcsetattr(TCSASOFT, none) - OK
tcsetattr(TCSANOW, even) - OK
-set_attributes - B38400 8-ODD-1
+set_attributes - B38400 8-ODD-2
tcsetattr(TCSADRAIN, even) - OK
+tcsetattr(TCSAFLUSH, even) - OK
+tcsetattr(TCSASOFT, even) - OK
tcsetattr(TCSANOW, odd) - OK
-set_attributes - B38400 8-EVEN-1
+set_attributes - B38400 8-EVEN-2
tcsetattr(TCSADRAIN, odd) - OK
+tcsetattr(TCSAFLUSH, odd) - OK
+tcsetattr(TCSASOFT, odd) - OK
@@ -213,10 +327,18 @@ tcsetattr(TCSANOW, 1 bit) - OK
tcsetattr(TCSADRAIN, 1 bits) - OK
+tcsetattr(TCSAFLUSH, 1 bits) - OK
+set_attributes - B38400 8-NONE-1
+tcsetattr(TCSASOFT, 1 bits) - OK
tcsetattr(TCSANOW, 2 bits) - OK
tcsetattr(TCSADRAIN, 2 bits) - OK
+tcsetattr(TCSAFLUSH, 2 bits) - OK
+tcsetattr(TCSASOFT, 2 bits) - OK
cfsetospeed(B0) - OK
cfgetospeed(B0) - OK
@@ -250,14 +372,24 @@ cfsetospeed(B19200) - OK
cfgetospeed(B19200) - OK
cfsetospeed(B38400) - OK
cfgetospeed(B38400) - OK
+cfsetospeed(B7200) - OK
+cfgetospeed(B7200) - OK
+cfsetospeed(B14400) - OK
+cfgetospeed(B14400) - OK
+cfsetospeed(B28800) - OK
+cfgetospeed(B28800) - OK
cfsetospeed(B57600) - OK
cfgetospeed(B57600) - OK
+cfsetospeed(B76800) - OK
+cfgetospeed(B76800) - OK
cfsetospeed(B115200) - OK
cfgetospeed(B115200) - OK
cfsetospeed(B230400) - OK
cfgetospeed(B230400) - OK
cfsetospeed(B460800) - OK
cfgetospeed(B460800) - OK
+cfsetospeed(B921600) - OK
+cfgetospeed(B921600) - OK
cfsetispeed(B0) - OK
cfgetispeed(B0) - OK
@@ -291,14 +423,24 @@ cfsetispeed(B19200) - OK
cfgetispeed(B19200) - OK
cfsetispeed(B38400) - OK
cfgetispeed(B38400) - OK
+cfsetispeed(B7200) - OK
+cfgetispeed(B7200) - OK
+cfsetispeed(B14400) - OK
+cfgetispeed(B14400) - OK
+cfsetispeed(B28800) - OK
+cfgetispeed(B28800) - OK
cfsetispeed(B57600) - OK
cfgetispeed(B57600) - OK
+cfsetispeed(B76800) - OK
+cfgetispeed(B76800) - OK
cfsetispeed(B115200) - OK
cfgetispeed(B115200) - OK
cfsetispeed(B230400) - OK
cfgetispeed(B230400) - OK
cfsetispeed(B460800) - OK
cfgetispeed(B460800) - OK
+cfsetispeed(B921600) - OK
+cfgetispeed(B921600) - OK
cfsetspeed(B0) - OK
cfgetspeed(B0) - checking both inspeed and outspeed - OK
@@ -332,14 +474,24 @@ cfsetspeed(B19200) - OK
cfgetspeed(B19200) - checking both inspeed and outspeed - OK
cfsetspeed(B38400) - OK
cfgetspeed(B38400) - checking both inspeed and outspeed - OK
+cfsetspeed(B7200) - OK
+cfgetspeed(B7200) - checking both inspeed and outspeed - OK
+cfsetspeed(B14400) - OK
+cfgetspeed(B14400) - checking both inspeed and outspeed - OK
+cfsetspeed(B28800) - OK
+cfgetspeed(B28800) - checking both inspeed and outspeed - OK
cfsetspeed(B57600) - OK
cfgetspeed(B57600) - checking both inspeed and outspeed - OK
+cfsetspeed(B76800) - OK
+cfgetspeed(B76800) - checking both inspeed and outspeed - OK
cfsetspeed(B115200) - OK
cfgetspeed(B115200) - checking both inspeed and outspeed - OK
cfsetspeed(B230400) - OK
cfgetspeed(B230400) - checking both inspeed and outspeed - OK
cfsetspeed(B460800) - OK
cfgetspeed(B460800) - checking both inspeed and outspeed - OK
+cfsetspeed(B921600) - OK
+cfgetspeed(B921600) - checking both inspeed and outspeed - OK
Multiple open of the device
@@ -395,4 +547,4 @@ Termios_test_driver - rtems_set_initial_baud - 38400 - OK
-*** END OF TEST TERMIOS 01 ***
+*** END OF TEST TERMIOS 1 ***
diff --git a/testsuites/libtests/termios01/termios_testdriver.c b/testsuites/libtests/termios01/termios_testdriver.c
index 43aeccd..bd5c7a1 100644
--- a/testsuites/libtests/termios01/termios_testdriver.c
+++ b/testsuites/libtests/termios01/termios_testdriver.c
@@ -85,7 +85,7 @@ int termios_test_driver_set_attributes(
const char *char_size = "5";
const char *stop = "NONE";
- baud_requested = t->c_cflag & CBAUD;
+ baud_requested = t->c_ispeed;
number = rtems_termios_baud_to_number( baud_requested );
@@ -164,7 +164,7 @@ rtems_device_driver termios_test_driver_open(
int rc;
rtems_libio_open_close_args_t *args = arg;
static bool firstCall = true;
static const rtems_termios_callbacks Callbacks = {
NULL, /* firstOpen */
NULL, /* lastClose */
@@ -192,7 +192,7 @@ rtems_device_driver termios_test_driver_open(
size_t i;
firstCall = false;
for (i = 0; i < sizeof( allocSizes ) / sizeof( allocSizes [0] ); ++i) {
void *opaque = rtems_heap_greedy_allocate( allocSizes, i );
diff --git a/testsuites/libtests/termios02/termios02.scn b/testsuites/libtests/termios02/termios02.scn
index 9b38d69..be46893 100644
--- a/testsuites/libtests/termios02/termios02.scn
+++ b/testsuites/libtests/termios02/termios02.scn
@@ -1,4 +1,4 @@
-*** TERMIOS 02 TEST ***
+*** BEGIN OF TEST TERMIOS 2 ***
tcdrain(12) - EBADF
tcdrain(stdin) - OK
tcdrain(stdout) - OK
@@ -24,4 +24,4 @@ ctermid( NULL ) - OK
ctermid ==> /dev/console
ctermid( term_name ) - OK
-*** END OF TERMIOS 02 TEST ***
+*** END OF TEST TERMIOS 2 ***
diff --git a/testsuites/libtests/termios03/termios03.scn b/testsuites/libtests/termios03/termios03.scn
index 17802fe..ed4a784 100644
--- a/testsuites/libtests/termios03/termios03.scn
+++ b/testsuites/libtests/termios03/termios03.scn
@@ -1,4 +1,4 @@
-*** TEST TERMIOS03 ***
+*** BEGIN OF TEST TERMIOS 3 ***
open(/dev/test) - OK
Writing: This is test output.
Transmitted 22 characters
@@ -68,7 +68,7 @@ Echoed 55 characters
54 65 73 74 69 6e 67 20 56 4b 49 4c 4c 08 20 08 |Testing VKILL. .|
08 20 08 08 20 08 08 20 08 08 20 08 08 20 08 08 |. .. .. .. .. ..|
20 08 08 20 08 08 20 08 08 20 08 08 20 08 08 20 | .. .. .. .. .. |
-08 08 20 08 2e 0d 0a
+08 08 20 08 2e 0d 0a |.. .... |
Reading (expected):
7f 54 65 73 74 69 6e 67 20 56 45 52 41 53 45 20 |.Testing VERASE |
@@ -97,4 +97,4 @@ Echoed 140 characters
20 08 08 08 08 08 08 08 08 08 0d 0a | ........... |
close(/dev/test) - OK
-*** END OF TEST TERMIOS03 ***
+*** END OF TEST TERMIOS 3 ***
diff --git a/testsuites/libtests/termios04/termios04.scn b/testsuites/libtests/termios04/termios04.scn
index 99b8eb0..812369a 100644
--- a/testsuites/libtests/termios04/termios04.scn
+++ b/testsuites/libtests/termios04/termios04.scn
@@ -1,5 +1,5 @@
-*** TEST TERMIOS04 ***
-open(/dev/test) - OK
+*** BEGIN OF TEST TERMIOS 4 ***
+open(/dev/test) - OK
Writing: This is interrupt driven test output.
Transmitted 39 characters
54 68 69 73 20 69 73 20 69 6e 74 65 72 72 75 70 |This is interrup|
@@ -29,5 +29,5 @@ As Read 37 characters
4e 6f 6e 2d 42 6c 6f 63 6b 69 6e 67 20 69 6e 74 |Non-Blocking int|
65 72 72 75 70 74 20 64 72 69 76 65 6e 20 72 65 |errupt driven re|
61 64 2e 0d 0a |ad... |
-close(/dev/test) - OK
-*** END OF TEST TERMIOS04 ***
+close(/dev/test) - OK
+*** END OF TEST TERMIOS 4 ***
diff --git a/testsuites/libtests/termios05/termios05.scn b/testsuites/libtests/termios05/termios05.scn
index 4d2988f..e30a243 100644
--- a/testsuites/libtests/termios05/termios05.scn
+++ b/testsuites/libtests/termios05/termios05.scn
@@ -1,5 +1,5 @@
-*** TEST TERMIOS05 ***
+*** BEGIN OF TEST TERMIOS 5 ***
Transmitted 20 characters
54 68 69 73 20 69 73 20 74 65 73 74 20 6f 75 74 |This is test out|
@@ -55,5 +55,5 @@ Read 10 bytes from read(2)
Echoed 12 characters
0a 61 62 63 64 65 66 67 68 2e 0d 0a |.abcdefgh... |
Changing c_iflag to: Disable to lower case mapping on input
-*** END OF TEST TERMIOS05 ***
+*** END OF TEST TERMIOS 5 ***
diff --git a/testsuites/libtests/termios06/init.c b/testsuites/libtests/termios06/init.c
index 759b444..9b59ad2 100644
--- a/testsuites/libtests/termios06/init.c
+++ b/testsuites/libtests/termios06/init.c
@@ -198,7 +198,7 @@ rtems_task Init(
ioctl_it();
read_it();
close_it();
TEST_END();
rtems_test_exit(0);
diff --git a/testsuites/libtests/termios06/termios06.scn b/testsuites/libtests/termios06/termios06.scn
index b558077..1039597 100644
--- a/testsuites/libtests/termios06/termios06.scn
+++ b/testsuites/libtests/termios06/termios06.scn
@@ -1,7 +1,5 @@
-*** TEST TERMIOS06 ***
+*** BEGIN OF TEST TERMIOS 6 ***
ioctl - RTEMS_IO_SNDWAKEUP - OK
ioctl - RTEMS_IO_RCVWAKEUP - OK
ioctl - TIOCGETD - OK
@@ -10,14 +8,13 @@ pppopen called
ioctl - TIOCSETD - OK
pppclose called
pppopen called
-write(PPPD TEST) - OK
+write(PPPD TEST) - OK
pppwrite called - 10 bytes
50 50 50 44 20 54 45 53 54 00 |PPPD TEST. |
pppstart called
-ioctl(/dev/test) - OK
+ioctl(/dev/test) - OK
pppioctl called
-tcgetattr(/dev/test) - OK
+tcgetattr(/dev/test) - OK
Turn on flow control on output - OK
Turn off flow control on output - OK
Turn on flow control on input - OK
@@ -25,9 +22,7 @@ Turn off flow control on input - OK
Reading (expected):
54 68 69 73 20 69 73 20 74 65 73 74 20 50 50 50 |This is test PPP|
20 69 6e 70 75 74 | input |
pppread called
pppinput called - with (T)
pppinput called - with (h)
@@ -53,8 +48,7 @@ pppinput called - with (u)
pppinput called - with (t)
pppinput called - with (.)
Rx_Wake - invoked
Read 0 bytes from read(2)
+Error: length must be greater than zero.close(/dev/test) - OK
pppclose called
-*** END OF TEST TERMIOS06 ***
+*** END OF TEST TERMIOS 6 ***
diff --git a/testsuites/libtests/termios07/termios07.scn b/testsuites/libtests/termios07/termios07.scn
index a636120..e5630db 100644
--- a/testsuites/libtests/termios07/termios07.scn
+++ b/testsuites/libtests/termios07/termios07.scn
@@ -1 +1,20 @@
-XXX fill in with test output
+*** BEGIN OF TEST TERMIOS 7 ***
+rtems_termios_bufsize( 64, 64, 64 ) - OK
+Changing c_iflag to: Set XON/XOFF
+Writing: 01234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789Transmitted 200 characters
+30 31 32 33 34 35 36 37 38 39 30 31 32 33 34 35 |0123456789012345|
+36 37 38 39 30 31 32 33 34 35 36 37 38 39 30 31 |6789012345678901|
+32 33 34 35 36 37 38 39 30 31 32 33 34 35 36 37 |2345678901234567|
+38 39 30 31 32 33 34 35 36 37 38 39 30 31 32 33 |8901234567890123|
+34 35 36 37 38 39 30 31 32 33 34 35 36 37 38 39 |4567890123456789|
+32 33 34 35 36 37 38 39 |23456789 |
+*** END OF TEST TERMIOS 7 ***
diff --git a/testsuites/libtests/termios08/termios08.scn b/testsuites/libtests/termios08/termios08.scn
index a636120..469d537 100644
--- a/testsuites/libtests/termios08/termios08.scn
+++ b/testsuites/libtests/termios08/termios08.scn
@@ -1 +1,18 @@
+*** BEGIN OF TEST TERMIOS 8 ***
+Changing c_lflag to: non-canonical
+Changing to polling - VMIN=0 VTIME=0
+read - 0 expected
+Changing to half-second timeout - VMIN=0 VTIME=5
+read - 0 expected
+Changing to half-second timeout - VMIN=5 VTIME=3
+Enqueue 2 characters
+read - 2 expected
+Enqueue 1 character
+read - 1 expected
+Enqueue 7 characters
+read - 5 expected
+read - 2 expected
+*** END OF TEST TERMIOS 8 ***
1.9.1
