Interested in GSoC 2017 Project: Memory Protection.
Abhimanyu Rawat h2015081 at pilani.bits-pilani.ac.in
Wed Mar 22 15:13:45 UTC 2017
Indeed, PowerPC code is somewhat developed, would you recommend if there
are some specific features in PowerPC that I should revisit? As this is
little confusing as some work has been done on exception handler, page
tables, cache already, so what should I target next and what to modify
first? Past developer of the PowerPC support might help if you would
connect me to?
ᐧ
*Closing with thank you and warm Regards,*
*Abhimanyu Rawat*
*M.E. Computer Science, *
*CS/IS Department, BITS Pilani, Pilani Campus*
*Email - h2015081 at pilani.bits-pilani.ac.in
<h2015081 at pilani.bits-pilani.ac.in> / abhimanyurawat at yahoo.com
<abhimanyurawat at yahoo.com>*
*Phone. 08930399302 (call/Whatsapp), 09466899302*
On Wed, Mar 22, 2017 at 8:29 PM, Gedare Bloom <gedare at rtems.org> wrote:
> On Wed, Mar 22, 2017 at 10:07 AM, Abhimanyu Rawat <
> h2015081 at pilani.bits-pilani.ac.in> wrote:
>> On Wed, Mar 22, 2017 at 7:17 PM, Gedare Bloom <gedare at rtems.org> wrote:
>>> Please prefer to try to keep general GSoC / RTEMS project discussions on
>>> the mailing list. Direct e-mail is ok but inefficient in many cases and
>>> should only be preferred for communciations of a personal or private matter.
>>> On Wed, Mar 22, 2017 at 5:33 AM, Abhimanyu Rawat <
>>>> On Fri, Mar 17, 2017 at 9:25 PM, Gedare Bloom <gedare at rtems.org> wrote:
>>>>> On Thu, Mar 16, 2017 at 1:05 PM, Abhimanyu Rawat <
>>>>>> Hello Dr. Bloom,
>>>>>> Sorry for writing after a big gap( was busy with a product
>>>>>> integration), although I found time to go through the pointers you put
>>>>>> together for me, thanks they were really helpful in getting an idea about
>>>>>> the project and how to process everything in time.
>>>>>> Gaps are normal and acceptable (until you are getting paid for work
>>>>> :)). You should also expect to have gaps in responses from developers on
>>>>> the mailing list, since we are also generally volunteering.
>>>>>> I noticed that all the existing work on MMU is not moving very fast
>>>>>> like other supporting components for RTEMS, last year too no one was
>>>>>> selected to do MMU project #2904. I know only one guy applied but the
>>>>>> proposal was not quite promising. But trust me, all that doesn't make it
>>>>>> any less desirable for me to take it. Now, I have a few questions:
>>>>>> I would not recommend judging the priority/value of a proposed
>>>>> project based on whether or not it was done in the past. Definitely discuss
>>>>> with mentors, etc. This project area is a good, long-term investment for
>>>>> RTEMS, but it does move slowly.
>>>>>> On Fri, Mar 10, 2017 at 1:51 AM, Gedare Bloom <gedare at rtems.org>
>>>>>> wrote:
>>>>>>> On Thu, Mar 9, 2017 at 2:14 PM, Abhimanyu Rawat <
>>>>>>>> Hello folks,
>>>>>>>> I am Abhimanyu Rawat, a Computer Science Masters degree student
>>>>>>>> from BITS Pilani Campus, India. I found Memory Protection project
>>>>>>>> #2904 <https://devel.rtems.org/ticket/2904> very interesting and
>>>>>>>> vital for the the RTEMS. Among the lots of projects listed on the ideas
>>>>>>>> page, Memory Protection draws me to RTEMS as it's a very challenging
>>>>>>>> project and I would thoroughly enjoy working on it. I am a really
>>>>>>>> enthusiastic person who would like to contribute to the project. I have
>>>>>>>> previous experience in C, C++ and Python etc.  At present I am an intern at
>>>>>>>> EMC ^2 where I am working on DataDomain Operating system, building
>>>>>>>> configuration tool for the latest DDOS software update. I have also lead a
>>>>>>>> BITS-Stanford inter-university project, where my team worked on Django
>>>>>>>> based project with an inbuilt authorization tool + chat application etc. I
>>>>>>>> usually help my friends with their projects as well.
>>>>>>>> When does your internship complete, and when does your school year
>>>>>>> begin again?
>>>>>>>> As required, I went through the initial brief about the project and
>>>>>>>> I think it would be a valuable addition to RTEMS. Also, I have completed
>>>>>>>> the https://devel.rtems.org/wiki/GSoC/GettingStarted, and
>>>>>>>> configured and Built RTEMS for SPARC/erc32. Subsequently, I have the
>>>>>>>> snapshot of the terminal showing my name and the GSOC text as pictured
>>>>>>>> here
>>>>>>>> <https://devel.rtems.org/attachment/wiki/GSoC/GettingStarted/SPARC-SIS-HelloWorld-Modded.png>.
>>>>>>>> Kindly tell me how  selectively pointed towto send the proof of the
>>>>>>>> terminal and the diff file as required.
>>>>>>>> Send to me by email is fine.
>>>>>>>> It would be great if you can give me some pointers about the
>>>>>>>> structure of the project and the direction I should pursue.
>>>>>>>> Have a look at the current approach taken to provide low-level
>>>>>>> support for the MMUs in the ARM bsps. You can find this looking in the
>>>>>>> source tree via c/src/lib/libbsp/arm/* with most of the relevant parts in
>>>>>>> the shared subdirectory there, where each BSP defines a table of
>>>>>>> statically-configured MMU initialization.
>>>>>> You selectively pointed towards the c/src/lib/libbsp/arm/* shared
>>>>>> subdirectory where some BSP's has low level code for MMU configuration, I
>>>>>> found ome cache code too. And trying digging deep to build a common
>>>>>> understanding of different BSP MMU code. The code initally is quite hard to
>>>>>> understand but as a unit what task is taking place is I can understand
>>>>>> like, data cache and line cleaing etc. Therefore I would request you to
>>>>>> provide me a documented code review or process guide( if available)
>>>>>> so that I can develop something to test the MMU code changes/patches,
>>>>>> otherwise I will have to brute force the search. As from this point I want
>>>>>> to move fast and reflect the my progress.
>>>>>> I recommend that you start by writing a blog post about your
>>>>> understanding of what is implemented there. Look in the other BSPs to see
>>>>> what, if any, MMU code they have.
>>>>> Sure, setting up a medium blog to write about the bsp underlying code
>>>>  related to memory related operations.
>>>>> Cache cleaning/invalidating is often tied with MMU state changes.
>>>>>> This is where the prior work has pretty much left off. Remaining
>>>>>>> items in this project area include:
>>>>>>> * Making a uniform approach to MMU/MPU setup across architectures
>>>>>> It seems nice to have a low level design which can point out the
>>>>>> mutual modules such as initialising the registers, stack and memory lines
>>>>>> etc. For this I think underying functionality have to be completed first or
>>>>>> complete the remaining pieces in existing code and then move bottom up.
>>>>> The underlying functionality exists for at least cp15-based ARM.
>>>>> Providing the functionality for another BSP family would be a good place to
>>>>> start.
>>>>>> * Supporting dynamic changes to MMU/MPU configurations
>>>>>>> * Leveraging dynamic MMU/MPU enforcement to create a mid-level
>>>>>>> memory management layers. Various proposals have been designed and
>>>>>>> implemented in the past that can be studied.
>>>>>> When you say dynamic changes, it means application level memory
>>>>>> proection, space quota management etc. ? I know you should be having a full
>>>>>> list, so l am willing to hear all that and then decide which work should be
>>>>>> done first and how I propose to do it.
>>>>> Dynamic here means the MMU entries can be changed at run-time after
>>>>> initialization. This is a building block for implementing higher-level
>>>>> services such as application-level memory protection and kernel-level APIs
>>>>> for memory management.
>>>>>> * Creating generally useful memory protection schemes such as
>>>>>>> per-task stack protection that can be enabled by applications with simple
>>>>>>> "switch it on" type of logic.
>>>>>> * Creating an application-layer interface for memory protection
>>>>>>> management at a finer granularity / with more application-level logic to
>>>>>>> control than the "generally useful" approaches would need.
>>>>>>> Ok this is exciting stuff that can be pushed first, the memory block
>>>>>> or segement(or whatever you say to a chunk but mostly I went through thesis
>>>>>> material online which denotes it as in different terms/name ) access
>>>>>> related control can be hacked together to provide the enclaved type of
>>>>>> execution for the application task. We can discuss more about it and how
>>>>>> much existing code base so far support this proposed project area.
>>>>>> I prefer memory region to refer to a generic "Base+Offset" contiguous
>>>>> area of memory. We have discussed terminology quite often in the past.
>>>>> Reach out to Hesham to get some more details.
>>>>> We can't do application-level memory protection without a good
>>>>> understanding of the intermediate layers. We can start to design an API,
>>>>> but the API is not mergeable until there is a generic layer that is not
>>>>> tightly bound to the BSP or even CPU layers.
>>>> In case of arm-cp15  it's underlying fucntionality are far more
>>>> developed(i.e. initialization, interrupt handling, underlying tlb update
>>>> after fage faults etc.) than the rest of the bsp's, so I think we can start
>>>> to design an API for application-level memory protection. This way we can
>>>> have atleast one fully functional bsp for arm-cp 15, whose prototype can we
>>>> can later use to speed up the development  You think it can be a good
>>>> proposal or shall I go with other bsp underlying support first?
>>>> I'm concerned that any mid-level/high-level framework built on top of
>>> the existing low-level support for arm-cp15 will be too rigid to work with
>>> less feature-ful BSPs/MMU/MPU combinations. It would be good to have
>>> another one or two kinds of MMU/MPU supported so that the upper layers can
>>> be more thoughtfully designed.
>>  I agree with your approach of having more than one type of bsp's with
>> MMU/MPU support, so which one should I take on ? I mean I can work on
>> AT91RM9200 of ARM family, or you would suggest other archiitecture
>> like(PowerPC) ?
>> PowerPC should be good. That was one of the targets worked on previously,
> so it should not be too difficult.
>> I look forward, to hear what is your take on them, and last but not the
>>>>>> least, thanks for the warm reply, it already makes me feel home with the
>>>>>> community.
>>>>> Overall, I look forward to working with the community and improving my
>>>>>>>> skills by actively contributing to the project(in long run also).
>>>>>>>> *Abhimanyu Rawat*
>>>>>>>> ᐧ
>>>>>>>> _______________________________________________
>>>>>>>> devel mailing list
>>>>>>>> devel at rtems.org
>>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
>>>>>> ᐧ
>> ᐧ
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170322/0a1bcaa4/attachment-0001.html>
