[PATCH 1/3] POSIX Users: Add posix_devctl()
Thu Mar 23 15:56:15 UTC 2017
 posix-users/devctl.rst | 76 ++++++++++++++++++++++++++++++++++++++++++++++++++
 posix-users/index.rst  |  1 +
 2 files changed, 77 insertions(+)
 create mode 100644 posix-users/devctl.rst
diff --git a/posix-users/devctl.rst b/posix-users/devctl.rst
new file mode 100644
index 0000000..6434cb5
--- /dev/null
+++ b/posix-users/devctl.rst
@@ -0,0 +1,76 @@
+.. comment SPDX-License-Identifier: CC-BY-SA-4.0
+.. COMMENT: COPYRIGHT(c) 2017.
+.. COMMENT: On-Line Applications Research Corporation(OAR).
+.. COMMENT: All rights reserved.
+Device Control
+Introduction
+The POSIX Device Control API is defined by POSIX 1003.26 and attempts
+to provides a portable alternative to the ioctl() service which is
+not standardized across POSIX implementations.  Support for this
+standard is required by the Open Group's FACE Technical Standard
+:cits:"FACE:2012:FTS".  Unfortunately, this part of the POSIX standard
+is not widely implemented.
+The services provided by the timer manager are:
+- posix_devctl_ - Control a Device
+Background
+Operations
+System Calls
+This section details the POSIX device control's services.  A subsection
+is dedicated to each of this manager's services and describes the calling
+sequence, related constants, usage, and status codes.
+.. COMMENT: posix_devctl
+.. _posix_devctl
+posix_devctl - Control a Device
+**CALLING SEQUENCE:**
+.. code-block:: c
+    #include <devctl.h>
+    int posix_devctl(
+      int            fd,
+      int            dcmd,
+      void *restrict dev_data_ptr,
+      size_t         nbyte,
+      int *restrict  dev_info_ptr
+**STATUS CODES:**
+The status codes returned reflect those returned by the ``ioctl()`` service
+and the underlying device drivers.
+**DESCRIPTION:**
+This method is intended to be a portable alternative to the ``ioctl()``
+method. The RTEMS implementation follows what is referred to as a library
+implementation which is a simple wrapper for the ``ioctl()`` method.
+The fd, fcmd, dev_data_ptr, and nbyte parameters are passed unmodified
+to the ``ioctl()`` method.
+If the dev_info_ptr parameter is not NULL, then the location pointed
+to by dev_info_ptr is set to 0.
+**NOTES:**
+NONE
diff --git a/posix-users/index.rst b/posix-users/index.rst
index b2e2154..6c359ec 100644
--- a/posix-users/index.rst
+++ b/posix-users/index.rst
@@ -60,6 +60,7 @@ to the Community Project hosted at http://www.rtems.org/.
 	thread_cancellation
 	services_provided_by_c
 	services_provided_by_math
+        devctl
 	status_of_implementation
 	command
1.8.3.1
