[PATCH 1/3] POSIX Users: Add posix_devctl()
Joel Sherrill
joel at rtems.org
Thu Mar 23 20:26:21 UTC 2017
On Thu, Mar 23, 2017 at 3:14 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 24/3/17 2:56 am, Joel Sherrill wrote:
> > posix-users/devctl.rst | 76 ++++++++++++++++++++++++++++++
> > posix-users/index.rst | 1 +
> > 2 files changed, 77 insertions(+)
> > create mode 100644 posix-users/devctl.rst
> > diff --git a/posix-users/devctl.rst b/posix-users/devctl.rst
> > new file mode 100644
> > index 0000000..6434cb5
> > --- /dev/null
> > +++ b/posix-users/devctl.rst
> > @@ -0,0 +1,76 @@
> > +.. comment SPDX-License-Identifier: CC-BY-SA-4.0
> > +.. COMMENT: COPYRIGHT(c) 2017.
> > +.. COMMENT: On-Line Applications Research Corporation(OAR).
> > +.. COMMENT: All rights reserved.
> > +Device Control
> > +Introduction
> > +The POSIX Device Control API is defined by POSIX 1003.26 and attempts
> > +to provides a portable alternative to the ioctl() service which is
> > +not standardized across POSIX implementations. Support for this
> > +standard is required by the Open Group's FACE Technical Standard
> > +:cits:"FACE:2012:FTS". Unfortunately, this part of the POSIX standard
> > +is not widely implemented.
> > +The services provided by the timer manager are:
> > +- posix_devctl_ - Control a Device
> > +Background
> > +Operations
> > +System Calls
> > +This section details the POSIX device control's services. A subsection
> > +is dedicated to each of this manager's services and describes the
> calling
> > +sequence, related constants, usage, and status codes.
> > +.. COMMENT: posix_devctl
> > +.. _posix_devctl
> > +posix_devctl - Control a Device
> > +**CALLING SEQUENCE:**
> > +.. code-block:: c
> > + #include <devctl.h>
> > + int posix_devctl(
> > + int fd,
> The other code in the POSIX manual has 4 spaces for the indent. :)
> > + int dcmd,
> > + void *restrict dev_data_ptr,
> > + size_t nbyte,
> > + int *restrict dev_info_ptr
> > +**STATUS CODES:**
> > +The status codes returned reflect those returned by the ``ioctl()``
> service
> > +and the underlying device drivers.
> > +**DESCRIPTION:**
> > +This method is intended to be a portable alternative to the ``ioctl()``
> > +method. The RTEMS implementation follows what is referred to as a
> library
> > +implementation which is a simple wrapper for the ``ioctl()`` method.
> > +The fd, fcmd, dev_data_ptr, and nbyte parameters are passed unmodified
> > +to the ``ioctl()`` method.
> > +If the dev_info_ptr parameter is not NULL, then the location pointed
> > +to by dev_info_ptr is set to 0.
> > +**NOTES:**
> > +NONE
> > diff --git a/posix-users/index.rst b/posix-users/index.rst
> > index b2e2154..6c359ec 100644
> > --- a/posix-users/index.rst
> > +++ b/posix-users/index.rst
> > @@ -60,6 +60,7 @@ to the Community Project hosted at
> http://www.rtems.org/.
> > thread_cancellation
> > services_provided_by_c
> > services_provided_by_math
> > + devctl
> Tabs or spaces? I suspect tabs are being used here. I suspect my emacs
> learned the formatting I inherited.
Do you mean the master list of chapters or somewhere else? The chapter
itself was based on a copy of the POSIX Timer Manager.
> Chris
> > status_of_implementation
> > command
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170323/3f43c69e/attachment.html>
