Interested in GSoC 2017 Project: Memory Protection.
Abhimanyu Rawat h2015081 at pilani.bits-pilani.ac.in
Fri Mar 24 15:26:23 UTC 2017
Hello Dr. Bloom,
I have contacted to the past contributors,  Peter and I will discuss
PowerPC and further support, next week, in the meantime, I am going through
PowerPC code and how I can build with the existing system a new bsp code
for MMU/MPU support. I will complete my application next week.
In the meantime, any suggestions from your side are most welcome.
On Wed, Mar 22, 2017 at 8:57 PM, Gedare Bloom <gedare at rtems.org> wrote:
> On Wed, Mar 22, 2017 at 11:13 AM, Abhimanyu Rawat <
> h2015081 at pilani.bits-pilani.ac.in> wrote:
>> Indeed, PowerPC code is somewhat developed, would you recommend if there
>> are some specific features in PowerPC that I should revisit? As this is
>> little confusing as some work has been done on exception handler, page
>> tables, cache already, so what should I target next and what to modify
>> first? Past developer of the PowerPC support might help if you would
>> connect me to?
>> ᐧ
>> I've CC'd some of the folks who previously worked on this topic. So
> perhaps they have input for you.
> I think the important thing is that when we design a framework that it is
> flexible enough to accommodate the many varieties of memory management
> hardware.
>> *Closing with thank you and warm Regards,*
>> *Abhimanyu Rawat*
>> *M.E. Computer Science, *
>> *CS/IS Department, BITS Pilani, Pilani Campus*
>> *Email - h2015081 at pilani.bits-pilani.ac.in
>> <h2015081 at pilani.bits-pilani.ac.in> / abhimanyurawat at yahoo.com
>> <abhimanyurawat at yahoo.com>*
>> *Phone. 08930399302 (call/Whatsapp), 09466899302*
>> On Wed, Mar 22, 2017 at 8:29 PM, Gedare Bloom <gedare at rtems.org> wrote:
>>> On Wed, Mar 22, 2017 at 10:07 AM, Abhimanyu Rawat <
>>>> On Wed, Mar 22, 2017 at 7:17 PM, Gedare Bloom <gedare at rtems.org> wrote:
>>>>> Please prefer to try to keep general GSoC / RTEMS project discussions
>>>>> on the mailing list. Direct e-mail is ok but inefficient in many cases and
>>>>> should only be preferred for communciations of a personal or private matter.
>>>>> On Wed, Mar 22, 2017 at 5:33 AM, Abhimanyu Rawat <
>>>>>> On Fri, Mar 17, 2017 at 9:25 PM, Gedare Bloom <gedare at rtems.org>
>>>>>> wrote:
>>>>>>> On Thu, Mar 16, 2017 at 1:05 PM, Abhimanyu Rawat <
>>>>>>>> Hello Dr. Bloom,
>>>>>>>> Sorry for writing after a big gap( was busy with a product
>>>>>>>> integration), although I found time to go through the pointers you put
>>>>>>>> together for me, thanks they were really helpful in getting an idea about
>>>>>>>> the project and how to process everything in time.
>>>>>>>> Gaps are normal and acceptable (until you are getting paid for work
>>>>>>> :)). You should also expect to have gaps in responses from developers on
>>>>>>> the mailing list, since we are also generally volunteering.
>>>>>>>> I noticed that all the existing work on MMU is not moving very fast
>>>>>>>> like other supporting components for RTEMS, last year too no one was
>>>>>>>> selected to do MMU project #2904. I know only one guy applied but the
>>>>>>>> proposal was not quite promising. But trust me, all that doesn't make it
>>>>>>>> any less desirable for me to take it. Now, I have a few questions:
>>>>>>>> I would not recommend judging the priority/value of a proposed
>>>>>>> project based on whether or not it was done in the past. Definitely discuss
>>>>>>> with mentors, etc. This project area is a good, long-term investment for
>>>>>>> RTEMS, but it does move slowly.
>>>>>>>> On Fri, Mar 10, 2017 at 1:51 AM, Gedare Bloom <gedare at rtems.org>
>>>>>>>> wrote:
>>>>>>>>> On Thu, Mar 9, 2017 at 2:14 PM, Abhimanyu Rawat <
>>>>>>>>>> Hello folks,
>>>>>>>>>> I am Abhimanyu Rawat, a Computer Science Masters degree student
>>>>>>>>>> from BITS Pilani Campus, India. I found Memory Protection project
>>>>>>>>>> #2904 <https://devel.rtems.org/ticket/2904> very interesting and
>>>>>>>>>> vital for the the RTEMS. Among the lots of projects listed on the ideas
>>>>>>>>>> page, Memory Protection draws me to RTEMS as it's a very challenging
>>>>>>>>>> project and I would thoroughly enjoy working on it. I am a really
>>>>>>>>>> enthusiastic person who would like to contribute to the project. I have
>>>>>>>>>> previous experience in C, C++ and Python etc.  At present I am an intern at
>>>>>>>>>> EMC ^2 where I am working on DataDomain Operating system, building
>>>>>>>>>> configuration tool for the latest DDOS software update. I have also lead a
>>>>>>>>>> BITS-Stanford inter-university project, where my team worked on Django
>>>>>>>>>> based project with an inbuilt authorization tool + chat application etc. I
>>>>>>>>>> usually help my friends with their projects as well.
>>>>>>>>>> When does your internship complete, and when does your school
>>>>>>>>> year begin again?
>>>>>>>>>> As required, I went through the initial brief about the project
>>>>>>>>>> and I think it would be a valuable addition to RTEMS. Also, I have
>>>>>>>>>> completed the https://devel.rtems.org/wiki/GSoC/GettingStarted, and
>>>>>>>>>> configured and Built RTEMS for SPARC/erc32. Subsequently, I have the
>>>>>>>>>> snapshot of the terminal showing my name and the GSOC text as pictured
>>>>>>>>>> here
>>>>>>>>>> <https://devel.rtems.org/attachment/wiki/GSoC/GettingStarted/SPARC-SIS-HelloWorld-Modded.png>.
>>>>>>>>>> Kindly tell me how  selectively pointed towto send the proof of the
>>>>>>>>>> terminal and the diff file as required.
>>>>>>>>>> Send to me by email is fine.
>>>>>>>>>> It would be great if you can give me some pointers about the
>>>>>>>>>> structure of the project and the direction I should pursue.
>>>>>>>>>> Have a look at the current approach taken to provide low-level
>>>>>>>>> support for the MMUs in the ARM bsps. You can find this looking in the
>>>>>>>>> source tree via c/src/lib/libbsp/arm/* with most of the relevant parts in
>>>>>>>>> the shared subdirectory there, where each BSP defines a table of
>>>>>>>>> statically-configured MMU initialization.
>>>>>>>> You selectively pointed towards the c/src/lib/libbsp/arm/* shared
>>>>>>>> subdirectory where some BSP's has low level code for MMU configuration, I
>>>>>>>> found ome cache code too. And trying digging deep to build a common
>>>>>>>> understanding of different BSP MMU code. The code initally is quite hard to
>>>>>>>> understand but as a unit what task is taking place is I can understand
>>>>>>>> like, data cache and line cleaing etc. Therefore I would request you to
>>>>>>>> provide me a documented code review or process guide( if
>>>>>>>> available) so that I can develop something to test the MMU code
>>>>>>>> changes/patches, otherwise I will have to brute force the search. As from
>>>>>>>> this point I want to move fast and reflect the my progress.
>>>>>>>> I recommend that you start by writing a blog post about your
>>>>>>> understanding of what is implemented there. Look in the other BSPs to see
>>>>>>> what, if any, MMU code they have.
>>>>>>> Sure, setting up a medium blog to write about the bsp underlying
>>>>>> code  related to memory related operations.
>>>>>>> Cache cleaning/invalidating is often tied with MMU state changes.
>>>>>>>> This is where the prior work has pretty much left off. Remaining
>>>>>>>>> items in this project area include:
>>>>>>>>> * Making a uniform approach to MMU/MPU setup across architectures
>>>>>>>> It seems nice to have a low level design which can point out the
>>>>>>>> mutual modules such as initialising the registers, stack and memory lines
>>>>>>>> etc. For this I think underying functionality have to be completed first or
>>>>>>>> complete the remaining pieces in existing code and then move bottom up.
>>>>>>> The underlying functionality exists for at least cp15-based ARM.
>>>>>>> Providing the functionality for another BSP family would be a good place to
>>>>>>> start.
>>>>>>>> * Supporting dynamic changes to MMU/MPU configurations
>>>>>>>>> * Leveraging dynamic MMU/MPU enforcement to create a mid-level
>>>>>>>>> memory management layers. Various proposals have been designed and
>>>>>>>>> implemented in the past that can be studied.
>>>>>>>> When you say dynamic changes, it means application level memory
>>>>>>>> proection, space quota management etc. ? I know you should be having a full
>>>>>>>> list, so l am willing to hear all that and then decide which work should be
>>>>>>>> done first and how I propose to do it.
>>>>>>> Dynamic here means the MMU entries can be changed at run-time after
>>>>>>> initialization. This is a building block for implementing higher-level
>>>>>>> services such as application-level memory protection and kernel-level APIs
>>>>>>> for memory management.
>>>>>>>> * Creating generally useful memory protection schemes such as
>>>>>>>>> per-task stack protection that can be enabled by applications with simple
>>>>>>>>> "switch it on" type of logic.
>>>>>>>> * Creating an application-layer interface for memory protection
>>>>>>>>> management at a finer granularity / with more application-level logic to
>>>>>>>>> control than the "generally useful" approaches would need.
>>>>>>>>> Ok this is exciting stuff that can be pushed first, the memory
>>>>>>>> block or segement(or whatever you say to a chunk but mostly I went through
>>>>>>>> thesis material online which denotes it as in different terms/name ) access
>>>>>>>> related control can be hacked together to provide the enclaved type of
>>>>>>>> execution for the application task. We can discuss more about it and how
>>>>>>>> much existing code base so far support this proposed project area.
>>>>>>>> I prefer memory region to refer to a generic "Base+Offset"
>>>>>>> contiguous area of memory. We have discussed terminology quite often in the
>>>>>>> past. Reach out to Hesham to get some more details.
>>>>>>> We can't do application-level memory protection without a good
>>>>>>> understanding of the intermediate layers. We can start to design an API,
>>>>>>> but the API is not mergeable until there is a generic layer that is not
>>>>>>> tightly bound to the BSP or even CPU layers.
>>>>>> In case of arm-cp15  it's underlying fucntionality are far more
>>>>>> developed(i.e. initialization, interrupt handling, underlying tlb update
>>>>>> after fage faults etc.) than the rest of the bsp's, so I think we can start
>>>>>> to design an API for application-level memory protection. This way we can
>>>>>> have atleast one fully functional bsp for arm-cp 15, whose prototype can we
>>>>>> can later use to speed up the development  You think it can be a good
>>>>>> proposal or shall I go with other bsp underlying support first?
>>>>>> I'm concerned that any mid-level/high-level framework built on top of
>>>>> the existing low-level support for arm-cp15 will be too rigid to work with
>>>>> less feature-ful BSPs/MMU/MPU combinations. It would be good to have
>>>>> another one or two kinds of MMU/MPU supported so that the upper layers can
>>>>> be more thoughtfully designed.
>>>>  I agree with your approach of having more than one type of bsp's with
>>>> MMU/MPU support, so which one should I take on ? I mean I can work on
>>>> AT91RM9200 of ARM family, or you would suggest other archiitecture
>>>> like(PowerPC) ?
>>>> PowerPC should be good. That was one of the targets worked on
>>> previously, so it should not be too difficult.
>>>> I look forward, to hear what is your take on them, and last but not the
>>>>>>>> least, thanks for the warm reply, it already makes me feel home with the
>>>>>>>> community.
>>>>>>> Overall, I look forward to working with the community and improving
>>>>>>>>>> my skills by actively contributing to the project(in long run also).
>>>>>>>>>> *Abhimanyu Rawat*
>>>>>>>>>> ᐧ
>>>>>>>>>> _______________________________________________
>>>>>>>>>> devel mailing list
>>>>>>>>>> devel at rtems.org
>>>>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
>>>>>>>> ᐧ
>>>> ᐧ
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170324/f677f1ab/attachment-0001.html>
