Interested in GSoC 2017 Project: Memory Protection.
Hesham Almatary heshamelmatary at gmail.com
Sat Mar 25 06:45:29 UTC 2017
On Sat, Mar 25, 2017 at 6:07 AM, Gedare Bloom <gedare at rtems.org> wrote:
> Work on shaping your proposal document and start to plan the work you
> would do during the summer. This is the best way for me to collaborate is
> if you begin writing out your ideas in sufficient detail that I can
> understand and provide feedback based on where you are at.
+1
> On Fri, Mar 24, 2017 at 11:26 AM, Abhimanyu Rawat <
> h2015081 at pilani.bits-pilani.ac.in> wrote:
>> Hello Dr. Bloom,
>> I have contacted to the past contributors,  Peter and I will discuss
>> PowerPC and further support, next week, in the meantime, I am going through
>> PowerPC code and how I can build with the existing system a new bsp code
>> for MMU/MPU support. I will complete my application next week.
>> In the meantime, any suggestions from your side are most welcome.
>> On Wed, Mar 22, 2017 at 8:57 PM, Gedare Bloom <gedare at rtems.org> wrote:
>>> On Wed, Mar 22, 2017 at 11:13 AM, Abhimanyu Rawat <
>>>> Indeed, PowerPC code is somewhat developed, would you recommend if
>>>> there are some specific features in PowerPC that I should revisit? As this
>>>> is little confusing as some work has been done on exception handler, page
>>>> tables, cache already, so what should I target next and what to modify
>>>> first? Past developer of the PowerPC support might help if you would
>>>> connect me to?
>>>> ᐧ
>>>> I've CC'd some of the folks who previously worked on this topic. So
>>> perhaps they have input for you.
>>> I think the important thing is that when we design a framework that it
>>> is flexible enough to accommodate the many varieties of memory management
>>> hardware.
>>>> *Closing with thank you and warm Regards,*
>>>> *Abhimanyu Rawat*
>>>> *M.E. Computer Science, *
>>>> *CS/IS Department, BITS Pilani, Pilani Campus*
>>>> *Email - h2015081 at pilani.bits-pilani.ac.in
>>>> <h2015081 at pilani.bits-pilani.ac.in> / abhimanyurawat at yahoo.com
>>>> <abhimanyurawat at yahoo.com>*
>>>> *Phone. 08930399302 (call/Whatsapp), 09466899302*
>>>> On Wed, Mar 22, 2017 at 8:29 PM, Gedare Bloom <gedare at rtems.org> wrote:
>>>>> On Wed, Mar 22, 2017 at 10:07 AM, Abhimanyu Rawat <
>>>>>> On Wed, Mar 22, 2017 at 7:17 PM, Gedare Bloom <gedare at rtems.org>
>>>>>> wrote:
>>>>>>> Please prefer to try to keep general GSoC / RTEMS project
>>>>>>> discussions on the mailing list. Direct e-mail is ok but inefficient in
>>>>>>> many cases and should only be preferred for communciations of a personal or
>>>>>>> private matter.
>>>>>>> On Wed, Mar 22, 2017 at 5:33 AM, Abhimanyu Rawat <
>>>>>>>> On Fri, Mar 17, 2017 at 9:25 PM, Gedare Bloom <gedare at rtems.org>
>>>>>>>> wrote:
>>>>>>>>> On Thu, Mar 16, 2017 at 1:05 PM, Abhimanyu Rawat <
>>>>>>>>>> Hello Dr. Bloom,
>>>>>>>>>> Sorry for writing after a big gap( was busy with a product
>>>>>>>>>> integration), although I found time to go through the pointers you put
>>>>>>>>>> together for me, thanks they were really helpful in getting an idea about
>>>>>>>>>> the project and how to process everything in time.
>>>>>>>>>> Gaps are normal and acceptable (until you are getting paid for
>>>>>>>>> work :)). You should also expect to have gaps in responses from developers
>>>>>>>>> on the mailing list, since we are also generally volunteering.
>>>>>>>>>> I noticed that all the existing work on MMU is not moving very
>>>>>>>>>> fast like other supporting components for RTEMS, last year too no one was
>>>>>>>>>> selected to do MMU project #2904. I know only one guy applied but the
>>>>>>>>>> proposal was not quite promising. But trust me, all that doesn't make it
>>>>>>>>>> any less desirable for me to take it. Now, I have a few questions:
>>>>>>>>>> I would not recommend judging the priority/value of a proposed
>>>>>>>>> project based on whether or not it was done in the past. Definitely discuss
>>>>>>>>> with mentors, etc. This project area is a good, long-term investment for
>>>>>>>>> RTEMS, but it does move slowly.
>>>>>>>>>> On Fri, Mar 10, 2017 at 1:51 AM, Gedare Bloom <gedare at rtems.org>
>>>>>>>>>> wrote:
>>>>>>>>>>> On Thu, Mar 9, 2017 at 2:14 PM, Abhimanyu Rawat <
>>>>>>>>>>>> Hello folks,
>>>>>>>>>>>> I am Abhimanyu Rawat, a Computer Science Masters degree student
>>>>>>>>>>>> from BITS Pilani Campus, India. I found Memory Protection project
>>>>>>>>>>>> #2904 <https://devel.rtems.org/ticket/2904> very interesting
>>>>>>>>>>>> and vital for the the RTEMS. Among the lots of projects listed on the ideas
>>>>>>>>>>>> page, Memory Protection draws me to RTEMS as it's a very challenging
>>>>>>>>>>>> project and I would thoroughly enjoy working on it. I am a really
>>>>>>>>>>>> enthusiastic person who would like to contribute to the project. I have
>>>>>>>>>>>> previous experience in C, C++ and Python etc.  At present I am an intern at
>>>>>>>>>>>> EMC ^2 where I am working on DataDomain Operating system, building
>>>>>>>>>>>> configuration tool for the latest DDOS software update. I have also lead a
>>>>>>>>>>>> BITS-Stanford inter-university project, where my team worked on Django
>>>>>>>>>>>> based project with an inbuilt authorization tool + chat application etc. I
>>>>>>>>>>>> usually help my friends with their projects as well.
>>>>>>>>>>>> When does your internship complete, and when does your school
>>>>>>>>>>> year begin again?
>>>>>>>>>>>> As required, I went through the initial brief about the project
>>>>>>>>>>>> and I think it would be a valuable addition to RTEMS. Also, I have
>>>>>>>>>>>> completed the https://devel.rtems.org/wiki/GSoC/GettingStarted, and
>>>>>>>>>>>> configured and Built RTEMS for SPARC/erc32. Subsequently, I have the
>>>>>>>>>>>> snapshot of the terminal showing my name and the GSOC text as pictured
>>>>>>>>>>>> here
>>>>>>>>>>>> <https://devel.rtems.org/attachment/wiki/GSoC/GettingStarted/SPARC-SIS-HelloWorld-Modded.png>.
>>>>>>>>>>>> Kindly tell me how  selectively pointed towto send the proof of the
>>>>>>>>>>>> terminal and the diff file as required.
>>>>>>>>>>>> Send to me by email is fine.
>>>>>>>>>>>> It would be great if you can give me some pointers about the
>>>>>>>>>>>> structure of the project and the direction I should pursue.
>>>>>>>>>>>> Have a look at the current approach taken to provide low-level
>>>>>>>>>>> support for the MMUs in the ARM bsps. You can find this looking in the
>>>>>>>>>>> source tree via c/src/lib/libbsp/arm/* with most of the relevant parts in
>>>>>>>>>>> the shared subdirectory there, where each BSP defines a table of
>>>>>>>>>>> statically-configured MMU initialization.
>>>>>>>>>> You selectively pointed towards the c/src/lib/libbsp/arm/* shared
>>>>>>>>>> subdirectory where some BSP's has low level code for MMU configuration, I
>>>>>>>>>> found ome cache code too. And trying digging deep to build a common
>>>>>>>>>> understanding of different BSP MMU code. The code initally is quite hard to
>>>>>>>>>> understand but as a unit what task is taking place is I can understand
>>>>>>>>>> like, data cache and line cleaing etc. Therefore I would request you to
>>>>>>>>>> provide me a documented code review or process guide( if
>>>>>>>>>> available) so that I can develop something to test the MMU code
>>>>>>>>>> changes/patches, otherwise I will have to brute force the search. As from
>>>>>>>>>> this point I want to move fast and reflect the my progress.
>>>>>>>>>> I recommend that you start by writing a blog post about your
>>>>>>>>> understanding of what is implemented there. Look in the other BSPs to see
>>>>>>>>> what, if any, MMU code they have.
>>>>>>>>> Sure, setting up a medium blog to write about the bsp underlying
>>>>>>>> code  related to memory related operations.
>>>>>>>>> Cache cleaning/invalidating is often tied with MMU state changes.
>>>>>>>>>> This is where the prior work has pretty much left off. Remaining
>>>>>>>>>>> items in this project area include:
>>>>>>>>>>> * Making a uniform approach to MMU/MPU setup across architectures
>>>>>>>>>> It seems nice to have a low level design which can point out the
>>>>>>>>>> mutual modules such as initialising the registers, stack and memory lines
>>>>>>>>>> etc. For this I think underying functionality have to be completed first or
>>>>>>>>>> complete the remaining pieces in existing code and then move bottom up.
>>>>>>>>> The underlying functionality exists for at least cp15-based ARM.
>>>>>>>>> Providing the functionality for another BSP family would be a good place to
>>>>>>>>> start.
>>>>>>>>>> * Supporting dynamic changes to MMU/MPU configurations
>>>>>>>>>>> * Leveraging dynamic MMU/MPU enforcement to create a mid-level
>>>>>>>>>>> memory management layers. Various proposals have been designed and
>>>>>>>>>>> implemented in the past that can be studied.
>>>>>>>>>> When you say dynamic changes, it means application level memory
>>>>>>>>>> proection, space quota management etc. ? I know you should be having a full
>>>>>>>>>> list, so l am willing to hear all that and then decide which work should be
>>>>>>>>>> done first and how I propose to do it.
>>>>>>>>> Dynamic here means the MMU entries can be changed at run-time
>>>>>>>>> after initialization. This is a building block for implementing
>>>>>>>>> higher-level services such as application-level memory protection and
>>>>>>>>> kernel-level APIs for memory management.
>>>>>>>>>> * Creating generally useful memory protection schemes such as
>>>>>>>>>>> per-task stack protection that can be enabled by applications with simple
>>>>>>>>>>> "switch it on" type of logic.
>>>>>>>>>> * Creating an application-layer interface for memory protection
>>>>>>>>>>> management at a finer granularity / with more application-level logic to
>>>>>>>>>>> control than the "generally useful" approaches would need.
>>>>>>>>>>> Ok this is exciting stuff that can be pushed first, the memory
>>>>>>>>>> block or segement(or whatever you say to a chunk but mostly I went through
>>>>>>>>>> thesis material online which denotes it as in different terms/name ) access
>>>>>>>>>> related control can be hacked together to provide the enclaved type of
>>>>>>>>>> execution for the application task. We can discuss more about it and how
>>>>>>>>>> much existing code base so far support this proposed project area.
>>>>>>>>>> I prefer memory region to refer to a generic "Base+Offset"
>>>>>>>>> contiguous area of memory. We have discussed terminology quite often in the
>>>>>>>>> past. Reach out to Hesham to get some more details.
>>>>>>>>> We can't do application-level memory protection without a good
>>>>>>>>> understanding of the intermediate layers. We can start to design an API,
>>>>>>>>> but the API is not mergeable until there is a generic layer that is not
>>>>>>>>> tightly bound to the BSP or even CPU layers.
>>>>>>>> In case of arm-cp15  it's underlying fucntionality are far more
>>>>>>>> developed(i.e. initialization, interrupt handling, underlying tlb update
>>>>>>>> after fage faults etc.) than the rest of the bsp's, so I think we can start
>>>>>>>> to design an API for application-level memory protection. This way we can
>>>>>>>> have atleast one fully functional bsp for arm-cp 15, whose prototype can we
>>>>>>>> can later use to speed up the development  You think it can be a good
>>>>>>>> proposal or shall I go with other bsp underlying support first?
>>>>>>>> I'm concerned that any mid-level/high-level framework built on top
>>>>>>> of the existing low-level support for arm-cp15 will be too rigid to work
>>>>>>> with less feature-ful BSPs/MMU/MPU combinations. It would be good to have
>>>>>>> another one or two kinds of MMU/MPU supported so that the upper layers can
>>>>>>> be more thoughtfully designed.
>>>>>>  I agree with your approach of having more than one type of bsp's
>>>>>> with MMU/MPU support, so which one should I take on ? I mean I can work on
>>>>>> AT91RM9200 of ARM family, or you would suggest other archiitecture
>>>>>> like(PowerPC) ?
>>>>>> PowerPC should be good. That was one of the targets worked on
>>>>> previously, so it should not be too difficult.
>>>>>> I look forward, to hear what is your take on them, and last but not
>>>>>>>>>> the least, thanks for the warm reply, it already makes me feel home with
>>>>>>>>>> the community.
>>>>>>>>> Overall, I look forward to working with the community and
>>>>>>>>>>>> improving my skills by actively contributing to the project(in long run
>>>>>>>>>>>> also).
>>>>>>>>>>>> *Abhimanyu Rawat*
>>>>>>>>>>>> ᐧ
>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>> devel mailing list
>>>>>>>>>>>> devel at rtems.org
>>>>>>>>>>>> http://lists.rtems.org/mailman/listinfo/devel
>>>>>>>>>> ᐧ
>>>>>> ᐧ
Hesham
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170325/61054584/attachment-0001.html>
