[GSoC] RTEMS Tester Improvements
Mon Mar 27 01:07:43 UTC 2017
On 27/03/2017 04:34, Tanu Hari Dixit wrote:
> Also, do you suggest against using PyYAML to parse .yml configuration
> files (since that will add a dependency into rtems-tester)?
PyYAML might be perfect for the task. We will need to find a suitable
solution as part of the change to Yaml. The YAML support maybe added to
the rtemstoolkit.
