[PATCH 3/7] benchmarks/dhrystone: Port to RTEMS
Tue Mar 28 12:55:58 UTC 2017
 testsuites/benchmarks/dhrystone/Makefile.am   |  5 ++-
 testsuites/benchmarks/dhrystone/dhry.h        | 12 +++++-
 testsuites/benchmarks/dhrystone/dhry_1.c      | 31 ++++++--------
 testsuites/benchmarks/dhrystone/dhry_2.c      |  8 ++--
 testsuites/benchmarks/dhrystone/dhrystone.scn | 62 +++++++++++++++++++++++++++
 testsuites/benchmarks/dhrystone/init.c        | 14 ++++--
 6 files changed, 105 insertions(+), 27 deletions(-)
diff --git a/testsuites/benchmarks/dhrystone/Makefile.am b/testsuites/benchmarks/dhrystone/Makefile.am
index 0354012..f9443e4 100644
--- a/testsuites/benchmarks/dhrystone/Makefile.am
+++ b/testsuites/benchmarks/dhrystone/Makefile.am
@@ -1,5 +1,5 @@
 rtems_tests_PROGRAMS = dhrystone
-dhrystone_SOURCES = init.c
+dhrystone_SOURCES = init.c dhry_1.c dhry_2.c
 dist_rtems_tests_DATA = dhrystone.scn dhrystone.doc
@@ -7,7 +7,8 @@ include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
 include $(top_srcdir)/../automake/compile.am
 include $(top_srcdir)/../automake/leaf.am
-AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include -DTIME
+AM_CFLAGS += -fno-inline -fno-builtin
 LINK_OBJS = $(dhrystone_OBJECTS)
 LINK_LIBS = $(dhrystone_LDLIBS)
diff --git a/testsuites/benchmarks/dhrystone/dhry.h b/testsuites/benchmarks/dhrystone/dhry.h
index 1714562..df52384 100644
--- a/testsuites/benchmarks/dhrystone/dhry.h
+++ b/testsuites/benchmarks/dhrystone/dhry.h
@@ -420,4 +420,14 @@ typedef struct record
           } variant;
       } Rec_Type, *Rec_Pointer;
+void Proc_1 (Rec_Pointer);
+void Proc_2 (One_Fifty *);
+void Proc_3 (Rec_Pointer *);
+void Proc_4 (void);
+void Proc_5 (void);
+void Proc_6 (Enumeration, Enumeration *);
+void Proc_7 (One_Fifty, One_Fifty, One_Fifty *);
+void Proc_8 (Arr_1_Dim, Arr_2_Dim, int, int);
+Enumeration Func_1 (Capital_Letter, Capital_Letter);
+Boolean Func_2 (Str_30, Str_30);
+Boolean Func_3 (Enumeration);
diff --git a/testsuites/benchmarks/dhrystone/dhry_1.c b/testsuites/benchmarks/dhrystone/dhry_1.c
index 7ab02a8..7370bb0 100644
--- a/testsuites/benchmarks/dhrystone/dhry_1.c
+++ b/testsuites/benchmarks/dhrystone/dhry_1.c
@@ -17,6 +17,9 @@
 #include "dhry.h"
+#include <stdlib.h>
+#include <string.h>
 /* Global Variables: */
 Rec_Pointer     Ptr_Glob,
@@ -28,10 +31,6 @@ char            Ch_1_Glob,
 int             Arr_1_Glob [50];
 int             Arr_2_Glob [50] [50];
-extern char     *malloc ();
-Enumeration     Func_1 ();
-  /* forward declaration necessary since Enumeration may not simply be int */
 #ifndef REG
         Boolean Reg = false;
 #define REG
@@ -51,7 +50,7 @@ extern  int     times ();
                 /* Measurements should last at least about 2 seconds */
 #endif
 #ifdef TIME
-extern long     time();
+#include <time.h>
                 /* see library function "time"  */
 #define Too_Small_Time 2
                 /* Measurements should last at least 2 seconds */
@@ -66,7 +65,7 @@ float           Microseconds,
 /* end of variables for time measurement */
-main ()
+int main (int argc, char **argv)
   /* main program, corresponds to procedures        */
@@ -114,13 +113,11 @@ main ()
     printf ("Program compiled without 'register' attribute\n");
     printf ("\n");
-  printf ("Please give the number of runs through the benchmark: ");
-    int n;
-    scanf ("%d", &n);
-    Number_Of_Runs = n;
+  Number_Of_Runs = atoi(argv[1]);
+  if (Number_Of_Runs < 1) {
+    return 1;
-  printf ("\n");
   printf ("Execution starts, %d runs through Dhrystone\n", Number_Of_Runs);
@@ -277,7 +274,7 @@ main ()
-Proc_1 (Ptr_Val_Par)
+void Proc_1 (Ptr_Val_Par)
 REG Rec_Pointer Ptr_Val_Par;
@@ -311,7 +308,7 @@ REG Rec_Pointer Ptr_Val_Par;
 } /* Proc_1 */
-Proc_2 (Int_Par_Ref)
+void Proc_2 (Int_Par_Ref)
     /* executed once */
     /* *Int_Par_Ref == 1, becomes 4 */
@@ -334,7 +331,7 @@ One_Fifty   *Int_Par_Ref;
 } /* Proc_2 */
-Proc_3 (Ptr_Ref_Par)
+void Proc_3 (Ptr_Ref_Par)
     /* executed once */
     /* Ptr_Ref_Par becomes Ptr_Glob */
@@ -349,7 +346,7 @@ Rec_Pointer *Ptr_Ref_Par;
 } /* Proc_3 */
-Proc_4 () /* without parameters */
+void Proc_4 (void) /* without parameters */
     /* executed once */
@@ -361,7 +358,7 @@ Proc_4 () /* without parameters */
 } /* Proc_4 */
-Proc_5 () /* without parameters */
+void Proc_5 (void) /* without parameters */
     /* executed once */
diff --git a/testsuites/benchmarks/dhrystone/dhry_2.c b/testsuites/benchmarks/dhrystone/dhry_2.c
index 63a3d3e..94a72eb 100644
--- a/testsuites/benchmarks/dhrystone/dhry_2.c
+++ b/testsuites/benchmarks/dhrystone/dhry_2.c
@@ -17,6 +17,8 @@
 #include "dhry.h"
 #ifndef REG
 #define REG
         /* REG becomes defined as empty */
@@ -27,7 +29,7 @@ extern  int     Int_Glob;
 extern  char    Ch_1_Glob;
-Proc_6 (Enum_Val_Par, Enum_Ref_Par)
+void Proc_6 (Enum_Val_Par, Enum_Ref_Par)
     /* executed once */
     /* Enum_Val_Par == Ident_3, Enum_Ref_Par becomes Ident_2 */
@@ -61,7 +63,7 @@ Enumeration *Enum_Ref_Par;
 } /* Proc_6 */
-Proc_7 (Int_1_Par_Val, Int_2_Par_Val, Int_Par_Ref)
+void Proc_7 (Int_1_Par_Val, Int_2_Par_Val, Int_Par_Ref)
     /* executed three times                                      */
     /* first call:      Int_1_Par_Val == 2, Int_2_Par_Val == 3,  */
@@ -81,7 +83,7 @@ One_Fifty      *Int_Par_Ref;
 } /* Proc_7 */
-Proc_8 (Arr_1_Par_Ref, Arr_2_Par_Ref, Int_1_Par_Val, Int_2_Par_Val)
+void Proc_8 (Arr_1_Par_Ref, Arr_2_Par_Ref, Int_1_Par_Val, Int_2_Par_Val)
     /* executed once      */
     /* Int_Par_Val_1 == 3 */
diff --git a/testsuites/benchmarks/dhrystone/dhrystone.scn b/testsuites/benchmarks/dhrystone/dhrystone.scn
index e69de29..206c475 100644
--- a/testsuites/benchmarks/dhrystone/dhrystone.scn
+++ b/testsuites/benchmarks/dhrystone/dhrystone.scn
@@ -0,0 +1,62 @@
+*** BEGIN OF TEST DHRYSTONE ***
+Dhrystone Benchmark, Version 2.1 (Language: C)
+Program compiled without 'register' attribute
+Execution starts, 1000000 runs through Dhrystone
+Execution ends
+Final values of the variables used in the benchmark:
+Int_Glob:            5
+        should be:   5
+Bool_Glob:           1
+        should be:   1
+Ch_1_Glob:           A
+        should be:   A
+Ch_2_Glob:           B
+        should be:   B
+Arr_1_Glob[8]:       7
+        should be:   7
+Arr_2_Glob[8][7]:    1000010
+        should be:   Number_Of_Runs + 10
+Ptr_Glob->
+  Ptr_Comp:          33770184
+        should be:   (implementation-dependent)
+  Discr:             0
+        should be:   0
+  Enum_Comp:         2
+        should be:   2
+  Int_Comp:          17
+        should be:   17
+  Str_Comp:          DHRYSTONE PROGRAM, SOME STRING
+        should be:   DHRYSTONE PROGRAM, SOME STRING
+Next_Ptr_Glob->
+        should be:   (implementation-dependent), same as above
+  Discr:             0
+        should be:   0
+  Enum_Comp:         1
+        should be:   1
+  Int_Comp:          18
+        should be:   18
+Int_1_Loc:           5
+        should be:   5
+Int_2_Loc:           13
+        should be:   13
+Int_3_Loc:           7
+        should be:   7
+Enum_Loc:            1
+        should be:   1
+Str_1_Loc:           DHRYSTONE PROGRAM, 1'ST STRING
+        should be:   DHRYSTONE PROGRAM, 1'ST STRING
+Str_2_Loc:           DHRYSTONE PROGRAM, 2'ND STRING
+        should be:   DHRYSTONE PROGRAM, 2'ND STRING
+Microseconds for one run through Dhrystone:   82.0
+Dhrystones per Second:                      12195.1
+*** END OF TEST DHRYSTONE ***
diff --git a/testsuites/benchmarks/dhrystone/init.c b/testsuites/benchmarks/dhrystone/init.c
index 6e339d4..3e6245c 100644
--- a/testsuites/benchmarks/dhrystone/init.c
+++ b/testsuites/benchmarks/dhrystone/init.c
@@ -20,15 +20,19 @@
 const char rtems_test_name[] = "DHRYSTONE";
-static void test(void)
+int main(int argc, char **argv);
 static void Init(rtems_task_argument arg)
+  char *argv[] = {
+    "dhrystone",
+    "1000000",
+    NULL
   TEST_BEGIN();
-  test();
+  main(2, argv);
   TEST_END();
   rtems_test_exit(0);
@@ -41,6 +45,8 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
 #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
1.8.4.5
