[PATCH 7/7] benchmarks/linpack: Port to RTEMS
Tue Mar 28 12:56:02 UTC 2017
 testsuites/benchmarks/linpack/Makefile.am  |   6 +-
 testsuites/benchmarks/linpack/init.c       |  14 +-
 testsuites/benchmarks/linpack/linpack-pc.c | 211 ++++++-----------------------
 testsuites/benchmarks/linpack/linpack.scn  |  52 +++++++
 4 files changed, 105 insertions(+), 178 deletions(-)
diff --git a/testsuites/benchmarks/linpack/Makefile.am b/testsuites/benchmarks/linpack/Makefile.am
index d947cd6..2f5c25c 100644
--- a/testsuites/benchmarks/linpack/Makefile.am
+++ b/testsuites/benchmarks/linpack/Makefile.am
@@ -1,5 +1,6 @@
 rtems_tests_PROGRAMS = linpack
-linpack_SOURCES = init.c
+linpack_SOURCES = init.c linpack-pc.c
+linpack_LDADD = -lm
 dist_rtems_tests_DATA = linpack.scn linpack.doc
@@ -8,8 +9,9 @@ include $(top_srcdir)/../automake/compile.am
 include $(top_srcdir)/../automake/leaf.am
 AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+AM_CFLAGS += -fno-inline -fno-builtin
-LINK_OBJS = $(linpack_OBJECTS)
+LINK_OBJS = $(linpack_OBJECTS) $(linpack_LDADD)
 LINK_LIBS = $(linpack_LDLIBS)
 linpack$(EXEEXT): $(linpack_OBJECTS) $(linpack_DEPENDENCIES)
diff --git a/testsuites/benchmarks/linpack/init.c b/testsuites/benchmarks/linpack/init.c
index 8b67e52..c94314b 100644
--- a/testsuites/benchmarks/linpack/init.c
+++ b/testsuites/benchmarks/linpack/init.c
@@ -20,15 +20,19 @@
 const char rtems_test_name[] = "LINPACK";
-static void test(void)
+int main(int argc, char **argv);
 static void Init(rtems_task_argument arg)
+  char *argv[] = {
+    "linpack",
+    "10",
+    NULL
   TEST_BEGIN();
-  test();
+  main(2, argv);
   TEST_END();
   rtems_test_exit(0);
@@ -41,6 +45,8 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
 #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
diff --git a/testsuites/benchmarks/linpack/linpack-pc.c b/testsuites/benchmarks/linpack/linpack-pc.c
index a5e6869..5b8bc1c 100644
--- a/testsuites/benchmarks/linpack/linpack-pc.c
+++ b/testsuites/benchmarks/linpack/linpack-pc.c
@@ -193,6 +193,8 @@
+#define DP
+#define ROLL
 #ifdef SP
 #define REAL float
@@ -216,17 +218,14 @@
 #endif
-#define NTIMES 10
+#define NTIMES atoi(argv[1])
 #include <math.h>
-#include <conio.h>
 static REAL atime[9][15];
-static char this_month;
-static int this_year;
 void print_time (int row);
 void matgen (REAL a[], int lda, int n, REAL b[], REAL *norma);
@@ -240,56 +239,25 @@ void dscal (int n, REAL da, REAL dx[], int incx);
 REAL ddot (int n, REAL dx[], int incx, REAL dy[], int incy);
 /* TIME TIME TIME TIME TIME TIME TIME TIME TIME TIME TIME TIME TIME */
-   #include <time.h>  /* for following time functions only */
-   REAL second()
+   #include <sys/time.h>  /* for following time functions only */
+   static REAL second(void)
-        REAL secs;
-        clock_t Time;
-        Time = clock();
-        secs = (REAL)Time / (REAL)CLOCKS_PER_SEC;
-        return secs ;
+        struct timeval tv;
-/* DATE DATE DATE DATE DATE DATE DATE DATE DATE DATE DATE DATE DATE */
-   #include <dos.h>   /* for following date functions only */
-   void what_date()
-         /*   Watcom   */
-         struct dosdate_t adate;
-         _dos_getdate( &adate );
-         this_month = adate.month;
-         this_year = adate.year;
-         /*   Borland
-         struct date adate;
-         getdate( &adate );
-         this_month = adate.da_mon;
-         this_year = adate.da_year;
-         return;
+        gettimeofday(&tv, NULL);
+        return (double)tv.tv_sec + (double)tv.tv_usec * 1e-6;
-main ()
+int main (int argc, char **argv)
         static REAL aa[200*200],a[200*201],b[200],x[200];
         REAL cray,ops,total,norma,normx;
         REAL resid,residn,eps,t1,tm2,epsn,x1,x2;
         REAL mflops;
         static int ipvt[200],n,i,j,ntimes,info,lda,ldaa;
-        int Endit, pass, loop;
+        int pass, loop;
         REAL overhead1, overhead2, time1, time2;
-        FILE    *outfile;
-        char *compiler, *options, general[9][80] = {" "};
-        outfile = fopen("Linpack.txt","a+");
-        if (outfile == NULL)
-            printf ("Cannot open results file \n\n");
-            printf("Press any key\n");
-            Endit = getch();
-            exit (0);
+        char *compiler, *options;
  *           Enter details of compiler and options used                 *
@@ -350,10 +318,10 @@ main ()
                (double)residn, (double)resid, (double)epsn,
                (double)x1, (double)x2);
-        fprintf(stderr,"Times are reported for matrices of order        %5d\n",n);
-        fprintf(stderr,"1 pass times for array with leading dimension of%5d\n\n",lda);
-        fprintf(stderr,"      dgefa      dgesl      total     Mflops       unit");
-        fprintf(stderr,"      ratio\n");
+        fprintf(stdout,"Times are reported for matrices of order        %5d\n",n);
+        fprintf(stdout,"1 pass times for array with leading dimension of%5d\n\n",lda);
+        fprintf(stdout,"      dgefa      dgesl      total     Mflops       unit");
+        fprintf(stdout,"      ratio\n");
         atime[2][0] = total;
         if (total > 0.0)
@@ -374,7 +342,7 @@ main ()
  *       Calculate overhead of executing matgen procedure              *
-        fprintf (stderr,"\nCalculating matgen overhead\n");
+        fprintf (stdout,"\nCalculating matgen overhead\n");
         pass = -20;
         loop = NTIMES;
         do
@@ -387,7 +355,7 @@ main ()
             time2 = second();
             overhead1 = (time2 - time1);
-            fprintf (stderr,"%10d times %6.2f seconds\n", loop, overhead1);
+            fprintf (stdout,"%10d times %6.2f seconds\n", loop, overhead1);
             if (overhead1 > 5.0)
                 pass = 0;
@@ -408,13 +376,13 @@ main ()
         overhead1 = overhead1 / (double)loop;
-        fprintf (stderr,"Overhead for 1 matgen %12.5f seconds\n\n", overhead1);
+        fprintf (stdout,"Overhead for 1 matgen %12.5f seconds\n\n", overhead1);
  *           Calculate matgen/dgefa passes for 5 seconds                *
-        fprintf (stderr,"Calculating matgen/dgefa passes for 5 seconds\n");
+        fprintf (stdout,"Calculating matgen/dgefa passes for 5 seconds\n");
         pass = -20;
         ntimes = NTIMES;
         do
@@ -427,7 +395,7 @@ main ()
                 dgefa(a,lda,n,ipvt,&info );
             time2 = second() - time1;
-            fprintf (stderr,"%10d times %6.2f seconds\n", ntimes, time2);
+            fprintf (stdout,"%10d times %6.2f seconds\n", ntimes, time2);
             if (time2 > 5.0)
                 pass = 0;
@@ -449,10 +417,10 @@ main ()
         ntimes =  5.0 * (double)ntimes / time2;
         if (ntimes == 0) ntimes = 1;
-        fprintf (stderr,"Passes used %10d \n\n", ntimes);
-        fprintf(stderr,"Times for array with leading dimension of%4d\n\n",lda);
+        fprintf (stdout,"Passes used %10d \n\n", ntimes);
+        fprintf(stdout,"Times for array with leading dimension of%4d\n\n",lda);
  *                              Execute 5 passes                        *
@@ -492,10 +460,10 @@ main ()
             print_time(j);
         atime[3][6] = atime[3][6] / 5.0;
-        fprintf (stderr,"Average                          %11.2f\n",
+        fprintf (stdout,"Average                          %11.2f\n",
                                                (double)atime[3][6]);
-        fprintf (stderr,"\nCalculating matgen2 overhead\n");
+        fprintf (stdout,"\nCalculating matgen2 overhead\n");
@@ -510,10 +478,10 @@ main ()
         overhead2 = (time2 - time1);
         overhead2 = overhead2 / (double)loop;
-        fprintf (stderr,"Overhead for 1 matgen %12.5f seconds\n\n", overhead2);
-        fprintf(stderr,"Times for array with leading dimension of%4d\n\n",ldaa);
+        fprintf (stdout,"Overhead for 1 matgen %12.5f seconds\n\n", overhead2);
+        fprintf(stdout,"Times for array with leading dimension of%4d\n\n",ldaa);
@@ -553,7 +521,7 @@ main ()
             print_time(j);
         atime[3][12] = atime[3][12] / 5.0;
                                               (double)atime[3][12]);
@@ -563,109 +531,16 @@ main ()
         mflops = atime[3][6];
         if (atime[3][12] < mflops) mflops = atime[3][12];
-        fprintf(stderr,"\n");
-        fprintf(stderr,ROLLING);fprintf(stderr,PREC);
-        fprintf(stderr," Precision %11.2f Mflops \n\n",mflops);
-        what_date();
- *             Type details of hardware, software etc.                  *
-    printf ("Enter the following data which will be "
-                                "appended to file Linpack.txt \n\n");
-    printf ("PC Supplier/model ?\n                    ");
-    scanf ("%[^\n]", general[1]);
-    fflush (stdin);
-    printf ("CPU               ?\n                    ");
-    scanf ("%[^\n]", general[2]);
-    fflush (stdin);
-    printf ("Clock MHz         ?\n                    ");
-    scanf ("%[^\n]", general[3]);
-    fflush (stdin);
-    printf ("Cache             ?\n                    ");
-    scanf ("%[^\n]", general[4]);
-    fflush (stdin);
-    printf ("Chipset/options   ?\n                    ");
-    scanf ("%[^\n]", general[5]);
-    fflush (stdin);
-    printf ("OS/DOS version    ?\n                    ");
-    scanf ("%[^\n]", general[6]);
-    fflush (stdin);
-    printf ("Your name         ?\n                    ");
-    scanf ("%[^\n]", general[7]);
-    fflush (stdin);
-    printf ("Where from        ?\n                    ");
-    scanf ("%[^\n]", general[8]);
-    fflush (stdin);
-    printf ("Mail address      ?\n                    ");
-    scanf ("%[^\n]", general[0]);
-    fflush (stdin);
- *              Add results to output file LLloops.txt                  *
-    fprintf (outfile, "----------------- ----------------- --------- "
-                      "--------- ---------\n");
-    fprintf (outfile, "LINPACK BENCHMARK FOR PCs 'C/C++'    n @ 100\n\n");
-    fprintf (outfile, "Month run         %d/%d\n", this_month, this_year);
-    fprintf (outfile, "PC model          %s\n", general[1]);
-    fprintf (outfile, "CPU               %s\n", general[2]);
-    fprintf (outfile, "Clock MHz         %s\n", general[3]);
-    fprintf (outfile, "Cache             %s\n", general[4]);
-    fprintf (outfile, "Options           %s\n", general[5]);
-    fprintf (outfile, "OS/DOS            %s\n", general[6]);
-    fprintf (outfile, "Compiler          %s\n", compiler);
-    fprintf (outfile, "OptLevel          %s\n", options);
-    fprintf (outfile, "Run by            %s\n", general[7]);
-    fprintf (outfile, "From              %s\n", general[8]);
-    fprintf (outfile, "Mail              %s\n\n", general[0]);
-    fprintf(outfile, "Rolling            %s\n",ROLLING);
-    fprintf(outfile, "Precision          %s\n",PREC);
-    fprintf(outfile, "norm. resid        %16.1f\n",(double)residn);
-    fprintf(outfile, "resid              %16.8e\n",(double)resid);
-    fprintf(outfile, "machep             %16.8e\n",(double)epsn);
-    fprintf(outfile, "x[0]-1             %16.8e\n",(double)x1);
-    fprintf(outfile, "x[n-1]-1           %16.8e\n",(double)x2);
-    fprintf(outfile, "matgen 1 seconds   %16.5f\n",overhead1);
-    fprintf(outfile, "matgen 2 seconds   %16.5f\n",overhead2);
-    fprintf(outfile, "Repetitions        %16d\n",ntimes);
-    fprintf(outfile, "Leading dimension  %16d\n",lda);
-    fprintf(outfile, "                              dgefa     dgesl "
-                     "    total    Mflops\n");
-    fprintf(outfile, "1 pass seconds     %16.5f %9.5f %9.5f\n",
-                      atime[0][0], atime[1][0], atime[2][0]);
-    for (i=1 ; i<6 ; i++)
-        fprintf(outfile, "Repeat seconds     %16.5f %9.5f %9.5f %9.2f\n",
-                       atime[0][i], atime[1][i], atime[2][i], atime[3][i]);
-    fprintf(outfile, "Average            %46.2f\n",atime[3][6]);
-    fprintf(outfile, "Leading dimension  %16d\n",ldaa);
-    for (i=7 ; i<12 ; i++)
-    fprintf(outfile, "Average            %46.2f\n\n",atime[3][12]);
-    fclose (outfile);
-    printf("\nPress any key\n");
-    Endit = getch();
+        fprintf(stdout,"\n");
+        fprintf(stdout,ROLLING);fprintf(stdout,PREC);
+        fprintf(stdout," Precision %11.2f Mflops \n\n",mflops);
-fprintf(stderr,"%11.5f%11.5f%11.5f%11.2f%11.4f%11.4f\n",   (double)atime[0][row],
+fprintf(stdout,"%11.5f%11.5f%11.5f%11.2f%11.4f%11.4f\n",   (double)atime[0][row],
        (double)atime[1][row], (double)atime[2][row], (double)atime[3][row],
        (double)atime[4][row], (double)atime[5][row]);
        return;
@@ -950,10 +825,7 @@ void daxpy(int n, REAL da, REAL dx[], int incx, REAL dy[], int incy)
-        int i,ix,iy,m,mp1;
-        mp1 = 0;
-        m = 0;
+        int i,ix,iy;
         if(n <= 0) return;
         if (da == ZERO) return;
@@ -1019,10 +891,7 @@ REAL ddot(int n, REAL dx[], int incx, REAL dy[], int incy)
         REAL dtemp;
-        mp1 = 0;
-        m = 0;
+        int i,ix,iy;
         dtemp = ZERO;
@@ -1086,10 +955,7 @@ void dscal(int n, REAL da, REAL dx[], int incx)
-        int i,m,mp1,nincx;
-        mp1 = 0;
-        m = 0;
+        int i,nincx;
         if(n <= 0)return;
         if(incx != 1) {
@@ -1150,6 +1016,7 @@ int idamax(int n, REAL dx[], int incx)
         if( n < 1 ) return(-1);
         if(n ==1 ) return(0);
+        itemp = -1;
         if(incx != 1) {
                 /* code for increment not equal to 1 */
diff --git a/testsuites/benchmarks/linpack/linpack.scn b/testsuites/benchmarks/linpack/linpack.scn
index e69de29..6d2b3fe 100644
--- a/testsuites/benchmarks/linpack/linpack.scn
+++ b/testsuites/benchmarks/linpack/linpack.scn
@@ -0,0 +1,52 @@
+*** BEGIN OF TEST LINPACK ***
+Rolled Double Precision Linpack Benchmark - PC Version in 'C/C++'
+Compiler     INSERT COMPILER NAME HERE
+Optimisation INSERT OPTIMISATION OPTIONS HERE
+norm resid      resid           machep         x[0]-1          x[n-1]-1
+   1.7    7.41628980e-14   2.22044605e-16  -1.49880108e-14  -1.89848137e-14
+Times are reported for matrices of order          100
+1 pass times for array with leading dimension of  201
+      dgefa      dgesl      total     Mflops       unit      ratio
+    0.93482    0.02799    0.96281       0.71     2.8043    17.1930
+Calculating matgen overhead
+        10 times   0.78 seconds
+        20 times   1.56 seconds
+        40 times   3.13 seconds
+        80 times   6.26 seconds
+Overhead for 1 matgen      0.07824 seconds
+Calculating matgen/dgefa passes for 5 seconds
+        10 times  10.13 seconds
+Passes used          4
+Times for array with leading dimension of 201
+    0.93483    0.02794    0.96278       0.71     2.8042    17.1924
+    0.93483    0.02791    0.96274       0.71     2.8041    17.1918
+    0.93483    0.02791    0.96274       0.71     2.8041    17.1919
+Average                                 0.71
+Calculating matgen2 overhead
+Times for array with leading dimension of 200
+    0.93487    0.02791    0.96278       0.71     2.8042    17.1924
+    0.93484    0.02791    0.96275       0.71     2.8041    17.1919
+Average                                 0.71
+Rolled Double  Precision        0.71 Mflops
+*** END OF TEST LINPACK ***
1.8.4.5
