[PATCH 1/2] Beaglebone black i2c code, modify by Punit Vara - Add beagle/bbb-i2c.c i2c driver - Modify include/i2c.h - Modify Makefile.am But i2c cannot work currently
Sichen Zhao
1473996754 at qq.com
Thu Mar 30 03:24:01 UTC 2017
c/src/lib/libbsp/arm/beagle/Makefile.am | 4 +-
c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c | 788 ++++++++++++++++++++++++++++++
c/src/lib/libbsp/arm/beagle/include/i2c.h | 153 +++++-
3 files changed, 926 insertions(+), 19 deletions(-)
create mode 100644 c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
diff --git a/c/src/lib/libbsp/arm/beagle/Makefile.am b/c/src/lib/libbsp/arm/beagle/Makefile.am
index 8bb8478..4da72bc 100644
--- a/c/src/lib/libbsp/arm/beagle/Makefile.am
+++ b/c/src/lib/libbsp/arm/beagle/Makefile.am
@@ -88,7 +88,6 @@ libbsp_a_SOURCES += ../../shared/timerstub.c
libbsp_a_SOURCES += ../../shared/cpucounterread.c
libbsp_a_SOURCES += ../shared/startup/bsp-start-memcpy.S
libbsp_a_SOURCES += ../shared/arm-cp15-set-exception-handler.c
-libbsp_a_SOURCES += ../shared/arm-cp15-set-ttb-entries.c
# Startup
libbsp_a_SOURCES += startup/bspreset.c
@@ -116,6 +115,9 @@ libbsp_a_SOURCES += ../../shared/console.c \
# I2C
libbsp_a_SOURCES += misc/i2c.c
+# i2c
+libbsp_a_SOURCES += i2c/bbb-i2c.c
# GPIO
libbsp_a_SOURCES += gpio/bbb-gpio.c
diff --git a/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c b/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
new file mode 100644
index 0000000..cd1e9c1
--- /dev/null
+++ b/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
@@ -0,0 +1,788 @@
+ * @file
+ * @ingroup arm_beagle
+ * @brief BeagleBoard I2C bus initialization and API Support.
+ * Copyright (c) 2016 Punit Vara <punitvara at gmail.com>
+#include <stdio.h>
+#include <bsp/i2c.h>
+#include <libcpu/am335x.h>
+#include <rtems/irq-extension.h>
+#include <bsp/bbb-gpio.h>
+#include <rtems/score/assert.h>
+static bool am335x_i2c_pinmux(bbb_i2c_bus *bus)
+ bool status =true;
+ // We will check i2c_bus_id in am335x_i2c_bus_register
+ // Apart from mode and pull_up register what about SCREWCTRL & RXACTIVE ??
+ if (bus->i2c_bus_id == I2C1) {
+ REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_CS0) = (BBB_MUXMODE(MODE2) | BBB_PU_EN);
+ REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_D1) = (BBB_MUXMODE(MODE2) | BBB_PU_EN);
+ REG(AM335X_PADCONF_BASE + AM335X_CONF_UART1_TXD) = (BBB_MUXMODE(MODE3) | BBB_PU_EN);
+ REG(AM335X_PADCONF_BASE + AM335X_CONF_UART1_RXD) = (BBB_MUXMODE(MODE3) | BBB_PU_EN);
+ } else if (bus->i2c_bus_id == I2C2) {
+ REG(AM335X_PADCONF_BASE + AM335X_CONF_UART1_RTSN) = (BBB_MUXMODE(MODE3) | BBB_PU_EN);
+ REG(AM335X_PADCONF_BASE + AM335X_CONF_UART1_CTSN) = (BBB_MUXMODE(MODE3) | BBB_PU_EN);
+ REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_D0) = (BBB_MUXMODE(MODE3) | BBB_PU_EN);
+ REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_SCLK) = (BBB_MUXMODE(MODE3) | BBB_PU_EN);
+ } else {
+ status = false;
+ return status;
+/* ref. Table 21-4 I2C Clock Signals */
+ For I2C1/2
+ Interface clock - 100MHz - CORE_LKOUTM4 / 2 - pd_per_l4ls_gclk
+ Functional clock - 48MHz - PER_CLKOUTM2 / 4 - pd_per_ic2_fclk
+static void am335x_i2c1_i2c2_module_clk_config(bbb_i2c_bus *bus)
+/*0x2 = SW_WKUP : SW_WKUP: Start a software forced wake-up
+transition on the domain. */
+ REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKSTCTRL) |=
+ AM335X_CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
+ while((REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKSTCTRL) &
+ AM335X_CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL) !=
+ AM335X_CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL_SW_WKUP);
+/* 0x2 = ENABLE : Module is explicitly enabled. Interface clock (if not
+used for functions) may be gated according to the clock domain
+state. Functional clocks are guarantied to stay present. As long as in
+this configuration, power domain sleep transition cannot happen.*/
+ /* REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKCTRL) |=
+ AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE;
+ while((REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKCTRL) &
+ AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE) != AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE);
+/*0x2 = ENABLE : Module is explicitly enabled. Interface clock (if not
+ REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C1_CLKCTRL) |=
+ AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE_ENABLE;
+ while(REG((AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C1_CLKCTRL) &
+ AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE) != AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE_ENABLE);
+ REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C2_CLKCTRL) |=
+ AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE_ENABLE;
+ while(REG((AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C2_CLKCTRL) &
+ AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE) != AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE_ENABLE);
+ while(!(REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKSTCTRL) &
+ (AM335X_CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_L4LS_GCLK |
+ AM335X_CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_I2C_FCLK)));
+static void am335x_i2c0_pinmux(bbb_i2c_bus *bus)
+ REG(bus->regs + AM335X_CONF_I2C0_SDA) =
+ (BBB_RXACTIVE | BBB_SLEWCTRL | BBB_PU_EN);
+ REG(bus->regs + AM335X_CONF_I2C0_SCL) =
+static void I2C0ModuleClkConfig(void)
+ /* Configuring L3 Interface Clocks. */
+ /* Writing to MODULEMODE field of CM_PER_L3_CLKCTRL register. */
+ REG(AM335X_CM_PER_ADDR + CM_PER_L3_CLKCTRL) |=
+ CM_PER_L3_CLKCTRL_MODULEMODE_ENABLE;
+ /* Waiting for MODULEMODE field to reflect the written value. */
+ while(CM_PER_L3_CLKCTRL_MODULEMODE_ENABLE !=
+ (REG(AM335X_CM_PER_ADDR + CM_PER_L3_CLKCTRL) &
+ CM_PER_L3_CLKCTRL_MODULEMODE));
+ /* Writing to MODULEMODE field of CM_PER_L3_INSTR_CLKCTRL register. */
+ REG(AM335X_CM_PER_ADDR + CM_PER_L3_INSTR_CLKCTRL) |=
+ CM_PER_L3_INSTR_CLKCTRL_MODULEMODE_ENABLE;
+ while(CM_PER_L3_INSTR_CLKCTRL_MODULEMODE_ENABLE !=
+ (REG(AM335X_CM_PER_ADDR + CM_PER_L3_INSTR_CLKCTRL) &
+ CM_PER_L3_INSTR_CLKCTRL_MODULEMODE));
+ /* Writing to CLKTRCTRL field of CM_PER_L3_CLKSTCTRL register. */
+ REG(AM335X_CM_PER_ADDR + CM_PER_L3_CLKSTCTRL) |=
+ CM_PER_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
+ /* Waiting for CLKTRCTRL field to reflect the written value. */
+ while(CM_PER_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
+ (REG(AM335X_CM_PER_ADDR + CM_PER_L3_CLKSTCTRL) &
+ CM_PER_L3_CLKSTCTRL_CLKTRCTRL));
+ /* Writing to CLKTRCTRL field of CM_PER_OCPWP_L3_CLKSTCTRL register. */
+ REG(AM335X_CM_PER_ADDR + CM_PER_OCPWP_L3_CLKSTCTRL) |=
+ CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
+ /*Waiting for CLKTRCTRL field to reflect the written value. */
+ while(CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
+ (REG(AM335X_CM_PER_ADDR + CM_PER_OCPWP_L3_CLKSTCTRL) &
+ CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL));
+ /* Writing to CLKTRCTRL field of CM_PER_L3S_CLKSTCTRL register. */
+ REG(AM335X_CM_PER_ADDR + CM_PER_L3S_CLKSTCTRL) |=
+ CM_PER_L3S_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
+ while(CM_PER_L3S_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
+ (REG(AM335X_CM_PER_ADDR + CM_PER_L3S_CLKSTCTRL) &
+ CM_PER_L3S_CLKSTCTRL_CLKTRCTRL));
+ /* Checking fields for necessary values. */
+ /* Waiting for IDLEST field in CM_PER_L3_CLKCTRL register to be set to 0x0. */
+ while((CM_PER_L3_CLKCTRL_IDLEST_FUNC << CM_PER_L3_CLKCTRL_IDLEST_SHIFT)!=
+ CM_PER_L3_CLKCTRL_IDLEST));
+ ** Waiting for IDLEST field in CM_PER_L3_INSTR_CLKCTRL register to attain the
+ ** desired value.
+ while((CM_PER_L3_INSTR_CLKCTRL_IDLEST_FUNC <<
+ CM_PER_L3_INSTR_CLKCTRL_IDLEST_SHIFT)!=
+ CM_PER_L3_INSTR_CLKCTRL_IDLEST));
+ ** Waiting for CLKACTIVITY_L3_GCLK field in CM_PER_L3_CLKSTCTRL register to
+ ** attain the desired value.
+ while(CM_PER_L3_CLKSTCTRL_CLKACTIVITY_L3_GCLK !=
+ CM_PER_L3_CLKSTCTRL_CLKACTIVITY_L3_GCLK));
+ ** Waiting for CLKACTIVITY_OCPWP_L3_GCLK field in CM_PER_OCPWP_L3_CLKSTCTRL
+ ** register to attain the desired value.
+ while(CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L3_GCLK !=
+ CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L3_GCLK));
+ ** Waiting for CLKACTIVITY_L3S_GCLK field in CM_PER_L3S_CLKSTCTRL register
+ ** to attain the desired value.
+ while(CM_PER_L3S_CLKSTCTRL_CLKACTIVITY_L3S_GCLK !=
+ CM_PER_L3S_CLKSTCTRL_CLKACTIVITY_L3S_GCLK));
+ /* Configuring registers related to Wake-Up region. */
+ /* Writing to MODULEMODE field of CM_WKUP_CONTROL_CLKCTRL register. */
+ REG(SOC_CM_WKUP_REGS + CM_WKUP_CONTROL_CLKCTRL) |=
+ CM_WKUP_CONTROL_CLKCTRL_MODULEMODE_ENABLE;
+ while(CM_WKUP_CONTROL_CLKCTRL_MODULEMODE_ENABLE !=
+ (REG(SOC_CM_WKUP_REGS + CM_WKUP_CONTROL_CLKCTRL) &
+ CM_WKUP_CONTROL_CLKCTRL_MODULEMODE));
+ REG(SOC_CM_WKUP_REGS + CM_WKUP_CLKSTCTRL) |=
+ CM_WKUP_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
+ while(CM_WKUP_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
+ (REG(SOC_CM_WKUP_REGS + CM_WKUP_CLKSTCTRL) &
+ CM_WKUP_CLKSTCTRL_CLKTRCTRL));
+ /* Writing to CLKTRCTRL field of CM_L3_AON_CLKSTCTRL register. */
+ REG(SOC_CM_WKUP_REGS + CM_WKUP_CM_L3_AON_CLKSTCTRL) |=
+ CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
+ while(CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
+ (REG(SOC_CM_WKUP_REGS + CM_WKUP_CM_L3_AON_CLKSTCTRL) &
+ CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKTRCTRL));
+ /* Writing to MODULEMODE field of CM_WKUP_I2C0_CLKCTRL register. */
+ REG(SOC_CM_WKUP_REGS + CM_WKUP_I2C0_CLKCTRL) |=
+ CM_WKUP_I2C0_CLKCTRL_MODULEMODE_ENABLE;
+ while(CM_WKUP_I2C0_CLKCTRL_MODULEMODE_ENABLE !=
+ (REG(SOC_CM_WKUP_REGS + CM_WKUP_I2C0_CLKCTRL) &
+ CM_WKUP_I2C0_CLKCTRL_MODULEMODE));
+ /* Verifying if the other bits are set to required settings. */
+ ** Waiting for IDLEST field in CM_WKUP_CONTROL_CLKCTRL register to attain
+ ** desired value.
+ while((CM_WKUP_CONTROL_CLKCTRL_IDLEST_FUNC <<
+ CM_WKUP_CONTROL_CLKCTRL_IDLEST_SHIFT) !=
+ CM_WKUP_CONTROL_CLKCTRL_IDLEST));
+ ** Waiting for CLKACTIVITY_L3_AON_GCLK field in CM_L3_AON_CLKSTCTRL
+ ** register to attain desired value.
+ while(CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKACTIVITY_L3_AON_GCLK !=
+ CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKACTIVITY_L3_AON_GCLK));
+ ** Waiting for IDLEST field in CM_WKUP_L4WKUP_CLKCTRL register to attain
+ ** desired value.
+ while((CM_WKUP_L4WKUP_CLKCTRL_IDLEST_FUNC <<
+ CM_WKUP_L4WKUP_CLKCTRL_IDLEST_SHIFT) !=
+ (REG(SOC_CM_WKUP_REGS + CM_WKUP_L4WKUP_CLKCTRL) &
+ CM_WKUP_L4WKUP_CLKCTRL_IDLEST));
+ ** Waiting for CLKACTIVITY_L4_WKUP_GCLK field in CM_WKUP_CLKSTCTRL register
+ ** to attain desired value.
+ while(CM_WKUP_CLKSTCTRL_CLKACTIVITY_L4_WKUP_GCLK !=
+ CM_WKUP_CLKSTCTRL_CLKACTIVITY_L4_WKUP_GCLK));
+ ** Waiting for CLKACTIVITY_L4_WKUP_AON_GCLK field in CM_L4_WKUP_AON_CLKSTCTRL
+ while(CM_WKUP_CM_L4_WKUP_AON_CLKSTCTRL_CLKACTIVITY_L4_WKUP_AON_GCLK !=
+ (REG(SOC_CM_WKUP_REGS + CM_WKUP_CM_L4_WKUP_AON_CLKSTCTRL) &
+ CM_WKUP_CM_L4_WKUP_AON_CLKSTCTRL_CLKACTIVITY_L4_WKUP_AON_GCLK));
+ ** Waiting for CLKACTIVITY_I2C0_GFCLK field in CM_WKUP_CLKSTCTRL
+ while(CM_WKUP_CLKSTCTRL_CLKACTIVITY_I2C0_GFCLK !=
+ CM_WKUP_CLKSTCTRL_CLKACTIVITY_I2C0_GFCLK));
+ ** Waiting for IDLEST field in CM_WKUP_I2C0_CLKCTRL register to attain
+ ** desired value.
+ while((CM_WKUP_I2C0_CLKCTRL_IDLEST_FUNC <<
+ CM_WKUP_I2C0_CLKCTRL_IDLEST_SHIFT) !=
+ CM_WKUP_I2C0_CLKCTRL_IDLEST));
+void am335x_i2c_init(bbb_i2c_bus *bus, uint32_t input_clock)
+ // am335x_i2c_pinmux()
+ // am335x_i2c1_i2c2_module_clk_config
+static bool am335x_i2c_busbusy(volatile bbb_i2c_regs *regs)
+ bool status;
+ if (REG(®s->BBB_I2C_IRQSTATUS_RAW) & AM335X_I2C_IRQSTATUS_RAW_BB)
+ status = true;
+ } else {
+ status = false;
+ return status;
+static void am335x_i2c_reset(bbb_i2c_bus *bus)
+ volatile bbb_i2c_regs *regs = bus->regs;
+ printk("reset bus->reg is %x \n",bus->regs);
+ /* Disable I2C module at the time of initialization*/
+ /*Should I use write32 ?? I guess mmio_clear is correct choice here*/
+ printk("inside BBB_I2C_CON value is %x \n",®s->BBB_I2C_CON);
+ mmio_clear((®s->BBB_I2C_CON),AM335X_I2C_CON_I2C_EN);
+ mmio_clear((®s->BBB_I2C_SYSC),AM335X_I2C_SYSC_AUTOIDLE);
+ //REG(bus->regs + AM335X_I2C_CON) &= ~(AM335X_I2C_CON_I2C_EN);
+ //REG(bus->regs + AM335X_I2C_SYSC) &= ~(AM335X_I2C_SYSC_AUTOIDLE);
+ can I clear all the interrupt here ?
+ mmio_write(get_reg_addr(bbb_i2c_bus->reg->AM335X_I2C_IRQ_ENABLE_CLR), ??)
+Possible values for msg->flag
+ * - @ref I2C_M_TEN,
+ * - @ref I2C_M_RD,
+ * - @ref I2C_M_STOP,
+ * - @ref I2C_M_NOSTART,
+ * - @ref I2C_M_REV_DIR_ADDR,
+ * - @ref I2C_M_IGNORE_NAK,
+ * - @ref I2C_M_NO_RD_ACK, and
+ * - @ref I2C_M_RECV_LEN.
+static void am335x_i2c_set_address_size(const i2c_msg *msgs,volatile bbb_i2c_regs *regs)
+ /*can be configured multiple modes here. Need to think about own address modes*/
+ if ((msgs->flags & I2C_M_TEN) == 0) {/* 7-bit mode slave address mode*/
+ mmio_write(®s->BBB_I2C_CON,(AM335X_I2C_CFG_7BIT_SLAVE_ADDR | AM335X_I2C_CON_I2C_EN));
+ } else { /* 10-bit slave address mode*/
+ mmio_write(®s->BBB_I2C_CON,(AM335X_I2C_CFG_10BIT_SLAVE_ADDR | AM335X_I2C_CON_I2C_EN));
+static void am335x_i2c_next_byte(bbb_i2c_bus *bus)
+ i2c_msg *msg;
+ printk("Enter next_byte\n");
+ ++bus->msgs;
+ --bus->msg_todo;
+ msg = &bus->msgs[0];
+ bus->current_msg_todo = msg->len;
+ bus->current_msg_byte = msg->buf;
+static unsigned int am335x_i2c_intrawstatus(volatile bbb_i2c_regs *regs)
+ return (REG(®s->BBB_I2C_IRQSTATUS_RAW));
+static void am335x_i2c_masterint_enable(volatile bbb_i2c_regs *regs, unsigned int flag)
+ REG(®s->BBB_I2C_IRQENABLE_SET) |= flag;
+static void am335x_i2c_masterint_disable(volatile bbb_i2c_regs *regs, unsigned int flag)
+ REG(®s->BBB_I2C_IRQENABLE_CLR) = flag;
+static void am335x_int_clear(volatile bbb_i2c_regs *regs, unsigned int flag)
+ REG(®s->BBB_I2C_IRQSTATUS) = flag;
+static void am335x_clean_interrupts(volatile bbb_i2c_regs *regs)
+ am335x_i2c_masterint_enable(regs,0x7FFF);
+ am335x_int_clear(regs,0x7FFF);
+ am335x_i2c_masterint_disable(regs,0x7FFF);
+static void am335x_i2c_setup_read_transfer(bbb_i2c_bus *bus, volatile bbb_i2c_regs *regs, const i2c_msg *msgs, bool send_stop)
+ volatile unsigned int no_bytes;
+ //am335x_i2c_masterint_enable(regs, AM335X_I2C_INT_RECV_READY);
+ // No of data to be transmitted at a time
+ REG(®s->BBB_I2C_CNT) = 0x02;
+ no_bytes = REG(®s->BBB_I2C_CNT);
+ // I2C Controller in Master Mode
+ REG(®s->BBB_I2C_CON) = AM335X_I2C_CFG_MST_TX | AM335X_I2C_CON_I2C_EN | AM335X_I2C_CON_START | AM335X_I2C_CON_MST;
+ printk("set master in transmission mode %x \n",REG(®s->BBB_I2C_CON));
+ // Set Slave address & Master enable, bring out of reset
+ REG(®s->BBB_I2C_SA) = msgs->addr;
+ printf("slave address : %x\n",REG(®s->BBB_I2C_SA));
+ // clear status of all interrupts
+ am335x_clean_interrupts(regs);
+ printk("\n set memory address to read\n");
+ // transmit interrupt is enabled
+ am335x_i2c_masterint_enable(regs,AM335X_I2C_IRQSTATUS_XRDY);
+ printk("Enable transmit interrupt \n");
+ //start condition
+ REG(®s->BBB_I2C_CON) |= AM335X_I2C_CON_START;
+ printk("start transmission \n");
+ while(am335x_i2c_busbusy(regs) == 0);
+ printk("bus is free \n");
+ printk("CNT : %x\n", no_bytes);
+ while(0 != no_bytes);
+ printk("total msg count for tranmission is zero \n");
+ while( !(am335x_i2c_intrawstatus(regs) & (AM335X_I2C_IRQSTATUS_ARDY)));
+ printk("Enter read transfer \n");
+ // No of data to be received at a time(msg_count!!)
+ printk("msg_todo for read is %d \n",bus->msg_todo);
+ REG(®s->BBB_I2C_CNT) = bus->msg_todo;
+ //am335x_clean_interrupts(regs);
+ REG(®s->BBB_I2C_CON) = AM335X_I2C_CFG_MST_RX | AM335X_I2C_CON_I2C_EN | AM335X_I2C_CON_MST;
+ printk("Set master to receiver mode %x \n", REG(®s->BBB_I2C_CON));
+ // receive interrupt is enabled
+ am335x_i2c_masterint_enable(regs, AM335X_I2C_INT_RECV_READY | AM335X_I2C_INT_STOP_CONDITION);
+ if (send_stop) {
+ // stop condition
+ printk("stop to read\n");
+ REG(®s->BBB_I2C_CON) |= AM335X_I2C_CON_STOP;
+ } else {
+ // start condition
+ printk("start to read\n");
+ printk("Exit read transfer\n");
+static void am335x_i2c_continue_read_transfer(
+ bbb_i2c_bus *bus,
+ printk("enter continue read transfer \n");
+ bus->current_msg_byte[bus->already_transferred] = REG(®s->BBB_I2C_DATA);
+ bus->already_transferred++;
+ am335x_int_clear(regs,AM335X_I2C_INT_RECV_READY);
+ printk("clear RRDY in continue read transfer\n");
+ if (bus->already_transferred == REG(®s->BBB_I2C_CNT)) {
+ printk("continue read transfer finished \n");
+ //am335x_i2c_setup_read_transfer(bus,regs,false);
+ am335x_i2c_masterint_disable(regs, AM335X_I2C_INT_RECV_READY);
+ printk("disable RRDY in continue read transfer\n");
+ printk("stop condition in continue read transfer %x\n",REG(®s->BBB_I2C_CON));
+static void am335x_i2c_continue_write(bbb_i2c_bus *bus, volatile bbb_i2c_regs *regs)
+ REG(®s->BBB_I2C_DATA) = 0x00;
+ am335x_int_clear(regs, AM335X_I2C_IRQSTATUS_XRDY);
+ printk("clear XRDY continue write\n");
+ printk("\n finished transfer \n");
+ am335x_i2c_masterint_disable(regs, AM335X_I2C_IRQSTATUS_XRDY);
+ printk("disable XRDY continue write \n");
+ } else {
+ printk("write memory address \n");
+ REG(®s->BBB_I2C_DATA) = *bus->current_msg_byte;
+ if (bus->already_transferred == bus->msg_todo) {
+ printk("finished transfer \n");
+ } else {
+ printk("remaining byte \n");
+ REG(®s->BBB_I2C_DATA) = bus->current_msg_byte[bus->already_transferred];
+ printk("%s",REG(®s->BBB_I2C_DATA));
+static void am335x_i2c_setup_write_transfer(bbb_i2c_bus *bus,volatile bbb_i2c_regs *regs)
+ printk(" \n Enter write transfer \n");
+ // Following data count specify bytes to be transmitted
+ // Already cleaned during reset
+ // I2C Controller in Master transmitter Mode
+ REG(®s->BBB_I2C_CON) = AM335X_I2C_CFG_MST_TX | AM335X_I2C_CON_I2C_EN;
+ printk("enable master in transmiter mode setup write %x\n",REG(®s->BBB_I2C_CON));
+ printk("enable XRDY setup write\n");
+ //start condition
+ printk("set start condition in setup write %x \n",REG(®s->BBB_I2C_CON));
+ printk("CNT in setup write : %x \n",REG(®s->BBB_I2C_CNT));
+ printk("setup write msg_todo %x \n",bus->current_todo);
+ printk("check whether ???\n");
+ printk("RAW = %x",REG(®s->BBB_I2C_IRQSTATUS_RAW));
+ while( !((am335x_i2c_intrawstatus(regs)) & (AM335X_I2C_IRQSTATUS_ARDY)));
+ printk("exit setup write \n");
+static void am335x_i2c_setup_transfer(bbb_i2c_bus *bus, volatile bbb_i2c_regs *regs)
+ const i2c_msg *msgs = bus->msgs;
+ uint32_t msg_todo = bus->msg_todo;
+ bool send_stop = false;
+ uint32_t i;
+ printk("Enter setup transfer\n");
+ bus->current_todo = msgs[0].len;
+ for (i = 1; i < msg_todo && (msgs[i].flags & I2C_M_NOSTART) != 0; ++i) {
+ bus->current_todo += msgs[i].len;
+ regs = bus->regs;
+ REG(&bus->regs->BBB_I2C_BUF) |= AM335X_I2C_BUF_TXFIFO_CLR;
+ REG(&bus->regs->BBB_I2C_BUF) |= AM335X_I2C_BUF_RXFIFO_CLR;
+ am335x_i2c_set_address_size(msgs,regs);
+ bus->read = ((bus->read == true) ? 0:1);
+ bus->already_transferred = (bus->read == true) ? 0 : 1;
+ if (bus->read) {
+ if (REG(®s->BBB_I2C_CNT) == 1) {
+ send_stop = true;
+ printk("configure to read bus\n");
+ am335x_i2c_setup_read_transfer(bus,regs,msgs,send_stop);
+ } else {
+ printk("configure to write bus\n");
+ am335x_i2c_setup_write_transfer(bus,regs);
+static void am335x_i2c_interrupt(void *arg)
+ bbb_i2c_bus *bus = arg;
+ /* get status of enabled interrupts */
+ uint32_t irqstatus = REG(®s->BBB_I2C_IRQSTATUS);
+ bool done = false;
+ printk("\n inside interrupt function \n");
+ /* Clear all enabled interrupt except receive ready and transmit ready interrupt in status register */
+ REG(®s->BBB_I2C_IRQSTATUS) = (irqstatus & ~(AM335X_I2C_IRQSTATUS_RRDY | AM335X_I2C_IRQSTATUS_XRDY));
+ printk("\n irqstatus = %x \n",REG(®s->BBB_I2C_IRQSTATUS));
+ if (irqstatus & AM335X_I2C_INT_RECV_READY) {
+ printk("\nInside receive interrupt\n");
+ am335x_i2c_continue_read_transfer(bus, regs);
+ if (irqstatus & AM335X_I2C_IRQSTATUS_XRDY) {
+ printk("\ninside transmit interrupt \n");
+ am335x_i2c_continue_write(bus,regs);
+ if (irqstatus & AM335X_I2C_IRQSTATUS_NACK) {
+ done = true;
+ printk("inside NACK\n");
+ am335x_i2c_masterint_disable(regs,AM335X_I2C_IRQSTATUS_NACK);
+ if (irqstatus & AM335X_I2C_IRQSTATUS_BF) {
+ done = true;
+ printk("inside BF \n ");
+ if (done) {
+ uint32_t err = irqstatus & BBB_I2C_IRQ_ERROR;
+ printk("interrupt done \n");
+ am335x_i2c_next_byte(bus);
+ if (bus->msg_todo == 0 || err != 0) {
+ rtems_status_code sc;
+ // am335x_i2c_disable_interrupts(regs);
+ am335x_i2c_masterint_disable(regs, (AM335X_I2C_IRQSTATUS_RRDY | AM335X_I2C_IRQSTATUS_XRDY | AM335X_I2C_IRQSTATUS_BF));
+ REG(®s->BBB_I2C_IRQSTATUS) = err;
+ sc = rtems_event_transient_send(bus->task_id);
+ _Assert(sc == RTEMS_SUCCESSFUL);
+ (void) sc;
+ } else {
+ am335x_i2c_setup_transfer(bus, regs);
+static int am335x_i2c_transfer(i2c_bus *base, i2c_msg *msgs, uint32_t msg_count)
+ bbb_i2c_bus *bus = (bbb_i2c_bus *)base;
+ volatile bbb_i2c_regs *regs;
+ uint32_t i;
+ printk("\n enter transfer ");
+ rtems_task_wake_after(1);
+ if (msg_count < 1){
+ return 1;
+ for (i=0; i<msg_count;++i) {
+ if ((msgs[i].flags & I2C_M_RECV_LEN) != 0) {
+ return -EINVAL;
+ bus->msgs = &msgs[0];
+ bus->msg_todo = msg_count;
+ printk("total msg = msg_count : %x \n",bus->msg_todo);
+ bus->current_msg_todo = msgs[0].len;// current data size
+ bus->current_msg_byte = msgs[0].buf;// current data
+ printk("\n current_msg_todo %x \n ",msgs[0].len);
+ printk("\n current_msg_byte %x \n ",msgs[0].buf);
+ bus->task_id = rtems_task_self();
+ regs = bus->regs;
+ am335x_i2c_setup_transfer(bus,regs);
+ REG(®s->BBB_I2C_IRQENABLE_SET) = BBB_I2C_IRQ_USED;
+ sc = rtems_event_transient_receive(RTEMS_WAIT, bus->base.timeout);
+ // If timeout then return timeout error
+ if (sc != RTEMS_SUCCESSFUL) {
+ am335x_i2c_reset(bus);
+ rtems_event_transient_clear();
+ return -ETIMEDOUT;
+ printk("exit transfer\n");
+ // return bus->regs->BBB_I2C_IRQSTATUS == 0 ? 0 : -EIO;
+ return 0;
+static int am335x_i2c_set_clock(i2c_bus *base, unsigned long clock)
+ bbb_i2c_bus *bus = (bbb_i2c_bus *) base;
+ uint32_t prescaler,divider;
+ printk("set clock start\n");
+ prescaler = (BBB_I2C_SYSCLK / BBB_I2C_INTERNAL_CLK) -1;
+ printk("PSC offset %x \n ",®s->BBB_I2C_PSC);
+ printk("PSC offset %x \n", &bus->regs->BBB_I2C_PSC);
+ //mmio_write((®s->BBB_I2C_PSC), prescaler);
+ REG(&bus->regs->BBB_I2C_PSC) = prescaler;
+ divider = BBB_I2C_INTERNAL_CLK/(2*clock);
+ printk("SCLL offset %x \n",&bus->regs->BBB_I2C_SCLL);
+ //mmio_write((®s->BBB_I2C_SCLL), (divider - 7));
+ REG(&bus->regs->BBB_I2C_SCLL) = (divider - 7);
+ //mmio_write((®s->BBB_I2C_SCLH), (divider - 5));
+ printk("SCHL offset %x\n",&bus->regs->BBB_I2C_SCLH);
+ REG(&bus->regs->BBB_I2C_SCLH) = (divider - 5);
+ printk("set clock end \n");
+ return 0;
+static void am335x_i2c_destroy(i2c_bus *base)
+ printk(" starting destroy\n");
+ sc = rtems_interrupt_handler_remove(bus->irq, am335x_i2c_interrupt, bus);
+ (void)sc;
+ printk("end destroy\n");
+ i2c_bus_destroy_and_free(&bus->base);
+int am335x_i2c_bus_register(
+ const char *bus_path,
+ uintptr_t register_base,
+ uint32_t input_clock,
+ rtems_vector_number irq
+ bbb_i2c_bus *bus;
+ int err;
+ /*check bus number is >0 & <MAX*/
+ bus = (bbb_i2c_bus *) i2c_bus_alloc_and_init(sizeof(*bus));
+ if (bus == NULL) {
+ return -1;
+ bus->regs = (volatile bbb_i2c_regs *) register_base;
+// 1. Enable clock for I2CX
+ I2C0ModuleClkConfig();
+// 2. pinmux setup
+ am335x_i2c0_pinmux(bus);
+// 3. RESET : Disable Master, autoideal
+// 4. configure bus speed
+ bus->input_clock = input_clock; // By default 100KHz. Normally pass 100KHz as argument
+ printk("Before set clock \n");
+ err = am335x_i2c_set_clock(&bus->base, I2C_BUS_CLOCK_DEFAULT);
+ if (err != 0) {
+ (*bus->base.destroy)(&bus->base);
+ rtems_set_errno_and_return_minus_one(-err);
+ bus->irq = irq;
+ //bring I2C out of reset
+ REG(&bus->regs->BBB_I2C_CON) |= AM335X_I2C_CON_I2C_EN;
+ // 5. Start interrupt service routine & one interrupt at a time
+ sc = rtems_interrupt_handler_install(
+ irq,
+ "BBB I2C",
+ RTEMS_INTERRUPT_UNIQUE,
+ am335x_i2c_interrupt,
+ bus
+ rtems_set_errno_and_return_minus_one(EIO);
+ // 6. start transfer for reading and writing
+ bus->base.transfer = am335x_i2c_transfer;
+ bus->base.set_clock = am335x_i2c_set_clock;
+ bus->base.destroy = am335x_i2c_destroy;
+ printk("exit register\n");
+ return i2c_bus_register(&bus->base,bus_path);
diff --git a/c/src/lib/libbsp/arm/beagle/include/i2c.h b/c/src/lib/libbsp/arm/beagle/include/i2c.h
index e7d1716..d4a9e32 100644
--- a/c/src/lib/libbsp/arm/beagle/include/i2c.h
+++ b/c/src/lib/libbsp/arm/beagle/include/i2c.h
@@ -1,5 +1,5 @@
- * @file
@@ -24,7 +24,7 @@
#define LIBBSP_ARM_BEAGLE_I2C_H
+#include <dev/i2c/i2c.h>
#include <bsp.h>
#ifdef __cplusplus
@@ -180,20 +180,8 @@ struct i2c {
unsigned short res15;
-static unsigned short wait_for_pin( void );
-static void wait_for_bb( void );
-static void flush_fifo( void );
void i2c_init( int speed, int slaveadd );
-static int i2c_read_byte(
- unsigned char devaddr,
- unsigned char regoffset,
- unsigned char *value
int i2c_write(
unsigned char chip,
unsigned int addr,
@@ -210,10 +198,6 @@ int i2c_read(
int len
-static int imw ( unsigned char chip, unsigned long addr, unsigned char byte );
-static int imd( unsigned char chip, unsigned int addr, unsigned int length );
* @brief Initializes the I2C module @a i2c.
@@ -361,6 +345,139 @@ static inline rtems_status_code beagle_i2c_read(
return beagle_i2c_write_and_read(i2c, addr, NULL, 0, in, in_size);
+#define BBB_I2C_SYSCLK 48000000
+#define BBB_I2C_INTERNAL_CLK 12000000
+#define BBB_I2C_SPEED_CLK 100000
+#define BBB_I2C_IRQ_ERROR \
+ (AM335X_I2C_IRQSTATUS_NACK \
+ | AM335X_I2C_IRQSTATUS_ROVR \
+ | AM335X_I2C_IRQSTATUS_AL \
+ | AM335X_I2C_IRQSTATUS_ARDY \
+ | AM335X_I2C_IRQSTATUS_RRDY \
+ | AM335X_I2C_IRQSTATUS_XRDY \
+ | AM335X_I2C_IRQSTATUS_XUDF)
+#define BBB_I2C_IRQ_USED \
+ ( BBB_I2C_IRQ_ERROR \
+ | AM335X_I2C_IRQSTATUS_AAS \
+ | AM335X_I2C_IRQSTATUS_BF \
+ | AM335X_I2C_IRQSTATUS_STC \
+ | AM335X_I2C_IRQSTATUS_GC \
+ | AM335X_I2C_IRQSTATUS_XDR \
+ | AM335X_I2C_IRQSTATUS_RDR)
+#define BBB_I2C_0_BUS_PATH "/dev/i2c-0"
+#define BBB_I2C_1_BUS_PATH "/dev/i2c-1"
+#define BBB_I2C_2_BUS_PATH "/dev/i2c-2"
+#define BBB_I2C0_IRQ 70
+#define BBB_I2C1_IRQ 71
+#define BBB_I2C2_IRQ 30
+#define MODE2 2
+#define MODE3 3
+typedef enum {
+ I2C0,
+ I2C1,
+ I2C2,
+ I2C_COUNT
+}bbb_i2c_id_t;
+typedef struct i2c_regs
+ uint32_t BBB_I2C_REVNB_LO; // 0h
+ uint32_t BBB_I2C_REVNB_HI; //4h
+ uint32_t dummy1[2];
+ uint32_t BBB_I2C_SYSC; // 10h =16
+ uint32_t dummy2[4];
+ uint32_t BBB_I2C_IRQSTATUS_RAW; //24h =36
+ uint32_t BBB_I2C_IRQSTATUS; //28h =40
+ uint32_t BBB_I2C_IRQENABLE_SET; //2Ch =44
+ uint32_t BBB_I2C_IRQENABLE_CLR; //30h =48
+ uint32_t BBB_I2C_WE; // 34h = 52
+ uint32_t BBB_I2C_DMARXENABLE_SET; //38h = 56
+ uint32_t BBB_I2C_DMATXENABLE_SET; //3Ch = 60
+ uint32_t BBB_I2C_DMARXENABLE_CLR; //40h = 64
+ uint32_t BBB_I2C_DMATXENABLE_CLR; //44h = 68
+ uint32_t BBB_I2C_DMARXWAKE_EN; //48h = 72
+ uint32_t BBB_I2C_DMATXWAKE_EN; //4Ch =76
+ uint32_t dummy3[16];
+ uint32_t BBB_I2C_SYSS; // 90h =144
+ uint32_t BBB_I2C_BUF; // 94h =148
+ uint32_t BBB_I2C_CNT; // 98h =152
+ uint32_t BBB_I2C_DATA; //9Ch =156
+ uint32_t dummy4;
+ uint32_t BBB_I2C_CON; // A4h = 164
+ uint32_t BBB_I2C_OA; //A8h = 168
+ uint32_t BBB_I2C_SA; //ACh = 172
+ uint32_t BBB_I2C_PSC; //B0h = 176
+ uint32_t BBB_I2C_SCLL; //B4h = 180
+ uint32_t BBB_I2C_SCLH; //B8h = 184
+ uint32_t BBB_I2C_SYSTEST; //BCh = 188
+ uint32_t BBB_I2C_BUFSTAT; //C0h 192
+ uint32_t BBB_I2C_OA1; //C4h 196
+ uint32_t BBB_I2C_OA2; //C8h 200
+ uint32_t BBB_I2C_OA3; //CCh 204
+ uint32_t BBB_I2C_ACTOA; //D0h 208
+ uint32_t BBB_I2C_SBLOCK; //D4h 212
+}bbb_i2c_regs;
+typedef struct bbb_i2c_bus{
+ i2c_bus base;
+ i2c_msg *msgs;
+ uint32_t msg_todo;
+ uint32_t current_msg_todo; // current_data_size
+ uint8_t *current_msg_byte; // current_data
+ uint32_t current_todo;
+ bool read;
+ bool hold;
+ rtems_id task_id;
+ rtems_vector_number irq;
+ uint32_t input_clock;
+ uint32_t already_transferred;
+} bbb_i2c_bus;
+static inline int bbb_register_i2c_0(void)
+ return am335x_i2c_bus_register(
+ BBB_I2C_0_BUS_PATH,
+ AM335X_I2C0_BASE,
+ I2C_BUS_CLOCK_DEFAULT,
+ BBB_I2C0_IRQ
+static inline int bbb_register_i2c_1(void)
+ BBB_I2C_1_BUS_PATH,
+ AM335X_I2C1_BASE,
+ BBB_I2C1_IRQ
+static inline int bbb_register_i2c_2(void)
+ BBB_I2C_2_BUS_PATH,
+ AM335X_I2C2_BASE,
+ BBB_I2C2_IRQ
#ifdef __cplusplus
#endif /* __cplusplus */
2.7.4
>From 6855dbe659d67e304cf05474b2753b4239ceca90 Mon Sep 17 00:00:00 2001
Date: Thu, 30 Mar 2017 11:08:32 +0800
Subject: [PATCH 2/2] Beaglebone Black i2c code, modify by Sichen Zhao - Modify
the bbb-i2c.c code, base on Punit Vara code - Modify the include/i2c.h, base
on Punit Vara code I2C is working now, BBB can read the EEPROM by i2c The
test suite code link: https://github.com/hahchenchen/rtems/tree/i2c_1.0/i2c0
c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c | 370 ++++++++++++------------------
c/src/lib/libbsp/arm/beagle/include/i2c.h | 11 +-
2 files changed, 150 insertions(+), 231 deletions(-)
index cd1e9c1..4d22831 100644
--- a/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
@@ -21,80 +21,8 @@
-static bool am335x_i2c_pinmux(bbb_i2c_bus *bus)
- bool status =true;
- // We will check i2c_bus_id in am335x_i2c_bus_register
- // Apart from mode and pull_up register what about SCREWCTRL & RXACTIVE ??
- if (bus->i2c_bus_id == I2C1) {
- REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_CS0) = (BBB_MUXMODE(MODE2) | BBB_PU_EN);
- REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_D1) = (BBB_MUXMODE(MODE2) | BBB_PU_EN);
- REG(AM335X_PADCONF_BASE + AM335X_CONF_UART1_TXD) = (BBB_MUXMODE(MODE3) | BBB_PU_EN);
- REG(AM335X_PADCONF_BASE + AM335X_CONF_UART1_RXD) = (BBB_MUXMODE(MODE3) | BBB_PU_EN);
- } else if (bus->i2c_bus_id == I2C2) {
- REG(AM335X_PADCONF_BASE + AM335X_CONF_UART1_RTSN) = (BBB_MUXMODE(MODE3) | BBB_PU_EN);
- REG(AM335X_PADCONF_BASE + AM335X_CONF_UART1_CTSN) = (BBB_MUXMODE(MODE3) | BBB_PU_EN);
- REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_D0) = (BBB_MUXMODE(MODE3) | BBB_PU_EN);
- REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_SCLK) = (BBB_MUXMODE(MODE3) | BBB_PU_EN);
- } else {
- status = false;
- return status;
-/* ref. Table 21-4 I2C Clock Signals */
- For I2C1/2
- Interface clock - 100MHz - CORE_LKOUTM4 / 2 - pd_per_l4ls_gclk
- Functional clock - 48MHz - PER_CLKOUTM2 / 4 - pd_per_ic2_fclk
-static void am335x_i2c1_i2c2_module_clk_config(bbb_i2c_bus *bus)
-/*0x2 = SW_WKUP : SW_WKUP: Start a software forced wake-up
-transition on the domain. */
- REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKSTCTRL) |=
- AM335X_CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
- while((REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKSTCTRL) &
- AM335X_CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL) !=
- AM335X_CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL_SW_WKUP);
-/* 0x2 = ENABLE : Module is explicitly enabled. Interface clock (if not
-used for functions) may be gated according to the clock domain
-state. Functional clocks are guarantied to stay present. As long as in
-this configuration, power domain sleep transition cannot happen.*/
- /* REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKCTRL) |=
- AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE;
- while((REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKCTRL) &
- AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE) != AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE);
-/*0x2 = ENABLE : Module is explicitly enabled. Interface clock (if not
- REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C1_CLKCTRL) |=
- AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE_ENABLE;
- while(REG((AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C1_CLKCTRL) &
- AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE) != AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE_ENABLE);
- REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C2_CLKCTRL) |=
- AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE_ENABLE;
- while(REG((AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C2_CLKCTRL) &
- AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE) != AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE_ENABLE);
- while(!(REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKSTCTRL) &
- (AM335X_CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_L4LS_GCLK |
- AM335X_CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_I2C_FCLK)));
+static void flush_fifo(i2c_bus *base);
@@ -295,43 +223,59 @@ static void I2C0ModuleClkConfig(void)
-void am335x_i2c_init(bbb_i2c_bus *bus, uint32_t input_clock)
- // am335x_i2c_pinmux()
- // am335x_i2c1_i2c2_module_clk_config
bool status;
+ int stat;
+ int timeout=I2C_TIMEOUT;
- if (REG(®s->BBB_I2C_IRQSTATUS_RAW) & AM335X_I2C_IRQSTATUS_RAW_BB)
+ while ((stat = readw(®s->BBB_I2C_IRQSTATUS_RAW) &
+ AM335X_I2C_IRQSTATUS_RAW_BB) && timeout--) {
+ writew(stat, ®s->BBB_I2C_IRQSTATUS);
+ udelay(100);
+ if (timeout <= 0) {
+ printf("Timed out in wait_for_bb: status=%04x\n",
+ stat);
+ status = true;
+ else
- status = true;
- } else {
- status = false;
+ writew(0xFFFF, ®s->BBB_I2C_IRQSTATUS); /* clear delayed stuff*/
+ status = false;
return status;
- printk("reset bus->reg is %x \n",bus->regs);
- /* Disable I2C module at the time of initialization*/
- /*Should I use write32 ?? I guess mmio_clear is correct choice here*/
- printk("inside BBB_I2C_CON value is %x \n",®s->BBB_I2C_CON);
- mmio_clear((®s->BBB_I2C_CON),AM335X_I2C_CON_I2C_EN);
- mmio_clear((®s->BBB_I2C_SYSC),AM335X_I2C_SYSC_AUTOIDLE);
- //REG(bus->regs + AM335X_I2C_CON) &= ~(AM335X_I2C_CON_I2C_EN);
- //REG(bus->regs + AM335X_I2C_SYSC) &= ~(AM335X_I2C_SYSC_AUTOIDLE);
- can I clear all the interrupt here ?
- mmio_write(get_reg_addr(bbb_i2c_bus->reg->AM335X_I2C_IRQ_ENABLE_CLR), ??)
+ int timeout = I2C_TIMEOUT;
+ if (readw(®s->BBB_I2C_CON) & I2C_CON_EN) {
+ writew(0, ®s->BBB_I2C_CON);
+ udelay(50000);
+ writew(0x2, ®s->BBB_I2C_SYSC); /* for ES2 after soft reset */
+ udelay(1000);
+ writew(I2C_CON_EN, ®s->BBB_I2C_CON);
+ while (!(readw(®s->BBB_I2C_SYSS) & I2C_SYSS_RDONE) && timeout--) {
+ puts("ERROR: Timeout in soft-reset\n");
+ return;
+ udelay(1000);
@@ -360,7 +304,7 @@ static void am335x_i2c_next_byte(bbb_i2c_bus *bus)
i2c_msg *msg;
- printk("Enter next_byte\n");
++bus->msgs;
--bus->msg_todo;
@@ -402,61 +346,26 @@ static void am335x_clean_interrupts(volatile bbb_i2c_regs *regs)
- //am335x_i2c_masterint_enable(regs, AM335X_I2C_INT_RECV_READY);
- // No of data to be transmitted at a time
- REG(®s->BBB_I2C_CNT) = 0x02;
- no_bytes = REG(®s->BBB_I2C_CNT);
- // I2C Controller in Master Mode
- REG(®s->BBB_I2C_CON) = AM335X_I2C_CFG_MST_TX | AM335X_I2C_CON_I2C_EN | AM335X_I2C_CON_START | AM335X_I2C_CON_MST;
- printk("set master in transmission mode %x \n",REG(®s->BBB_I2C_CON));
- // Set Slave address & Master enable, bring out of reset
- REG(®s->BBB_I2C_SA) = msgs->addr;
- printf("slave address : %x\n",REG(®s->BBB_I2C_SA));
+ int status;
- // clear status of all interrupts
- am335x_clean_interrupts(regs);
- printk("\n set memory address to read\n");
- // transmit interrupt is enabled
- am335x_i2c_masterint_enable(regs,AM335X_I2C_IRQSTATUS_XRDY);
- printk("Enable transmit interrupt \n");
- //start condition
- REG(®s->BBB_I2C_CON) |= AM335X_I2C_CON_START;
- printk("start transmission \n");
- while(am335x_i2c_busbusy(regs) == 0);
- printk("bus is free \n");
- printk("CNT : %x\n", no_bytes);
- while(0 != no_bytes);
- printk("total msg count for tranmission is zero \n");
- while( !(am335x_i2c_intrawstatus(regs) & (AM335X_I2C_IRQSTATUS_ARDY)));
+ REG(®s->BBB_I2C_CNT) = bus->current_msg_todo;
- printk("Enter read transfer \n");
- // No of data to be received at a time(msg_count!!)
- printk("msg_todo for read is %d \n",bus->msg_todo);
- REG(®s->BBB_I2C_CNT) = bus->msg_todo;
- //am335x_clean_interrupts(regs);
- printk("Set master to receiver mode %x \n", REG(®s->BBB_I2C_CON));
if (send_stop) {
// stop condition
- printk("stop to read\n");
} else {
// start condition
- printk("start to read\n");
- printk("Exit read transfer\n");
@@ -465,85 +374,63 @@ static void am335x_i2c_continue_read_transfer(
- printk("enter continue read transfer \n");
- printk("clear RRDY in continue read transfer\n");
- printk("continue read transfer finished \n");
- //am335x_i2c_setup_read_transfer(bus,regs,false);
- printk("disable RRDY in continue read transfer\n");
- printk("stop condition in continue read transfer %x\n",REG(®s->BBB_I2C_CON));
- REG(®s->BBB_I2C_DATA) = 0x00;
- am335x_int_clear(regs, AM335X_I2C_IRQSTATUS_XRDY);
- printk("clear XRDY continue write\n");
- if (bus->already_transferred == REG(®s->BBB_I2C_CNT)) {
- printk("\n finished transfer \n");
- am335x_i2c_masterint_disable(regs, AM335X_I2C_IRQSTATUS_XRDY);
- printk("disable XRDY continue write \n");
- REG(®s->BBB_I2C_CON) |= AM335X_I2C_CON_STOP;
- } else {
- printk("write memory address \n");
- REG(®s->BBB_I2C_DATA) = *bus->current_msg_byte;
- if (bus->already_transferred == bus->msg_todo) {
- printk("finished transfer \n");
- } else {
- printk("remaining byte \n");
- REG(®s->BBB_I2C_DATA) = bus->current_msg_byte[bus->already_transferred];
- printk("%s",REG(®s->BBB_I2C_DATA));
- bus->already_transferred++;
+ writeb(0x0,®s->BBB_I2C_DATA);
+ writew(AM335X_I2C_IRQSTATUS_XRDY, ®s->BBB_I2C_IRQSTATUS);
-static void am335x_i2c_setup_write_transfer(bbb_i2c_bus *bus,volatile bbb_i2c_regs *regs)
+static void am335x_i2c_setup_write_transfer(bbb_i2c_bus *bus,volatile bbb_i2c_regs *regs, const i2c_msg *msgs)
- printk(" \n Enter write transfer \n");
- // Already cleaned during reset
- printk("enable master in transmiter mode setup write %x\n",REG(®s->BBB_I2C_CON));
- printk("enable XRDY setup write\n");
+ am335x_i2c_masterint_enable(regs,AM335X_I2C_IRQSTATUS_XRDY );
//start condition
- printk("set start condition in setup write %x \n",REG(®s->BBB_I2C_CON));
- printk("CNT in setup write : %x \n",REG(®s->BBB_I2C_CNT));
- printk("setup write msg_todo %x \n",bus->current_todo);
- printk("check whether ???\n");
- printk("RAW = %x",REG(®s->BBB_I2C_IRQSTATUS_RAW));
+ while(am335x_i2c_busbusy(regs)==0);
- printk("exit setup write \n");
@@ -554,9 +441,7 @@ static void am335x_i2c_setup_transfer(bbb_i2c_bus *bus, volatile bbb_i2c_regs *r
uint32_t i;
- printk("Enter setup transfer\n");
@@ -566,18 +451,22 @@ static void am335x_i2c_setup_transfer(bbb_i2c_bus *bus, volatile bbb_i2c_regs *r
- bus->read = ((bus->read == true) ? 0:1);
+ bus->read = (msgs->flags & I2C_M_RD) != 0;
if (bus->read) {
send_stop = true;
- printk("configure to read bus\n");
} else {
- printk("configure to write bus\n");
- am335x_i2c_setup_write_transfer(bus,regs);
+ am335x_i2c_setup_write_transfer(bus,regs,msgs);
@@ -589,42 +478,45 @@ static void am335x_i2c_interrupt(void *arg)
bool done = false;
- printk("\n inside interrupt function \n");
- REG(®s->BBB_I2C_IRQSTATUS) = (irqstatus & ~(AM335X_I2C_IRQSTATUS_RRDY | AM335X_I2C_IRQSTATUS_XRDY));
- printk("\n irqstatus = %x \n",REG(®s->BBB_I2C_IRQSTATUS));
+ REG(®s->BBB_I2C_IRQSTATUS) = (irqstatus & ~( AM335X_I2C_IRQSTATUS_RRDY | AM335X_I2C_IRQSTATUS_XRDY));
- printk("\nInside receive interrupt\n");
+ delay_bbb_i2c
- printk("\ninside transmit interrupt \n");
done = true;
- printk("inside NACK\n");
+ if (irqstatus & AM335X_I2C_IRQSTATUS_ARDY) {
+ done = true;
+ writew(I2C_STAT_ARDY, ®s->BBB_I2C_IRQSTATUS);
done = true;
- printk("inside BF \n ");
if (done) {
- printk("interrupt done \n");
- if (bus->msg_todo == 0 || err != 0) {
+ if (bus->msg_todo == 0 ) {
- // am335x_i2c_disable_interrupts(regs);
@@ -633,6 +525,7 @@ static void am335x_i2c_interrupt(void *arg)
(void) sc;
} else {
@@ -644,7 +537,6 @@ static int am335x_i2c_transfer(i2c_bus *base, i2c_msg *msgs, uint32_t msg_count)
uint32_t i;
- printk("\n enter transfer ");
@@ -660,11 +552,11 @@ static int am335x_i2c_transfer(i2c_bus *base, i2c_msg *msgs, uint32_t msg_count)
- printk("total msg = msg_count : %x \n",bus->msg_todo);
- printk("\n current_msg_todo %x \n ",msgs[0].len);
- printk("\n current_msg_byte %x \n ",msgs[0].buf);
regs = bus->regs;
@@ -680,8 +572,6 @@ static int am335x_i2c_transfer(i2c_bus *base, i2c_msg *msgs, uint32_t msg_count)
return -ETIMEDOUT;
- printk("exit transfer\n");
- // return bus->regs->BBB_I2C_IRQSTATUS == 0 ? 0 : -EIO;
return 0;
@@ -691,21 +581,17 @@ static int am335x_i2c_set_clock(i2c_bus *base, unsigned long clock)
- printk("set clock start\n");
- printk("PSC offset %x \n ",®s->BBB_I2C_PSC);
- printk("PSC offset %x \n", &bus->regs->BBB_I2C_PSC);
- //mmio_write((®s->BBB_I2C_PSC), prescaler);
- printk("SCLL offset %x \n",&bus->regs->BBB_I2C_SCLL);
- //mmio_write((®s->BBB_I2C_SCLL), (divider - 7));
- //mmio_write((®s->BBB_I2C_SCLH), (divider - 5));
- printk("SCHL offset %x\n",&bus->regs->BBB_I2C_SCLH);
- printk("set clock end \n");
return 0;
@@ -713,11 +599,11 @@ static void am335x_i2c_destroy(i2c_bus *base)
- printk(" starting destroy\n");
(void)sc;
- printk("end destroy\n");
@@ -751,7 +637,7 @@ int am335x_i2c_bus_register(
- printk("Before set clock \n");
if (err != 0) {
@@ -763,7 +649,11 @@ int am335x_i2c_bus_register(
- REG(&bus->regs->BBB_I2C_CON) |= AM335X_I2C_CON_I2C_EN;
+ udelay(1000);
+ flush_fifo(&bus->base);
+ writew(0xFFFF, &bus->regs->BBB_I2C_IRQSTATUS);
@@ -783,6 +673,30 @@ int am335x_i2c_bus_register(
- printk("exit register\n");
+ int stat;
+ * note: if you try and read data when its not there or ready
+ * you get a bus error
+ while (1) {
+ stat = readw(&bus->regs->BBB_I2C_IRQSTATUS);
+ if (stat == I2C_STAT_RRDY) {
+ readb(&bus->regs->BBB_I2C_DATA);
+ writew(I2C_STAT_RRDY, &bus->regs->BBB_I2C_IRQSTATUS);
+ udelay(1000);
+ } else
+ break;
index d4a9e32..a4fcf21 100644
@@ -132,11 +132,11 @@ extern "C" {
#define DISP_LINE_LEN 128
-#define I2C_TIMEOUT 1000
+#define I2C_TIMEOUT 500
#define I2C_BUS_MAX 3
-#define I2C_BASE1 (OMAP34XX_CORE_L4_IO_BASE + 0x070000)
+#define I2C_BASE1 (OMAP34XX_CORE_L4_IO_BASE + 0x070000) //0x48000000+0x070000
#define I2C_DEFAULT_BASE I2C_BASE1
@@ -356,7 +356,7 @@ static inline rtems_status_code beagle_i2c_read(
- | AM335X_I2C_IRQSTATUS_XUDF)
+ | AM335X_I2C_IRQSTATUS_XUDF )
@@ -378,6 +378,8 @@ static inline rtems_status_code beagle_i2c_read(
#define MODE2 2
#define MODE3 3
+#define delay_bbb_i2c printf(" ");
typedef enum {
I2C0,
I2C1,
@@ -478,6 +480,9 @@ static inline int bbb_register_i2c_2(void)
#ifdef __cplusplus
2.7.4
