bsp sorting for acinclude.m4 (was: ampolish3 sorting issues (again))
Thu Mar 30 23:15:35 UTC 2017
On 31/03/2017 09:24, Chris Johns wrote:
> I am getting this on master (4.12) after a bootstrap on FreeBSD 11.0 so
> I am wondering if perl has changed something which effects us.
It is not perl or ampolish3 related so the subject has changed.
It is looking like a mismatch between a command line sort on some hosts
and python's sorted where the sb-bootstrap command is being run.
I have run the sb-bootstrap and the bootstrap script on FreeBSD 11.0 and
I get the same results.
> Anyone else seeing this?
Joel and Kevin?
What hosts and what commands did you use to create these patches?
It looks like the python based sb-bootstrap is doing a case sensitive
sort while some hosts are doing a case insensitive sort.
On FreeBSD 11.0 and 10.3 I get:
$ echo "bf537Stamp/bsp_specs
 > TLL6527M/bsp_specs
 > eZKit533/bsp_specs" | sort
TLL6527M/bsp_specs
eZKit533/bsp_specs
$ python
Python 2.7.13 (default, Jan 12 2017, 01:19:30)
[GCC 4.2.1 Compatible FreeBSD Clang 3.8.0 (tags/RELEASE_380/final
262564)] on freebsd11
Type "help", "copyright", "credits" or "license" for more information.
 >>> b=['bf537Stamp/bsp_specs', 'TLL6527M/bsp_specs', 'eZKit533/bsp_specs']
 >>> sorted(b)
['TLL6527M/bsp_specs', 'bf537Stamp/bsp_specs', 'eZKit533/bsp_specs']
These results show the sort and python match.
I have looked into POSIX and sort and the sort order defaults are locale
related and the bootstrap script forces C so there looks like a
difference between FreeBSD and your hosts in what the defaults are.
> I do not want to push a change if conflicts with other hosts.
Unless I hear back I think a patch to revert the acinclude.m4 change is ok.
> ruru rtems.git $ git diff
> diff --git a/c/src/lib/libbsp/bfin/acinclude.m4
> b/c/src/lib/libbsp/bfin/acinclude.m4
> index 828fd894dd..ab6082ef47 100644
> --- a/c/src/lib/libbsp/bfin/acinclude.m4
> +++ b/c/src/lib/libbsp/bfin/acinclude.m4
> @@ -2,12 +2,12 @@
>  AC_DEFUN([RTEMS_CHECK_BSPDIR],
>    case "$1" in
> +  TLL6527M )
> +    AC_CONFIG_SUBDIRS([TLL6527M]);;
>    bf537Stamp )
>      AC_CONFIG_SUBDIRS([bf537Stamp]);;
>    eZKit533 )
>      AC_CONFIG_SUBDIRS([eZKit533]);;
> -  TLL6527M )
> -    AC_CONFIG_SUBDIRS([TLL6527M]);;
>      AC_MSG_ERROR([Invalid BSP]);;
>    esac
This change is hidden in the mega patch to remove texinfo ..
https://git.rtems.org/rtems/commit/?id=48a7fa31f918a6fc88719b3c9393a9ba2829f42a
> diff --git a/c/src/lib/libbsp/powerpc/acinclude.m4
> b/c/src/lib/libbsp/powerpc/acinclude.m4
> index edc67b5414..4c83475dd8 100644
> --- a/c/src/lib/libbsp/powerpc/acinclude.m4
> +++ b/c/src/lib/libbsp/powerpc/acinclude.m4
> @@ -32,12 +32,12 @@ AC_DEFUN([RTEMS_CHECK_BSPDIR],
>      AC_CONFIG_SUBDIRS([t32mppc]);;
>    tqm8xx )
>      AC_CONFIG_SUBDIRS([tqm8xx]);;
> +  virtex )
> +    AC_CONFIG_SUBDIRS([virtex]);;
>    virtex4 )
>      AC_CONFIG_SUBDIRS([virtex4]);;
>    virtex5 )
>      AC_CONFIG_SUBDIRS([virtex5]);;
> -  virtex )
> -    AC_CONFIG_SUBDIRS([virtex]);;
>    esac
And in this patch from Kevin ...
https://git.rtems.org/rtems/commit/?id=1c6926c11f2e5efcb166c668b097d64a0321d66e
