[PATCH 1/2] Beaglebone black i2c code, modify by Punit Vara - Addbeagle/bbb-i2c.c i2c driver - Modify include/i2c.h - Modify Makefile.am Buti2c cannot work currently
Sichen Zhao
1473996754 at qq.com
Fri Mar 31 01:44:47 UTC 2017
Hi Gedare Bloom,
Ok, i see, i will commit the code again.
Best Regards
Sichen Zhao
------------------ Original ------------------
Date: Thu, Mar 30, 2017 11:24 PM
To: "Sichen Zhao"<1473996754 at qq.com>;
Cc: "devel at rtems.org"<devel at rtems.org>;
Subject: Re: [PATCH 1/2] Beaglebone black i2c code, modify by Punit Vara - Addbeagle/bbb-i2c.c i2c driver - Modify include/i2c.h - Modify Makefile.am Buti2c cannot work currently
Hi Sichen,
Can you please make your git commit message a bit "cleaner" so that it
appears more nicely in git-log and in the email subject?
https://devel.rtems.org/wiki/Developer/Git#GitCommits Give a
descriptive short first line, followed by a blank line, and then the
more detailed commit message can follow.
Since this code was written by someone else, you should use the
--author="Punit Vara <...>" to give proper credit to him. This is part
of the reason to provide separate commits. Note that the author's name
is included in the git-commit information, so you don't need to also
repeat it in your commit message.
Thanks!
Gedare
On Wed, Mar 29, 2017 at 11:24 PM, Sichen Zhao <1473996754 at qq.com> wrote:
> c/src/lib/libbsp/arm/beagle/Makefile.am | 4 +-
> c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c | 788 ++++++++++++++++++++++++++++++
> c/src/lib/libbsp/arm/beagle/include/i2c.h | 153 +++++-
> 3 files changed, 926 insertions(+), 19 deletions(-)
> create mode 100644 c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
> diff --git a/c/src/lib/libbsp/arm/beagle/Makefile.am b/c/src/lib/libbsp/arm/beagle/Makefile.am
> index 8bb8478..4da72bc 100644
> --- a/c/src/lib/libbsp/arm/beagle/Makefile.am
> +++ b/c/src/lib/libbsp/arm/beagle/Makefile.am
> @@ -88,7 +88,6 @@ libbsp_a_SOURCES += ../../shared/timerstub.c
> libbsp_a_SOURCES += ../../shared/cpucounterread.c
> libbsp_a_SOURCES += ../shared/startup/bsp-start-memcpy.S
> libbsp_a_SOURCES += ../shared/arm-cp15-set-exception-handler.c
> -libbsp_a_SOURCES += ../shared/arm-cp15-set-ttb-entries.c
> # Startup
> libbsp_a_SOURCES += startup/bspreset.c
> @@ -116,6 +115,9 @@ libbsp_a_SOURCES += ../../shared/console.c \
> # I2C
> libbsp_a_SOURCES += misc/i2c.c
> +# i2c
> +libbsp_a_SOURCES += i2c/bbb-i2c.c
> # GPIO
> libbsp_a_SOURCES += gpio/bbb-gpio.c
> diff --git a/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c b/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
> new file mode 100644
> index 0000000..cd1e9c1
> --- /dev/null
> +++ b/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
> @@ -0,0 +1,788 @@
> + * @file
> + * @ingroup arm_beagle
> + * @brief BeagleBoard I2C bus initialization and API Support.
> + * Copyright (c) 2016 Punit Vara <punitvara at gmail.com>
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.org/license/LICENSE.
> +#include <stdio.h>
> +#include <bsp/i2c.h>
> +#include <libcpu/am335x.h>
> +#include <rtems/irq-extension.h>
> +#include <bsp/bbb-gpio.h>
> +#include <rtems/score/assert.h>
> +static bool am335x_i2c_pinmux(bbb_i2c_bus *bus)
> + bool status =true;
> + // We will check i2c_bus_id in am335x_i2c_bus_register
> + // Apart from mode and pull_up register what about SCREWCTRL & RXACTIVE ??
> + if (bus->i2c_bus_id == I2C1) {
> + REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_CS0) = (BBB_MUXMODE(MODE2) | BBB_PU_EN);
> + REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_D1) = (BBB_MUXMODE(MODE2) | BBB_PU_EN);
> + REG(AM335X_PADCONF_BASE + AM335X_CONF_UART1_TXD) = (BBB_MUXMODE(MODE3) | BBB_PU_EN);
> + REG(AM335X_PADCONF_BASE + AM335X_CONF_UART1_RXD) = (BBB_MUXMODE(MODE3) | BBB_PU_EN);
> + } else if (bus->i2c_bus_id == I2C2) {
> + REG(AM335X_PADCONF_BASE + AM335X_CONF_UART1_RTSN) = (BBB_MUXMODE(MODE3) | BBB_PU_EN);
> + REG(AM335X_PADCONF_BASE + AM335X_CONF_UART1_CTSN) = (BBB_MUXMODE(MODE3) | BBB_PU_EN);
> + REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_D0) = (BBB_MUXMODE(MODE3) | BBB_PU_EN);
> + REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_SCLK) = (BBB_MUXMODE(MODE3) | BBB_PU_EN);
> + } else {
> + status = false;
> + return status;
> +/* ref. Table 21-4 I2C Clock Signals */
> + For I2C1/2
> + Interface clock - 100MHz - CORE_LKOUTM4 / 2 - pd_per_l4ls_gclk
> + Functional clock - 48MHz - PER_CLKOUTM2 / 4 - pd_per_ic2_fclk
> +static void am335x_i2c1_i2c2_module_clk_config(bbb_i2c_bus *bus)
> +/*0x2 = SW_WKUP : SW_WKUP: Start a software forced wake-up
> +transition on the domain. */
> + REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKSTCTRL) |=
> + AM335X_CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
> + while((REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKSTCTRL) &
> + AM335X_CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL) !=
> + AM335X_CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL_SW_WKUP);
> +/* 0x2 = ENABLE : Module is explicitly enabled. Interface clock (if not
> +used for functions) may be gated according to the clock domain
> +state. Functional clocks are guarantied to stay present. As long as in
> +this configuration, power domain sleep transition cannot happen.*/
> + /* REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKCTRL) |=
> + AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE;
> + while((REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKCTRL) &
> + AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE) != AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE);
> +/*0x2 = ENABLE : Module is explicitly enabled. Interface clock (if not
> + REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C1_CLKCTRL) |=
> + AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE_ENABLE;
> + while(REG((AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C1_CLKCTRL) &
> + AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE) != AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE_ENABLE);
> + REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C2_CLKCTRL) |=
> + AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE_ENABLE;
> + while(REG((AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C2_CLKCTRL) &
> + AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE) != AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE_ENABLE);
> + while(!(REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKSTCTRL) &
> + (AM335X_CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_L4LS_GCLK |
> + AM335X_CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_I2C_FCLK)));
> +static void am335x_i2c0_pinmux(bbb_i2c_bus *bus)
> + REG(bus->regs + AM335X_CONF_I2C0_SDA) =
> + (BBB_RXACTIVE | BBB_SLEWCTRL | BBB_PU_EN);
> + REG(bus->regs + AM335X_CONF_I2C0_SCL) =
> +static void I2C0ModuleClkConfig(void)
> + /* Configuring L3 Interface Clocks. */
> + /* Writing to MODULEMODE field of CM_PER_L3_CLKCTRL register. */
> + REG(AM335X_CM_PER_ADDR + CM_PER_L3_CLKCTRL) |=
> + CM_PER_L3_CLKCTRL_MODULEMODE_ENABLE;
> + /* Waiting for MODULEMODE field to reflect the written value. */
> + while(CM_PER_L3_CLKCTRL_MODULEMODE_ENABLE !=
> + (REG(AM335X_CM_PER_ADDR + CM_PER_L3_CLKCTRL) &
> + CM_PER_L3_CLKCTRL_MODULEMODE));
> + /* Writing to MODULEMODE field of CM_PER_L3_INSTR_CLKCTRL register. */
> + REG(AM335X_CM_PER_ADDR + CM_PER_L3_INSTR_CLKCTRL) |=
> + CM_PER_L3_INSTR_CLKCTRL_MODULEMODE_ENABLE;
> + while(CM_PER_L3_INSTR_CLKCTRL_MODULEMODE_ENABLE !=
> + (REG(AM335X_CM_PER_ADDR + CM_PER_L3_INSTR_CLKCTRL) &
> + CM_PER_L3_INSTR_CLKCTRL_MODULEMODE));
> + /* Writing to CLKTRCTRL field of CM_PER_L3_CLKSTCTRL register. */
> + REG(AM335X_CM_PER_ADDR + CM_PER_L3_CLKSTCTRL) |=
> + CM_PER_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
> + /* Waiting for CLKTRCTRL field to reflect the written value. */
> + while(CM_PER_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
> + (REG(AM335X_CM_PER_ADDR + CM_PER_L3_CLKSTCTRL) &
> + CM_PER_L3_CLKSTCTRL_CLKTRCTRL));
> + /* Writing to CLKTRCTRL field of CM_PER_OCPWP_L3_CLKSTCTRL register. */
> + REG(AM335X_CM_PER_ADDR + CM_PER_OCPWP_L3_CLKSTCTRL) |=
> + CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
> + /*Waiting for CLKTRCTRL field to reflect the written value. */
> + while(CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
> + (REG(AM335X_CM_PER_ADDR + CM_PER_OCPWP_L3_CLKSTCTRL) &
> + CM_PER_OCPWP_L3_CLKSTCTRL_CLKTRCTRL));
> + /* Writing to CLKTRCTRL field of CM_PER_L3S_CLKSTCTRL register. */
> + REG(AM335X_CM_PER_ADDR + CM_PER_L3S_CLKSTCTRL) |=
> + CM_PER_L3S_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
> + while(CM_PER_L3S_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
> + (REG(AM335X_CM_PER_ADDR + CM_PER_L3S_CLKSTCTRL) &
> + CM_PER_L3S_CLKSTCTRL_CLKTRCTRL));
> + /* Checking fields for necessary values. */
> + /* Waiting for IDLEST field in CM_PER_L3_CLKCTRL register to be set to 0x0. */
> + while((CM_PER_L3_CLKCTRL_IDLEST_FUNC << CM_PER_L3_CLKCTRL_IDLEST_SHIFT)!=
> + CM_PER_L3_CLKCTRL_IDLEST));
> + ** Waiting for IDLEST field in CM_PER_L3_INSTR_CLKCTRL register to attain the
> + ** desired value.
> + while((CM_PER_L3_INSTR_CLKCTRL_IDLEST_FUNC <<
> + CM_PER_L3_INSTR_CLKCTRL_IDLEST_SHIFT)!=
> + CM_PER_L3_INSTR_CLKCTRL_IDLEST));
> + ** Waiting for CLKACTIVITY_L3_GCLK field in CM_PER_L3_CLKSTCTRL register to
> + ** attain the desired value.
> + while(CM_PER_L3_CLKSTCTRL_CLKACTIVITY_L3_GCLK !=
> + CM_PER_L3_CLKSTCTRL_CLKACTIVITY_L3_GCLK));
> + ** Waiting for CLKACTIVITY_OCPWP_L3_GCLK field in CM_PER_OCPWP_L3_CLKSTCTRL
> + ** register to attain the desired value.
> + while(CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L3_GCLK !=
> + CM_PER_OCPWP_L3_CLKSTCTRL_CLKACTIVITY_OCPWP_L3_GCLK));
> + ** Waiting for CLKACTIVITY_L3S_GCLK field in CM_PER_L3S_CLKSTCTRL register
> + ** to attain the desired value.
> + while(CM_PER_L3S_CLKSTCTRL_CLKACTIVITY_L3S_GCLK !=
> + CM_PER_L3S_CLKSTCTRL_CLKACTIVITY_L3S_GCLK));
> + /* Configuring registers related to Wake-Up region. */
> + /* Writing to MODULEMODE field of CM_WKUP_CONTROL_CLKCTRL register. */
> + REG(SOC_CM_WKUP_REGS + CM_WKUP_CONTROL_CLKCTRL) |=
> + CM_WKUP_CONTROL_CLKCTRL_MODULEMODE_ENABLE;
> + while(CM_WKUP_CONTROL_CLKCTRL_MODULEMODE_ENABLE !=
> + (REG(SOC_CM_WKUP_REGS + CM_WKUP_CONTROL_CLKCTRL) &
> + CM_WKUP_CONTROL_CLKCTRL_MODULEMODE));
> + REG(SOC_CM_WKUP_REGS + CM_WKUP_CLKSTCTRL) |=
> + CM_WKUP_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
> + while(CM_WKUP_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
> + (REG(SOC_CM_WKUP_REGS + CM_WKUP_CLKSTCTRL) &
> + CM_WKUP_CLKSTCTRL_CLKTRCTRL));
> + /* Writing to CLKTRCTRL field of CM_L3_AON_CLKSTCTRL register. */
> + REG(SOC_CM_WKUP_REGS + CM_WKUP_CM_L3_AON_CLKSTCTRL) |=
> + CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
> + while(CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKTRCTRL_SW_WKUP !=
> + (REG(SOC_CM_WKUP_REGS + CM_WKUP_CM_L3_AON_CLKSTCTRL) &
> + CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKTRCTRL));
> + /* Writing to MODULEMODE field of CM_WKUP_I2C0_CLKCTRL register. */
> + REG(SOC_CM_WKUP_REGS + CM_WKUP_I2C0_CLKCTRL) |=
> + CM_WKUP_I2C0_CLKCTRL_MODULEMODE_ENABLE;
> + while(CM_WKUP_I2C0_CLKCTRL_MODULEMODE_ENABLE !=
> + (REG(SOC_CM_WKUP_REGS + CM_WKUP_I2C0_CLKCTRL) &
> + CM_WKUP_I2C0_CLKCTRL_MODULEMODE));
> + /* Verifying if the other bits are set to required settings. */
> + ** Waiting for IDLEST field in CM_WKUP_CONTROL_CLKCTRL register to attain
> + ** desired value.
> + while((CM_WKUP_CONTROL_CLKCTRL_IDLEST_FUNC <<
> + CM_WKUP_CONTROL_CLKCTRL_IDLEST_SHIFT) !=
> + CM_WKUP_CONTROL_CLKCTRL_IDLEST));
> + ** Waiting for CLKACTIVITY_L3_AON_GCLK field in CM_L3_AON_CLKSTCTRL
> + ** register to attain desired value.
> + while(CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKACTIVITY_L3_AON_GCLK !=
> + CM_WKUP_CM_L3_AON_CLKSTCTRL_CLKACTIVITY_L3_AON_GCLK));
> + ** Waiting for IDLEST field in CM_WKUP_L4WKUP_CLKCTRL register to attain
> + ** desired value.
> + while((CM_WKUP_L4WKUP_CLKCTRL_IDLEST_FUNC <<
> + CM_WKUP_L4WKUP_CLKCTRL_IDLEST_SHIFT) !=
> + (REG(SOC_CM_WKUP_REGS + CM_WKUP_L4WKUP_CLKCTRL) &
> + CM_WKUP_L4WKUP_CLKCTRL_IDLEST));
> + ** Waiting for CLKACTIVITY_L4_WKUP_GCLK field in CM_WKUP_CLKSTCTRL register
> + ** to attain desired value.
> + while(CM_WKUP_CLKSTCTRL_CLKACTIVITY_L4_WKUP_GCLK !=
> + CM_WKUP_CLKSTCTRL_CLKACTIVITY_L4_WKUP_GCLK));
> + ** Waiting for CLKACTIVITY_L4_WKUP_AON_GCLK field in CM_L4_WKUP_AON_CLKSTCTRL
> + while(CM_WKUP_CM_L4_WKUP_AON_CLKSTCTRL_CLKACTIVITY_L4_WKUP_AON_GCLK !=
> + (REG(SOC_CM_WKUP_REGS + CM_WKUP_CM_L4_WKUP_AON_CLKSTCTRL) &
> + CM_WKUP_CM_L4_WKUP_AON_CLKSTCTRL_CLKACTIVITY_L4_WKUP_AON_GCLK));
> + ** Waiting for CLKACTIVITY_I2C0_GFCLK field in CM_WKUP_CLKSTCTRL
> + while(CM_WKUP_CLKSTCTRL_CLKACTIVITY_I2C0_GFCLK !=
> + CM_WKUP_CLKSTCTRL_CLKACTIVITY_I2C0_GFCLK));
> + ** Waiting for IDLEST field in CM_WKUP_I2C0_CLKCTRL register to attain
> + ** desired value.
> + while((CM_WKUP_I2C0_CLKCTRL_IDLEST_FUNC <<
> + CM_WKUP_I2C0_CLKCTRL_IDLEST_SHIFT) !=
> + CM_WKUP_I2C0_CLKCTRL_IDLEST));
> +void am335x_i2c_init(bbb_i2c_bus *bus, uint32_t input_clock)
> + // am335x_i2c_pinmux()
> + // am335x_i2c1_i2c2_module_clk_config
> +static bool am335x_i2c_busbusy(volatile bbb_i2c_regs *regs)
> + bool status;
> + if (REG(®s->BBB_I2C_IRQSTATUS_RAW) & AM335X_I2C_IRQSTATUS_RAW_BB)
> + status = true;
> + } else {
> + status = false;
> + return status;
> +static void am335x_i2c_reset(bbb_i2c_bus *bus)
> + volatile bbb_i2c_regs *regs = bus->regs;
> + printk("reset bus->reg is %x \n",bus->regs);
> + /* Disable I2C module at the time of initialization*/
> + /*Should I use write32 ?? I guess mmio_clear is correct choice here*/
> + printk("inside BBB_I2C_CON value is %x \n",®s->BBB_I2C_CON);
> + mmio_clear((®s->BBB_I2C_CON),AM335X_I2C_CON_I2C_EN);
> + mmio_clear((®s->BBB_I2C_SYSC),AM335X_I2C_SYSC_AUTOIDLE);
> + //REG(bus->regs + AM335X_I2C_CON) &= ~(AM335X_I2C_CON_I2C_EN);
> + //REG(bus->regs + AM335X_I2C_SYSC) &= ~(AM335X_I2C_SYSC_AUTOIDLE);
> + can I clear all the interrupt here ?
> + mmio_write(get_reg_addr(bbb_i2c_bus->reg->AM335X_I2C_IRQ_ENABLE_CLR), ??)
> +Possible values for msg->flag
> + * - @ref I2C_M_TEN,
> + * - @ref I2C_M_RD,
> + * - @ref I2C_M_STOP,
> + * - @ref I2C_M_NOSTART,
> + * - @ref I2C_M_REV_DIR_ADDR,
> + * - @ref I2C_M_IGNORE_NAK,
> + * - @ref I2C_M_NO_RD_ACK, and
> + * - @ref I2C_M_RECV_LEN.
> +static void am335x_i2c_set_address_size(const i2c_msg *msgs,volatile bbb_i2c_regs *regs)
> + /*can be configured multiple modes here. Need to think about own address modes*/
> + if ((msgs->flags & I2C_M_TEN) == 0) {/* 7-bit mode slave address mode*/
> + mmio_write(®s->BBB_I2C_CON,(AM335X_I2C_CFG_7BIT_SLAVE_ADDR | AM335X_I2C_CON_I2C_EN));
> + } else { /* 10-bit slave address mode*/
> + mmio_write(®s->BBB_I2C_CON,(AM335X_I2C_CFG_10BIT_SLAVE_ADDR | AM335X_I2C_CON_I2C_EN));
> +static void am335x_i2c_next_byte(bbb_i2c_bus *bus)
> + i2c_msg *msg;
> + printk("Enter next_byte\n");
> + ++bus->msgs;
> + --bus->msg_todo;
> + msg = &bus->msgs[0];
> + bus->current_msg_todo = msg->len;
> + bus->current_msg_byte = msg->buf;
> +static unsigned int am335x_i2c_intrawstatus(volatile bbb_i2c_regs *regs)
> + return (REG(®s->BBB_I2C_IRQSTATUS_RAW));
> +static void am335x_i2c_masterint_enable(volatile bbb_i2c_regs *regs, unsigned int flag)
> + REG(®s->BBB_I2C_IRQENABLE_SET) |= flag;
> +static void am335x_i2c_masterint_disable(volatile bbb_i2c_regs *regs, unsigned int flag)
> + REG(®s->BBB_I2C_IRQENABLE_CLR) = flag;
> +static void am335x_int_clear(volatile bbb_i2c_regs *regs, unsigned int flag)
> + REG(®s->BBB_I2C_IRQSTATUS) = flag;
> +static void am335x_clean_interrupts(volatile bbb_i2c_regs *regs)
> + am335x_i2c_masterint_enable(regs,0x7FFF);
> + am335x_int_clear(regs,0x7FFF);
> + am335x_i2c_masterint_disable(regs,0x7FFF);
> +static void am335x_i2c_setup_read_transfer(bbb_i2c_bus *bus, volatile bbb_i2c_regs *regs, const i2c_msg *msgs, bool send_stop)
> + volatile unsigned int no_bytes;
> + //am335x_i2c_masterint_enable(regs, AM335X_I2C_INT_RECV_READY);
> + // No of data to be transmitted at a time
> + REG(®s->BBB_I2C_CNT) = 0x02;
> + no_bytes = REG(®s->BBB_I2C_CNT);
> + // I2C Controller in Master Mode
> + REG(®s->BBB_I2C_CON) = AM335X_I2C_CFG_MST_TX | AM335X_I2C_CON_I2C_EN | AM335X_I2C_CON_START | AM335X_I2C_CON_MST;
> + printk("set master in transmission mode %x \n",REG(®s->BBB_I2C_CON));
> + // Set Slave address & Master enable, bring out of reset
> + REG(®s->BBB_I2C_SA) = msgs->addr;
> + printf("slave address : %x\n",REG(®s->BBB_I2C_SA));
> + // clear status of all interrupts
> + am335x_clean_interrupts(regs);
> + printk("\n set memory address to read\n");
> + // transmit interrupt is enabled
> + am335x_i2c_masterint_enable(regs,AM335X_I2C_IRQSTATUS_XRDY);
> + printk("Enable transmit interrupt \n");
> + //start condition
> + REG(®s->BBB_I2C_CON) |= AM335X_I2C_CON_START;
> + printk("start transmission \n");
> + while(am335x_i2c_busbusy(regs) == 0);
> + printk("bus is free \n");
> + printk("CNT : %x\n", no_bytes);
> + while(0 != no_bytes);
> + printk("total msg count for tranmission is zero \n");
> + while( !(am335x_i2c_intrawstatus(regs) & (AM335X_I2C_IRQSTATUS_ARDY)));
> + printk("Enter read transfer \n");
> + // No of data to be received at a time(msg_count!!)
> + printk("msg_todo for read is %d \n",bus->msg_todo);
> + REG(®s->BBB_I2C_CNT) = bus->msg_todo;
> + //am335x_clean_interrupts(regs);
> + REG(®s->BBB_I2C_CON) = AM335X_I2C_CFG_MST_RX | AM335X_I2C_CON_I2C_EN | AM335X_I2C_CON_MST;
> + printk("Set master to receiver mode %x \n", REG(®s->BBB_I2C_CON));
> + // receive interrupt is enabled
> + am335x_i2c_masterint_enable(regs, AM335X_I2C_INT_RECV_READY | AM335X_I2C_INT_STOP_CONDITION);
> + if (send_stop) {
> + // stop condition
> + printk("stop to read\n");
> + REG(®s->BBB_I2C_CON) |= AM335X_I2C_CON_STOP;
> + } else {
> + // start condition
> + printk("start to read\n");
> + printk("Exit read transfer\n");
> +static void am335x_i2c_continue_read_transfer(
> + bbb_i2c_bus *bus,
> + printk("enter continue read transfer \n");
> + bus->current_msg_byte[bus->already_transferred] = REG(®s->BBB_I2C_DATA);
> + bus->already_transferred++;
> + am335x_int_clear(regs,AM335X_I2C_INT_RECV_READY);
> + printk("clear RRDY in continue read transfer\n");
> + if (bus->already_transferred == REG(®s->BBB_I2C_CNT)) {
> + printk("continue read transfer finished \n");
> + //am335x_i2c_setup_read_transfer(bus,regs,false);
> + am335x_i2c_masterint_disable(regs, AM335X_I2C_INT_RECV_READY);
> + printk("disable RRDY in continue read transfer\n");
> + printk("stop condition in continue read transfer %x\n",REG(®s->BBB_I2C_CON));
> +static void am335x_i2c_continue_write(bbb_i2c_bus *bus, volatile bbb_i2c_regs *regs)
> + REG(®s->BBB_I2C_DATA) = 0x00;
> + am335x_int_clear(regs, AM335X_I2C_IRQSTATUS_XRDY);
> + printk("clear XRDY continue write\n");
> + printk("\n finished transfer \n");
> + am335x_i2c_masterint_disable(regs, AM335X_I2C_IRQSTATUS_XRDY);
> + printk("disable XRDY continue write \n");
> + } else {
> + printk("write memory address \n");
> + REG(®s->BBB_I2C_DATA) = *bus->current_msg_byte;
> + if (bus->already_transferred == bus->msg_todo) {
> + printk("finished transfer \n");
> + } else {
> + printk("remaining byte \n");
> + REG(®s->BBB_I2C_DATA) = bus->current_msg_byte[bus->already_transferred];
> + printk("%s",REG(®s->BBB_I2C_DATA));
> +static void am335x_i2c_setup_write_transfer(bbb_i2c_bus *bus,volatile bbb_i2c_regs *regs)
> + printk(" \n Enter write transfer \n");
> + // Following data count specify bytes to be transmitted
> + // Already cleaned during reset
> + // I2C Controller in Master transmitter Mode
> + REG(®s->BBB_I2C_CON) = AM335X_I2C_CFG_MST_TX | AM335X_I2C_CON_I2C_EN;
> + printk("enable master in transmiter mode setup write %x\n",REG(®s->BBB_I2C_CON));
> + printk("enable XRDY setup write\n");
> + //start condition
> + printk("set start condition in setup write %x \n",REG(®s->BBB_I2C_CON));
> + printk("CNT in setup write : %x \n",REG(®s->BBB_I2C_CNT));
> + printk("setup write msg_todo %x \n",bus->current_todo);
> + printk("check whether ???\n");
> + printk("RAW = %x",REG(®s->BBB_I2C_IRQSTATUS_RAW));
> + while( !((am335x_i2c_intrawstatus(regs)) & (AM335X_I2C_IRQSTATUS_ARDY)));
> + printk("exit setup write \n");
> +static void am335x_i2c_setup_transfer(bbb_i2c_bus *bus, volatile bbb_i2c_regs *regs)
> + const i2c_msg *msgs = bus->msgs;
> + uint32_t msg_todo = bus->msg_todo;
> + bool send_stop = false;
> + uint32_t i;
> + printk("Enter setup transfer\n");
> + bus->current_todo = msgs[0].len;
> + for (i = 1; i < msg_todo && (msgs[i].flags & I2C_M_NOSTART) != 0; ++i) {
> + bus->current_todo += msgs[i].len;
> + regs = bus->regs;
> + REG(&bus->regs->BBB_I2C_BUF) |= AM335X_I2C_BUF_TXFIFO_CLR;
> + REG(&bus->regs->BBB_I2C_BUF) |= AM335X_I2C_BUF_RXFIFO_CLR;
> + am335x_i2c_set_address_size(msgs,regs);
> + bus->read = ((bus->read == true) ? 0:1);
> + bus->already_transferred = (bus->read == true) ? 0 : 1;
> + if (bus->read) {
> + if (REG(®s->BBB_I2C_CNT) == 1) {
> + send_stop = true;
> + printk("configure to read bus\n");
> + am335x_i2c_setup_read_transfer(bus,regs,msgs,send_stop);
> + } else {
> + printk("configure to write bus\n");
> + am335x_i2c_setup_write_transfer(bus,regs);
> +static void am335x_i2c_interrupt(void *arg)
> + bbb_i2c_bus *bus = arg;
> + /* get status of enabled interrupts */
> + uint32_t irqstatus = REG(®s->BBB_I2C_IRQSTATUS);
> + bool done = false;
> + printk("\n inside interrupt function \n");
> + /* Clear all enabled interrupt except receive ready and transmit ready interrupt in status register */
> + REG(®s->BBB_I2C_IRQSTATUS) = (irqstatus & ~(AM335X_I2C_IRQSTATUS_RRDY | AM335X_I2C_IRQSTATUS_XRDY));
> + printk("\n irqstatus = %x \n",REG(®s->BBB_I2C_IRQSTATUS));
> + if (irqstatus & AM335X_I2C_INT_RECV_READY) {
> + printk("\nInside receive interrupt\n");
> + am335x_i2c_continue_read_transfer(bus, regs);
> + if (irqstatus & AM335X_I2C_IRQSTATUS_XRDY) {
> + printk("\ninside transmit interrupt \n");
> + am335x_i2c_continue_write(bus,regs);
> + if (irqstatus & AM335X_I2C_IRQSTATUS_NACK) {
> + done = true;
> + printk("inside NACK\n");
> + am335x_i2c_masterint_disable(regs,AM335X_I2C_IRQSTATUS_NACK);
> + if (irqstatus & AM335X_I2C_IRQSTATUS_BF) {
> + done = true;
> + printk("inside BF \n ");
> + if (done) {
> + uint32_t err = irqstatus & BBB_I2C_IRQ_ERROR;
> + printk("interrupt done \n");
> + am335x_i2c_next_byte(bus);
> + if (bus->msg_todo == 0 || err != 0) {
> + rtems_status_code sc;
> + // am335x_i2c_disable_interrupts(regs);
> + am335x_i2c_masterint_disable(regs, (AM335X_I2C_IRQSTATUS_RRDY | AM335X_I2C_IRQSTATUS_XRDY | AM335X_I2C_IRQSTATUS_BF));
> + REG(®s->BBB_I2C_IRQSTATUS) = err;
> + sc = rtems_event_transient_send(bus->task_id);
> + _Assert(sc == RTEMS_SUCCESSFUL);
> + (void) sc;
> + } else {
> + am335x_i2c_setup_transfer(bus, regs);
> +static int am335x_i2c_transfer(i2c_bus *base, i2c_msg *msgs, uint32_t msg_count)
> + bbb_i2c_bus *bus = (bbb_i2c_bus *)base;
> + volatile bbb_i2c_regs *regs;
> + uint32_t i;
> + printk("\n enter transfer ");
> + rtems_task_wake_after(1);
> + if (msg_count < 1){
> + return 1;
> + for (i=0; i<msg_count;++i) {
> + if ((msgs[i].flags & I2C_M_RECV_LEN) != 0) {
> + return -EINVAL;
> + bus->msgs = &msgs[0];
> + bus->msg_todo = msg_count;
> + printk("total msg = msg_count : %x \n",bus->msg_todo);
> + bus->current_msg_todo = msgs[0].len;// current data size
> + bus->current_msg_byte = msgs[0].buf;// current data
> + printk("\n current_msg_todo %x \n ",msgs[0].len);
> + printk("\n current_msg_byte %x \n ",msgs[0].buf);
> + bus->task_id = rtems_task_self();
> + regs = bus->regs;
> + am335x_i2c_setup_transfer(bus,regs);
> + REG(®s->BBB_I2C_IRQENABLE_SET) = BBB_I2C_IRQ_USED;
> + sc = rtems_event_transient_receive(RTEMS_WAIT, bus->base.timeout);
> + // If timeout then return timeout error
> + if (sc != RTEMS_SUCCESSFUL) {
> + am335x_i2c_reset(bus);
> + rtems_event_transient_clear();
> + return -ETIMEDOUT;
> + printk("exit transfer\n");
> + // return bus->regs->BBB_I2C_IRQSTATUS == 0 ? 0 : -EIO;
> + return 0;
> +static int am335x_i2c_set_clock(i2c_bus *base, unsigned long clock)
> + bbb_i2c_bus *bus = (bbb_i2c_bus *) base;
> + uint32_t prescaler,divider;
> + printk("set clock start\n");
> + prescaler = (BBB_I2C_SYSCLK / BBB_I2C_INTERNAL_CLK) -1;
> + printk("PSC offset %x \n ",®s->BBB_I2C_PSC);
> + printk("PSC offset %x \n", &bus->regs->BBB_I2C_PSC);
> + //mmio_write((®s->BBB_I2C_PSC), prescaler);
> + REG(&bus->regs->BBB_I2C_PSC) = prescaler;
> + divider = BBB_I2C_INTERNAL_CLK/(2*clock);
> + printk("SCLL offset %x \n",&bus->regs->BBB_I2C_SCLL);
> + //mmio_write((®s->BBB_I2C_SCLL), (divider - 7));
> + REG(&bus->regs->BBB_I2C_SCLL) = (divider - 7);
> + //mmio_write((®s->BBB_I2C_SCLH), (divider - 5));
> + printk("SCHL offset %x\n",&bus->regs->BBB_I2C_SCLH);
> + REG(&bus->regs->BBB_I2C_SCLH) = (divider - 5);
> + printk("set clock end \n");
> + return 0;
> +static void am335x_i2c_destroy(i2c_bus *base)
> + printk(" starting destroy\n");
> + sc = rtems_interrupt_handler_remove(bus->irq, am335x_i2c_interrupt, bus);
> + (void)sc;
> + printk("end destroy\n");
> + i2c_bus_destroy_and_free(&bus->base);
> +int am335x_i2c_bus_register(
> + const char *bus_path,
> + uintptr_t register_base,
> + uint32_t input_clock,
> + rtems_vector_number irq
> + bbb_i2c_bus *bus;
> + int err;
> + /*check bus number is >0 & <MAX*/
> + bus = (bbb_i2c_bus *) i2c_bus_alloc_and_init(sizeof(*bus));
> + if (bus == NULL) {
> + return -1;
> + bus->regs = (volatile bbb_i2c_regs *) register_base;
> +// 1. Enable clock for I2CX
> + I2C0ModuleClkConfig();
> +// 2. pinmux setup
> + am335x_i2c0_pinmux(bus);
> +// 3. RESET : Disable Master, autoideal
> +// 4. configure bus speed
> + bus->input_clock = input_clock; // By default 100KHz. Normally pass 100KHz as argument
> + printk("Before set clock \n");
> + err = am335x_i2c_set_clock(&bus->base, I2C_BUS_CLOCK_DEFAULT);
> + if (err != 0) {
> + (*bus->base.destroy)(&bus->base);
> + rtems_set_errno_and_return_minus_one(-err);
> + bus->irq = irq;
> + //bring I2C out of reset
> + REG(&bus->regs->BBB_I2C_CON) |= AM335X_I2C_CON_I2C_EN;
> + // 5. Start interrupt service routine & one interrupt at a time
> + sc = rtems_interrupt_handler_install(
> + irq,
> + "BBB I2C",
> + RTEMS_INTERRUPT_UNIQUE,
> + am335x_i2c_interrupt,
> + bus
> + rtems_set_errno_and_return_minus_one(EIO);
> + // 6. start transfer for reading and writing
> + bus->base.transfer = am335x_i2c_transfer;
> + bus->base.set_clock = am335x_i2c_set_clock;
> + bus->base.destroy = am335x_i2c_destroy;
> + printk("exit register\n");
> + return i2c_bus_register(&bus->base,bus_path);
> diff --git a/c/src/lib/libbsp/arm/beagle/include/i2c.h b/c/src/lib/libbsp/arm/beagle/include/i2c.h
> index e7d1716..d4a9e32 100644
> --- a/c/src/lib/libbsp/arm/beagle/include/i2c.h
> +++ b/c/src/lib/libbsp/arm/beagle/include/i2c.h
> @@ -1,5 +1,5 @@
> - * @file
> @@ -24,7 +24,7 @@
> #define LIBBSP_ARM_BEAGLE_I2C_H
> #include <rtems.h>
> +#include <dev/i2c/i2c.h>
> #include <bsp.h>
> #ifdef __cplusplus
> @@ -180,20 +180,8 @@ struct i2c {
> unsigned short res15;
> -static unsigned short wait_for_pin( void );
> -static void wait_for_bb( void );
> -static void flush_fifo( void );
> void i2c_init( int speed, int slaveadd );
> -static int i2c_read_byte(
> - unsigned char devaddr,
> - unsigned char regoffset,
> - unsigned char *value
> int i2c_write(
> unsigned char chip,
> unsigned int addr,
> @@ -210,10 +198,6 @@ int i2c_read(
> int len
> -static int imw ( unsigned char chip, unsigned long addr, unsigned char byte );
> -static int imd( unsigned char chip, unsigned int addr, unsigned int length );
> * @brief Initializes the I2C module @a i2c.
> @@ -361,6 +345,139 @@ static inline rtems_status_code beagle_i2c_read(
> return beagle_i2c_write_and_read(i2c, addr, NULL, 0, in, in_size);
> +#define BBB_I2C_SYSCLK 48000000
> +#define BBB_I2C_INTERNAL_CLK 12000000
> +#define BBB_I2C_SPEED_CLK 100000
> +#define BBB_I2C_IRQ_ERROR \
> + (AM335X_I2C_IRQSTATUS_NACK \
> + | AM335X_I2C_IRQSTATUS_ROVR \
> + | AM335X_I2C_IRQSTATUS_AL \
> + | AM335X_I2C_IRQSTATUS_ARDY \
> + | AM335X_I2C_IRQSTATUS_RRDY \
> + | AM335X_I2C_IRQSTATUS_XRDY \
> + | AM335X_I2C_IRQSTATUS_XUDF)
> +#define BBB_I2C_IRQ_USED \
> + ( BBB_I2C_IRQ_ERROR \
> + | AM335X_I2C_IRQSTATUS_AAS \
> + | AM335X_I2C_IRQSTATUS_BF \
> + | AM335X_I2C_IRQSTATUS_STC \
> + | AM335X_I2C_IRQSTATUS_GC \
> + | AM335X_I2C_IRQSTATUS_XDR \
> + | AM335X_I2C_IRQSTATUS_RDR)
> +#define BBB_I2C_0_BUS_PATH "/dev/i2c-0"
> +#define BBB_I2C_1_BUS_PATH "/dev/i2c-1"
> +#define BBB_I2C_2_BUS_PATH "/dev/i2c-2"
> +#define BBB_I2C0_IRQ 70
> +#define BBB_I2C1_IRQ 71
> +#define BBB_I2C2_IRQ 30
> +#define MODE2 2
> +#define MODE3 3
> +typedef enum {
> + I2C0,
> + I2C1,
> + I2C2,
> + I2C_COUNT
> +}bbb_i2c_id_t;
> +typedef struct i2c_regs
> + uint32_t BBB_I2C_REVNB_LO; // 0h
> + uint32_t BBB_I2C_REVNB_HI; //4h
> + uint32_t dummy1[2];
> + uint32_t BBB_I2C_SYSC; // 10h =16
> + uint32_t dummy2[4];
> + uint32_t BBB_I2C_IRQSTATUS_RAW; //24h =36
> + uint32_t BBB_I2C_IRQSTATUS; //28h =40
> + uint32_t BBB_I2C_IRQENABLE_SET; //2Ch =44
> + uint32_t BBB_I2C_IRQENABLE_CLR; //30h =48
> + uint32_t BBB_I2C_WE; // 34h = 52
> + uint32_t BBB_I2C_DMARXENABLE_SET; //38h = 56
> + uint32_t BBB_I2C_DMATXENABLE_SET; //3Ch = 60
> + uint32_t BBB_I2C_DMARXENABLE_CLR; //40h = 64
> + uint32_t BBB_I2C_DMATXENABLE_CLR; //44h = 68
> + uint32_t BBB_I2C_DMARXWAKE_EN; //48h = 72
> + uint32_t BBB_I2C_DMATXWAKE_EN; //4Ch =76
> + uint32_t dummy3[16];
> + uint32_t BBB_I2C_SYSS; // 90h =144
> + uint32_t BBB_I2C_BUF; // 94h =148
> + uint32_t BBB_I2C_CNT; // 98h =152
> + uint32_t BBB_I2C_DATA; //9Ch =156
> + uint32_t dummy4;
> + uint32_t BBB_I2C_CON; // A4h = 164
> + uint32_t BBB_I2C_OA; //A8h = 168
> + uint32_t BBB_I2C_SA; //ACh = 172
> + uint32_t BBB_I2C_PSC; //B0h = 176
> + uint32_t BBB_I2C_SCLL; //B4h = 180
> + uint32_t BBB_I2C_SCLH; //B8h = 184
> + uint32_t BBB_I2C_SYSTEST; //BCh = 188
> + uint32_t BBB_I2C_BUFSTAT; //C0h 192
> + uint32_t BBB_I2C_OA1; //C4h 196
> + uint32_t BBB_I2C_OA2; //C8h 200
> + uint32_t BBB_I2C_OA3; //CCh 204
> + uint32_t BBB_I2C_ACTOA; //D0h 208
> + uint32_t BBB_I2C_SBLOCK; //D4h 212
> +}bbb_i2c_regs;
> +typedef struct bbb_i2c_bus{
> + i2c_bus base;
> + i2c_msg *msgs;
> + uint32_t msg_todo;
> + uint32_t current_msg_todo; // current_data_size
> + uint8_t *current_msg_byte; // current_data
> + uint32_t current_todo;
> + bool read;
> + bool hold;
> + rtems_id task_id;
> + rtems_vector_number irq;
> + uint32_t input_clock;
> + uint32_t already_transferred;
> +} bbb_i2c_bus;
> +static inline int bbb_register_i2c_0(void)
> + return am335x_i2c_bus_register(
> + BBB_I2C_0_BUS_PATH,
> + AM335X_I2C0_BASE,
> + I2C_BUS_CLOCK_DEFAULT,
> + BBB_I2C0_IRQ
> +static inline int bbb_register_i2c_1(void)
> + BBB_I2C_1_BUS_PATH,
> + AM335X_I2C1_BASE,
> + BBB_I2C1_IRQ
> +static inline int bbb_register_i2c_2(void)
> + BBB_I2C_2_BUS_PATH,
> + AM335X_I2C2_BASE,
> + BBB_I2C2_IRQ
> #ifdef __cplusplus
> #endif /* __cplusplus */
> 2.7.4
> From 6855dbe659d67e304cf05474b2753b4239ceca90 Mon Sep 17 00:00:00 2001
> From: Sichen Zhao <1473996754 at qq.com>
> Date: Thu, 30 Mar 2017 11:08:32 +0800
> Subject: [PATCH 2/2] Beaglebone Black i2c code, modify by Sichen Zhao - Modify
> the bbb-i2c.c code, base on Punit Vara code - Modify the include/i2c.h, base
> on Punit Vara code I2C is working now, BBB can read the EEPROM by i2c The
> test suite code link: https://github.com/hahchenchen/rtems/tree/i2c_1.0/i2c0
> c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c | 370 ++++++++++++------------------
> c/src/lib/libbsp/arm/beagle/include/i2c.h | 11 +-
> 2 files changed, 150 insertions(+), 231 deletions(-)
> index cd1e9c1..4d22831 100644
> --- a/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
> @@ -21,80 +21,8 @@
> -static bool am335x_i2c_pinmux(bbb_i2c_bus *bus)
> - bool status =true;
> - // We will check i2c_bus_id in am335x_i2c_bus_register
> - // Apart from mode and pull_up register what about SCREWCTRL & RXACTIVE ??
> - if (bus->i2c_bus_id == I2C1) {
> - REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_CS0) = (BBB_MUXMODE(MODE2) | BBB_PU_EN);
> - REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_D1) = (BBB_MUXMODE(MODE2) | BBB_PU_EN);
> - REG(AM335X_PADCONF_BASE + AM335X_CONF_UART1_TXD) = (BBB_MUXMODE(MODE3) | BBB_PU_EN);
> - REG(AM335X_PADCONF_BASE + AM335X_CONF_UART1_RXD) = (BBB_MUXMODE(MODE3) | BBB_PU_EN);
> - } else if (bus->i2c_bus_id == I2C2) {
> - REG(AM335X_PADCONF_BASE + AM335X_CONF_UART1_RTSN) = (BBB_MUXMODE(MODE3) | BBB_PU_EN);
> - REG(AM335X_PADCONF_BASE + AM335X_CONF_UART1_CTSN) = (BBB_MUXMODE(MODE3) | BBB_PU_EN);
> - REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_D0) = (BBB_MUXMODE(MODE3) | BBB_PU_EN);
> - REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_SCLK) = (BBB_MUXMODE(MODE3) | BBB_PU_EN);
> - } else {
> - status = false;
> - return status;
> -/* ref. Table 21-4 I2C Clock Signals */
> - For I2C1/2
> - Interface clock - 100MHz - CORE_LKOUTM4 / 2 - pd_per_l4ls_gclk
> - Functional clock - 48MHz - PER_CLKOUTM2 / 4 - pd_per_ic2_fclk
> -static void am335x_i2c1_i2c2_module_clk_config(bbb_i2c_bus *bus)
> -/*0x2 = SW_WKUP : SW_WKUP: Start a software forced wake-up
> -transition on the domain. */
> - REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKSTCTRL) |=
> - AM335X_CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
> - while((REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKSTCTRL) &
> - AM335X_CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL) !=
> - AM335X_CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL_SW_WKUP);
> -/* 0x2 = ENABLE : Module is explicitly enabled. Interface clock (if not
> -used for functions) may be gated according to the clock domain
> -state. Functional clocks are guarantied to stay present. As long as in
> -this configuration, power domain sleep transition cannot happen.*/
> - /* REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKCTRL) |=
> - AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE;
> - while((REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKCTRL) &
> - AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE) != AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE);
> -/*0x2 = ENABLE : Module is explicitly enabled. Interface clock (if not
> - REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C1_CLKCTRL) |=
> - AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE_ENABLE;
> - while(REG((AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C1_CLKCTRL) &
> - AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE) != AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE_ENABLE);
> - REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C2_CLKCTRL) |=
> - AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE_ENABLE;
> - while(REG((AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C2_CLKCTRL) &
> - AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE) != AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE_ENABLE);
> - while(!(REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKSTCTRL) &
> - (AM335X_CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_L4LS_GCLK |
> - AM335X_CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_I2C_FCLK)));
> +static void flush_fifo(i2c_bus *base);
> @@ -295,43 +223,59 @@ static void I2C0ModuleClkConfig(void)
> -void am335x_i2c_init(bbb_i2c_bus *bus, uint32_t input_clock)
> - // am335x_i2c_pinmux()
> - // am335x_i2c1_i2c2_module_clk_config
> bool status;
> + int stat;
> + int timeout=I2C_TIMEOUT;
> - if (REG(®s->BBB_I2C_IRQSTATUS_RAW) & AM335X_I2C_IRQSTATUS_RAW_BB)
> + while ((stat = readw(®s->BBB_I2C_IRQSTATUS_RAW) &
> + AM335X_I2C_IRQSTATUS_RAW_BB) && timeout--) {
> + writew(stat, ®s->BBB_I2C_IRQSTATUS);
> + udelay(100);
> + if (timeout <= 0) {
> + printf("Timed out in wait_for_bb: status=%04x\n",
> + stat);
> + status = true;
> + else
> - status = true;
> - } else {
> - status = false;
> + writew(0xFFFF, ®s->BBB_I2C_IRQSTATUS); /* clear delayed stuff*/
> + status = false;
> return status;
> - printk("reset bus->reg is %x \n",bus->regs);
> - /* Disable I2C module at the time of initialization*/
> - /*Should I use write32 ?? I guess mmio_clear is correct choice here*/
> - printk("inside BBB_I2C_CON value is %x \n",®s->BBB_I2C_CON);
> - mmio_clear((®s->BBB_I2C_CON),AM335X_I2C_CON_I2C_EN);
> - mmio_clear((®s->BBB_I2C_SYSC),AM335X_I2C_SYSC_AUTOIDLE);
> - //REG(bus->regs + AM335X_I2C_CON) &= ~(AM335X_I2C_CON_I2C_EN);
> - //REG(bus->regs + AM335X_I2C_SYSC) &= ~(AM335X_I2C_SYSC_AUTOIDLE);
> - can I clear all the interrupt here ?
> - mmio_write(get_reg_addr(bbb_i2c_bus->reg->AM335X_I2C_IRQ_ENABLE_CLR), ??)
> + int timeout = I2C_TIMEOUT;
> + if (readw(®s->BBB_I2C_CON) & I2C_CON_EN) {
> + writew(0, ®s->BBB_I2C_CON);
> + udelay(50000);
> + writew(0x2, ®s->BBB_I2C_SYSC); /* for ES2 after soft reset */
> + udelay(1000);
> + writew(I2C_CON_EN, ®s->BBB_I2C_CON);
> + while (!(readw(®s->BBB_I2C_SYSS) & I2C_SYSS_RDONE) && timeout--) {
> + puts("ERROR: Timeout in soft-reset\n");
> + return;
> + udelay(1000);
> @@ -360,7 +304,7 @@ static void am335x_i2c_next_byte(bbb_i2c_bus *bus)
> i2c_msg *msg;
> - printk("Enter next_byte\n");
> ++bus->msgs;
> --bus->msg_todo;
> @@ -402,61 +346,26 @@ static void am335x_clean_interrupts(volatile bbb_i2c_regs *regs)
> - //am335x_i2c_masterint_enable(regs, AM335X_I2C_INT_RECV_READY);
> - // No of data to be transmitted at a time
> - REG(®s->BBB_I2C_CNT) = 0x02;
> - no_bytes = REG(®s->BBB_I2C_CNT);
> - // I2C Controller in Master Mode
> - REG(®s->BBB_I2C_CON) = AM335X_I2C_CFG_MST_TX | AM335X_I2C_CON_I2C_EN | AM335X_I2C_CON_START | AM335X_I2C_CON_MST;
> - printk("set master in transmission mode %x \n",REG(®s->BBB_I2C_CON));
> - // Set Slave address & Master enable, bring out of reset
> - REG(®s->BBB_I2C_SA) = msgs->addr;
> - printf("slave address : %x\n",REG(®s->BBB_I2C_SA));
> + int status;
> - // clear status of all interrupts
> - am335x_clean_interrupts(regs);
> - printk("\n set memory address to read\n");
> - // transmit interrupt is enabled
> - am335x_i2c_masterint_enable(regs,AM335X_I2C_IRQSTATUS_XRDY);
> - printk("Enable transmit interrupt \n");
> - //start condition
> - REG(®s->BBB_I2C_CON) |= AM335X_I2C_CON_START;
> - printk("start transmission \n");
> - while(am335x_i2c_busbusy(regs) == 0);
> - printk("bus is free \n");
> - printk("CNT : %x\n", no_bytes);
> - while(0 != no_bytes);
> - printk("total msg count for tranmission is zero \n");
> - while( !(am335x_i2c_intrawstatus(regs) & (AM335X_I2C_IRQSTATUS_ARDY)));
> + REG(®s->BBB_I2C_CNT) = bus->current_msg_todo;
> - printk("Enter read transfer \n");
> - // No of data to be received at a time(msg_count!!)
> - printk("msg_todo for read is %d \n",bus->msg_todo);
> - REG(®s->BBB_I2C_CNT) = bus->msg_todo;
> - //am335x_clean_interrupts(regs);
> - printk("Set master to receiver mode %x \n", REG(®s->BBB_I2C_CON));
> if (send_stop) {
> // stop condition
> - printk("stop to read\n");
> } else {
> // start condition
> - printk("start to read\n");
> - printk("Exit read transfer\n");
> @@ -465,85 +374,63 @@ static void am335x_i2c_continue_read_transfer(
> - printk("enter continue read transfer \n");
> - printk("clear RRDY in continue read transfer\n");
> - printk("continue read transfer finished \n");
> - //am335x_i2c_setup_read_transfer(bus,regs,false);
> - printk("disable RRDY in continue read transfer\n");
> - printk("stop condition in continue read transfer %x\n",REG(®s->BBB_I2C_CON));
> - REG(®s->BBB_I2C_DATA) = 0x00;
> - am335x_int_clear(regs, AM335X_I2C_IRQSTATUS_XRDY);
> - printk("clear XRDY continue write\n");
> - if (bus->already_transferred == REG(®s->BBB_I2C_CNT)) {
> - printk("\n finished transfer \n");
> - am335x_i2c_masterint_disable(regs, AM335X_I2C_IRQSTATUS_XRDY);
> - printk("disable XRDY continue write \n");
> - REG(®s->BBB_I2C_CON) |= AM335X_I2C_CON_STOP;
> - } else {
> - printk("write memory address \n");
> - REG(®s->BBB_I2C_DATA) = *bus->current_msg_byte;
> - if (bus->already_transferred == bus->msg_todo) {
> - printk("finished transfer \n");
> - } else {
> - printk("remaining byte \n");
> - REG(®s->BBB_I2C_DATA) = bus->current_msg_byte[bus->already_transferred];
> - printk("%s",REG(®s->BBB_I2C_DATA));
> - bus->already_transferred++;
> + writeb(0x0,®s->BBB_I2C_DATA);
> + writew(AM335X_I2C_IRQSTATUS_XRDY, ®s->BBB_I2C_IRQSTATUS);
> -static void am335x_i2c_setup_write_transfer(bbb_i2c_bus *bus,volatile bbb_i2c_regs *regs)
> +static void am335x_i2c_setup_write_transfer(bbb_i2c_bus *bus,volatile bbb_i2c_regs *regs, const i2c_msg *msgs)
> - printk(" \n Enter write transfer \n");
> - // Already cleaned during reset
> - printk("enable master in transmiter mode setup write %x\n",REG(®s->BBB_I2C_CON));
> - printk("enable XRDY setup write\n");
> + am335x_i2c_masterint_enable(regs,AM335X_I2C_IRQSTATUS_XRDY );
> //start condition
> - printk("set start condition in setup write %x \n",REG(®s->BBB_I2C_CON));
> - printk("CNT in setup write : %x \n",REG(®s->BBB_I2C_CNT));
> - printk("setup write msg_todo %x \n",bus->current_todo);
> - printk("check whether ???\n");
> - printk("RAW = %x",REG(®s->BBB_I2C_IRQSTATUS_RAW));
> + while(am335x_i2c_busbusy(regs)==0);
> - printk("exit setup write \n");
> @@ -554,9 +441,7 @@ static void am335x_i2c_setup_transfer(bbb_i2c_bus *bus, volatile bbb_i2c_regs *r
> uint32_t i;
> - printk("Enter setup transfer\n");
> @@ -566,18 +451,22 @@ static void am335x_i2c_setup_transfer(bbb_i2c_bus *bus, volatile bbb_i2c_regs *r
> - bus->read = ((bus->read == true) ? 0:1);
> + bus->read = (msgs->flags & I2C_M_RD) != 0;
> if (bus->read) {
> send_stop = true;
> - printk("configure to read bus\n");
> } else {
> - printk("configure to write bus\n");
> - am335x_i2c_setup_write_transfer(bus,regs);
> + am335x_i2c_setup_write_transfer(bus,regs,msgs);
> @@ -589,42 +478,45 @@ static void am335x_i2c_interrupt(void *arg)
> bool done = false;
> - printk("\n inside interrupt function \n");
> - REG(®s->BBB_I2C_IRQSTATUS) = (irqstatus & ~(AM335X_I2C_IRQSTATUS_RRDY | AM335X_I2C_IRQSTATUS_XRDY));
> - printk("\n irqstatus = %x \n",REG(®s->BBB_I2C_IRQSTATUS));
> + REG(®s->BBB_I2C_IRQSTATUS) = (irqstatus & ~( AM335X_I2C_IRQSTATUS_RRDY | AM335X_I2C_IRQSTATUS_XRDY));
> - printk("\nInside receive interrupt\n");
> + delay_bbb_i2c
> - printk("\ninside transmit interrupt \n");
> done = true;
> - printk("inside NACK\n");
> + if (irqstatus & AM335X_I2C_IRQSTATUS_ARDY) {
> + done = true;
> + writew(I2C_STAT_ARDY, ®s->BBB_I2C_IRQSTATUS);
> done = true;
> - printk("inside BF \n ");
> if (done) {
> - printk("interrupt done \n");
> - if (bus->msg_todo == 0 || err != 0) {
> + if (bus->msg_todo == 0 ) {
> - // am335x_i2c_disable_interrupts(regs);
> @@ -633,6 +525,7 @@ static void am335x_i2c_interrupt(void *arg)
> (void) sc;
> } else {
> @@ -644,7 +537,6 @@ static int am335x_i2c_transfer(i2c_bus *base, i2c_msg *msgs, uint32_t msg_count)
> uint32_t i;
> - printk("\n enter transfer ");
> @@ -660,11 +552,11 @@ static int am335x_i2c_transfer(i2c_bus *base, i2c_msg *msgs, uint32_t msg_count)
> - printk("total msg = msg_count : %x \n",bus->msg_todo);
> - printk("\n current_msg_todo %x \n ",msgs[0].len);
> - printk("\n current_msg_byte %x \n ",msgs[0].buf);
> regs = bus->regs;
> @@ -680,8 +572,6 @@ static int am335x_i2c_transfer(i2c_bus *base, i2c_msg *msgs, uint32_t msg_count)
> return -ETIMEDOUT;
> - printk("exit transfer\n");
> - // return bus->regs->BBB_I2C_IRQSTATUS == 0 ? 0 : -EIO;
> return 0;
> @@ -691,21 +581,17 @@ static int am335x_i2c_set_clock(i2c_bus *base, unsigned long clock)
> - printk("set clock start\n");
> - printk("PSC offset %x \n ",®s->BBB_I2C_PSC);
> - printk("PSC offset %x \n", &bus->regs->BBB_I2C_PSC);
> - //mmio_write((®s->BBB_I2C_PSC), prescaler);
> - printk("SCLL offset %x \n",&bus->regs->BBB_I2C_SCLL);
> - //mmio_write((®s->BBB_I2C_SCLL), (divider - 7));
> - //mmio_write((®s->BBB_I2C_SCLH), (divider - 5));
> - printk("SCHL offset %x\n",&bus->regs->BBB_I2C_SCLH);
> - printk("set clock end \n");
> return 0;
> @@ -713,11 +599,11 @@ static void am335x_i2c_destroy(i2c_bus *base)
> - printk(" starting destroy\n");
> (void)sc;
> - printk("end destroy\n");
> @@ -751,7 +637,7 @@ int am335x_i2c_bus_register(
> - printk("Before set clock \n");
> if (err != 0) {
> @@ -763,7 +649,11 @@ int am335x_i2c_bus_register(
> - REG(&bus->regs->BBB_I2C_CON) |= AM335X_I2C_CON_I2C_EN;
> + udelay(1000);
> + flush_fifo(&bus->base);
> + writew(0xFFFF, &bus->regs->BBB_I2C_IRQSTATUS);
> @@ -783,6 +673,30 @@ int am335x_i2c_bus_register(
> - printk("exit register\n");
> + int stat;
> + * note: if you try and read data when its not there or ready
> + * you get a bus error
> + while (1) {
> + stat = readw(&bus->regs->BBB_I2C_IRQSTATUS);
> + if (stat == I2C_STAT_RRDY) {
> + readb(&bus->regs->BBB_I2C_DATA);
> + writew(I2C_STAT_RRDY, &bus->regs->BBB_I2C_IRQSTATUS);
> + udelay(1000);
> + } else
> + break;
> index d4a9e32..a4fcf21 100644
> @@ -132,11 +132,11 @@ extern "C" {
> #define DISP_LINE_LEN 128
> -#define I2C_TIMEOUT 1000
> +#define I2C_TIMEOUT 500
> #define I2C_BUS_MAX 3
> -#define I2C_BASE1 (OMAP34XX_CORE_L4_IO_BASE + 0x070000)
> +#define I2C_BASE1 (OMAP34XX_CORE_L4_IO_BASE + 0x070000) //0x48000000+0x070000
> #define I2C_DEFAULT_BASE I2C_BASE1
> @@ -356,7 +356,7 @@ static inline rtems_status_code beagle_i2c_read(
> - | AM335X_I2C_IRQSTATUS_XUDF)
> + | AM335X_I2C_IRQSTATUS_XUDF )
> @@ -378,6 +378,8 @@ static inline rtems_status_code beagle_i2c_read(
> #define MODE2 2
> #define MODE3 3
> +#define delay_bbb_i2c printf(" ");
> typedef enum {
> I2C0,
> I2C1,
> @@ -478,6 +480,9 @@ static inline int bbb_register_i2c_2(void)
> #ifdef __cplusplus
> 2.7.4
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170331/5898ddb7/attachment-0001.html>
