bsp sorting for acinclude.m4 (was: ampolish3 sorting issues (again))
Joel Sherrill
joel at rtems.org
Fri Mar 31 02:49:46 UTC 2017
Sorry to top post. I am usually on CentOS 7 or whatever rtbf64c is running
which is also CentOS 7 I think. I am not in a position to check that this
evening.
What do we need to check to narrow down the difference?
On Mar 30, 2017 7:15 PM, "Chris Johns" <chrisj at rtems.org> wrote:
> On 31/03/2017 09:24, Chris Johns wrote:
>> I am getting this on master (4.12) after a bootstrap on FreeBSD 11.0 so
>> I am wondering if perl has changed something which effects us.
> It is not perl or ampolish3 related so the subject has changed.
> It is looking like a mismatch between a command line sort on some hosts
> and python's sorted where the sb-bootstrap command is being run.
> I have run the sb-bootstrap and the bootstrap script on FreeBSD 11.0 and I
> get the same results.
>> Anyone else seeing this?
> Joel and Kevin?
> What hosts and what commands did you use to create these patches?
> It looks like the python based sb-bootstrap is doing a case sensitive sort
> while some hosts are doing a case insensitive sort.
> On FreeBSD 11.0 and 10.3 I get:
> $ echo "bf537Stamp/bsp_specs
> > TLL6527M/bsp_specs
> > eZKit533/bsp_specs" | sort
> TLL6527M/bsp_specs
> eZKit533/bsp_specs
> $ python
> Python 2.7.13 (default, Jan 12 2017, 01:19:30)
> [GCC 4.2.1 Compatible FreeBSD Clang 3.8.0 (tags/RELEASE_380/final 262564)]
> on freebsd11
> Type "help", "copyright", "credits" or "license" for more information.
> >>> b=['bf537Stamp/bsp_specs', 'TLL6527M/bsp_specs', 'eZKit533/bsp_specs']
> >>> sorted(b)
> ['TLL6527M/bsp_specs', 'bf537Stamp/bsp_specs', 'eZKit533/bsp_specs']
> These results show the sort and python match.
> I have looked into POSIX and sort and the sort order defaults are locale
> related and the bootstrap script forces C so there looks like a difference
> between FreeBSD and your hosts in what the defaults are.
> I do not want to push a change if conflicts with other hosts.
> Unless I hear back I think a patch to revert the acinclude.m4 change is ok.
>> ruru rtems.git $ git diff
>> diff --git a/c/src/lib/libbsp/bfin/acinclude.m4
>> b/c/src/lib/libbsp/bfin/acinclude.m4
>> index 828fd894dd..ab6082ef47 100644
>> --- a/c/src/lib/libbsp/bfin/acinclude.m4
>> +++ b/c/src/lib/libbsp/bfin/acinclude.m4
>> @@ -2,12 +2,12 @@
>> AC_DEFUN([RTEMS_CHECK_BSPDIR],
>> case "$1" in
>> + TLL6527M )
>> + AC_CONFIG_SUBDIRS([TLL6527M]);;
>> bf537Stamp )
>> AC_CONFIG_SUBDIRS([bf537Stamp]);;
>> eZKit533 )
>> AC_CONFIG_SUBDIRS([eZKit533]);;
>> - TLL6527M )
>> - AC_CONFIG_SUBDIRS([TLL6527M]);;
>> AC_MSG_ERROR([Invalid BSP]);;
>> esac
> This change is hidden in the mega patch to remove texinfo ..
> https://git.rtems.org/rtems/commit/?id=48a7fa31f918a6fc88719
> b3c9393a9ba2829f42a
> diff --git a/c/src/lib/libbsp/powerpc/acinclude.m4
>> b/c/src/lib/libbsp/powerpc/acinclude.m4
>> index edc67b5414..4c83475dd8 100644
>> --- a/c/src/lib/libbsp/powerpc/acinclude.m4
>> +++ b/c/src/lib/libbsp/powerpc/acinclude.m4
>> @@ -32,12 +32,12 @@ AC_DEFUN([RTEMS_CHECK_BSPDIR],
>> AC_CONFIG_SUBDIRS([t32mppc]);;
>> tqm8xx )
>> AC_CONFIG_SUBDIRS([tqm8xx]);;
>> + virtex )
>> + AC_CONFIG_SUBDIRS([virtex]);;
>> virtex4 )
>> AC_CONFIG_SUBDIRS([virtex4]);;
>> virtex5 )
>> AC_CONFIG_SUBDIRS([virtex5]);;
>> - virtex )
>> - AC_CONFIG_SUBDIRS([virtex]);;
>> esac
> And in this patch from Kevin ...
> https://git.rtems.org/rtems/commit/?id=1c6926c11f2e5efcb166c
> 668b097d64a0321d66e
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170330/dd944e0b/attachment.html>
