bsp sorting for acinclude.m4
Fri Mar 31 02:56:27 UTC 2017
On 31/03/2017 13:49, Joel Sherrill wrote:
> Sorry to top post. I am usually on CentOS​ 7 or whatever rtbf64c is
> running which is also CentOS 7 I think. I am not in a position to check
> that this evening.
> What do we need to check to narrow down the difference?
The commands to test with are in this email. Please try them and post
back the results.
Thanks
> On Mar 30, 2017 7:15 PM, "Chris Johns" <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
>     On 31/03/2017 09:24, Chris Johns wrote:
>         I am getting this on master (4.12) after a bootstrap on FreeBSD
>         11.0 so
>         I am wondering if perl has changed something which effects us.
>     It is not perl or ampolish3 related so the subject has changed.
>     It is looking like a mismatch between a command line sort on some
>     hosts and python's sorted where the sb-bootstrap command is being run.
>     I have run the sb-bootstrap and the bootstrap script on FreeBSD 11.0
>     and I get the same results.
>         Anyone else seeing this?
>     Joel and Kevin?
>     What hosts and what commands did you use to create these patches?
>     It looks like the python based sb-bootstrap is doing a case
>     sensitive sort while some hosts are doing a case insensitive sort.
>     On FreeBSD 11.0 and 10.3 I get:
>     $ echo "bf537Stamp/bsp_specs
>     > TLL6527M/bsp_specs
>     > eZKit533/bsp_specs" | sort
>     TLL6527M/bsp_specs
>     eZKit533/bsp_specs
>     $ python
>     Python 2.7.13 (default, Jan 12 2017, 01:19:30)
>     [GCC 4.2.1 Compatible FreeBSD Clang 3.8.0 (tags/RELEASE_380/final
>     262564)] on freebsd11
>     Type "help", "copyright", "credits" or "license" for more information.
>     >>> b=['bf537Stamp/bsp_specs', 'TLL6527M/bsp_specs',
>     'eZKit533/bsp_specs']
>     >>> sorted(b)
>     ['TLL6527M/bsp_specs', 'bf537Stamp/bsp_specs', 'eZKit533/bsp_specs']
>     These results show the sort and python match.
>     I have looked into POSIX and sort and the sort order defaults are
>     locale related and the bootstrap script forces C so there looks like
>     a difference between FreeBSD and your hosts in what the defaults are.
>         I do not want to push a change if conflicts with other hosts.
>     Unless I hear back I think a patch to revert the acinclude.m4 change
>     is ok.
>         ruru rtems.git $ git diff
>         diff --git a/c/src/lib/libbsp/bfin/acinclude.m4
>         b/c/src/lib/libbsp/bfin/acinclude.m4
>         index 828fd894dd..ab6082ef47 100644
>         --- a/c/src/lib/libbsp/bfin/acinclude.m4
>         +++ b/c/src/lib/libbsp/bfin/acinclude.m4
>         @@ -2,12 +2,12 @@
>          AC_DEFUN([RTEMS_CHECK_BSPDIR],
>            case "$1" in
>         +  TLL6527M )
>         +    AC_CONFIG_SUBDIRS([TLL6527M]);;
>            bf537Stamp )
>              AC_CONFIG_SUBDIRS([bf537Stamp]);;
>            eZKit533 )
>              AC_CONFIG_SUBDIRS([eZKit533]);;
>         -  TLL6527M )
>         -    AC_CONFIG_SUBDIRS([TLL6527M]);;
>              AC_MSG_ERROR([Invalid BSP]);;
>            esac
>     This change is hidden in the mega patch to remove texinfo ..
>     https://git.rtems.org/rtems/commit/?id=48a7fa31f918a6fc88719b3c9393a9ba2829f42a
>     <https://git.rtems.org/rtems/commit/?id=48a7fa31f918a6fc88719b3c9393a9ba2829f42a>
>         diff --git a/c/src/lib/libbsp/powerpc/acinclude.m4
>         b/c/src/lib/libbsp/powerpc/acinclude.m4
>         index edc67b5414..4c83475dd8 100644
>         --- a/c/src/lib/libbsp/powerpc/acinclude.m4
>         +++ b/c/src/lib/libbsp/powerpc/acinclude.m4
>         @@ -32,12 +32,12 @@ AC_DEFUN([RTEMS_CHECK_BSPDIR],
>              AC_CONFIG_SUBDIRS([t32mppc]);;
>            tqm8xx )
>              AC_CONFIG_SUBDIRS([tqm8xx]);;
>         +  virtex )
>         +    AC_CONFIG_SUBDIRS([virtex]);;
>            virtex4 )
>              AC_CONFIG_SUBDIRS([virtex4]);;
>            virtex5 )
>              AC_CONFIG_SUBDIRS([virtex5]);;
>         -  virtex )
>         -    AC_CONFIG_SUBDIRS([virtex]);;
>            esac
>     And in this patch from Kevin ...
>     https://git.rtems.org/rtems/commit/?id=1c6926c11f2e5efcb166c668b097d64a0321d66e
>     <https://git.rtems.org/rtems/commit/?id=1c6926c11f2e5efcb166c668b097d64a0321d66e>
>     Chris
