bsp sorting for acinclude.m4
Fri Mar 31 19:38:35 UTC 2017
On Thu, Mar 30, 2017 at 10:56 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 31/03/2017 13:49, Joel Sherrill wrote:
>> Sorry to top post. I am usually on CentOS 7 or whatever rtbf64c is
>> running which is also CentOS 7 I think. I am not in a position to check
>> that this evening.
>> What do we need to check to narrow down the difference?
> The commands to test with are in this email. Please try them and post back
> the results.
> Thanks
> Chris
>> On Mar 30, 2017 7:15 PM, "Chris Johns" <chrisj at rtems.org
>> <mailto:chrisj at rtems.org>> wrote:
>>     On 31/03/2017 09:24, Chris Johns wrote:
>>         I am getting this on master (4.12) after a bootstrap on FreeBSD
>>         11.0 so
>>         I am wondering if perl has changed something which effects us.
>>     It is not perl or ampolish3 related so the subject has changed.
>>     It is looking like a mismatch between a command line sort on some
>>     hosts and python's sorted where the sb-bootstrap command is being run.
>>     I have run the sb-bootstrap and the bootstrap script on FreeBSD 11.0
>>     and I get the same results.
>>         Anyone else seeing this?
>>     Joel and Kevin?
>>     What hosts and what commands did you use to create these patches?
>>     It looks like the python based sb-bootstrap is doing a case
>>     sensitive sort while some hosts are doing a case insensitive sort.
>>     On FreeBSD 11.0 and 10.3 I get:
>>     $ echo "bf537Stamp/bsp_specs
>>     > TLL6527M/bsp_specs
>>     > eZKit533/bsp_specs" | sort
>>     TLL6527M/bsp_specs
>>     eZKit533/bsp_specs
> TLL6527M/bsp_specs
eZKit533/bsp_specs
TLL6527M/bsp_specs
>>     $ python
>>     Python 2.7.13 (default, Jan 12 2017, 01:19:30)
>>     [GCC 4.2.1 Compatible FreeBSD Clang 3.8.0 (tags/RELEASE_380/final
>>     262564)] on freebsd11
>>     Type "help", "copyright", "credits" or "license" for more information.
>>     >>> b=['bf537Stamp/bsp_specs', 'TLL6527M/bsp_specs',
>>     'eZKit533/bsp_specs']
>>     >>> sorted(b)
>>     ['TLL6527M/bsp_specs', 'bf537Stamp/bsp_specs', 'eZKit533/bsp_specs']
>>> sorted(b)
My python and sort don't agree (on Ubuntu 16.04).
>>     These results show the sort and python match.
>>     I have looked into POSIX and sort and the sort order defaults are
>>     locale related and the bootstrap script forces C so there looks like
>>     a difference between FreeBSD and your hosts in what the defaults are.
>>         I do not want to push a change if conflicts with other hosts.
>>     Unless I hear back I think a patch to revert the acinclude.m4 change
>>     is ok.
Yes, we should prefer to use the output from sb-bootstrap as it is
more consistent across hosts. And be diligent about not pushing
patches that make these changes.
>>         ruru rtems.git $ git diff
>>         diff --git a/c/src/lib/libbsp/bfin/acinclude.m4
>>         b/c/src/lib/libbsp/bfin/acinclude.m4
>>         index 828fd894dd..ab6082ef47 100644
>>         --- a/c/src/lib/libbsp/bfin/acinclude.m4
>>         +++ b/c/src/lib/libbsp/bfin/acinclude.m4
>>         @@ -2,12 +2,12 @@
>>          AC_DEFUN([RTEMS_CHECK_BSPDIR],
>>            case "$1" in
>>         +  TLL6527M )
>>         +    AC_CONFIG_SUBDIRS([TLL6527M]);;
>>            bf537Stamp )
>>              AC_CONFIG_SUBDIRS([bf537Stamp]);;
>>            eZKit533 )
>>              AC_CONFIG_SUBDIRS([eZKit533]);;
>>         -  TLL6527M )
>>         -    AC_CONFIG_SUBDIRS([TLL6527M]);;
>>              AC_MSG_ERROR([Invalid BSP]);;
>>            esac
>>     This change is hidden in the mega patch to remove texinfo ..
>> https://git.rtems.org/rtems/commit/?id=48a7fa31f918a6fc88719b3c9393a9ba2829f42a
>> <https://git.rtems.org/rtems/commit/?id=48a7fa31f918a6fc88719b3c9393a9ba2829f42a>
>>         diff --git a/c/src/lib/libbsp/powerpc/acinclude.m4
>>         b/c/src/lib/libbsp/powerpc/acinclude.m4
>>         index edc67b5414..4c83475dd8 100644
>>         --- a/c/src/lib/libbsp/powerpc/acinclude.m4
>>         +++ b/c/src/lib/libbsp/powerpc/acinclude.m4
>>         @@ -32,12 +32,12 @@ AC_DEFUN([RTEMS_CHECK_BSPDIR],
>>              AC_CONFIG_SUBDIRS([t32mppc]);;
>>            tqm8xx )
>>              AC_CONFIG_SUBDIRS([tqm8xx]);;
>>         +  virtex )
>>         +    AC_CONFIG_SUBDIRS([virtex]);;
>>            virtex4 )
>>              AC_CONFIG_SUBDIRS([virtex4]);;
>>            virtex5 )
>>              AC_CONFIG_SUBDIRS([virtex5]);;
>>         -  virtex )
>>         -    AC_CONFIG_SUBDIRS([virtex]);;
>>            esac
>>     And in this patch from Kevin ...
>> https://git.rtems.org/rtems/commit/?id=1c6926c11f2e5efcb166c668b097d64a0321d66e
>> <https://git.rtems.org/rtems/commit/?id=1c6926c11f2e5efcb166c668b097d64a0321d66e>
>>     Chris
> devel mailing list
> devel at rtems.org
