bsp sorting for acinclude.m4
Fri Mar 31 19:54:17 UTC 2017
Chris,
If you approve, please commit my patch and also revert/commit the
acinclude.m4 changes.
On Fri, Mar 31, 2017 at 3:41 PM, Gedare Bloom <gedare at rtems.org> wrote:
> On Fri, Mar 31, 2017 at 3:38 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> On Thu, Mar 30, 2017 at 10:56 PM, Chris Johns <chrisj at rtems.org> wrote:
>>> On 31/03/2017 13:49, Joel Sherrill wrote:
>>>> Sorry to top post. I am usually on CentOS 7 or whatever rtbf64c is
>>>> running which is also CentOS 7 I think. I am not in a position to check
>>>> that this evening.
>>>> What do we need to check to narrow down the difference?
>>> The commands to test with are in this email. Please try them and post back
>>> the results.
>>> Thanks
>>> Chris
>>>> On Mar 30, 2017 7:15 PM, "Chris Johns" <chrisj at rtems.org
>>>> <mailto:chrisj at rtems.org>> wrote:
>>>>     On 31/03/2017 09:24, Chris Johns wrote:
>>>>         I am getting this on master (4.12) after a bootstrap on FreeBSD
>>>>         11.0 so
>>>>         I am wondering if perl has changed something which effects us.
>>>>     It is not perl or ampolish3 related so the subject has changed.
>>>>     It is looking like a mismatch between a command line sort on some
>>>>     hosts and python's sorted where the sb-bootstrap command is being run.
>>>>     I have run the sb-bootstrap and the bootstrap script on FreeBSD 11.0
>>>>     and I get the same results.
>>>>         Anyone else seeing this?
>>>>     Joel and Kevin?
>>>>     What hosts and what commands did you use to create these patches?
>>>>     It looks like the python based sb-bootstrap is doing a case
>>>>     sensitive sort while some hosts are doing a case insensitive sort.
>>>>     On FreeBSD 11.0 and 10.3 I get:
>>>>     $ echo "bf537Stamp/bsp_specs
>>>>     > TLL6527M/bsp_specs
>>>>     > eZKit533/bsp_specs" | sort
>>>>     TLL6527M/bsp_specs
>>>>     eZKit533/bsp_specs
>>> TLL6527M/bsp_specs
>> eZKit533/bsp_specs
>> TLL6527M/bsp_specs
> I found this out:
>  TLL6527M/bsp_specs
>  eZKit533/bsp_specs" | LC_ALL=C sort
>  TLL6527M/bsp_specs
>  eZKit533/bsp_specs
> So we can also tweak the bootstrap script to be more consistent. Patch
> forthcoming.
>>>>     $ python
>>>>     Python 2.7.13 (default, Jan 12 2017, 01:19:30)
>>>>     [GCC 4.2.1 Compatible FreeBSD Clang 3.8.0 (tags/RELEASE_380/final
>>>>     262564)] on freebsd11
>>>>     Type "help", "copyright", "credits" or "license" for more information.
>>>>     >>> b=['bf537Stamp/bsp_specs', 'TLL6527M/bsp_specs',
>>>>     'eZKit533/bsp_specs']
>>>>     >>> sorted(b)
>>>>     ['TLL6527M/bsp_specs', 'bf537Stamp/bsp_specs', 'eZKit533/bsp_specs']
>>>>> sorted(b)
>> My python and sort don't agree (on Ubuntu 16.04).
>>>>     These results show the sort and python match.
>>>>     I have looked into POSIX and sort and the sort order defaults are
>>>>     locale related and the bootstrap script forces C so there looks like
>>>>     a difference between FreeBSD and your hosts in what the defaults are.
>>>>         I do not want to push a change if conflicts with other hosts.
>>>>     Unless I hear back I think a patch to revert the acinclude.m4 change
>>>>     is ok.
>> Yes, we should prefer to use the output from sb-bootstrap as it is
>> more consistent across hosts. And be diligent about not pushing
>> patches that make these changes.
>>>>         ruru rtems.git $ git diff
>>>>         diff --git a/c/src/lib/libbsp/bfin/acinclude.m4
>>>>         b/c/src/lib/libbsp/bfin/acinclude.m4
>>>>         index 828fd894dd..ab6082ef47 100644
>>>>         --- a/c/src/lib/libbsp/bfin/acinclude.m4
>>>>         +++ b/c/src/lib/libbsp/bfin/acinclude.m4
>>>>         @@ -2,12 +2,12 @@
>>>>          AC_DEFUN([RTEMS_CHECK_BSPDIR],
>>>>            case "$1" in
>>>>         +  TLL6527M )
>>>>         +    AC_CONFIG_SUBDIRS([TLL6527M]);;
>>>>            bf537Stamp )
>>>>              AC_CONFIG_SUBDIRS([bf537Stamp]);;
>>>>            eZKit533 )
>>>>              AC_CONFIG_SUBDIRS([eZKit533]);;
>>>>         -  TLL6527M )
>>>>         -    AC_CONFIG_SUBDIRS([TLL6527M]);;
>>>>              AC_MSG_ERROR([Invalid BSP]);;
>>>>            esac
>>>>     This change is hidden in the mega patch to remove texinfo ..
>>>> https://git.rtems.org/rtems/commit/?id=48a7fa31f918a6fc88719b3c9393a9ba2829f42a
>>>> <https://git.rtems.org/rtems/commit/?id=48a7fa31f918a6fc88719b3c9393a9ba2829f42a>
>>>>         diff --git a/c/src/lib/libbsp/powerpc/acinclude.m4
>>>>         b/c/src/lib/libbsp/powerpc/acinclude.m4
>>>>         index edc67b5414..4c83475dd8 100644
>>>>         --- a/c/src/lib/libbsp/powerpc/acinclude.m4
>>>>         +++ b/c/src/lib/libbsp/powerpc/acinclude.m4
>>>>         @@ -32,12 +32,12 @@ AC_DEFUN([RTEMS_CHECK_BSPDIR],
>>>>              AC_CONFIG_SUBDIRS([t32mppc]);;
>>>>            tqm8xx )
>>>>              AC_CONFIG_SUBDIRS([tqm8xx]);;
>>>>         +  virtex )
>>>>         +    AC_CONFIG_SUBDIRS([virtex]);;
>>>>            virtex4 )
>>>>              AC_CONFIG_SUBDIRS([virtex4]);;
>>>>            virtex5 )
>>>>              AC_CONFIG_SUBDIRS([virtex5]);;
>>>>         -  virtex )
>>>>         -    AC_CONFIG_SUBDIRS([virtex]);;
>>>>            esac
>>>>     And in this patch from Kevin ...
>>>> https://git.rtems.org/rtems/commit/?id=1c6926c11f2e5efcb166c668b097d64a0321d66e
>>>> <https://git.rtems.org/rtems/commit/?id=1c6926c11f2e5efcb166c668b097d64a0321d66e>
>>>>     Chris
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
