[PATCH] modify punitvara's works on BBB i2c, and now can read the eeprom info.
Tue Mar 14 16:37:57 UTC 2017
We eventually need all of the combined patches at once in order to
merge. If this is functionally working, then it is time to focus on
cleaning up.
It would be good to separate the testsuite change from the others. I'm
not sure the testsuite is mergeable.
It would also be best to separate the eeprom.c change from the others,
since it is modifying more shared code and should be reviewed/merged
separately from the BB changes.
I have a few comments for you to improve below.
On Tue, Mar 14, 2017 at 10:05 AM, Sichen Zhao <1473996754 at qq.com> wrote:
>  c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c | 684 ++++++++++++++++++++++++++++--
>  c/src/lib/libbsp/arm/beagle/include/i2c.h |  18 +-
>  cpukit/dev/i2c/eeprom.c                   |  24 +-
>  testsuites/samples/i2c0/init.c            |  98 ++++-
>  4 files changed, 777 insertions(+), 47 deletions(-)
> diff --git a/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c b/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
> index 6b790e5..6a22125 100644
> --- a/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
> +++ b/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
> @@ -21,11 +21,23 @@
>  #include <bsp/bbb-gpio.h>
>  #include <rtems/score/assert.h>
> +#define u16 unsigned int
If this is just for your convenience, prefer to use the standard and
available uint16_t instead. Is there an advantage to use the 16 bit
versus 32 bit? (As you have it, the u16 is going to be 32 bit.)
> +static int am335x_i2c_set_clock(i2c_bus *base, unsigned long clock);
> +static void omap24_i2c_init(i2c_bus *base);
> +static void flush_fifo(i2c_bus *base);
> +static int wait_for_bb(i2c_bus *base);
> +static int omap24_i2c_probe(i2c_bus *base);
> +static u16 wait_for_event(i2c_bus *base);
> +static int am335x_i2c_read(i2c_bus *base, unsigned char chip, uint addr, int alen, unsigned char *buffer,
> +                           int len);
> +static int read_eeprom(i2c_bus *base,struct am335x_baseboard_id *header);
> +static int am335x_i2c_write(i2c_bus *base, unsigned char chip, uint addr,int alen, unsigned char *buffer,
> +                            int len);
Eventually need to remove/fix the commented-out code.
>  static bool am335x_i2c_pinmux(bbb_i2c_bus *bus)
>    bool status =true;
>      // We will check i2c_bus_id in am335x_i2c_bus_register
>      // Apart from mode and pull_up register what about SCREWCTRL & RXACTIVE ??
>    if (bus->i2c_bus_id == I2C1) {
> @@ -48,9 +60,7 @@ static bool am335x_i2c_pinmux(bbb_i2c_bus *bus)
>  /* ref. Table 21-4 I2C Clock Signals */
>   For I2C1/2
>   Interface clock - 100MHz - CORE_LKOUTM4 / 2 - pd_per_l4ls_gclk
>   Functional clock - 48MHz - PER_CLKOUTM2 / 4 - pd_per_ic2_fclk
> @@ -74,7 +84,6 @@ state. Functional clocks are guarantied to stay present. As long as in
>  this configuration, power domain sleep transition cannot happen.*/
>   /* REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKCTRL) |=
>                          AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE;
>    while((REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKCTRL) &
>        AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE) != AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE);
> @@ -86,30 +95,29 @@ this configuration, power domain sleep transition cannot happen.*/
>    REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C1_CLKCTRL) |=
>                               AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE_ENABLE;
>    while(REG((AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C1_CLKCTRL) &
>       AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE) != AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE_ENABLE);
>    } else if (bus->i2c_bus_id == I2C2) {
>    REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C2_CLKCTRL) |=
>                               AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE_ENABLE;
>    while(REG((AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C2_CLKCTRL) &
>       AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE) != AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE_ENABLE);
>    while(!(REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKSTCTRL) &
>             (AM335X_CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_L4LS_GCLK |
>              AM335X_CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_I2C_FCLK)));
>  static void am335x_i2c0_pinmux(bbb_i2c_bus *bus)
> -  REG(bus->regs + AM335X_CONF_I2C0_SDA) =
> +  printf("0x44e10000 + AM335X_CONF_I2C0_SDA:%x\n",0x44e10000 + AM335X_CONF_I2C0_SDA);
This line exceeds 80 char. Please have a read through
https://devel.rtems.org/wiki/Developer/Coding/Conventions
debug prints should be wrapped in an ifdef controlled by a define flag
either at the top of the file (preferred, to localize debug output) or
from RTEMS_DEBUG.
> +  printf("bus->regs:%x\n", bus->regs);
> +  REG(0x44e10000 + AM335X_CONF_I2C0_SDA) =
Replacing a variable with a hard-coded value (here, 0x44e10000) is not
good for maintainability or readability. Please provide/use a proper
variable or macro.
>    (BBB_RXACTIVE | BBB_SLEWCTRL | BBB_PU_EN);
> -  REG(bus->regs + AM335X_CONF_I2C0_SCL) =
> +  REG(0x44e10000 + AM335X_CONF_I2C0_SCL) =
> @@ -314,14 +322,29 @@ void am335x_i2c_init(bbb_i2c_bus *bus, uint32_t input_clock)
>  static bool am335x_i2c_busbusy(volatile bbb_i2c_regs *regs)
>    bool status;
> -  if (REG(&regs->BBB_I2C_IRQSTATUS_RAW) & AM335X_I2C_IRQSTATUS_RAW_BB)
> +  unsigned short stat;
> +  int timeout = I2C_TIMEOUT;
> +  REG(&regs->BBB_I2C_IRQSTATUS)=0xffff;
> +  printf("REG(&regs->BBB_I2C_IRQSTATUS_RAW):%x\n",REG(&regs->BBB_I2C_IRQSTATUS_RAW) );
> + // printf("%x\n",0x1400 & 0x1000 );
Avoid including commented-out lines. This one can probably just be deleted.
> + printf("REG(&regs->BBB_I2C_IRQSTATUS_RAW) & AM335X_I2C_IRQSTATUS_RAW_BB:%x\n",(REG(&regs->BBB_I2C_IRQSTATUS_RAW) & AM335X_I2C_IRQSTATUS_RAW_BB));
> +while(stat =( REG(&regs->BBB_I2C_IRQSTATUS_RAW) & AM335X_I2C_IRQSTATUS_RAW_BB) && timeout--)
This is a very complex conditional statement. Consider simplifying the logic.
> -    status = true;
> -  } else {
> -    status = false;
> +REG(&regs->BBB_I2C_IRQSTATUS)=stat;
Use whitespace consistently with the rest of the file / with RTEMS
coding conventions.
> +    udelay(20);
Document any need for delays and the reason for the chosen values.
> +  if (timeout <= 0) {
> +    printf("Timed out in wait_for_bb: status=%04x\n",
> +           stat);
> +    return 1;
We can use return true for a bool return type.
> -  return status;
> +  REG(&regs->BBB_I2C_IRQSTATUS)=0xffff;   /* clear delayed stuff*/
It might be sensible to wrap this REGS() stuff with a function interface like:
register_read(regs, BBB_I2C_IRQSTATUS);
register_write(regs, BBB_I2C_IRQSTATUS, 0xffff);
> +  return 0;
return false;
>  static void am335x_i2c_reset(bbb_i2c_bus *bus)
> @@ -330,9 +353,27 @@ static void am335x_i2c_reset(bbb_i2c_bus *bus)
>    printk("reset bus->reg is %x \n",bus->regs);
>    /* Disable I2C module at the time of initialization*/
>    /*Should I use write32 ?? I guess mmio_clear is correct choice here*/
> +  REG(&regs->BBB_I2C_CON)=0x00;
>    printk("inside BBB_I2C_CON value is %x \n",&regs->BBB_I2C_CON);
> -  mmio_clear((&regs->BBB_I2C_CON),AM335X_I2C_CON_I2C_EN);
> -  mmio_clear((&regs->BBB_I2C_SYSC),AM335X_I2C_SYSC_AUTOIDLE);
> +   REG(&regs->BBB_I2C_SYSC)= 0x2;
> +//  mmio_clear((&regs->BBB_I2C_CON),AM335X_I2C_CON_I2C_EN);
> +   REG(&regs->BBB_I2C_CON)= AM335X_I2C_CON_I2C_EN;
> +   while((REG(&regs->BBB_I2C_SYSS) &I2C_SYSS_RDONE)==0)  //wait reset done
register_flag_is_set(regs, BBB_I2C_SYSS, I2C_SYSS_RDONE) maybe?
> +    udelay(100);
> +   am335x_i2c_set_clock(&bus->base, I2C_BUS_CLOCK_DEFAULT);
> +   REG(&regs->BBB_I2C_CON)= AM335X_I2C_CON_MST | AM335X_I2C_CON_I2C_EN;
> +//  mmio_clear((&regs->BBB_I2C_SYSC),AM335X_I2C_SYSC_AUTOIDLE);
>    //REG(bus->regs + AM335X_I2C_CON) &= ~(AM335X_I2C_CON_I2C_EN);
>    //REG(bus->regs + AM335X_I2C_SYSC) &= ~(AM335X_I2C_SYSC_AUTOIDLE);
> @@ -385,6 +426,7 @@ static unsigned int am335x_i2c_intrawstatus(volatile bbb_i2c_regs *regs)
>  static void am335x_i2c_masterint_enable(volatile bbb_i2c_regs *regs, unsigned int flag)
> +  printf("am335x_i2c_masterint_enable func\n");
>    REG(&regs->BBB_I2C_IRQENABLE_SET) |= flag;
> @@ -401,6 +443,7 @@ static void am335x_int_clear(volatile bbb_i2c_regs *regs, unsigned int flag)
>  static void am335x_clean_interrupts(volatile bbb_i2c_regs *regs)
> +  printf("am335x_clean_interrupts func\n");
>    am335x_i2c_masterint_enable(regs,0x7FFF);
>    am335x_int_clear(regs,0x7FFF);
>    am335x_i2c_masterint_disable(regs,0x7FFF);
> @@ -412,30 +455,69 @@ static void am335x_i2c_setup_read_transfer(bbb_i2c_bus *bus, volatile bbb_i2c_re
>    volatile unsigned int no_bytes;
>    //am335x_i2c_masterint_enable(regs, AM335X_I2C_INT_RECV_READY);
>     // No of data to be transmitted at a time
Avoid more than one blank new line.
> +//bbb_i2c_bus *bus = (bbb_i2c_bus *) base;
> +//  volatile bbb_i2c_regs *regs = bus->regs;
> +  struct am335x_baseboard_id header;
> +  omap24_i2c_probe(&bus->base);
> +   read_eeprom(&bus->base,&header);
whitespace
>    REG(&regs->BBB_I2C_CNT) = 0x02;
>    no_bytes = REG(&regs->BBB_I2C_CNT);
> + // Set Slave address & Master enable, bring out of reset
> +  REG(&regs->BBB_I2C_SA) = msgs->addr;
> +  printf("slave address : %x\n",REG(&regs->BBB_I2C_SA));
>    // I2C Controller in Master Mode
> -  REG(&regs->BBB_I2C_CON) = AM335X_I2C_CFG_MST_TX | AM335X_I2C_CON_I2C_EN | AM335X_I2C_CON_START | AM335X_I2C_CON_MST;
> +  REG(&regs->BBB_I2C_CON) = AM335X_I2C_CFG_MST_TX  | AM335X_I2C_CON_MST | AM335X_I2C_CON_START | AM335X_I2C_CON_I2C_EN | AM335X_I2C_CON_STOP;
>    printk("set master in transmission mode %x \n",REG(&regs->BBB_I2C_CON));
> -  // Set Slave address & Master enable, bring out of reset
> -  REG(&regs->BBB_I2C_SA) = msgs->addr;
> -  printf("slave address : %x\n",REG(&regs->BBB_I2C_SA));
> +while(am335x_i2c_busbusy(regs) != 0);
> +  printk("bus is free \n");
>    // clear status of all interrupts
>    am335x_clean_interrupts(regs);
>    printk("\n set memory address to read\n");
>    // transmit interrupt is enabled
>    am335x_i2c_masterint_enable(regs,AM335X_I2C_IRQSTATUS_XRDY);
>    printk("Enable transmit interrupt \n");
>    //start condition
> -  REG(&regs->BBB_I2C_CON) |= AM335X_I2C_CON_START;
> +  REG(&regs->BBB_I2C_CON) |= AM335X_I2C_CON_START | AM335X_I2C_CON_I2C_EN;
>    printk("start transmission \n");
> -  while(am335x_i2c_busbusy(regs) == 0);
> -  printk("bus is free \n");
>    printk("CNT : %x\n", no_bytes);
> +  printf("BBB_I2C_DATA:%x\n", readb(&regs->BBB_I2C_DATA));
> +writeb(0x5,&regs->BBB_I2C_DATA);
> +printf("(0x50 >> 8)& 0xff:%x\n",(0x50 >> 8)& 0xff);
> +printf("REG(&regs->BBB_I2C_DATA):%x\n",readb(&regs->BBB_I2C_DATA) );
> +printf("&regs->BBB_I2C_DATA:%x\n",&regs->BBB_I2C_DATA);
> +//REG(&regs->BBB_I2C_IRQSTATUS)=AM335X_I2C_IRQSTATUS_XRDY;
> +udelay(10);
> +writeb(0x0,&regs->BBB_I2C_DATA);
> +//REG(&regs->BBB_I2C_DATA)= ( (0x50 >> 0)& 0xff);
> +printf("(0x50 >> 0)& 0xff:%x\n",(0x50 >> 0)& 0xff);
> +REG(&regs->BBB_I2C_IRQSTATUS)=AM335X_I2C_IRQSTATUS_XRDY;
> + // no_bytes = REG(&regs->BBB_I2C_CNT);
>    while(0 != no_bytes);
>    printk("total msg count for tranmission is zero \n");
>    while( !(am335x_i2c_intrawstatus(regs) & (AM335X_I2C_IRQSTATUS_ARDY)));
> @@ -464,6 +546,7 @@ static void am335x_i2c_setup_read_transfer(bbb_i2c_bus *bus, volatile bbb_i2c_re
>    printk("Exit read transfer\n");
> @@ -570,11 +653,16 @@ static void am335x_i2c_setup_transfer(bbb_i2c_bus *bus, volatile bbb_i2c_regs *r
>    regs = bus->regs;
> -  REG(&bus->regs->BBB_I2C_BUF) |= AM335X_I2C_BUF_TXFIFO_CLR;
> -  REG(&bus->regs->BBB_I2C_BUF) |= AM335X_I2C_BUF_RXFIFO_CLR;
> -  am335x_i2c_set_address_size(msgs,regs);
> -  bus->read = ((bus->read == true) ? 0:1);
> +  printf("REG(&regs->BBB_I2C_DATA):%x\n",REG(&regs->BBB_I2C_DATA) );
> + // REG(&bus->regs->BBB_I2C_BUF) |= AM335X_I2C_BUF_TXFIFO_CLR;
> + // REG(&bus->regs->BBB_I2C_BUF) |= AM335X_I2C_BUF_RXFIFO_CLR;
> +printf("REG(&regs->BBB_I2C_DATA):%x\n",REG(&regs->BBB_I2C_DATA) );
> + // am335x_i2c_set_address_size(msgs,regs);
> +bus->read = (msgs->flags & I2C_M_RD) != 0;
> +printf("bus->read:%d\n",bus->read );
> +  //bus->read = ((bus->read == true) ? 0:1);
>    bus->already_transferred = (bus->read == true) ? 0 : 1;
>    if (bus->read) {
> @@ -652,7 +740,7 @@ static int am335x_i2c_transfer(i2c_bus *base, i2c_msg *msgs, uint32_t msg_count)
>    bbb_i2c_bus *bus = (bbb_i2c_bus *)base;
>    volatile bbb_i2c_regs *regs;
>    uint32_t i;
> - printk("\n enter transfer ");
> + printk("\n enter transfer\n ");
>    rtems_task_wake_after(1);
> @@ -665,20 +753,23 @@ static int am335x_i2c_transfer(i2c_bus *base, i2c_msg *msgs, uint32_t msg_count)
>          return -EINVAL;
> +  printf("bus->regs:%x\n",bus->regs );
>    bus->msgs = &msgs[0];
>    bus->msg_todo = msg_count;
>    printk("total msg = msg_count : %x \n",bus->msg_todo);
>    bus->current_msg_todo = msgs[0].len;// current data size
> -  bus->current_msg_byte = msgs[0].buf;// current data
> +  //bus->current_msg_byte = msgs[0].buf;// current data
>    printk("\n current_msg_todo %x \n ",msgs[0].len);
>    printk("\n current_msg_byte %x \n ",msgs[0].buf);
> +  //printf("8011A5CC:%x\n",  *(unsigned int *)(0x8011A5CC) );
>    bus->task_id = rtems_task_self();
>    regs = bus->regs;
> -  am335x_i2c_setup_transfer(bus,regs);
> -  REG(&regs->BBB_I2C_IRQENABLE_SET) = BBB_I2C_IRQ_USED;
> + // REG(&regs->BBB_I2C_IRQENABLE_SET) = BBB_I2C_IRQ_USED;
> +  am335x_i2c_setup_transfer(bus,regs);
>    sc = rtems_event_transient_receive(RTEMS_WAIT, bus->base.timeout);
>    // If timeout then return timeout error
>    if (sc != RTEMS_SUCCESSFUL) {
> @@ -688,7 +779,9 @@ static int am335x_i2c_transfer(i2c_bus *base, i2c_msg *msgs, uint32_t msg_count)
>      return -ETIMEDOUT;
>    printk("exit transfer\n");
>    // return bus->regs->BBB_I2C_IRQSTATUS == 0 ? 0 : -EIO;
>    return 0;
> @@ -700,19 +793,28 @@ static int am335x_i2c_set_clock(i2c_bus *base, unsigned long clock)
>    uint32_t prescaler,divider;
>    printk("set clock start\n");
> +  REG(&regs->BBB_I2C_CON)=0;
>    prescaler = (BBB_I2C_SYSCLK / BBB_I2C_INTERNAL_CLK) -1;
> +  printf("prescaler:%d\n",prescaler );
>    printk("PSC offset %x \n ",&regs->BBB_I2C_PSC);
>    printk("PSC offset %x \n", &bus->regs->BBB_I2C_PSC);
>    //mmio_write((&regs->BBB_I2C_PSC), prescaler);
>    REG(&bus->regs->BBB_I2C_PSC) = prescaler;
>    divider = BBB_I2C_INTERNAL_CLK/(2*clock);
> +  printf("divider:%d\n", divider);
>    printk("SCLL offset %x \n",&bus->regs->BBB_I2C_SCLL);
>    //mmio_write((&regs->BBB_I2C_SCLL), (divider - 7));
>    REG(&bus->regs->BBB_I2C_SCLL) = (divider - 7);
>    //mmio_write((&regs->BBB_I2C_SCLH), (divider - 5));
>    printk("SCHL offset %x\n",&bus->regs->BBB_I2C_SCLH);
>    REG(&bus->regs->BBB_I2C_SCLH) = (divider - 5);
> + REG(&regs->BBB_I2C_CON)=I2C_CON_EN;
> +writew(0xFFFF, &bus->regs->BBB_I2C_IRQSTATUS);  /* clear all pending status */
>    printk("set clock end \n");
>    return 0;
> @@ -729,6 +831,8 @@ static void am335x_i2c_destroy(i2c_bus *base)
>    i2c_bus_destroy_and_free(&bus->base);
>  int am335x_i2c_bus_register(
>    const char *bus_path,
>    uintptr_t register_base,
> @@ -751,14 +855,15 @@ int am335x_i2c_bus_register(
>    bus->regs = (volatile bbb_i2c_regs *) register_base;
>  // 1. Enable clock for I2CX
> -  I2C0ModuleClkConfig();
> + I2C0ModuleClkConfig();
>  // 2. pinmux setup
>    am335x_i2c0_pinmux(bus);
>  // 3. RESET : Disable Master, autoideal
> -  am335x_i2c_reset(bus);
> + // am335x_i2c_reset(bus);
>  // 4. configure bus speed
>    bus->input_clock = input_clock; // By default 100KHz. Normally pass 100KHz as argument
>    printk("Before set clock \n");
>    err = am335x_i2c_set_clock(&bus->base, I2C_BUS_CLOCK_DEFAULT);
> @@ -768,12 +873,16 @@ int am335x_i2c_bus_register(
>      rtems_set_errno_and_return_minus_one(-err);
>     bus->irq = irq;
> +omap24_i2c_init(&bus->base);
>    //bring I2C out of reset
> -   REG(&bus->regs->BBB_I2C_CON) |= AM335X_I2C_CON_I2C_EN;
> +//printf("REG(&regs->BBB_I2C_IRQSTATUS):%x\n",REG(&bus->regs->BBB_I2C_IRQSTATUS));
> +  // REG(&bus->regs->BBB_I2C_CON) |= AM335X_I2C_CON_I2C_EN;
>    // 5. Start interrupt service routine & one interrupt at a time
>    sc  = rtems_interrupt_handler_install(
>      irq,
>      "BBB I2C",
> @@ -787,6 +896,7 @@ int am335x_i2c_bus_register(
>      rtems_set_errno_and_return_minus_one(EIO);
>    // 6. start transfer for reading and writing
>    bus->base.transfer = am335x_i2c_transfer;
>    bus->base.set_clock = am335x_i2c_set_clock;
> @@ -794,3 +904,499 @@ int am335x_i2c_bus_register(
>    printk("exit register\n");
>    return i2c_bus_register(&bus->base,bus_path);
> +   bbb_i2c_bus *bus = (bbb_i2c_bus *) base;
> +  volatile bbb_i2c_regs *regs = bus->regs;
> +  int deblock = 1;
> +printf("omap24_i2c_init func!!!!!!\n");
> +retry:
> +  if (readw(&bus->regs->BBB_I2C_CON) & I2C_CON_EN) {
> +    writew(0, &bus->regs->BBB_I2C_CON);
> +    udelay(50000);
> +  writew(0x2, &bus->regs->BBB_I2C_SYSC); /* for ES2 after soft reset */
> +  udelay(1000);
> +  writew(I2C_CON_EN, &bus->regs->BBB_I2C_CON);
> +  while (!(readw(&bus->regs->BBB_I2C_SYSS) & I2C_SYSS_RDONE) && timeout--) {
> +      puts("ERROR: Timeout in soft-reset\n");
> +      return;
> +    udelay(1000);
> +am335x_i2c_set_clock(&bus->base, I2C_BUS_CLOCK_DEFAULT);
> +  /* own address */
> +  writew(1, &bus->regs->BBB_I2C_OA);
> +//#if defined(CONFIG_OMAP243X) || defined(CONFIG_OMAP34XX)
> +   * Have to enable interrupts for OMAP2/3, these IPs don't have
> +   * an 'irqstatus_raw' register and we shall have to poll 'stat'
> + // writew(I2C_IE_XRDY_IE | I2C_IE_RRDY_IE | I2C_IE_ARDY_IE | I2C_IE_NACK_IE | I2C_IE_AL_IE, &i2c_base->ie);
> +//#endif
> +  udelay(1000);
> +  flush_fifo(&bus->base);
> +  writew(0xFFFF, &bus->regs->BBB_I2C_IRQSTATUS);
> +  /* Handle possible failed I2C state */
> +  if (wait_for_bb(&bus->base))
> +    if (deblock == 1) {
> +      //omap24_i2c_deblock(&bus->base);
> +      printf("deblock\n");
> +      deblock = 0;
> +      goto retry;
> +  //  omap24_i2c_probe(&bus->base);
> + //  read_eeprom(&bus->base,&header);
> +  u16 stat;
> +printf("flush_fifo\n");
> +   * note: if you try and read data when its not there or ready
> +   * you get a bus error
> +  while (1) {
> +    stat = readw(&bus->regs->BBB_I2C_IRQSTATUS);
> +    if (stat == I2C_STAT_RRDY) {
> +      readb(&bus->regs->BBB_I2C_DATA);
> +      writew(I2C_STAT_RRDY, &bus->regs->BBB_I2C_IRQSTATUS);
> +      udelay(1000);
> +    } else
> +      break;
> +  u16 stat;
> +printf("wait_for_bb\n");
> +  writew(0xFFFF, &bus->regs->BBB_I2C_IRQSTATUS);  /* clear current interrupts...*/
> +//printf("test1\n");
> +  /* Read RAW status */
> +//printf("%x\n", readw(&bus->regs->BBB_I2C_IRQSTATUS_RAW) & I2C_STAT_BB);
> +  while ((stat = readw(&bus->regs->BBB_I2C_IRQSTATUS_RAW) &
> +    I2C_STAT_BB) && timeout--) {
> +    writew(stat, &bus->regs->BBB_I2C_IRQSTATUS);
> +    udelay(200);
> +           stat);
> +    return 1;
> +  writew(0xFFFF, &bus->regs->BBB_I2C_IRQSTATUS);   /* clear delayed stuff*/
> +  return 0;
> +  unsigned char chip = 0x50;
> +  u16 status;
> +  int res = 1; /* default = fail */
> +printf("omap24_i2c_probe\n");
> +  if (chip == readw(&bus->regs->BBB_I2C_OA))
> +    return res;
> +  /* Wait until bus is free */
> +    return res;
> +  /* No data transfer, slave addr only */
> +  writew(chip, &bus->regs->BBB_I2C_SA);
> +  /* Stop bit needed here */
> +  writew(I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_TRX |
> +         I2C_CON_STP, &bus->regs->BBB_I2C_CON);
> +  status = wait_for_event(&bus->base);
> +  if ((status & ~I2C_STAT_XRDY) == 0 || (status & I2C_STAT_AL)) {
> +     * With current high-level command implementation, notifying
> +     * the user shall flood the console with 127 messages. If
> +     * silent exit is desired upon unconfigured bus, remove the
> +     * following 'if' section:
> +    if (status == I2C_STAT_XRDY)
> +      printf("i2c_probe: pads on bus probably not configured (status=0x%x)\n",status);
> +    goto pr_exit;
> +  /* Check for ACK (!NAK) */
> +  if (!(status & I2C_STAT_NACK)) {
> +    printf("Device found\n");
> +    res = 0;        /* Device found */
> +    udelay(200);/* Required by AM335X in SPL */
> +    /* Abort transfer (force idle state) */
> +    writew(I2C_CON_MST | I2C_CON_TRX, &bus->regs->BBB_I2C_CON); /* Reset */
> +    udelay(1000);
> +    writew(I2C_CON_EN | I2C_CON_MST | I2C_CON_TRX |
> +           I2C_CON_STP, &bus->regs->BBB_I2C_CON);    /* STP */
> +pr_exit:
> +  return res;
> +  u16 status;
> +//printf("wait_for_event \n");
> +  do {
> +    udelay(200);
> +    status = readw(&bus->regs->BBB_I2C_IRQSTATUS_RAW);
> +  } while (!(status &
> +       (I2C_STAT_ROVR | I2C_STAT_XUDF | I2C_STAT_XRDY |
> +        I2C_STAT_RRDY | I2C_STAT_ARDY | I2C_STAT_NACK |
> +        I2C_STAT_AL)) && timeout--);
> +    printf("Timed out in wait_for_event: status=%04x\n",
> +           status);
> +     * If status is still 0 here, probably the bus pads have
> +     * not been configured for I2C, and/or pull-ups are missing.
> +    printf("Check if pads/pull-ups of bus are properly configured\n");
> +    status = 0;
> +  return status;
> +                           int len)
> +  int i2c_error = 0;
> +  int i=0;
> +  u16 status;
> +printf("am335x_i2c_read\n");
> +  if (alen < 0) {
> +    puts("I2C read: addr len < 0\n");
> +    return 1;
> +  if (len < 0) {
> +    puts("I2C read: data len < 0\n");
> +    return 1;
> +  if (buffer == NULL) {
> +    puts("I2C read: NULL pointer passed\n");
> +    return 1;
> +  if (alen > 2) {
> +    printf("I2C read: addr len %d not supported\n", alen);
> +    return 1;
> +  if (addr + len > (1 << 16)) {
> +    puts("I2C read: address out of range\n");
> +    return 1;
> +  /* Wait until bus not busy */
> +    return 1;
> +//printf("test2\n");
> +  /* Zero, one or two bytes reg address (offset) */
> +  writew(alen, &bus->regs->BBB_I2C_CNT);
> +  /* Set slave address */
> +//printf("test3\n");
> +  if (alen) {
> +    /* Must write reg offset first */
> +    /* Stop - Start (P-S) */
> +    writew(I2C_CON_EN | I2C_CON_MST | I2C_CON_STT | I2C_CON_STP |
> +           I2C_CON_TRX, &bus->regs->BBB_I2C_CON);
> +    /* Send register offset */
> +    while (1) {
> +      printf("status:%x\n",status );
> +      /* Try to identify bus that is not padconf'd for I2C */
> +      if (status == I2C_STAT_XRDY) {
> +        i2c_error = 2;
> +        printf("i2c_read (addr phase): pads on bus probably not configured (status=0x%x)\n",
> +              status);
> +        goto rd_exit;
> +      if (status == 0 || (status & I2C_STAT_NACK)) {
> +        i2c_error = 1;
> +        printf("i2c_read: error waiting for addr ACK (status=0x%x)\n",
> +               status);
> +        goto rd_exit;
> +      if (alen) {
> +        if (status & I2C_STAT_XRDY) {
> +      //    printf("alen:%d\n",alen );
> +          alen--;
> +      //    printf("addr:%x\n",addr );
> +      //    printf("(addr >> (8 * alen)) & 0xff:%x\n",(addr >> (8 * alen)) & 0xff );
> +          /* Do we have to use byte access? */
> +          writeb((addr >> (8 * alen)) & 0xff,
> +                 &bus->regs->BBB_I2C_DATA);
> +          writew(I2C_STAT_XRDY, &bus->regs->BBB_I2C_IRQSTATUS);
> +      if (status & I2C_STAT_ARDY) {
> +        writew(I2C_STAT_ARDY, &bus->regs->BBB_I2C_IRQSTATUS);
> +        break;
> +  /* Read len bytes from slave */
> +  writew(len, &bus->regs->BBB_I2C_CNT);
> +  /* Need stop bit here */
> +         I2C_CON_STT | I2C_CON_STP,
> +         &bus->regs->BBB_I2C_CON);
> +//printf("test4\n");
> +  /* Receive data */
> +  while (1) {
> + //   printf("test 5\n");
> +     * Try to identify bus that is not padconf'd for I2C. This
> +     * state could be left over from previous transactions if
> +     * the address phase is skipped due to alen=0.
> +      i2c_error = 2;
> +      printf("i2c_read (data phase): pads on bus probably not configured (status=0x%x)\n",
> +              status);
> +      goto rd_exit;
> +     // printf("i2c_error = 1\n");
> +      i2c_error = 1;
> +      goto rd_exit;
> +    if (status & I2C_STAT_RRDY) {
> +      char temp;
> +      temp=readb(&bus->regs->BBB_I2C_DATA);
> +      *buffer++ =temp;
> +     *bus->msgs[0].buf++=temp;
> +  //   (*(uint8_t *) bus->current_msg_byte[0]) = readb(&bus->regs->BBB_I2C_DATA) & 0xFF;
> +      i++;
> +      break;
> +rd_exit:
> +//printf("rd_exit\n");
> +//printf("i2c_error:%d\n",i2c_error);
> +  return i2c_error;
> +bbb_i2c_bus *bus = (bbb_i2c_bus *) base;
> +printf("sizeof(struct am335x_baseboard_id):%d\n",sizeof(struct am335x_baseboard_id) );
> +//printf("sizeof(struct am335x_baseboard_id):%d\n",sizeof(unsigned int) );
> + am335x_i2c_read(&bus->base,0x50,0,2,(unsigned char *)header,sizeof(struct am335x_baseboard_id));
> +printf("am335x_i2c_read end\n");
> +    printf("header->magic:%x\n", header->magic);
> +     printf("header->name[0]:%x\n", header->name[0]);
> +      printf("header->name[1]:%x\n", header->name[1]);
> +     printf("header->name[2]:%x\n", header->name[2]);
> +      printf("header->name[3]:%x\n", header->name[3]);
> +       printf("header->name[4]:%x\n", header->name[4]);
> +        printf("header->name[5]:%x\n", header->name[5]);
> +         printf("header->name[6]:%x\n", header->name[6]);
> +          printf("header->name[7]:%x\n", header->name[7]);
> +                            int len)
> +  int i;
> +  u16 status;
> +  if (alen < 0) {
> +    puts("I2C write: addr len < 0\n");
> +    return 1;
> +  if (len < 0) {
> +    puts("I2C write: data len < 0\n");
> +    return 1;
> +    puts("I2C write: NULL pointer passed\n");
> +    return 1;
> +  if (alen > 2) {
> +    printf("I2C write: addr len %d not supported\n", alen);
> +    return 1;
> +    printf("I2C write: address 0x%x + 0x%x out of range\n",
> +           addr, len);
> +    return 1;
> +    return 1;
> +  /* Start address phase - will write regoffset + len bytes data */
> +  writew(alen + len, &bus->regs->BBB_I2C_CNT);
> +  writew(chip,&bus->regs->BBB_I2C_SA);
> +         I2C_CON_STP,&bus->regs->BBB_I2C_CON);
> +  while (alen) {
> +    /* Must write reg offset (one or two bytes) */
> +      i2c_error = 2;
> +      printf("i2c_write: pads on bus probably not configured (status=0x%x)\n",status);
> +      goto wr_exit;
> +      i2c_error = 1;
> +      printf("i2c_write: error waiting for addr ACK (status=0x%x)\n",
> +             status);
> +      goto wr_exit;
> +      alen--;
> +      writeb((addr >> (8 * alen)) & 0xff, &bus->regs->BBB_I2C_DATA);
> +    } else {
> +      i2c_error = 1;
> +      printf("i2c_write: bus not ready for addr Tx (status=0x%x)\n",
> +             status);
> +      goto wr_exit;
> +  /* Address phase is over, now write data */
> +  for (i = 0; i < len; i++) {
> +      i2c_error = 1;
> +      printf("i2c_write: error waiting for data ACK (status=0x%x)\n",
> +             status);
> +      goto wr_exit;
> +      writeb(buffer[i], &bus->regs->BBB_I2C_DATA);
> +    } else {
> +      i2c_error = 1;
> +      printf("i2c_write: bus not ready for data Tx (i=%d)\n",
> +             i);
> +      goto wr_exit;
> +   * poll ARDY bit for making sure that last byte really has been
> +   * transferred on the bus.
> +  do {
> +  } while (!(status & I2C_STAT_ARDY) && timeout--);
> +  if (timeout <= 0)
> +    printf("i2c_write: timed out writig last byte!\n");
> +wr_exit:
> +  return i2c_error;
> diff --git a/c/src/lib/libbsp/arm/beagle/include/i2c.h b/c/src/lib/libbsp/arm/beagle/include/i2c.h
> index d4a9e32..6c924ee 100644
> --- a/c/src/lib/libbsp/arm/beagle/include/i2c.h
> +++ b/c/src/lib/libbsp/arm/beagle/include/i2c.h
> @@ -132,11 +132,11 @@ extern "C" {
>  #define DISP_LINE_LEN 128
> -#define I2C_TIMEOUT 1000
> +#define I2C_TIMEOUT 1001
>  #define I2C_BUS_MAX 3
> -#define I2C_BASE1         (OMAP34XX_CORE_L4_IO_BASE + 0x070000)
> +#define I2C_BASE1         (OMAP34XX_CORE_L4_IO_BASE + 0x070000) //0x48000000+0x070000
>  #define I2C_DEFAULT_BASE      I2C_BASE1
> @@ -356,7 +356,7 @@ static inline rtems_status_code beagle_i2c_read(
>      | AM335X_I2C_IRQSTATUS_ARDY \
>      | AM335X_I2C_IRQSTATUS_RRDY \
>      | AM335X_I2C_IRQSTATUS_XRDY \
> -    | AM335X_I2C_IRQSTATUS_XUDF)
> +    | AM335X_I2C_IRQSTATUS_XUDF )
>  #define BBB_I2C_IRQ_USED \
>    ( BBB_I2C_IRQ_ERROR \
> @@ -478,6 +478,18 @@ static inline int bbb_register_i2c_2(void)
> +struct am335x_baseboard_id {
> +       unsigned int  magic;
> +       char name[8];
> +       char version[4];
> +       char serial[12];
> +       char config[32];
> +       char mac_addr[3][6];
>  #ifdef __cplusplus
>  #endif /* __cplusplus */
> diff --git a/cpukit/dev/i2c/eeprom.c b/cpukit/dev/i2c/eeprom.c
> index 39cff95..15040af 100644
> --- a/cpukit/dev/i2c/eeprom.c
> +++ b/cpukit/dev/i2c/eeprom.c
> @@ -55,6 +55,7 @@ static ssize_t eeprom_read(
>    off_t offset
>    eeprom *dev = (eeprom *) base;
>    off_t avail = dev->size - offset;
>    uint32_t off = (uint32_t) offset;
> @@ -86,6 +87,17 @@ static ssize_t eeprom_read(
>        (uint8_t) (off >> 16),
>        (uint8_t) (off >> 24)
> +    i2c_msg msgs[1] = {
> +        .addr = i2c_addr,
> +        .flags = I2C_M_RD,
> +        .buf = in,
> +        .len = cur
>      i2c_msg msgs[2] = {
>          .addr = i2c_addr,
> @@ -99,14 +111,22 @@ static ssize_t eeprom_read(
>          .len = cur
>      int err;
>      err = i2c_bus_transfer(dev->base.bus, &msgs[0], RTEMS_ARRAY_SIZE(msgs));
>      if (err != 0) {
>        return err;
>      todo -= cur;
>      off += cur;
>      in += cur;
> @@ -236,7 +256,7 @@ int i2c_dev_register_eeprom(
>    if (program_timeout_in_ms == 0) {
> -    program_timeout_in_ms = 1000;
> +    program_timeout_in_ms = 5000;
>    dev = (eeprom *)
> diff --git a/testsuites/samples/i2c0/init.c b/testsuites/samples/i2c0/init.c
> index b428216..70bbe12 100644
> --- a/testsuites/samples/i2c0/init.c
> +++ b/testsuites/samples/i2c0/init.c
> @@ -23,10 +23,62 @@
>  #include <dev/i2c/eeprom.h>
> +#include <rtems/shell.h>
> +#include <stdio.h>
> +#include <stdarg.h>
> +#include <stdlib.h>
> +#include <string.h>
> +#include <errno.h>
> +#include <rtems/userenv.h>
> +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> +#define CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
> +#define CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER
> +#define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
> +#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
> +#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 32
> +#define CONFIGURE_MAXIMUM_USER_EXTENSIONS 1
> +#define CONFIGURE_UNLIMITED_ALLOCATION_SIZE 32
> +#define CONFIGURE_UNLIMITED_OBJECTS
> +#define CONFIGURE_UNIFIED_WORK_AREAS
> +#define CONFIGURE_STACK_CHECKER_ENABLED
> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> +#define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_DEFAULT_MODES
> +#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
> +#include <rtems/confdefs.h>
> +#define CONFIGURE_SHELL_COMMAND_CP
> +#define CONFIGURE_SHELL_COMMAND_PWD
> +#define CONFIGURE_SHELL_COMMAND_LS
> +#define CONFIGURE_SHELL_COMMAND_LN
> +#define CONFIGURE_SHELL_COMMAND_LSOF
> +#define CONFIGURE_SHELL_COMMAND_CHDIR
> +#define CONFIGURE_SHELL_COMMAND_CD
> +#define CONFIGURE_SHELL_COMMAND_MKDIR
> +#define CONFIGURE_SHELL_COMMAND_RMDIR
> +#define CONFIGURE_SHELL_COMMAND_CAT
> +#define CONFIGURE_SHELL_COMMAND_MV
> +#define CONFIGURE_SHELL_COMMAND_MALLOC_INFO
> +#include <rtems/shellconfig.h>
>  /* I2C address of CAT24C256 eeprom
>     EEPROM SIZE 32 KB Ref: BBB SRM */
>  #define I2C_SLAVE_ADDR         (0x50)
> -#define EEPROM_SIZE 256
> +#define EEPROM_SIZE 78
>  #define EEPROM_PATH "/dev/i2c-0.eeprom"
>  /* forward declarations to avoid warnings */
> @@ -35,16 +87,23 @@ rtems_task Init(rtems_task_argument argument);
>  const char rtems_test_name[] = "GSOC 2016 I2C TESTING";
>  rtems_printer rtems_test_printer;
>  rtems_task Init(
>    rtems_task_argument ignored
>    rtems_test_begin();
>    int i;
>    int rv,fd_bus,fd_in_dev;
>    uint8_t in[EEPROM_SIZE];
>    struct stat st;
>    off_t off;
> +  ssize_t n;
> +  rtems_shell_env_t env;
>    /*bus registration */
>    rv = bbb_register_i2c_0();
> @@ -64,23 +123,56 @@ rtems_task Init(
>        256, // size_in_bytes
>        0 // program time out in ms
> + _Assert(rv == 0);
> +// exit( 0 );
>    printf("register EEPROM \n");
>    fd_in_dev = open(EEPROM_PATH, O_RDWR);
> +  printf("fd_in_dev:%d\n", fd_in_dev);
>    _Assert(fd_in_dev >=0);
>    printf("open eeprom \n");
>    rv = fstat(fd_in_dev, &st);
>    _Assert(rv == 0);
>    _Assert(st.st_blksize == 8);
>    _Assert(st.st_size == sizeof(in));
> +printf("read func\n");
> +  n = read(fd_in_dev, &in[0], sizeof(in));
> +   printf("n:%d\n",n );
> +    printf("0:%x, ",in[0]);
> +   printf("1:%x, ",in[1]);
> + for(i=0;i<sizeof(in);++i)
> +printf("%x\n",in[i]);
> +   printf("sizeof(in):%d\n", sizeof(in));
> +   // _Assert(n == -1);
> +printf("test\n");
>    for ( i = 0; i < sizeof(in); ++i) {
> +    printf("i:%d\n",i);
>      off = lseek(fd_in_dev, 0, SEEK_SET);
> +    printf("lseek func done!\n");
>      rv = read(fd_in_dev,&in[0], sizeof(in));
> -    printf("\n %s \n ",in[i]);
> +   // printf("\n %s \n ",in[i]);
>    printf("EXIT from test case");
>    close(fd_bus);
> -  unlink(BBB_I2C_2_BUS_PATH);
> + unlink(BBB_I2C_2_BUS_PATH);
>    rtems_test_end();
> 2.7.4
> devel mailing list
> devel at rtems.org
