GSOC 2017 Beagleboard BSP projects
Mon Mar 20 23:45:13 UTC 2017
On Sun, Mar 19, 2017 at 4:38 PM, Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> ----- Ursprüngliche Mail -----
> > Von: "赵 思晨" <zsc19940506 at outlook.com>
> > An: "RTEMS" <devel at rtems.org>
> > Gesendet: Sonntag, 19. März 2017 15:29:03
> > Betreff: GSOC 2017 Beagleboard BSP projects
> > Hi all:
> > I am interested in the ticket #2819 Beagleboard BSP projects
> > And i have a idea about the project: add the USB and wireless network
> card
> > driver to RTEMS. So RTEMS can apply on many scene applications such as
> the UAV.
> > And for now, i am working on transplant the USB driver from FreeBSD to
> RTEMS.
> > I am a master student from China NanJing University. and i am interested
> in
> > applying for GSoC 2017 under RTEMS.
> > I have develop project on RTEMS for almost a year, so i am very familiar
> with
> > RTEMS development.
> > For now, i have done these works on RTEMS:
> > 1.Porting the ethernet driver from FreeBSD to RTEMS on BBB bsp.
> > 2.Transplant the ION-DTN protocol stack on RTEMS.
> > 3.Took over Punitvara's(GSOC 2016 student) unfinished work on BBB i2c
> driver,
> > and can use i2c read the EEPROM info..(already send PV my pull request)
> > 4.Porting  the ethernet driver from UBoot to RTEMS on BBB bsp.
> > Best Regrads
> > Sichen Zhao
> > 发自 Outlook<http://aka.ms/weboutlook>
> > devel mailing list
> > devel at rtems.org
> Hello Sichen Zhao,
> just a note regarding the WLAN support in rtems-libbsd: I have just
> recently ported a lot of the necessary kernel modules for unencrypted WLAN.
> Depending on the projects progress, It's quite possible that we (embedded
> brains) will work on encrypted WLAN too in the near future. So this might
> could collide with the goals in your proposal that relate to the hardware
> independent parts of the network stack.
Christian.. I appreciate you giving a heads up but isn't the work of
USB support for a BB and a specific WLAN driver for a USB WLAN stick
rather independent of adding encryption support? It would seem they
are in different areas of the tree.
I can see where he could focus on unencrypted support and then
if things work out, take advantage of the encrypted support later.
I thought the tree was already up to date so there wouldn't be any
massive updates of code.
What conflicts do you foresee? And can you work with the student
to avoid or minimize them.
Working in the open and coordinating efforts is critical in any open
source project. This seems like one which can be managed. Especially
if you help out on this project so you can help avoid the issues.
Thanks.
--joel
Kind regards
> Christian Mauderer
> embedded brains GmbH
> Christian Mauderer
> Dornierstr. 4
> D-82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> Phone: +49-89-18 94 741 - 18
> Fax:   +49-89-18 94 741 - 08
> PGP: Public key available on request.
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170320/a8cfa509/attachment-0002.html>
