[PATCH] bootstrap: make sort use C locale consistently
Joel Sherrill
joel at rtems.org
Fri Mar 31 19:59:53 UTC 2017
That seems more correct. The shell variable settings may only have been
applying to the ls.
--joel
On Fri, Mar 31, 2017 at 2:49 PM, Gedare Bloom <gedare at rtems.org> wrote:
> Closes #2965.
> bootstrap | 2 +-
> 1 file changed, 1 insertion(+), 1 deletion(-)
> diff --git a/bootstrap b/bootstrap
> index 455f642..9c2efa8 100755
> --- a/bootstrap
> +++ b/bootstrap
> @@ -42,7 +42,7 @@ AC_DEFUN([RTEMS_CHECK_BSPDIR],
> case "\$1" in
> EOF
> -for i in `LANG=C LC_COLLATE=C ls */bsp_specs | sort`; do
> +for i in `ls */bsp_specs | LANG=C LC_COLLATE=C sort`; do
> d=`dirname $i`
> cat << EOF >> acinclude.m4~
> $d )
> 2.7.4
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170331/275a1a41/attachment-0002.html>
