[PATCH 29/30] leon, greth: SMP support by using spin-lock protection
Daniel Hellstrom daniel at gaisler.com
Tue May 2 07:32:23 UTC 2017
On 2017-05-02 07:48, Sebastian Huber wrote:
> On 13/04/17 21:31, Daniel Hellstrom wrote:
>>   c/src/lib/libbsp/sparc/shared/net/greth.c | 134
>>   1 file changed, 71 insertions(+), 63 deletions(-)
>> diff --git a/c/src/lib/libbsp/sparc/shared/net/greth.c
>> b/c/src/lib/libbsp/sparc/shared/net/greth.c
>> index 7726799..9af2de2 100644
>> --- a/c/src/lib/libbsp/sparc/shared/net/greth.c
>> +++ b/c/src/lib/libbsp/sparc/shared/net/greth.c
>> @@ -41,6 +41,18 @@
>>   #include <netinet/in.h>
>>   #include <netinet/if_ether.h>
>>   +#include <rtems/score/isrlock.h> /* spin-lock */
>> +/* map via ISR lock: */
>> +#define SPIN_DECLARE(lock) ISR_LOCK_MEMBER(lock)
>> +#define SPIN_INIT(lock, name) _ISR_lock_Initialize(lock, name)
>> +#define SPIN_LOCK(lock, level) _ISR_lock_Acquire_inline(lock, &level)
>> +#define SPIN_LOCK_IRQ(lock, level)
>> _ISR_lock_ISR_disable_and_acquire(lock, &level)
>> +#define SPIN_UNLOCK(lock, level) _ISR_lock_Release_inline(lock, &level)
>> +#define SPIN_UNLOCK_IRQ(lock, level)
>> _ISR_lock_Release_and_ISR_enable(lock, &level)
>> +#define SPIN_IRQFLAGS(k) ISR_lock_Context k
>> +#define SPIN_ISR_IRQFLAGS(k) SPIN_IRQFLAGS(k)
> Could you please use the rtems_interrupt_lock_*() API and not the
> internal _ISR_lock_*() stuff.
Thanks. I think the reason for this may come from that the inline
equivalent. I will add a patch which adds inline macros to the
rtems_interrupt_lock interface instead. I can't see any reason why that
can not be supported?
Daniel
