Warning Report on Master
Tue May 2 08:28:43 UTC 2017
On 02/05/17 10:02, Daniel Hellstrom wrote:
> I started to look into the leon3 smp build recent problem and I think
> I located the problem with the version check. Since commit
> d420b679afc03f17d597193268e98966a0acd83d 2017-04-14 __RTEMS_REVISION__
> was changed to __RTEMS_REVISION___ causing macros looking at
> __RTEMS_REVISION__ to fail because use of undefined macro name. I will
> add a patch to to my patch series and push it ASAP.
Please have a look at this patch:
https://lists.rtems.org/pipermail/devel/2017-May/017687.html
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
