[PATCH] cpukit: Fix __RTEMS_REVISION__ define
Tue May 2 21:30:33 UTC 2017
On 2/5/17 6:20 pm, Sebastian Huber wrote:
> +  rtems_test_assert(__RTEMS_MAJOR__ == 4);
> +  rtems_test_assert(__RTEMS_MINOR__ == 11);
> +  rtems_test_assert(__RTEMS_REVISION__ == 99);
Please do not push this test like this, it breaks releases. The test
will never pass on a release.
If you want to add this test please extract the version details from the
build system and pass into the compiler the values and compare them.
Thanks.
