GCC 7.1 Released
Wed May 3 01:33:48 UTC 2017
On 3/5/17 3:04 am, Joel Sherrill wrote:
> Thoughts on upgrading the 4.12 tools?
Looks good with updated dependent packages for gcc and with
binutils-2.28. There are no build failures for just the tests. Attached
is the warnings report which looks good if the networking warnings are
ignored.
The test results for erc32 are:
Passed:        548
Failed:          2
User Input:      4
Expected Fail:   0
Indeterminate:   0
Benchmark:       3
Timeout:         1
Invalid:         1
Total:         559
Failures:
 tar01.exe
 spcontext01.exe
User Input:
 fileio.exe
 top.exe
 termios.exe
 monitor.exe
Benchmark:
 dhrystone.exe
 whetstone.exe
 linpack.exe
Timeouts:
 capture.exe
Invalid:
 minimum.exe
I think capture needs to be tagged as user input.
RTEMS Tools Project - RTEMS Kernel BSP Builder, 4.12.not_released
Date: Wed May  3 21:04:05 2017
command: /opt/work/rtems/4.12/bin/rtems-bsp-builder --rtems-\
         tools=/build/rtems/tools/4.12\
         --rtems=/opt/work/chris/rtems/kernel/rtems.git --build=tests\
         --log=x --warnings-report=warnings-tier-1-tests.txt
 | By Architecture (total : 288)                                       |
 | common : 33 warning(s)                                              |
 |   Shared :    0 |     BSP :    0 | Network :  136 |    Tests :    0 |
 |   LibCPU :    0 | CPU Kit :    0 |                |                 |
 |     4 | cpukit/librpc/src/rpc/get_myaddress.c:130:5                 |
 |     2 | cpukit/libnetworking/libc/getservbyport.c:52:4              |
 |     2 | cpukit/libnetworking/netinet/tcp_usrreq.c:106:16            |
 |     2 | cpukit/librpc/src/rpc/rpc_dtablesize.c:55:1                 |
 |     2 | cpukit/libnetworking/libc/getservbyname.c:52:4              |
 |     2 | cpukit/librpc/src/rpc/rpc_prot.c:215:2                      |
 |     2 | cpukit/librpc/src/rpc/get_myaddress.c:80:1                  |
 |     2 | cpukit/librpc/src/rpc/rpc_prot.c:255:2                      |
 |     2 | cpukit/librpc/src/rpc/rpcdname.c:78:1                       |
 |     2 | cpukit/libnetworking/libc/res_update.c:90:12                |
 |     2 | cpukit/libnetworking/netinet/tcp_output.c:408:4             |
 |     2 | cpukit/libnetworking/netinet/tcp_output.c:422:5             |
 |     2 | cpukit/librpc/src/rpc/getrpcport.c:52:1                     |
 |     2 | cpukit/libnetworking/netinet/tcp_usrreq.c:497:16            |
 |     2 | cpukit/libnetworking/lib/getprotoby.c:37:1                  |
 |     2 | cpukit/librpc/src/rpc/rpc_prot.c:115:2                      |
 |     2 | cpukit/librpc/src/rpc/auth_unix.c:102:1                     |
 |     2 | cpukit/libnetworking/netinet/tcp_output.c:393:4             |
 |     2 | cpukit/libnetworking/lib/getprotoby.c:22:1                  |
 |     2 | cpukit/librpc/src/rpc/svc_simple.c:71:1                     |
 |     2 | cpukit/libnetworking/netinet/tcp_output.c:429:5             |
 |     2 | cpukit/libnetworking/netinet/tcp_usrreq.c:182:16            |
 |     2 | cpukit/librpc/src/rpc/clnt_simple.c:65:1                    |
 |     2 | cpukit/librpc/src/rpc/rpc_prot.c:138:1                      |
 |     2 | cpukit/librpc/src/rpc/rpc_prot.c:105:1                      |
 |     2 | cpukit/librpc/src/rpc/svc_udp.c:346:5                       |
 |     2 | cpukit/librpc/src/rpc/svc_auth_unix.c:147:1                 |
 |     2 | cpukit/librpc/src/rpc/svc_auth_unix.c:59:1                  |
 |     2 | cpukit/libnetworking/netinet/tcp_usrreq.c:292:16            |
 |     2 | cpukit/libnetworking/libc/gethostnamadr.c:169:4             |
 |     2 | cpukit/librpc/src/rpc/rtime.c:75:1                          |
 |     2 | cpukit/libnetworking/netinet/tcp_usrreq.c:484:16            |
 |     2 | cpukit/librpc/src/rpc/rpc_prot.c:146:2                      |
 | arm : 1 warning(s)                                                  |
 |   Shared :    0 |     BSP :    0 | Network :  175 |    Tests :    0 |
 |     5 | cpukit/libnetworking/netinet/in_cksum.c:84:1                |
 | i386 : 1 warning(s)                                                 |
 |   Shared :    0 |     BSP :    0 | Network :   35 |    Tests :    0 |
 |     1 | cpukit/libnetworking/netinet/in_cksum_i386.h:30:1           |
 | sparc : 5 warning(s)                                                |
 |   Shared :    4 |     BSP :    0 | Network :   68 |    Tests :    0 |
 |     2 | c/src/libchip/network/smc91111.c:1237:8                     |
 |     2 | c/src/libchip/network/smc91111.c:1048:12                    |
 |     2 | c/src/libchip/network/smc91111.c:442:16                     |
 |     2 | c/src/lib/libbsp/sparc/shared/amba/ahbstat.c:185:62         |
 |     2 | c/src/lib/libbsp/sparc/shared/amba/ahbstat.c:185:48         |
 | By BSP (total : 288)                                                |
 | common : 39 warning(s)                                              |
 |   Shared :    2 |     BSP :    0 | Network :  242 |    Tests :    0 |
 |     2 | cpukit/librpc/src/rpc/get_myaddress.c:130:5                 |
 |     1 | cpukit/libnetworking/libc/getservbyport.c:52:4              |
 |     1 | cpukit/libnetworking/netinet/tcp_usrreq.c:106:16            |
 |     1 | cpukit/librpc/src/rpc/rpc_dtablesize.c:55:1                 |
 |     1 | cpukit/libnetworking/libc/getservbyname.c:52:4              |
 |     1 | cpukit/librpc/src/rpc/rpc_prot.c:215:2                      |
 |     1 | cpukit/librpc/src/rpc/get_myaddress.c:80:1                  |
 |     1 | cpukit/librpc/src/rpc/rpc_prot.c:255:2                      |
 |     1 | c/src/libchip/network/smc91111.c:1237:8                     |
 |     1 | cpukit/librpc/src/rpc/rpcdname.c:78:1                       |
 |     1 | cpukit/libnetworking/libc/res_update.c:90:12                |
 |     1 | cpukit/libnetworking/netinet/tcp_output.c:408:4             |
 |     1 | cpukit/libnetworking/netinet/tcp_output.c:422:5             |
 |     1 | cpukit/librpc/src/rpc/getrpcport.c:52:1                     |
 |     1 | cpukit/libnetworking/netinet/tcp_usrreq.c:497:16            |
 |     1 | cpukit/libnetworking/lib/getprotoby.c:37:1                  |
 |     1 | cpukit/librpc/src/rpc/rpc_prot.c:115:2                      |
 |     1 | cpukit/librpc/src/rpc/auth_unix.c:102:1                     |
 |     1 | c/src/libchip/network/smc91111.c:1048:12                    |
 |     1 | cpukit/libnetworking/netinet/tcp_output.c:393:4             |
 |     1 | cpukit/libnetworking/lib/getprotoby.c:22:1                  |
 |     1 | cpukit/librpc/src/rpc/svc_simple.c:71:1                     |
 |     1 | cpukit/libnetworking/netinet/tcp_output.c:429:5             |
 |     1 | cpukit/libnetworking/netinet/tcp_usrreq.c:182:16            |
 |     1 | cpukit/librpc/src/rpc/clnt_simple.c:65:1                    |
 |     1 | c/src/libchip/network/smc91111.c:442:16                     |
 |     1 | cpukit/librpc/src/rpc/rpc_prot.c:138:1                      |
 |     1 | cpukit/librpc/src/rpc/rpc_prot.c:105:1                      |
 |     1 | cpukit/librpc/src/rpc/svc_udp.c:346:5                       |
 |     1 | cpukit/librpc/src/rpc/svc_auth_unix.c:147:1                 |
 |     1 | cpukit/librpc/src/rpc/svc_auth_unix.c:59:1                  |
 |     1 | cpukit/libnetworking/netinet/tcp_usrreq.c:292:16            |
 |     1 | c/src/lib/libbsp/sparc/shared/amba/ahbstat.c:185:62         |
 |     1 | cpukit/libnetworking/libc/gethostnamadr.c:169:4             |
 |     1 | cpukit/librpc/src/rpc/rtime.c:75:1                          |
 |     1 | cpukit/libnetworking/netinet/tcp_usrreq.c:484:16            |
 |     1 | cpukit/librpc/src/rpc/rpc_prot.c:146:2                      |
 |     1 | cpukit/libnetworking/netinet/in_cksum.c:84:1                |
 |     1 | c/src/lib/libbsp/sparc/shared/amba/ahbstat.c:185:48         |
 | arm/altcycv_devkit : 0 warning(s)                                   |
 | arm/altcycv_devkit_smp : 0 warning(s)                               |
 | arm/xilinx_zynq_zc702 : 0 warning(s)                                |
 | arm/xilinx_zynq_zc706 : 0 warning(s)                                |
 | arm/xilinx_zynq_zedboard : 0 warning(s)                             |
 | i386/pc686 : 1 warning(s)                                           |
 | sparc/leon2 : 0 warning(s)                                          |
 | sparc/leon3 : 0 warning(s)                                          |
 | By Build (total : 288)                                              |
 | common : 0 warning(s)                                               |
 | tests : 40 warning(s)                                               |
 |   Shared :    4 |     BSP :    0 | Network :  278 |    Tests :    0 |
 |    16 | cpukit/librpc/src/rpc/get_myaddress.c:130:5                 |
 |     8 | cpukit/libnetworking/libc/getservbyport.c:52:4              |
 |     8 | cpukit/libnetworking/netinet/tcp_usrreq.c:106:16            |
 |     8 | cpukit/libnetworking/netinet/tcp_output.c:393:4             |
 |     8 | cpukit/libnetworking/libc/getservbyname.c:52:4              |
 |     8 | cpukit/librpc/src/rpc/rpc_prot.c:215:2                      |
 |     8 | cpukit/librpc/src/rpc/get_myaddress.c:80:1                  |
 |     8 | cpukit/librpc/src/rpc/rpc_prot.c:255:2                      |
 |     8 | cpukit/librpc/src/rpc/rpcdname.c:78:1                       |
 |     8 | cpukit/libnetworking/libc/res_update.c:90:12                |
 |     8 | cpukit/libnetworking/netinet/tcp_output.c:408:4             |
 |     8 | cpukit/libnetworking/netinet/tcp_output.c:422:5             |
 |     8 | cpukit/librpc/src/rpc/getrpcport.c:52:1                     |
 |     8 | cpukit/libnetworking/netinet/tcp_usrreq.c:497:16            |
 |     8 | cpukit/libnetworking/lib/getprotoby.c:37:1                  |
 |     8 | cpukit/librpc/src/rpc/rpc_prot.c:105:1                      |
 |     8 | cpukit/librpc/src/rpc/auth_unix.c:102:1                     |
 |     8 | cpukit/librpc/src/rpc/rpc_dtablesize.c:55:1                 |
 |     8 | cpukit/libnetworking/lib/getprotoby.c:22:1                  |
 |     8 | cpukit/librpc/src/rpc/svc_simple.c:71:1                     |
 |     8 | cpukit/libnetworking/netinet/tcp_output.c:429:5             |
 |     8 | cpukit/libnetworking/netinet/tcp_usrreq.c:182:16            |
 |     8 | cpukit/librpc/src/rpc/clnt_simple.c:65:1                    |
 |     8 | cpukit/librpc/src/rpc/rpc_prot.c:138:1                      |
 |     8 | cpukit/librpc/src/rpc/rpc_prot.c:115:2                      |
 |     8 | cpukit/librpc/src/rpc/svc_udp.c:346:5                       |
 |     8 | cpukit/librpc/src/rpc/svc_auth_unix.c:147:1                 |
 |     8 | cpukit/librpc/src/rpc/svc_auth_unix.c:59:1                  |
 |     8 | cpukit/libnetworking/netinet/tcp_usrreq.c:292:16            |
 |     8 | cpukit/libnetworking/libc/gethostnamadr.c:169:4             |
 |     8 | cpukit/librpc/src/rpc/rtime.c:75:1                          |
 |     8 | cpukit/libnetworking/netinet/tcp_usrreq.c:484:16            |
 |     8 | cpukit/librpc/src/rpc/rpc_prot.c:146:2                      |
 | Warning Map                                                         |
 | i386/pc686-tests : 34                                               |
 |    warning: #warning "implement a proper getservbyport_r" [-Wcpp]   |
 |    warning: incompatible implicit declaration of built-in function  |
 |    'memmove'                                                        |
 |    warning: variable 'tp' set but not used [-Wunused-but-set-       |
 |    variable]                                                        |
 |    warning: no previous prototype for '_rpc_dtablesize'             |
 |    [-Wmissing-prototypes]                                           |
 |    warning: enumeration value '_ACCEPT_STAT' not handled in switch  |
 |    [-Wswitch]                                                       |
 |    warning: no previous prototype for 'get_myaddress' [-Wmissing-   |
 |    prototypes]                                                      |
 |    warning: enumeration value '_REJECT_STAT' not handled in switch  |
 |    [-Wswitch]                                                       |
 |    warning: no previous prototype for '_rpc_get_default_domain'     |
 |    warning: variable 'ttl' set but not used [-Wunused-but-set-      |
 |    variable]                                                        |
 |    warning: dereferencing type-punned pointer will break strict-    |
 |    aliasing rules [-Wstrict-aliasing]                               |
 |    warning: no previous prototype for 'getrpcport' [-Wmissing-      |
 |    prototypes]                                                      |
 |    warning: no previous prototype for 'in_cksum' [-Wmissing-        |
 |    prototypes]                                                      |
 |    variable]                                                        |
 |    warning: no previous prototype for 'getprotobynumber_static'     |
 |    [-Wswitch]                                                       |
 |    warning: no previous prototype for 'set_rpc_maxgrouplist'        |
 |    warning: no previous prototype for 'getprotobyname_static'       |
 |    warning: no previous prototype for 'registerrpc' [-Wmissing-     |
 |    prototypes]                                                      |
 |    variable]                                                        |
 |    warning: no previous prototype for 'callrpc' [-Wmissing-         |
 |    prototypes]                                                      |
 |    warning: no previous prototype for 'xdr_rejected_reply'          |
 |    warning: no previous prototype for 'xdr_accepted_reply'          |
 |    warning: no previous prototype for 'svcudp_enablecache'          |
 |    warning: no previous prototype for '_svcauth_short' [-Wmissing-  |
 |    prototypes]                                                      |
 |    warning: no previous prototype for '_svcauth_unix' [-Wmissing-   |
 |    prototypes]                                                      |
 |    variable]                                                        |
 |    warning: #warning "implement a proper gethostbyaddr_r" [-Wcpp]   |
 |    warning: no previous prototype for 'rtime' [-Wmissing-           |
 |    prototypes]                                                      |
 |    variable]                                                        |
 |    [-Wswitch]                                                       |
 | arm/xilinx_zynq_zc706-tests : 34                                    |
 |    'memmove'                                                        |
 |    variable]                                                        |
 |    [-Wswitch]                                                       |
 |    prototypes]                                                      |
 |    [-Wswitch]                                                       |
 |    variable]                                                        |
 |    prototypes]                                                      |
 |    variable]                                                        |
 |    [-Wswitch]                                                       |
 |    prototypes]                                                      |
 |    variable]                                                        |
 |    prototypes]                                                      |
 |    prototypes]                                                      |
 |    prototypes]                                                      |
 |    variable]                                                        |
 |    prototypes]                                                      |
 |    variable]                                                        |
 |    [-Wswitch]                                                       |
 |    prototypes]                                                      |
 | sparc/leon3-tests : 38                                              |
 |    'memmove'                                                        |
 |    variable]                                                        |
 |    [-Wswitch]                                                       |
 |    prototypes]                                                      |
 |    [-Wswitch]                                                       |
 |    warning: format '%x' expects argument of type 'unsigned int',    |
 |    but argument 2 has type 'short unsigned int *' [-Wformat=]       |
 |    variable]                                                        |
 |    prototypes]                                                      |
 |    variable]                                                        |
 |    [-Wswitch]                                                       |
 |    warning: format '%d' expects argument of type 'int', but         |
 |    argument 2 has type 'rtems_vector_number {aka long unsigned      |
 |    int}' [-Wformat=]                                                |
 |    prototypes]                                                      |
 |    variable]                                                        |
 |    prototypes]                                                      |
 |    but argument 2 has type 'caddr_t {aka char *}' [-Wformat=]       |
 |    prototypes]                                                      |
 |    prototypes]                                                      |
 |    variable]                                                        |
 |    warning: format '%ld' expects argument of type 'long int', but   |
 |    argument 5 has type 'int' [-Wformat=]                            |
 |    prototypes]                                                      |
 |    variable]                                                        |
 |    [-Wswitch]                                                       |
 |    argument 4 has type 'int' [-Wformat=]                            |
 | arm/altcycv_devkit_smp-tests : 34                                   |
 |    'memmove'                                                        |
 |    variable]                                                        |
 |    [-Wswitch]                                                       |
 |    prototypes]                                                      |
 |    [-Wswitch]                                                       |
 |    variable]                                                        |
 |    prototypes]                                                      |
 |    variable]                                                        |
 |    [-Wswitch]                                                       |
 |    prototypes]                                                      |
 |    variable]                                                        |
 |    prototypes]                                                      |
 |    prototypes]                                                      |
 |    prototypes]                                                      |
 |    variable]                                                        |
 |    prototypes]                                                      |
 |    variable]                                                        |
 |    [-Wswitch]                                                       |
 |    prototypes]                                                      |
 | arm/xilinx_zynq_zc702-tests : 34                                    |
 |    'memmove'                                                        |
 |    variable]                                                        |
 |    [-Wswitch]                                                       |
 |    prototypes]                                                      |
 |    [-Wswitch]                                                       |
 |    variable]                                                        |
 |    prototypes]                                                      |
 |    variable]                                                        |
 |    [-Wswitch]                                                       |
 |    prototypes]                                                      |
 |    variable]                                                        |
 |    prototypes]                                                      |
 |    prototypes]                                                      |
 |    prototypes]                                                      |
 |    variable]                                                        |
 |    prototypes]                                                      |
 |    variable]                                                        |
 |    [-Wswitch]                                                       |
 |    prototypes]                                                      |
 | arm/xilinx_zynq_zedboard-tests : 34                                 |
 |    'memmove'                                                        |
 |    variable]                                                        |
 |    [-Wswitch]                                                       |
 |    prototypes]                                                      |
 |    [-Wswitch]                                                       |
 |    variable]                                                        |
 |    prototypes]                                                      |
 |    variable]                                                        |
 |    [-Wswitch]                                                       |
 |    prototypes]                                                      |
 |    variable]                                                        |
 |    prototypes]                                                      |
 |    prototypes]                                                      |
 |    prototypes]                                                      |
 |    variable]                                                        |
 |    prototypes]                                                      |
 |    variable]                                                        |
 |    [-Wswitch]                                                       |
 |    prototypes]                                                      |
 | sparc/leon2-tests : 38                                              |
 |    'memmove'                                                        |
 |    variable]                                                        |
 |    [-Wswitch]                                                       |
 |    prototypes]                                                      |
 |    [-Wswitch]                                                       |
 |    variable]                                                        |
 |    prototypes]                                                      |
 |    variable]                                                        |
 |    [-Wswitch]                                                       |
 |    int}' [-Wformat=]                                                |
 |    prototypes]                                                      |
 |    variable]                                                        |
 |    prototypes]                                                      |
 |    prototypes]                                                      |
 |    prototypes]                                                      |
 |    variable]                                                        |
 |    prototypes]                                                      |
 |    variable]                                                        |
 |    [-Wswitch]                                                       |
 | arm/altcycv_devkit-tests : 34                                       |
 |    'memmove'                                                        |
 |    variable]                                                        |
 |    [-Wswitch]                                                       |
 |    prototypes]                                                      |
 |    [-Wswitch]                                                       |
 |    variable]                                                        |
 |    prototypes]                                                      |
 |    variable]                                                        |
 |    [-Wswitch]                                                       |
 |    prototypes]                                                      |
 |    variable]                                                        |
 |    prototypes]                                                      |
 |    prototypes]                                                      |
 |    prototypes]                                                      |
 |    variable]                                                        |
 |    prototypes]                                                      |
 |    variable]                                                        |
 |    [-Wswitch]                                                       |
 |    prototypes]                                                      |
