[PATCH] cpukit: Fix __RTEMS_REVISION__ define
Wed May 3 06:28:46 UTC 2017
On 03/05/17 08:17, Chris Johns wrote:
> On 3/5/17 3:40 pm, Sebastian Huber wrote:
>> On 03/05/17 07:28, Chris Johns wrote:
>>> On 3/5/17 3:09 pm, Sebastian Huber wrote:
>>>> On 02/05/17 23:30, Chris Johns wrote:
>>>>> On 2/5/17 6:20 pm, Sebastian Huber wrote:
>>>>> If you want to add this test please extract the version details from
>>>>> the
>>>>> build system
>>>> Can we trust the build system?
>>> Given the header file with the values it created by the build system yes
>>> we can.
>> I don't think we can trust the build system. The requirement for a
>> release is that the version macros should have specific values. We
>> should test that this is the case.
> We have to trust the build system for a clean or fresh build and if we
> cannot not it is a bug. To state otherwise expands the scope of
> uncertainty and I do not believe we need too.
> I will state again, doing this breaks the release process. I am sorry
> but this is just now the release model and supporting configuration
> control structures exist.
I still don't see how this breaks the release process. One task of it is
surly to change the version from N to N + 1. This requires to modify
some files (with a script). This test would be just one of these files.
Some are *.m4 files, some *.c files, it doesn't matter.
>> Maybe we have some time in the future something like this:
>> Requirement 2341: There shall be a C pre-processor define
>> __RTEMS_MAJOR__ available via #include <rtems.h> defined to 123.
> I doubt this would be in the RTEMS Project's requirements. It might be
> in a qualification package for the specific qualification effort.
It is a RTEMS Project's requirement. Its just not explicitly stated. If
you release RTEMS 3.4.531 a user expects to have
#define __RTEMS_MAJOR__ 3
#define __RTEMS_MINOR__ 4
#define __RTEMS_REVISION__ 531
> How
> that define it created is for the RTEMS Project to determine.
Yes, but somehow the define must exist with the right value and this is
what needs to be tested.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
