[PATCH] sptests/spversion01: New test
Thu May 4 05:31:00 UTC 2017
 testsuites/sptests/Makefile.am                 |  1 +
 testsuites/sptests/configure.ac                |  1 +
 testsuites/sptests/spversion01/Makefile.am     | 19 +++++++++
 testsuites/sptests/spversion01/init.c          | 55 ++++++++++++++++++++++++++
 testsuites/sptests/spversion01/spversion01.doc | 11 ++++++
 testsuites/sptests/spversion01/spversion01.scn |  2 +
 6 files changed, 89 insertions(+)
 create mode 100644 testsuites/sptests/spversion01/Makefile.am
 create mode 100644 testsuites/sptests/spversion01/init.c
 create mode 100644 testsuites/sptests/spversion01/spversion01.doc
 create mode 100644 testsuites/sptests/spversion01/spversion01.scn
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index c50e757..d47bbca 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -33,6 +33,7 @@ _SUBDIRS = \
     spsignal_err01 spport_err01 spmsgq_err01 spmsgq_err02 spsem_err01 \
     spsem_err02 sptask_err01 spevent_err03 sptask_err03 sptask_err02 \
     sptask_err04 spclock_err01
+_SUBDIRS += spversion01
 _SUBDIRS += spfatal29
 _SUBDIRS += spmutex01
 _SUBDIRS += spextensions01
diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
index e14c937..a797d91 100644
--- a/testsuites/sptests/configure.ac
+++ b/testsuites/sptests/configure.ac
@@ -36,6 +36,7 @@ AM_CONDITIONAL(HAS_SMP,test "$rtems_cv_RTEMS_SMP" = "yes")
 # Explicitly list all Makefiles here
 AC_CONFIG_FILES([Makefile
+spversion01/Makefile
 spmutex01/Makefile
 spextensions01/Makefile
 sptimerserver01/Makefile
diff --git a/testsuites/sptests/spversion01/Makefile.am b/testsuites/sptests/spversion01/Makefile.am
new file mode 100644
index 0000000..73134d8
--- /dev/null
+++ b/testsuites/sptests/spversion01/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = spversion01
+spversion01_SOURCES = init.c
+dist_rtems_tests_DATA = spversion01.scn spversion01.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(spversion01_OBJECTS)
+LINK_LIBS = $(spversion01_LDLIBS)
+spversion01$(EXEEXT): $(spversion01_OBJECTS) $(spversion01_DEPENDENCIES)
+	@rm -f spversion01$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/sptests/spversion01/init.c b/testsuites/sptests/spversion01/init.c
index 0000000..820feee
--- /dev/null
+++ b/testsuites/sptests/spversion01/init.c
@@ -0,0 +1,55 @@
+ * Copyright (c) 2017 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems.h>
+#include "tmacros.h"
+const char rtems_test_name[] = "SPVERSION 1";
+#ifndef __RTEMS_MAJOR__
+#error "__RTEMS_MAJOR__ not defined"
+#endif
+#ifndef __RTEMS_MINOR__
+#error "__RTEMS_MINOR__ not defined"
+#endif
+#ifndef __RTEMS_REVISION__
+#error "__RTEMS_REVISION__ not defined"
+#endif
+static void Init(rtems_task_argument arg)
+  TEST_BEGIN();
+  TEST_END();
+  rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/sptests/spversion01/spversion01.doc b/testsuites/sptests/spversion01/spversion01.doc
index 0000000..d72e20b
--- /dev/null
+++ b/testsuites/sptests/spversion01/spversion01.doc
@@ -0,0 +1,11 @@
+This file describes the directives and concepts tested by this test set.
+test set name: spversion01
+directives:
+  None.
+concepts:
+  Ensure that the RTEMS version macros are defined.
diff --git a/testsuites/sptests/spversion01/spversion01.scn b/testsuites/sptests/spversion01/spversion01.scn
index 0000000..735ed11
--- /dev/null
+++ b/testsuites/sptests/spversion01/spversion01.scn
@@ -0,0 +1,2 @@
+*** BEGIN OF TEST SPVERSION 1 ***
+*** END OF TEST SPVERSION 1 ***
1.8.4.5
