Execution Time of Whetstone on LEON3
Joel Sherrill
joel at rtems.org
Thu May 4 14:00:31 UTC 2017
On Thu, May 4, 2017 at 12:34 AM, Sebastian Huber <
> On 03/05/17 22:52, Joel Sherrill wrote:
>> Has anyone run the whetstone benchmark on real leon3 HW?
>> I'm almost at 20 minutes of simulated CPU time on tsim so
>> am suspicious something is wrong.
>> Any ideas?
> Maybe soft-float plus a low CPU frequency? Do you have a function
> profiling histogram of the execution?
It is the default leon3 build and the leon3 is simulated at 50Mhz. I have
never used profiling on tsim. Any guidance?
The test did finally finish and here is the output of tsim's perf command:
*** END OF TEST WHETSTONE ***
Program exited normally.
tsim> perf
Cycles : 74462444473
Instructions : 45632185502
Overall CPI : 1.63
CPU performance (50.0 MHz) : 30.64 MOPS (30.64 MIPS, 0.00 MFLOPS)
Cache hit rate : 98.0 % (inst: 97.9, data:99.7)
AHB bandwidth utilisation : 34.8 % (inst: 14.1, data: 20.8)
Simulated time : 1489.25 s
Processor utilisation : 100.00 %
Real-time performance : 122.02 %
Simulator performance : 37.39 MIPS
Used time (sys + user) : 1220.46 s
So it just took a LONG time.
--joel
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170504/c33ca25d/attachment.html>
