Execution Time of Whetstone on LEON3
Jiri Gaisler
jiri at gaisler.se
Thu May 4 19:27:24 UTC 2017
On 05/04/2017 04:00 PM, Joel Sherrill wrote:
> On Thu, May 4, 2017 at 12:34 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> On 03/05/17 22:52, Joel Sherrill wrote:
> Has anyone run the whetstone benchmark on real leon3 HW?
> I'm almost at 20 minutes of simulated CPU time on tsim so
> am suspicious something is wrong.
> Any ideas?
> Maybe soft-float plus a low CPU frequency? Do you have a function
> profiling histogram of the execution?
> It is the default leon3 build and the leon3 is simulated at 50Mhz. I
> have
> never used profiling on tsim. Any guidance?
> The test did finally finish and here is the output of tsim's perf
> command:
> *** END OF TEST WHETSTONE ***
> Program exited normally.
> tsim> perf
> Cycles : 74462444473
> Instructions : 45632185502
> Overall CPI : 1.63
> CPU performance (50.0 MHz) : 30.64 MOPS (30.64 MIPS, 0.00 MFLOPS)
> Cache hit rate : 98.0 % (inst: 97.9, data:99.7)
> AHB bandwidth utilisation : 34.8 % (inst: 14.1, data: 20.8)
> Simulated time : 1489.25 s
> Processor utilisation : 100.00 %
> Real-time performance : 122.02 %
> Simulator performance : 37.39 MIPS
> Used time (sys + user) : 1220.46 s
> So it just took a LONG time.
> --joel
Note that TSIM reports 0.0 MFLOPS. This means that soft-float was used
to compile the benchmark. Using hard-float should give about 100x
speed-up ...
Jiri.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170504/78bae3a2/attachment.html>
