[PATCH 06/32] bsp/leon3: Cleaner namespace for LEON3 debug UART
Daniel Hellstrom daniel at gaisler.com
Thu May 11 14:25:51 UTC 2017
Prefix BSP specific symbols with BSP name:
dbg_uart -> leon3_debug_uart
debug_uart_index -> leon3_debug_uart_index
 .../libbsp/sparc/leon3/console/printk_support.c    | 34 +++++++++++-----------
 c/src/lib/libbsp/sparc/leon3/include/leon.h        |  2 +-
 c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c  |  8 +++--
 3 files changed, 23 insertions(+), 21 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/leon3/console/printk_support.c b/c/src/lib/libbsp/sparc/leon3/console/printk_support.c
index 27c2a72..f7e1fb6 100644
--- a/c/src/lib/libbsp/sparc/leon3/console/printk_support.c
+++ b/c/src/lib/libbsp/sparc/leon3/console/printk_support.c
@@ -25,8 +25,8 @@
 #include <bsp/apbuart.h>
 #include <bsp/apbuart_termios.h>
-int debug_uart_index __attribute__((weak)) = 0;
-struct apbuart_regs *dbg_uart = NULL;
+int leon3_debug_uart_index __attribute__((weak)) = 0;
+struct apbuart_regs *leon3_debug_uart = NULL;
 /* Before UART driver has registered (or when no UART is available), calls to
  * printk that gets to bsp_out_char() will be filling data into the
@@ -45,24 +45,24 @@ static void bsp_debug_uart_init(void)
   struct ambapp_dev *adev;
   struct ambapp_apb_info *apb;
-  /* Update debug_uart_index to index used as debug console.
-   * Let user select Debug console by setting debug_uart_index. If the
-   * BSP is to provide the default UART (debug_uart_index==0):
+  /* Update leon3_debug_uart_index to index used as debug console. Let user
+   * select Debug console by setting leon3_debug_uart_index. If the BSP is to
+   * provide the default UART (leon3_debug_uart_index==0):
    *   non-MP: APBUART[0] is debug console
    *   MP: LEON CPU index select UART
-  if (debug_uart_index == 0) {
+  if (leon3_debug_uart_index == 0) {
 #if defined(RTEMS_MULTIPROCESSING)
-    debug_uart_index = LEON3_Cpu_Index;
+    leon3_debug_uart_index = LEON3_Cpu_Index;
 #else
-    debug_uart_index = 0;
+    leon3_debug_uart_index = 0;
 #endif
   } else {
-    debug_uart_index = debug_uart_index - 1; /* User selected dbg-console */
+    leon3_debug_uart_index--; /* User selected dbg-console */
   /* Find APBUART core for System Debug Console */
-  i = debug_uart_index;
+  i = leon3_debug_uart_index;
   adev = (void *)ambapp_for_each(&ambapp_plb, (OPTIONS_ALL|OPTIONS_APB_SLVS),
                                  VENDOR_GAISLER, GAISLER_APBUART,
                                  ambapp_find_by_idx, (void *)&i);
@@ -71,9 +71,9 @@ static void bsp_debug_uart_init(void)
      * for printk
     apb = (struct ambapp_apb_info *)adev->devinfo;
-    dbg_uart = (struct apbuart_regs *)apb->start;
-    dbg_uart->ctrl |= APBUART_CTRL_RE | APBUART_CTRL_TE;
-    dbg_uart->status = 0;
+    leon3_debug_uart = (struct apbuart_regs *)apb->start;
+    leon3_debug_uart->ctrl |= APBUART_CTRL_RE | APBUART_CTRL_TE;
+    leon3_debug_uart->status = 0;
@@ -86,14 +86,14 @@ RTEMS_SYSINIT_ITEM(
 /* putchar/getchar for printk */
 static void bsp_out_char(char c)
-  if (dbg_uart == NULL) {
+  if (leon3_debug_uart == NULL) {
     /* Local debug buffer when UART driver has not registered */
     pre_printk_dbgbuf[pre_printk_pos++] = c;
     pre_printk_pos = pre_printk_pos & (sizeof(pre_printk_dbgbuf)-1);
     return;
-  apbuart_outbyte_polled(dbg_uart, c, 1, 1);
+  apbuart_outbyte_polled(leon3_debug_uart, c, 1, 1);
@@ -108,10 +108,10 @@ static int bsp_in_char(void)
   int tmp;
     return EOF;
-  while ((tmp = apbuart_inbyte_nonblocking(dbg_uart)) < 0)
+  while ((tmp = apbuart_inbyte_nonblocking(leon3_debug_uart)) < 0)
   return tmp;
diff --git a/c/src/lib/libbsp/sparc/leon3/include/leon.h b/c/src/lib/libbsp/sparc/leon3/include/leon.h
index 36f9495..9b2597f 100644
--- a/c/src/lib/libbsp/sparc/leon3/include/leon.h
+++ b/c/src/lib/libbsp/sparc/leon3/include/leon.h
@@ -364,7 +364,7 @@ extern int syscon_uart_index;
  * 3 = APBUART[2]
-extern int debug_uart_index;
+extern int leon3_debug_uart_index;
 /* Let user override which on-chip TIMER core will be used for system clock
  * timer. This controls which timer core will be accociated with
diff --git a/c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c b/c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c
index c79d408..e406bc0 100644
--- a/c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c
+++ b/c/src/lib/libbsp/sparc/shared/uart/apbuart_cons.c
@@ -48,7 +48,9 @@ extern void apbuart_outbyte_polled(
   int do_cr_on_newline,
   int wait_sent);
 extern int apbuart_inbyte_nonblocking(struct apbuart_regs *regs);
-extern struct apbuart_regs *dbg_uart; /* The debug UART */
+#ifdef LEON3
+extern struct apbuart_regs *leon3_debug_uart; /* The debug UART */
+#endif
 /* Probed hardware capabilities */
 enum {
@@ -263,7 +265,7 @@ int apbuart_init1(struct drvmgr_dev *dev)
 	db = 0;
 #ifdef LEON3
-	if (priv->regs == dbg_uart) {
+	if (priv->regs == leon3_debug_uart) {
 		db = priv->regs->ctrl & (LEON_REG_UART_CTRL_RE |
 					LEON_REG_UART_CTRL_TE |
 					LEON_REG_UART_CTRL_PE |
@@ -510,7 +512,7 @@ static void last_close(
 #ifdef LEON3
 	/* Disable TX/RX if not used for DEBUG */
-	if (uart->regs != dbg_uart)
+	if (uart->regs != leon3_debug_uart)
 		uart->regs->ctrl &= ~(APBUART_CTRL_RE | APBUART_CTRL_TE);
 #endif
2.7.4
