[PATCH 14/32] leon, grcan: redesigned bus-off and AHB error handling
Daniel Hellstrom daniel at gaisler.com
Thu May 11 14:25:59 UTC 2017
When bus-off condition is detected by the ISR, it sets the started flag to
STATE_BUSOFF. This is monitored by the user functions grcan_read() and
grcan_write() each time they want to enable DMA or update interrupt mask. If
they detect that ISR has detected bus-off then they will return either with an
error or with the number of CAN messages processed. Future calls to functions
which require STARTED mode will be rejected and grcan_isstarted() will return
0. The next call to grcan_stop() will do the transition from BUSOFF->STOPPED
and the device can then be started again with grcan_start().
Similar to a bus-off condition, the AHB error condition detected by the ISR
will trigger the same shut-down logic of the driver. The difference is that
the state entered is STATE_AHBERR and the routines will return a different
value to indicate AHB error state.
This commit also fixes an issue where ISR was not always unregistered on close.
User functions can cause these transitions:
  STATE_STOPPED -> STATE_STARTED (grcan_start)
  STATE_STARTED -> STATE_STOPPED (grcan_stop)
  STATE_BUSOFF  -> STATE_STOPPED (grcan_stop, grcan_close)
  STATE_AHBERR  -> STATE_STOPPED (grcan_stop, grcan_close)
ISR can cause these transition
  STATE_STARTED -> STATE_BUSOFF (grcan_interrupt)
  STATE_STARTED -> STATE_AHBERR (grcan_interrupt)
STATE_BUSOFF/AHBERR is entered from ISR on bus-off condition. At transition
the ISR disables DMA, masks all interrupts and flushes semaphores.
Other related updates:
 * Statistics are updated from the ISR. Update is now spin-locked to ensure a
   consistent user view.
 * The debug output has been updated to include state changes.
 * For read/write/flush, return error (-4) if driver aborted the operation
   due to bus-off. Likewise if abourted due to AHB error -5 is returned.
 * Collect bus-off statistics
Related to the new BUSOFF and AHBERR states the API has been updated to
reflect the current SW driver state. The isstarted() function has been
replaced with get_state().
 c/src/lib/libbsp/sparc/shared/can/grcan.c     | 408 +++++++++++++++++---------
 c/src/lib/libbsp/sparc/shared/include/grcan.h |  80 ++++-
 2 files changed, 334 insertions(+), 154 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/shared/can/grcan.c b/c/src/lib/libbsp/sparc/shared/can/grcan.c
index 515efa3..45b7af1 100644
--- a/c/src/lib/libbsp/sparc/shared/can/grcan.c
+++ b/c/src/lib/libbsp/sparc/shared/can/grcan.c
@@ -92,11 +92,11 @@
 /* Uncomment for debug output */
 /****************** DEBUG Definitions ********************/
-#define DBG_IOCTRL 1
 #define DBG_TX 2
 #define DBG_RX 4
+#define DBG_STATE 8
-#define DEBUG_FLAGS (DBG_IOCTRL | DBG_RX | DBG_TX )
+#define DEBUG_FLAGS (DBG_STATE | DBG_RX | DBG_TX )
 #define DEBUG
 #define DEBUGFUNCS
@@ -105,6 +105,13 @@
+int state2err[4] = {
+	/* STATE_STOPPED */ GRCAN_RET_NOTSTARTED,
+	/* STATE_STARTED */ GRCAN_RET_OK,
+	/* STATE_BUSOFF  */ GRCAN_RET_BUSOFF,
+	/* STATE_AHBERR  */ GRCAN_RET_AHBERR
 struct grcan_msg {
 	unsigned int head[2];
 	unsigned char data[8];
@@ -156,13 +163,13 @@ struct grcan_priv {
 static void __inline__ grcan_hw_reset(struct grcan_regs *regs);
-static unsigned int grcan_hw_read_try(
+static int grcan_hw_read_try(
 	struct grcan_priv *pDev,
 	struct grcan_regs *regs,
 	CANMsg *buffer,
 	int max);
-static unsigned int grcan_hw_write_try(
+static int grcan_hw_write_try(
 	CANMsg *buffer,
@@ -601,17 +608,6 @@ static unsigned int grcan_hw_txspace(
 	return left / GRCAN_MSG_SIZE - WRAP_AROUND_TX_MSGS;
-static int grcan_hw_rx_ongoing(struct grcan_regs *regs)
-	return READ_REG(&regs->rx0ctrl) & GRCAN_RXCTRL_ONGOING;
-static int grcan_hw_tx_ongoing(struct grcan_regs *regs)
-	return READ_REG(&regs->tx0ctrl) & GRCAN_TXCTRL_ONGOING;
 #define MIN_TSEG1 1
 #define MIN_TSEG2 2
 #define MAX_TSEG1 14
@@ -723,7 +719,7 @@ static int grcan_calc_timing(
 	return 0;
 	CANMsg * buffer,
@@ -733,7 +729,8 @@ static unsigned int grcan_hw_read_try(
 	int i, j;
 	CANMsg *dest;
 	struct grcan_msg *source, tmp;
-	unsigned int wp, rp, size, rxmax, addr, trunk_msg_cnt;
+	unsigned int wp, rp, size, rxmax, addr;
+	int trunk_msg_cnt;
 	FUNCDBG();
@@ -775,6 +772,15 @@ static unsigned int grcan_hw_read_try(
 			/* Read CAN message from DMA buffer */
 			tmp.head[0] = READ_DMA_WORD(&source->head[0]);
 			tmp.head[1] = READ_DMA_WORD(&source->head[1]);
+			if (tmp.head[1] & 0x4) {
+				DBGC(DBG_RX, "overrun\n");
+			if (tmp.head[1] & 0x2) {
+				DBGC(DBG_RX, "bus-off mode\n");
+			if (tmp.head[1] & 0x1) {
+				DBGC(DBG_RX, "error-passive mode\n");
 			/* Convert one grcan CAN message to one "software" CAN message */
 			dest->extended = tmp.head[0] >> 31;
 			dest->rtr = (tmp.head[0] >> 30) & 0x1;
@@ -794,29 +800,34 @@ static unsigned int grcan_hw_read_try(
 			dest++;	/* straight user buffer */
 			i--;
-		/* Increment Hardware READ pointer (mark read byte as read)
-		 * ! wait for registers to be safely re-configurable
-		regs->rx0ctrl = 0;	/* DISABLE RX CHANNEL */
-		i = 0;
-		while (grcan_hw_rx_ongoing(regs) && (i < 1000)) {
-			i++;
+			/* A bus off interrupt may have occured after checking pDev->started */
+			SPIN_IRQFLAGS(oldLevel);
+			SPIN_LOCK_IRQ(&pDev->devlock, oldLevel);
+			if (pDev->started == STATE_STARTED) {
+				regs->rx0rd = (unsigned int) source - addr;
+				regs->rx0ctrl = GRCAN_RXCTRL_ENABLE;
+			} else {
+				DBGC(DBG_STATE, "cancelled due to a BUS OFF error\n");
+				trunk_msg_cnt = state2err[pDev->started];
+			SPIN_UNLOCK_IRQ(&pDev->devlock, oldLevel);
-		regs->rx0rd = (unsigned int)source - addr;
-		regs->rx0ctrl = GRCAN_RXCTRL_ENABLE;	/* ENABLE_RX_CHANNEL */
 		return trunk_msg_cnt;
 	return 0;
 	CANMsg * buffer,
 	int count
-	unsigned int rp, wp, size, txmax, addr, ret;
+	unsigned int rp, wp, size, txmax, addr;
+	int ret;
 	struct grcan_msg *dest;
 	CANMsg *source;
 	int space_left;
@@ -867,16 +878,20 @@ static unsigned int grcan_hw_write_try(
 		space_left--;
-	/* Update write pointer
-	regs->tx0ctrl = 0;	/* DISABLE TX CHANNEL */
-	i = 0;
-	while ((grcan_hw_tx_ongoing(regs)) && i < 1000) {
-		i++;
+			regs->tx0wr = (unsigned int) dest - addr;
+			regs->tx0ctrl = GRCAN_TXCTRL_ENABLE;
+		} else {
+			ret = state2err[pDev->started];
-	regs->tx0wr = (unsigned int)dest - addr;	/* Update write pointer */
-	regs->tx0ctrl = GRCAN_TXCTRL_ENABLE;	/* ENABLE_TX_CHANNEL */
 	return ret;
@@ -884,7 +899,7 @@ static int grcan_wait_rxdata(struct grcan_priv *pDev, int min)
 	unsigned int wp, rp, size, irq;
 	unsigned int irq_trunk, dataavail;
-	int wait;
+	int wait, state;
 	FUNCDBG();
@@ -894,6 +909,20 @@ static int grcan_wait_rxdata(struct grcan_priv *pDev, int min)
 	 * when one or more messages are received
+	state = pDev->started;
+	if (state != STATE_STARTED) {
+		if (state == STATE_BUSOFF) {
+		} else if (state == STATE_AHBERR) {
+			DBGC(DBG_STATE, "cancelled due to a AHB error\n");
+		} else {
+			DBGC(DBG_STATE, "cancelled due to STOP (unexpected) \n");
+		return state2err[state];
 	size = READ_REG(&pDev->regs->rx0size);
 	rp = READ_REG(&pDev->regs->rx0rd);
@@ -936,15 +965,18 @@ static int grcan_wait_rxdata(struct grcan_priv *pDev, int min)
 				RTEMS_WAIT,
 				RTEMS_NO_TIMEOUT
 			) == RTEMS_UNSATISFIED
-			return -1;	/* Device driver has been closed or stopped, return with error status */
+			DBGC(DBG_STATE, "UNSATISFIED\n");
+			/* Device driver has been closed or stopped, return with error status */
+			return state2err[pDev->started];
 	return 0;
-/* Wait until min bytes available in TX circular buffer.
- * The IRQ RxIrq is used to pin point the location of
+/* Wait until min bytes available in TX circular buffer. TXIRQ is used to pin
+ * point the location of the CAN message corresponding to min.
  * min must be at least WRAP_AROUND_TX_BYTES bytes less
  * than max buffer for this algo to work.
@@ -952,7 +984,7 @@ static int grcan_wait_rxdata(struct grcan_priv *pDev, int min)
 static int grcan_wait_txspace(struct grcan_priv *pDev, int min)
-	int wait;
+	int wait, state;
 	unsigned int irq, rp, wp, size, space_left;
 	unsigned int irq_trunk;
@@ -961,6 +993,19 @@ static int grcan_wait_txspace(struct grcan_priv *pDev, int min)
 	/*FUNCDBG(); */
+		} else {
+			DBGC(DBG_STATE, "cancelled due to STOP (unexpected)\n");
 	pDev->regs->tx0ctrl = GRCAN_TXCTRL_ENABLE;
@@ -1010,7 +1055,8 @@ static int grcan_wait_txspace(struct grcan_priv *pDev, int min)
 		    RTEMS_UNSATISFIED) {
 			/* Device driver has flushed us, this may be due to another thread has
 			 * closed the device, this is to avoid deadlock */
-			return -1;
@@ -1020,7 +1066,7 @@ static int grcan_wait_txspace(struct grcan_priv *pDev, int min)
 static int grcan_tx_flush(struct grcan_priv *pDev)
-	int wait;
+	int wait, state;
 	unsigned int rp, wp;
 	FUNCDBG();
@@ -1036,6 +1082,21 @@ static int grcan_tx_flush(struct grcan_priv *pDev)
 		/* Wait for TX empty IRQ */
+			} else {
 		/* Clear pending TXEmpty IRQ */
 		pDev->regs->picr = GRCAN_TXEMPTY_IRQ;
@@ -1056,7 +1117,8 @@ static int grcan_tx_flush(struct grcan_priv *pDev)
 		if (rtems_semaphore_obtain
 		    (pDev->txempty_sem, RTEMS_WAIT,
 		     RTEMS_NO_TIMEOUT) == RTEMS_UNSATISFIED) {
-			return -1;
 	return 0;
@@ -1231,7 +1293,7 @@ void *grcan_open(int dev_no)
 	pDev->txblock = pDev->rxblock = 1;
 	pDev->txcomplete = pDev->rxcomplete = 0;
-	pDev->started = 0;
+	pDev->started = STATE_STOPPED;
 	pDev->config_changed = 1;
 	pDev->config.silent = 0;
 	pDev->config.abort = 0;
@@ -1296,12 +1358,7 @@ int grcan_close(void *d)
 	FUNCDBG();
-	if ( pDev->started ) {
-		/* Disable interrupts */
-		drvmgr_interrupt_unregister(pDev->dev, 0, grcan_interrupt, pDev);
-		grcan_hw_stop(pDev);
+	grcan_stop(d);
 	grcan_hw_reset(pDev->regs);
@@ -1318,6 +1375,7 @@ int grcan_read(void *d, CANMsg *msg, size_t ucount)
 	struct grcan_priv *pDev = d;
 	CANMsg *dest;
 	unsigned int count, left;
+	int nread;
 	int req_cnt;
 	FUNCDBG();
@@ -1326,14 +1384,19 @@ int grcan_read(void *d, CANMsg *msg, size_t ucount)
 	req_cnt = ucount;
 	if ( (!dest) || (req_cnt<1) )
-		return -1;
+		return GRCAN_RET_INVARG;
-	if ( !pDev->started )
-		return -2;
+	if (pDev->started != STATE_STARTED) {
+		return GRCAN_RET_NOTSTARTED;
-	/*FUNCDBG("grcan_read [%i,%i]: buf: 0x%x len: %i\n",major, minor, (unsigned int)rw_args->buffer,rw_args->count);*/
+	DBGC(DBG_RX, "grcan_read [%p]: buf: %p len: %u\n", d, msg, (unsigned int) ucount);
-	count = grcan_hw_read_try(pDev,pDev->regs,dest,req_cnt);
+	nread = grcan_hw_read_try(pDev,pDev->regs,dest,req_cnt);
+	if (nread < 0) {
+		return nread;
+	count = nread;
 	if ( !( pDev->rxblock && pDev->rxcomplete && (count!=req_cnt) ) ){
 		if ( count > 0 ) {
 			/* Successfully received messages (at least one) */
@@ -1343,7 +1406,7 @@ int grcan_read(void *d, CANMsg *msg, size_t ucount)
 		/* nothing read, shall we block? */
 		if ( !pDev->rxblock ) {
 			/* non-blocking mode */
-			return -3;
+			return GRCAN_RET_TIMEOUT;
@@ -1363,20 +1426,27 @@ int grcan_read(void *d, CANMsg *msg, size_t ucount)
-		if (grcan_wait_rxdata(pDev, left)) {
+		nread = grcan_wait_rxdata(pDev, left);
+		if (nread) {
 			/* The wait has been aborted, probably due to
 			 * the device driver has been closed by another
-			 * thread.
+			 * thread or a bus-off. Return error code.
-			return count;
+			return nread;
 		/* Try read bytes from circular buffer */
-		count += grcan_hw_read_try(
 				pDev,
 				pDev->regs,
 				dest+count,
 				req_cnt-count);
+		if (nread < 0) {
+			/* The read was aborted by bus-off. */
+			return nread;
+		count += nread;
 	/* no need to unmask IRQ as IRQ Handler do that for us. */
 	return count;
@@ -1387,22 +1457,27 @@ int grcan_write(void *d, CANMsg *msg, size_t ucount)
 	CANMsg *source;
+	int nwritten;
 	int req_cnt;
 	DBGC(DBG_TX,"\n");
-	if ( !pDev->started || pDev->config.silent || pDev->flushing )
-		return -2;
+	if ((pDev->started != STATE_STARTED) || pDev->config.silent || pDev->flushing)
 	req_cnt = ucount;
 	source = (CANMsg *) msg;
 	/* check proper length and buffer pointer */
 	if (( req_cnt < 1) || (source == NULL) ){
-		return -1;
-	count = grcan_hw_write_try(pDev,pDev->regs,source,req_cnt);
+	nwritten = grcan_hw_write_try(pDev,pDev->regs,source,req_cnt);
+	if (nwritten < 0) {
+		return nwritten;
+	count = nwritten;
 	if ( !(pDev->txblock && pDev->txcomplete && (count!=req_cnt)) ) {
 		if ( count > 0 ) {
 			/* Successfully transmitted chars (at least one char) */
@@ -1412,7 +1487,7 @@ int grcan_write(void *d, CANMsg *msg, size_t ucount)
 		/* nothing written, shall we block? */
 		if ( !pDev->txblock ) {
-			return -3;
@@ -1436,14 +1511,15 @@ int grcan_write(void *d, CANMsg *msg, size_t ucount)
+		nwritten = grcan_wait_txspace(pDev,left);
 		/* Wait until more room in transmit buffer */
-		if ( grcan_wait_txspace(pDev,left) ){
+		if ( nwritten ) {
 			 * thread. To avoid deadlock we return directly
 			 * with error status.
-			return count;
+			return nwritten;
 		if ( pDev->txerror ){
@@ -1455,11 +1531,17 @@ int grcan_write(void *d, CANMsg *msg, size_t ucount)
-		count += grcan_hw_write_try(
 			pDev,
 			pDev->regs,
 			source+count,
 			req_cnt-count);
+			/* Write was aborted by bus-off. */
+			return nwritten;
+		count += nwritten;
@@ -1469,19 +1551,20 @@ int grcan_write(void *d, CANMsg *msg, size_t ucount)
 int grcan_start(void *d)
-	rtems_device_driver status;
 	FUNCDBG();
+	if (grcan_get_state(d) == STATE_STARTED) {
 		return -1;
-	if ( (status=grcan_hw_start(pDev)) != RTEMS_SUCCESSFUL ){
+	if ( (grcan_hw_start(pDev)) != RTEMS_SUCCESSFUL ){
 		return -2;
 	/* Read and write are now open... */
-	pDev->started = 1;
+	pDev->started = STATE_STARTED;
+	DBGC(DBG_STATE, "STOPPED|BUSOFF|AHBERR->STARTED\n");
 	/* Register interrupt routine and enable IRQ at IRQ ctrl */
 	drvmgr_interrupt_register(pDev->dev, 0, pDev->devName,
@@ -1493,22 +1576,34 @@ int grcan_start(void *d)
 int grcan_stop(void *d)
 	FUNCDBG();
+	if (pDev->started == STATE_STOPPED)
 		return -1;
+		grcan_hw_stop(pDev);
+		DBGC(DBG_STATE, "STARTED->STOPPED\n");
+	} else {
+		 * started == STATE_[STOPPED|BUSOFF|AHBERR] so grcan_hw_stop()
+		 * might already been called from ISR.
+		DBGC(DBG_STATE, "[STOPPED|BUSOFF|AHBERR]->STOPPED\n");
 	return 0;
-int grcan_isstarted(void *d)
+int grcan_get_state(void *d)
@@ -1524,7 +1619,7 @@ int grcan_flush(void *d)
 	FUNCDBG();
-	if ( !pDev->started || pDev->flushing || pDev->config.silent )
+	if ((pDev->started != STATE_STARTED) || pDev->flushing || pDev->config.silent)
 		return -1;
 	pDev->flushing = 1;
@@ -1547,7 +1642,7 @@ int grcan_set_silent(void* d, int silent)
 	FUNCDBG();
 		return -1;
 	pDev->config.silent = silent;
@@ -1562,7 +1657,7 @@ int grcan_set_abort(void* d, int abort)
 	FUNCDBG();
 		return -1;
 	pDev->config.abort = abort;
@@ -1579,7 +1674,7 @@ int grcan_set_selection(void *d, const struct grcan_selection *selection)
 	FUNCDBG();
 		return -1;
 	if ( !selection )
@@ -1675,7 +1770,7 @@ int grcan_set_speed(void *d, unsigned int speed)
 	FUNCDBG();
 	/* cannot change speed during run mode */
 		return -1;
 	/* get speed rate from argument */
@@ -1699,7 +1794,7 @@ int grcan_set_btrs(void *d, const struct grcan_timing *timing)
 	/* Set BTR registers manually
 	 * Read GRCAN/HurriCANe Manual.
 		return -1;
 	if ( !timing )
@@ -1777,94 +1872,129 @@ int grcan_get_status(void* d, unsigned int *data)
 	return 0;
+/* Error indicators */
+#define GRCAN_IRQ_ERRORS \
+		(GRCAN_RXAHBERR_IRQ | GRCAN_TXAHBERR_IRQ | GRCAN_OFF_IRQ)
+#define GRCAN_STAT_ERRORS (GRCAN_STAT_AHBERR | GRCAN_STAT_OFF)
+/* Warning & RX/TX sync indicators */
+#define GRCAN_IRQ_WARNS \
+		(GRCAN_ERR_IRQ | GRCAN_OR_IRQ | GRCAN_TXLOSS_IRQ | \
+		 GRCAN_RXSYNC_IRQ | GRCAN_TXSYNC_IRQ)
+#define GRCAN_STAT_WARNS (GRCAN_STAT_OR | GRCAN_STAT_PASS)
 /* Handle the IRQ */
 static void grcan_interrupt(void *arg)
 	struct grcan_priv *pDev = arg;
 	unsigned int status = READ_REG(&pDev->regs->pimsr);
 	unsigned int canstat = READ_REG(&pDev->regs->stat);
+	unsigned int imr_clear;
 	SPIN_ISR_IRQFLAGS(irqflags);
 	/* Spurious IRQ call? */
 	if ( !status && !canstat )
 		return;
-	FUNCDBG();
-	/* Increment number of interrupts counter */
-	pDev->stats.ints++;
-	if ( (status & GRCAN_ERR_IRQ) || (canstat & GRCAN_STAT_PASS) ){
-		/* Error-Passive interrupt */
-		pDev->stats.passive_cnt++;
+		DBGC(DBG_STATE, "not STARTED (unexpected interrupt)\n");
+		pDev->regs->picr = status;
+		return;
-	if ( (status & GRCAN_OFF_IRQ) || (canstat & GRCAN_STAT_OFF) ){
-		/* Bus-off condition interrupt
+	FUNCDBG();
+	if ( (status & GRCAN_IRQ_ERRORS) || (canstat & GRCAN_STAT_ERRORS) ) {
+		/* Bus-off condition interrupt
 		 * The link is brought down by hardware, we wake all threads
 		 * that is blocked in read/write calls and stop futher calls
 		 * to read/write until user has called ioctl(fd,START,0).
 		SPIN_LOCK(&pDev->devlock, irqflags);
+		DBGC(DBG_STATE, "STARTED->BUSOFF|AHBERR\n");
+		pDev->stats.ints++;
+		if ((status & GRCAN_OFF_IRQ) || (canstat & GRCAN_STAT_OFF)) {
+			/* CAN Bus-off interrupt */
+			DBGC(DBG_STATE, "BUSOFF: status: 0x%x, canstat: 0x%x\n",
+				status, canstat);
+			pDev->started = STATE_BUSOFF;
+			pDev->stats.busoff_cnt++;
+		} else {
+			/* RX or Tx AHB Error interrupt */
+			printk("AHBERROR: status: 0x%x, canstat: 0x%x\n",
+				status, canstat);
+			pDev->started = STATE_AHBERR;
+			pDev->stats.ahberr_cnt++;
 		grcan_hw_stop(pDev); /* this mask all IRQ sources */
+		pDev->regs->picr = 0x1ffff; /* clear all interrupts */
+		 * Prevent driver from affecting bus. Driver can be started
+		 * again with grcan_start().
 		SPIN_UNLOCK(&pDev->devlock, irqflags);
-		status=0x1ffff; /* clear all interrupts */
-		goto out;
+		 * NOTE: Another interrupt may be pending now so ISR could be
+		 * executed one more time aftert this (first) return.
+		return;
-	if ( (status & GRCAN_OR_IRQ) || (canstat & GRCAN_STAT_OR) ){
-		/* Over-run during reception interrupt */
-		pDev->stats.overrun_cnt++;
+	/* Mask interrupts in one place under spin-lock. */
+	imr_clear = status & (GRCAN_RXIRQ_IRQ | GRCAN_TXIRQ_IRQ | GRCAN_TXEMPTY_IRQ);
-	if ( (status & GRCAN_RXAHBERR_IRQ) ||
-	     (status & GRCAN_TXAHBERR_IRQ) ||
-	     (canstat & GRCAN_STAT_AHBERR) ){
-		/* RX or Tx AHB Error interrupt */
-		printk("AHBERROR: status: 0x%x, canstat: 0x%x\n",status,canstat);
-		pDev->stats.ahberr_cnt++;
+	SPIN_LOCK(&pDev->devlock, irqflags);
-	if ( status & GRCAN_TXLOSS_IRQ ) {
-		pDev->stats.txloss_cnt++;
+	/* Increment number of interrupts counter */
+	if ((status & GRCAN_IRQ_WARNS) || (canstat & GRCAN_STAT_WARNS)) {
-	if ( status & GRCAN_RXIRQ_IRQ ){
-		/* RX IRQ pointer interrupt */
-		/*printk("RxIrq 0x%x\n",status);*/
-		SPIN_LOCK(&pDev->devlock, irqflags);
-		pDev->regs->imr = READ_REG(&pDev->regs->imr) & ~GRCAN_RXIRQ_IRQ;
-		SPIN_UNLOCK(&pDev->devlock, irqflags);
-		rtems_semaphore_release(pDev->rx_sem);
+		if ( (status & GRCAN_ERR_IRQ) || (canstat & GRCAN_STAT_PASS) ) {
+			/* Error-Passive interrupt */
+			pDev->stats.passive_cnt++;
+		if ( (status & GRCAN_OR_IRQ) || (canstat & GRCAN_STAT_OR) ) {
+			/* Over-run during reception interrupt */
+			pDev->stats.overrun_cnt++;
+		if ( status & GRCAN_TXLOSS_IRQ ) {
+			pDev->stats.txloss_cnt++;
+		if ( status & GRCAN_TXSYNC_IRQ ) {
+			/* TxSync message transmitted interrupt */
+			pDev->stats.txsync_cnt++;
+		if ( status & GRCAN_RXSYNC_IRQ ) {
+			/* RxSync message received interrupt */
+			pDev->stats.rxsync_cnt++;
-	if ( status & GRCAN_TXIRQ_IRQ ){
-		/* TX IRQ pointer interrupt */
-		pDev->regs->imr = READ_REG(&pDev->regs->imr) & ~GRCAN_TXIRQ_IRQ;
+	if (imr_clear) {
+		pDev->regs->imr = READ_REG(&pDev->regs->imr) & ~imr_clear;
-		rtems_semaphore_release(pDev->tx_sem);
-	if ( status & GRCAN_TXSYNC_IRQ ){
-		/* TxSync message transmitted interrupt */
-		pDev->stats.txsync_cnt++;
+		if ( status & GRCAN_RXIRQ_IRQ ) {
+			/* RX IRQ pointer interrupt */
+			rtems_semaphore_release(pDev->rx_sem);
-	if ( status & GRCAN_RXSYNC_IRQ ){
-		/* RxSync message received interrupt */
-		pDev->stats.rxsync_cnt++;
+		if ( status & GRCAN_TXIRQ_IRQ ) {
+			/* TX IRQ pointer interrupt */
+			rtems_semaphore_release(pDev->tx_sem);
-	if ( status & GRCAN_TXEMPTY_IRQ ){
-		pDev->regs->imr = READ_REG(&pDev->regs->imr) & ~GRCAN_TXEMPTY_IRQ;
+		if (status & GRCAN_TXEMPTY_IRQ ) {
+			rtems_semaphore_release(pDev->txempty_sem);
+	} else {
-		rtems_semaphore_release(pDev->txempty_sem);
-out:
 	/* Clear IRQs */
diff --git a/c/src/lib/libbsp/sparc/shared/include/grcan.h b/c/src/lib/libbsp/sparc/shared/include/grcan.h
index 7de76a7..5cdbad4 100644
--- a/c/src/lib/libbsp/sparc/shared/include/grcan.h
+++ b/c/src/lib/libbsp/sparc/shared/include/grcan.h
@@ -68,6 +68,7 @@ struct grcan_stats {
 	unsigned int txloss_cnt;
 	unsigned int ahberr_cnt;
 	unsigned int ints;
+	unsigned int busoff_cnt;
 struct grcan_timing {
@@ -99,6 +100,39 @@ typedef struct {
 	unsigned int id;
 } CANMsg;
+enum {
+	GRCAN_RET_OK            =  0,
+	GRCAN_RET_INVARG        = -1,
+	GRCAN_RET_NOTSTARTED    = -2,
+	GRCAN_RET_TIMEOUT       = -3,
+	/* Bus-off condition detected (request aborted by driver) */
+	GRCAN_RET_BUSOFF        = -4,
+	/* AHB error condition detected (request aborted by driver) */
+	GRCAN_RET_AHBERR        = -5,
+ * User functions can cause these transitions:
+ *   STATE_STOPPED -> STATE_STARTED
+ *   STATE_STARTED -> STATE_STOPPED
+ *   STATE_BUSOFF  -> STATE_STOPPED
+ *   STATE_AHBERR  -> STATE_STOPPED
+ * ISR can cause these transition
+ *   STATE_STARTED -> STATE_BUSOFF
+ *   STATE_STARTED -> STATE_AHBERR
+ * STATE_BUSOFF is entered from ISR on bus-off condition. STATE_AHBERR is
+ * entered from ISR on AHB DMA errors on RX/TX operations. At transition the ISR
+ * disables DMA, masks all interrupts and releases semaphores.
+enum grcan_state {
+	STATE_STOPPED		= 0,
+	STATE_STARTED		= 1,
+	STATE_BUSOFF		= 2,
+	STATE_AHBERR		= 3,
 #define GRCAN_CFG_ABORT      0x00000001
 #define GRCAN_CFG_ENABLE0    0x00000002
 #define GRCAN_CFG_ENABLE1    0x00000004
@@ -198,13 +232,14 @@ extern int grcan_close(void *d);
  * count: Number of CAN messages to receive
  * return:
- *   >=0:	Number of CAN messages received. This can be less than the
- *		count parameter.
- *   -1:	count parameter less than size of struct grcan_msg or NULL msg.
- *   -2:	Device not in started mode
- *   -3:	Timeout in non-blocking mode
- *   -4:	A blocking read was interrupted by a Bus-off error. Device has
- *		left started mode.
+ *   >=0:                       Number of CAN messages received. This can be
+ *                              less than the count parameter.
+ *   GRCAN_RET_INVARG:          count parameter less than one or NULL msg.
+ *   GRCAN_RET_NOTSTARTED:      Device not in started mode
+ *   GRCAN_RET_TIMEOUT:         Timeout in non-blocking mode
+ *   GRCAN_RET_BUSOFF:          A read was interrupted by a bus-off error.
+ *                              Device has left started mode.
+ *   GRCAN_RET_AHBERR:          Similar to BUSOFF, but was caused by AHB Error.
 extern int grcan_read(
 	void *d,
@@ -222,12 +257,14 @@ extern int grcan_read(
  * count: Number of CAN messages to transmit
  * return:
- *   >=0:	Number of CAN messages transmitted. This can be less than the
- *   -4:	Bus-off error. Device has left started mode
+ *   >=0:                       Number of CAN messages transmitted. This can be
+ *   GRCAN_RET_INVARG:          count parameter less than one.
+ *   GRCAN_RET_BUSOFF:          A write was interrupted by a Bus-off error.
 extern int grcan_write(
 	void *d,
@@ -235,6 +272,21 @@ extern int grcan_write(
 	size_t count
+ * Returns current GRCAN software state
+ * If STATE_BUSOFF or STATE_AHBERR is returned then the function grcan_stop()
+ * shall be called before continue using the driver.
+ * d: Device handle
+ * return:
+ *   STATE_STOPPED              Stopped
+ *   STATE_STARTED              Started
+ *   STATE_BUSOFF               Bus-off has been detected
+ *   STATE_AHBERR               AHB error has been detected
+extern int grcan_get_state(void *d);
 /* The remaining functions return 0 on success and non-zero on failure. */
 /* Functions controlling operational
@@ -244,8 +296,6 @@ extern int grcan_write(
 extern int grcan_start(void *d);
 /* stop to change baud rate/config or closing down */
 extern int grcan_stop(void *d);
-/* return 1 when started, othervise 0 */
-extern int grcan_isstarted(void *d);
 /* Wait until all TX messages have been sent */
 extern int grcan_flush(void *d);
2.7.4
