[PATCH 18/32] leon, grcan: fixed historical comment
Daniel Hellstrom daniel at gaisler.com
Thu May 11 14:26:03 UTC 2017
 c/src/lib/libbsp/sparc/shared/can/grcan.c | 7 +++----
 1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/shared/can/grcan.c b/c/src/lib/libbsp/sparc/shared/can/grcan.c
index ac1c718..b1eacc0 100644
--- a/c/src/lib/libbsp/sparc/shared/can/grcan.c
+++ b/c/src/lib/libbsp/sparc/shared/can/grcan.c
@@ -979,12 +979,11 @@ static int grcan_wait_rxdata(struct grcan_priv *pDev, int min)
 	return 0;
-/* Wait until min bytes available in TX circular buffer. TXIRQ is used to pin
+/* Wait for TX circular buffer to have room for min CAN messagges. TXIRQ is used to pin
  * point the location of the CAN message corresponding to min.
- * min must be at least WRAP_AROUND_TX_BYTES bytes less
- * than max buffer for this algo to work.
+ * min must be at least WRAP_AROUND_TX_MSGS less than max buffer capacity
+ * (pDev->txbuf_size/GRCAN_MSG_SIZE) for this algo to work.
 static int grcan_wait_txspace(struct grcan_priv *pDev, int min)
2.7.4
