[PATCH 25/32] leon, apbuart: remove old RAW UART driver
Daniel Hellstrom daniel at gaisler.com
Thu May 11 14:26:10 UTC 2017
This driver was initially intended for APBUART access on GRLIB PCI
peripherals (AMBA-over-PCI). There are already many APBUART drivers
for LEON. Instead of using this one the termios APBUART should work
on AMBA-over-PCI systems with recent changes on LEON3, however that
has not been tested yet.
 c/src/lib/libbsp/sparc/Makefile.am              |   1 -
 c/src/lib/libbsp/sparc/leon2/Makefile.am        |   1 -
 c/src/lib/libbsp/sparc/leon3/Makefile.am        |   3 +-
 c/src/lib/libbsp/sparc/shared/include/apbuart.h |  33 -
 c/src/lib/libbsp/sparc/shared/uart/apbuart.c    | 897 ------------------------
 5 files changed, 1 insertion(+), 934 deletions(-)
 delete mode 100644 c/src/lib/libbsp/sparc/shared/uart/apbuart.c
diff --git a/c/src/lib/libbsp/sparc/Makefile.am b/c/src/lib/libbsp/sparc/Makefile.am
index a894f34..d17d691 100644
--- a/c/src/lib/libbsp/sparc/Makefile.am
+++ b/c/src/lib/libbsp/sparc/Makefile.am
@@ -83,7 +83,6 @@ EXTRA_DIST += shared/uart/cons.c
 EXTRA_DIST += shared/uart/apbuart_cons.c
 EXTRA_DIST += shared/include/cons.h
 EXTRA_DIST += shared/include/apbuart_cons.h
-EXTRA_DIST += shared/uart/apbuart.c
 EXTRA_DIST += shared/include/apbuart.h
 # CAN (OC_CAN, GRCAN)
diff --git a/c/src/lib/libbsp/sparc/leon2/Makefile.am b/c/src/lib/libbsp/sparc/leon2/Makefile.am
index 94e10cd..349b44d 100644
--- a/c/src/lib/libbsp/sparc/leon2/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon2/Makefile.am
@@ -154,7 +154,6 @@ libbsp_a_SOURCES += ../../sparc/shared/spw/grspw_router.c
 # UART (RAW)
 include_bsp_HEADERS += ../../sparc/shared/include/apbuart.h
-libbsp_a_SOURCES += ../../sparc/shared/uart/apbuart.c
 # I2CMST
 include_bsp_HEADERS += ../../sparc/shared/include/i2cmst.h
diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
index 83e1dff..52f6b56 100644
--- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
@@ -170,8 +170,7 @@ libbsp_a_SOURCES += ../../sparc/shared/spw/grspw_router.c
 # UART
 include_bsp_HEADERS += ../../sparc/shared/include/apbuart.h \
     ../../sparc/shared/include/apbuart_termios.h
-libbsp_a_SOURCES += ../../sparc/shared/uart/apbuart.c \
-    ../../sparc/shared/uart/apbuart_termios.c
+libbsp_a_SOURCES += ../../sparc/shared/uart/apbuart_termios.c
 # I2CMST
diff --git a/c/src/lib/libbsp/sparc/shared/include/apbuart.h b/c/src/lib/libbsp/sparc/shared/include/apbuart.h
index 326e769..a324805 100644
--- a/c/src/lib/libbsp/sparc/shared/include/apbuart.h
+++ b/c/src/lib/libbsp/sparc/shared/include/apbuart.h
@@ -25,33 +25,6 @@
 extern "C" {
 #endif
-typedef struct {
-  unsigned int hw_dovr;
-  unsigned int hw_parity;
-  unsigned int hw_frame;
-  unsigned int sw_dovr;
-  unsigned int rx_cnt;
-  unsigned int tx_cnt;
-} apbuart_stats;
-#define APBUART_START    0
-#define APBUART_STOP     1
-#define APBUART_SET_RXFIFO_LEN 2
-#define APBUART_SET_TXFIFO_LEN 3
-#define APBUART_SET_BAUDRATE   4
-#define APBUART_SET_SCALER     5
-#define APBUART_SET_BLOCKING   6
-#define APBUART_SET_ASCII_MODE 7
-#define APBUART_GET_STATS 16
-#define APBUART_CLR_STATS 17
-#define APBUART_BLK_RX 0x1
-#define APBUART_BLK_TX 0x2
-#define APBUART_BLK_FLUSH 0x4
 #define APBUART_CTRL_RE 0x1
 #define APBUART_CTRL_TE 0x2
 #define APBUART_CTRL_RI 0x4
@@ -80,12 +53,6 @@ typedef struct {
 #define APBUART_STATUS_TF 0x200
 #define APBUART_STATUS_RF 0x400
-/* Register APBUART driver
- * bus =  pointer to AMBA bus description used to search for APBUART(s).
- *        (&ambapp_plb for LEON3), (LEON2: see amba_scan)
-int apbuart_register (struct ambapp_bus *bus);
 #ifdef __cplusplus
 #endif
diff --git a/c/src/lib/libbsp/sparc/shared/uart/apbuart.c b/c/src/lib/libbsp/sparc/shared/uart/apbuart.c
deleted file mode 100644
index 171f114..0000000
--- a/c/src/lib/libbsp/sparc/shared/uart/apbuart.c
+++ /dev/null
@@ -1,897 +0,0 @@
- *  This file contains the driver for the APBUART serial port.
- *  No console driver, only char driver.
- *  COPYRIGHT (c) 2007.
- *  Gaisler Research.
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
- *  2007-07-11, Daniel Hellstrom <daniel at gaisler.com>
- *    Added ioctl command APBUART_CLR_STATS
-#include <bsp.h>
-#include <rtems/libio.h>
-#include <stdlib.h>
-#include <assert.h>
-#include <rtems/bspIo.h>
-#include <string.h>
-#include <ambapp.h>
-#include <grlib.h>
-#include <bsp/apbuart.h>
-#ifndef DEFAULT_TXBUF_SIZE
- #define DEFAULT_TXBUF_SIZE 32
-#endif
-#ifndef DEFAULT_RXBUF_SIZE
- #define DEFAULT_RXBUF_SIZE 32
-#endif
-#ifndef APBUART_PREFIX
- #define APBUART_PREFIX(name) apbuart##name
-#else
- #define APBUART_REGISTER_STATIC
-#endif
-#if !defined(APBUART_DEVNAME) || !defined(APBUART_DEVNAME_NO)
- #undef APBUART_DEVNAME
- #undef APBUART_DEVNAME_NO
- #define APBUART_DEVNAME "/dev/apbuart0"
- #define APBUART_DEVNAME_NO(devstr,no) ((devstr)[12]='0'+(no))
-#endif
-#ifndef APBUART_REG_INT
-	#define APBUART_REG_INT(handler,irq,arg) set_vector(handler,irq+0x10,1)
-  #undef APBUART_DEFINE_INTHANDLER
-  #define APBUART_DEFINE_INTHANDLER
-#endif
-/* Default to 40MHz system clock */
-/*#ifndef SYS_FREQ_HZ
- #define SYS_FREQ_HZ 40000000
-#endif*/
-typedef struct {
-	int size;
-	unsigned char *buf,
-	              *tail,
-		            *head,
-								*max;
-	int full; /* no more place in fifo */
-} apbuart_fifo;
-static apbuart_fifo *apbuart_fifo_create(int size);
-static void apbuart_fifo_free(apbuart_fifo *fifo);
-static inline int apbuart_fifo_isFull(apbuart_fifo *fifo);
-static inline int apbuart_fifo_isEmpty(apbuart_fifo *fifo);
-static int apbuart_fifo_put(apbuart_fifo *fifo, unsigned char c);
-static int apbuart_fifo_get(apbuart_fifo *fifo, unsigned char *c);
-static int inline apbuart_fifo_peek(apbuart_fifo *fifo, unsigned char **c);
-static void inline apbuart_fifo_skip(apbuart_fifo *fifo);
-static rtems_device_driver apbuart_initialize(rtems_device_major_number  major, rtems_device_minor_number  minor,  void *arg);
-static rtems_device_driver apbuart_open(rtems_device_major_number major, rtems_device_minor_number minor, void *arg);
-static rtems_device_driver apbuart_close(rtems_device_major_number major, rtems_device_minor_number minor, void *arg);
-static rtems_device_driver apbuart_read(rtems_device_major_number major, rtems_device_minor_number minor, void *arg);
-static rtems_device_driver apbuart_write(rtems_device_major_number major, rtems_device_minor_number minor, void *arg);
-static rtems_device_driver apbuart_control(rtems_device_major_number major, rtems_device_minor_number minor, void *arg);
-typedef struct {
-	struct apbuart_regs *regs;
-	int irq;
-	int minor;
-	int scaler;
-	unsigned int baud;
-	int txblk;    /* Make write block until at least 1 char has
-	               * been put into software send fifo
-	int tx_flush; /* Set this to block until all data has
-	               * placed into the hardware send fifo
-	int rxblk;    /* Make read block until at least 1 char has
-	               * been received (or taken from software fifo).
-	int started;  /* Set to 1 when in running mode */
-	int ascii_mode; /* Set to 1 to make \n be printed as \r\n */
-	/* TX/RX software FIFO Buffers */
-	apbuart_fifo *txfifo;
-	apbuart_fifo *rxfifo;
-	apbuart_stats stats;
-	rtems_id dev_sem;
-	rtems_id rx_sem;
-	rtems_id tx_sem;
-} apbuart_priv;
-static int dev_cnt;
-static apbuart_priv *apbuarts;
-static unsigned int sys_freq_hz;
-#define APBUART_DRIVER_TABLE_ENTRY { apbuart_initialize, apbuart_open, apbuart_close, apbuart_read, apbuart_write, apbuart_control }
-static rtems_driver_address_table apbuart_driver = APBUART_DRIVER_TABLE_ENTRY;
-static struct ambapp_bus *amba_bus;
-static void apbuart_interrupt(apbuart_priv *uart);
-#ifdef APBUART_DEFINE_INTHANDLER
-static void apbuart_interrupt_handler(rtems_vector_number v);
-#endif
-static void apbuart_hw_close(apbuart_priv *uart);
-static void apbuart_hw_open(apbuart_priv *uart);
-/* Uncomment for debug output */
-/* #define DEBUG 1
- #define FUNCDEBUG 1 */
-#ifdef DEBUG
-#define DBG(x...) printk(x)
-#else
-#define DBG(x...)
-#endif
-#ifdef FUNCDEBUG
-#define FUNCDBG(x...) printk(x)
-#else
-#endif
-#ifndef READ_REG
-	#define READ_REG(address) _APBUART_READ_REG((unsigned int)(address))
-  static __inline__ unsigned int _APBUART_READ_REG(unsigned int addr) {
-        unsigned int tmp;
-        __asm__ (" lda [%1]1, %0 "
-            : "=r"(tmp)
-            : "r"(addr)
-        return tmp;
-#endif
-#if 0
-static int apbuart_outbyte_try(struct apbuart_regs *regs, unsigned char ch)
-	if ( (READ_REG(&regs->status) & APBUART_STATUS_TE) == 0 )
-		return -1; /* Failed */
-	/* There is room in fifo, put ch in it */
-	regs->data = (unsigned int) ch;
-	return 0;
-static int apbuart_inbyte_try(struct apbuart_regs *regs)
-	unsigned int status;
-	/* Clear errors if any */
-	if ( (status=READ_REG(&regs->status)) & APBUART_STATUS_ERR) {
-		regs->status = status & ~APBUART_STATUS_ERR;
-	/* Is Data available? */
-	if ( (READ_REG(&regs->status) & APBUART_STATUS_DR) == 0 )
-		return -1; /* No data avail */
-	/* Return Data */
-	return (int)READ_REG(&regs->data);
-static int apbuart_write_support(apbuart_priv *uart, const char *buf, int len)
-	int nwrite = 0;
-	while (nwrite < len) {
-		if ( apbuart_outbyte_try(minor, *buf++) ){
-			/* TX Fifo full */
-		nwrite++;
-	return nwrite;
-#endif
-static void apbuart_hw_open(apbuart_priv *uart){
-	unsigned int scaler;
-	/* Calculate Baudrate */
-	if ( uart->scaler > 0 ) {
-		scaler = uart->scaler;
-	}else{
-		scaler = (((sys_freq_hz*10)/(uart->baud*8))-5)/10;
-	/* Set new baud rate */
-	uart->regs->scaler = scaler;
-	/* Enable receiver & Transmitter */
-	uart->regs->ctrl = APBUART_CTRL_RE | APBUART_CTRL_RF | APBUART_CTRL_RI | APBUART_CTRL_TI;
-static void apbuart_hw_close(apbuart_priv *uart){
-	/* disable receiver & transmitter & all IRQs */
-	uart->regs->ctrl = 0;
-/* interrupt handler */
-static void apbuart_interrupt_handler(rtems_vector_number v){
-	int minor;
-	/* convert to */
-  for(minor = 0; minor < dev_cnt; minor++) {
-  	if ( v == (apbuarts[minor].irq+0x10) ) {
-			apbuart_interrupt(&apbuarts[minor]);
-			return;
-#endif
-/* The interrupt handler, taking care of the
- * APBUART hardware
-static void apbuart_interrupt(apbuart_priv *uart){
-	int empty;
-	unsigned char c, *next_char = NULL;
-	int signal;
-	/* Clear & record any error */
-	status = READ_REG(&uart->regs->status);
-	if ( status & (APBUART_STATUS_OV|APBUART_STATUS_PE|APBUART_STATUS_FE) ){
-		/* Data overrun */
-		if ( status & APBUART_STATUS_OV ){
-			uart->stats.hw_dovr++;
-		/* Parity error */
-		if ( status & APBUART_STATUS_PE ){
-			uart->stats.hw_parity++;
-		/* Framing error */
-		if ( status & APBUART_STATUS_FE ){
-			uart->stats.hw_frame++;
-		uart->regs->status = status & ~(APBUART_STATUS_OV|APBUART_STATUS_PE|APBUART_STATUS_FE);
-	/* Empty RX fifo into software fifo */
-	signal = 0;
-	while ( (status=READ_REG(&uart->regs->status)) & APBUART_STATUS_DR ){
-		c = READ_REG(&uart->regs->data);
-		if ( apbuart_fifo_isFull(uart->rxfifo) ){
-			uart->stats.sw_dovr++;
-      DBG("]");
-			break;
-		/* put into fifo */
-		apbuart_fifo_put(uart->rxfifo,c);
-		/* bump RX counter */
-		uart->stats.rx_cnt++;
-		signal = 1;
-	/* Wake RX thread if any */
-	if ( signal )
-		rtems_semaphore_release(uart->rx_sem);
-	/* If room in HW fifo and we got more chars to be sent */
-	if ( !(status & APBUART_STATUS_TF) ){
-		if ( apbuart_fifo_isEmpty(uart->txfifo) ){
-			/* Turn off TX interrupt when no data is to be sent */
-			if ( status & APBUART_STATUS_TE ){
-				uart->regs->ctrl = READ_REG(&uart->regs->ctrl) & ~APBUART_CTRL_TF;
-				DBG("?");
-			return;
-		/* signal when there will be more room in SW fifo */
-		if ( apbuart_fifo_isFull(uart->txfifo) )
-			signal = 1;
-		do{
-			/* Put data into HW TX fifo */
-			apbuart_fifo_peek(uart->txfifo,&next_char);
-			c = *next_char;
-			if ( uart->ascii_mode && ( c == '\n') ){
-				uart->regs->data = '\n';
-				*next_char = '\r'; /* avoid sending mutiple '\n' or '\r' */
-			}else{
-				uart->regs->data = c;
-				apbuart_fifo_skip(uart->txfifo); /* remove sent char from fifo */
-			uart->regs->ctrl = READ_REG(&uart->regs->ctrl) | APBUART_CTRL_TE | APBUART_CTRL_TF;
-			DBG("!");
-		}while(!(empty=apbuart_fifo_isEmpty(uart->txfifo)) &&
-		       !((status=READ_REG(&uart->regs->status))&APBUART_STATUS_TF) );
-		/* Wake userspace thread, on empty or full fifo
-		 * This makes tx_flush and block work.
-		if ( signal || empty ){
-			rtems_semaphore_release(uart->tx_sem);
-#ifdef APBUART_REGISTER_STATIC
-static
-#endif
-int APBUART_PREFIX(_register)(struct ambapp_bus *bus) {
-	rtems_status_code r;
-	rtems_device_major_number m;
-	amba_bus = bus;
-	FUNCDBG("apbuart_register:\n");
-	if ((r = rtems_io_register_driver(0, &apbuart_driver, &m)) == RTEMS_SUCCESSFUL) {
-		DBG("APBUART driver successfully registered, major: %d\n", m);
-	} else {
-		switch(r) {
-		case RTEMS_TOO_MANY:
-			printk("APBUART rtems_io_register_driver failed: RTEMS_TOO_MANY\n"); return -1;
-		case RTEMS_INVALID_NUMBER:
-			printk("APBUART rtems_io_register_driver failed: RTEMS_INVALID_NUMBER\n"); return -1;
-		case RTEMS_RESOURCE_IN_USE:
-			printk("APBUART rtems_io_register_driver failed: RTEMS_RESOURCE_IN_USE\n"); return -1;
-		default:
-		   printk("APBUART rtems_io_register_driver failed\n");
-			 return -1;
-	return 0;
-	rtems_status_code status;
-	int i;
-	struct ambapp_apb_info dev;
-	char fs_name[20];
-	FUNCDBG("apbuart_initialize\n");
-	/* Find all APB UART devices */
-	dev_cnt = ambapp_get_number_apbslv_devices(amba_bus, VENDOR_GAISLER,
-	                                           GAISLER_APBUART);
-	if ( dev_cnt < 1 ){
-		/* Failed to find any CAN cores! */
-		printk("APBUART: Failed to find any APBUART cores\n\r");
-		return -1;
-	strcpy(fs_name,APBUART_DEVNAME);
-	DBG("Found %d APBUART(s)\n\r",dev_cnt);
-	/* Allocate memory for device structures */
-	apbuarts = calloc(dev_cnt, sizeof(*apbuarts));
-	if ( !apbuarts ){
-		printk("APBUART: Failed to allocate SW memory\n\r");
-		return -1;
-	/* Detect System Frequency from initialized timer */
-#ifndef SYS_FREQ_HZ
-#if defined(LEON3)
-	/* LEON3: find timer address via AMBA Plug&Play info */
-		struct ambapp_apb_info gptimer;
-		struct gptimer_regs *tregs;
-		if ( ambapp_find_apbslv(&ambapp_plb, VENDOR_GAISLER,
-		                        GAISLER_GPTIMER, &gptimer) == 1 ){
-			tregs = (struct gptimer_regs *)gptimer.start;
-			sys_freq_hz = (tregs->scaler_reload+1)*1000*1000;
-			DBG("APBUART: detected %dHZ system frequency\n\r",sys_freq_hz);
-		}else{
-			sys_freq_hz = 40000000; /* Default to 40MHz */
-			printk("APBUART: Failed to detect system frequency\n\r");
-#elif defined(LEON2)
-	/* LEON2: use hardcoded address to get to timer */
-		LEON_Register_Map *regs = (LEON_Register_Map *)0x80000000;
-		sys_freq_hz = (regs->Scaler_Reload+1)*1000*1000;
-#else
-  #error CPU not supported for OC_CAN driver
-#endif
-#else
-	/* Use hardcoded frequency */
-	sys_freq_hz = SYS_FREQ_HZ;
-#endif
-	for(i=0; i<dev_cnt; i++){
-		/* Get AMBA AHB device info from Plug&Play */
-		ambapp_find_apbslv_next(amba_bus,VENDOR_GAISLER,GAISLER_APBUART,&dev,i);
-		printk("APBUART[%d]: at 0x%x irq %d (0x%x)\n\r",i,dev.start,dev.irq,(unsigned int)&apbuarts[i]);
-		apbuarts[i].regs = (struct apbuart_regs *)dev.start;
-		apbuarts[i].irq = dev.irq;
-		apbuarts[i].minor = i;
-		/* Clear HW regs */
-		apbuarts[i].regs->status = 0;
-		apbuarts[i].regs->ctrl = 0;
-		/* Allocate default software buffers */
-		apbuarts[i].txfifo = apbuart_fifo_create(DEFAULT_TXBUF_SIZE);
-		apbuarts[i].rxfifo = apbuart_fifo_create(DEFAULT_RXBUF_SIZE);
-		if ( !apbuarts[i].txfifo || !apbuarts[i].rxfifo )
-			rtems_fatal_error_occurred(RTEMS_NO_MEMORY);
-		APBUART_DEVNAME_NO(fs_name,i);
-		/* Bind name to device */
-		DBG("APBUART[%d]: binding to name %s\n\r",i,fs_name);
-		status = rtems_io_register_name(fs_name, major, i);
-		if (status != RTEMS_SUCCESSFUL)
-			rtems_fatal_error_occurred(status);
-		/* Setup interrupt handler for each channel */
-   	APBUART_REG_INT(APBUART_PREFIX(_interrupt_handler), apbuarts[i].irq, &apbuarts[i]);
-		/* Device A Semaphore created with count = 1 */
-		if ( rtems_semaphore_create(rtems_build_name('A', 'U', 'D', '0'+i),
-		     1,
-		     RTEMS_FIFO|RTEMS_SIMPLE_BINARY_SEMAPHORE|RTEMS_NO_INHERIT_PRIORITY|RTEMS_LOCAL|RTEMS_NO_PRIORITY_CEILING,
-		     0,
-		     &apbuarts[i].dev_sem) != RTEMS_SUCCESSFUL )
-			return RTEMS_INTERNAL_ERROR;
-		if ( rtems_semaphore_create(rtems_build_name('A', 'U', 'T', '0'+i),
-		     1,
-		     0,
-		     &apbuarts[i].tx_sem) != RTEMS_SUCCESSFUL )
-		if ( rtems_semaphore_create(rtems_build_name('A', 'U', 'R', '0'+i),
-		     1,
-		     0,
-		     &apbuarts[i].rx_sem) != RTEMS_SUCCESSFUL )
-	return RTEMS_SUCCESSFUL;
-	apbuart_priv *uart;
-	FUNCDBG("apbuart_open: major %d, minor %d\n", major, minor);
-	if ( (minor < 0) || (minor >= dev_cnt) ) {
-		DBG("Wrong minor %d\n", minor);
-		return RTEMS_INVALID_NAME;
-	uart = &apbuarts[minor];
-	if (rtems_semaphore_obtain(uart->dev_sem, RTEMS_NO_WAIT, RTEMS_NO_TIMEOUT) != RTEMS_SUCCESSFUL) {
-		DBG("apbuart_open: resource in use\n");
-		return RTEMS_RESOURCE_IN_USE;
-	uart->regs->status = 0;
-	/* Set Defaults */
-	/* 38400 baudrate */
-	uart->scaler = 0; /* use uart->baud */
-	uart->baud = 38400;
-	/* Default to Blocking mode */
-	uart->txblk = 1;
-	uart->rxblk = 1;
-	/* Default to no flush mode */
-	uart->tx_flush = 0;
-	/* non-ascii mode */
-	uart->ascii_mode = 0;
-  /* not started */
-  uart->started = 0;
-	if ( !uart->txfifo || (uart->txfifo->size!=DEFAULT_TXBUF_SIZE) ){
-		apbuart_fifo_free(uart->txfifo);
-		uart->txfifo = apbuart_fifo_create(DEFAULT_TXBUF_SIZE);
-	if ( !uart->rxfifo || (uart->rxfifo->size!=DEFAULT_RXBUF_SIZE) ){
-		apbuart_fifo_free(uart->rxfifo);
-		uart->rxfifo = apbuart_fifo_create(DEFAULT_RXBUF_SIZE);
-	if ( !uart->rxfifo || !uart->txfifo ){
-		/* Failed to get memory */
-		return RTEMS_NO_MEMORY;
-	/* Now user must call ioctl(START,0) to begin */
-	apbuart_priv *uart = &apbuarts[minor];
-	FUNCDBG("apbuart_close[%d]:\n",minor);
-	apbuart_hw_close(uart);
-	/* Software state will be set when open is called again */
-	rtems_semaphore_release(uart->dev_sem);
-	rtems_libio_rw_args_t *rw_args;
-	unsigned int count = 0, oldLevel;
-	unsigned char *buf;
-	rw_args = (rtems_libio_rw_args_t *) arg;
-	FUNCDBG("apbuart_read\n");
-	buf = (unsigned char *)rw_args->buffer;
-	if ( (rw_args->count < 1) || !buf )
-		return RTEMS_INVALID_NAME; /* EINVAL */
-	rtems_interrupt_disable(oldLevel);
-	do {
-		if ( (unsigned int)uart < 0x40000000 ) {
-	printk("UART %p is screwed\n",uart);
-		/* Read from SW fifo */
-		if ( apbuart_fifo_get(uart->rxfifo,&buf[count]) != 0 ){
-			/* non blocking or read at least 1 byte */
-			if ( (count > 0) || (!uart->rxblk) )
-				break; /* Return */
-			rtems_interrupt_enable(oldLevel);
-			/* Block thread until a char is received */
-			rtems_semaphore_obtain(uart->rx_sem, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
-			continue;
-		/* Got char from SW FIFO */
-		count++;
-	} while (count < rw_args->count );
-	rw_args->bytes_moved = count;
-	if (count == 0)
-		return RTEMS_TIMEOUT; /* ETIMEDOUT should be EAGAIN/EWOULDBLOCK */
-	unsigned int count, oldLevel, ctrl;
-	char *buf;
-	int direct=0;
-	FUNCDBG("apbuart_write\n");
-	buf = rw_args->buffer;
-	if ( rw_args->count < 1 || !buf )
-	count = 0;
-	/* Do we need to start to send first char direct via HW
-	 * to get IRQ going.
-	ctrl = READ_REG(&uart->regs->ctrl);
-	if ( (ctrl & APBUART_CTRL_TF) == 0 ){
-		/* TX interrupt is disabled ==>
-		 * SW FIFO is empty and,
-		 * HW FIFO empty
-		uart->regs->ctrl = ctrl | APBUART_CTRL_TF;
-		if ( uart->ascii_mode && (buf[0] == '\n') ){
-			uart->regs->data = '\r';
-		}else{
-			uart->regs->data = buf[0];
-			count++;
-		uart->regs->ctrl = ctrl | APBUART_CTRL_TE | APBUART_CTRL_TF;
-		direct = 1;
-	while( count < rw_args->count ) {
-		/* write to HW FIFO direct skipping SW FIFO */
-		if ( direct && ((READ_REG(&uart->regs->status) & APBUART_STATUS_TF) == 0) ){
-			uart->regs->data = buf[count];
-		/* write to SW FIFO */
-		else if ( apbuart_fifo_put(uart->txfifo,buf[count]) ){
-			direct = 0;
-			DBG("APBUART[%d]: write: SW FIFO Full\n\r",minor);
-			/* is full, block? */
-			if ( ((count < 1) && uart->txblk) || uart->tx_flush ){
-				rtems_semaphore_obtain(uart->tx_sem, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
-					 * HW FIFO empty
-					if ( uart->ascii_mode && (buf[count] == '\n') ){
-					}else{
-						count++;
-					uart->regs->ctrl = ctrl | APBUART_CTRL_TF | APBUART_CTRL_TE;
-					direct = 1;
-				continue;
-			/* don't block, return current status */
-			break;
-		}else{
-			direct = 0;
-		count++;
-	if (count == 0)
-	rtems_libio_ioctl_args_t *ioarg = (rtems_libio_ioctl_args_t *)arg;
-	unsigned int *data = ioarg->buffer;
-	int size;
-	unsigned int baudrate, blocking;
-	apbuart_stats *stats;
-	FUNCDBG("apbuart_control [%i,%i]\n",major, minor);
-	if (!ioarg)
-  ioarg->ioctl_return = 0;
-	switch(ioarg->command) {
-	/* Enable Receiver & transmitter */
-	case APBUART_START:
-		if ( uart->started )
-		apbuart_hw_open(uart);
-		uart->started = 1;
-		break;
-	/* Close Receiver & transmitter */
-	case APBUART_STOP:
-		if ( !uart->started )
-		break;
-	/* Set RX FIFO Software buffer length
-	 * It is only possible to change buffer size in
-	 * non-running mode.
-	case APBUART_SET_RXFIFO_LEN:
-			return RTEMS_RESOURCE_IN_USE; /* EBUSY */
-		size = (int)ioarg->buffer;
-		if ( size < 1 )
-		/* Free old buffer */
-		/* Allocate new buffer & init it */
-		uart->rxfifo = apbuart_fifo_create(size);
-		if ( !uart->rxfifo )
-		break;
-	/* Set TX FIFO Software buffer length
-	 * while in non-running mode.
-	case APBUART_SET_TXFIFO_LEN:
-		if ( size < 1 )
-		uart->txfifo = apbuart_fifo_create(size);
-		if ( !uart->txfifo )
-		break;
-	case APBUART_SET_BAUDRATE:
-		/* Set baud rate of */
-		baudrate = (int)ioarg->buffer;
-		if ( (baudrate < 1) || (baudrate > 115200) ){
-		uart->baud = baudrate;
-		break;
-	case APBUART_SET_SCALER:
-		/* use uart->scaler not uart->baud */
-		uart->scaler = data[0];
-		break;
-	case APBUART_SET_BLOCKING:
-		blocking = (unsigned int)ioarg->buffer;
-		uart->rxblk = ( blocking & APBUART_BLK_RX );
-		uart->txblk = ( blocking & APBUART_BLK_TX );
-		uart->tx_flush = ( blocking & APBUART_BLK_FLUSH );
-		break;
-	case APBUART_GET_STATS:
-		stats = (void *)ioarg->buffer;
-		if ( !stats )
-		/* Copy Stats */
-		*stats = uart->stats;
-		break;
-  case APBUART_CLR_STATS:
-		/* Clear/reset Stats */
-    memset(&uart->stats,0,sizeof(uart->stats));
-		break;
-	case APBUART_SET_ASCII_MODE:
-		uart->ascii_mode = (int)ioarg->buffer;
-		break;
-	default:
-		return RTEMS_NOT_DEFINED;
-/******************* APBUART FIFO implementation ***********************/
-static apbuart_fifo *apbuart_fifo_create(int size){
-	apbuart_fifo *fifo;
-	fifo = (apbuart_fifo *) malloc(size + sizeof(apbuart_fifo));
-	if ( fifo ) {
-		/* Init fifo */
-		fifo->size = size;
-		fifo->buf = (unsigned char *)(fifo+1);
-		fifo->tail = fifo->buf;
-		fifo->head = fifo->buf;
-		fifo->max = &fifo->buf[size-1];
-		fifo->full=0;
-	return fifo;
-static void apbuart_fifo_free(apbuart_fifo *fifo){
-	if ( fifo )
-		free(fifo);
-static inline int apbuart_fifo_isFull(apbuart_fifo *fifo){
-	return fifo->full;
-static inline int apbuart_fifo_isEmpty(apbuart_fifo *fifo){
-	if ( (fifo->head == fifo->tail) && !fifo->full )
-		return -1;
-	return 0;
-static int apbuart_fifo_put(apbuart_fifo *fifo, unsigned char c){
-	if ( !fifo->full ){
-		*fifo->head = c;
-		fifo->head = (fifo->head >= fifo->max ) ? fifo->buf : fifo->head+1;
-		if ( fifo->head == fifo->tail )
-			fifo->full = -1;
-		return 0;
-	return -1;
-static int apbuart_fifo_get(apbuart_fifo *fifo, unsigned char *c){
-	if ( apbuart_fifo_isEmpty(fifo) )
-		return -1;
-	if ( c )
-		*c = *fifo->tail;
-	fifo->tail = (fifo->tail >= fifo->max ) ? fifo->buf : fifo->tail+1;
-	fifo->full = 0;
-	return 0;
-static int inline apbuart_fifo_peek(apbuart_fifo *fifo, unsigned char **c){
-		return -1;
-	if ( c )
-		*c = fifo->tail;
-	return 0;
-static void inline apbuart_fifo_skip(apbuart_fifo *fifo){
-	if ( !apbuart_fifo_isEmpty(fifo) ){
-		fifo->full = 0;
2.7.4
