[PATCH] confdefs.h: Add SMP enabled field to configuration
Sebastian Huber
Fri May 12 08:11:32 UTC 2017
Do not use the processor count to determine if SMP is enabled. Instead
use a dedicated configuration option. Enable SMP by default in SMP
configurations.
Add CONFIGURE_DISABLE_SMP_CONFIGURATION to all test which would fail
otherwise.
Update #3001.
cpukit/sapi/include/confdefs.h | 7 +++++++
cpukit/sapi/include/rtems/config.h | 6 +++++-
testsuites/libtests/cpuuse/system.h | 2 ++
testsuites/libtests/rtmonuse/system.h | 2 ++
testsuites/libtests/termios05/init.c | 2 ++
testsuites/sptests/sp01/system.h | 2 ++
testsuites/sptests/sp08/init.c | 2 ++
testsuites/sptests/sp14/system.h | 2 ++
testsuites/sptests/sp20/system.h | 2 ++
testsuites/sptests/sp37/system.h | 2 ++
testsuites/sptests/spcbssched01/system.h | 2 ++
testsuites/sptests/spcbssched02/system.h | 2 ++
testsuites/sptests/spcbssched03/system.h | 2 ++
testsuites/sptests/spedfsched01/system.h | 2 ++
testsuites/sptests/spedfsched02/system.h | 2 ++
testsuites/sptests/spedfsched03/system.h | 2 ++
testsuites/sptests/spfifo03/init.c | 2 +-
testsuites/sptests/spfifo05/init.c | 2 +-
testsuites/tmtests/tm08/system.h | 2 ++
testsuites/tmtests/tm22/system.h | 2 ++
20 files changed, 46 insertions(+), 3 deletions(-)
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index 5cba1a8..4ac6700 100755
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -3320,6 +3320,13 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#else
false,
#endif
+ #ifdef RTEMS_SMP
+ #ifdef _CONFIGURE_SMP_APPLICATION
+ true,
+ #else
+ false,
+ #endif
+ #endif
_CONFIGURE_NUMBER_OF_INITIAL_EXTENSIONS, /* number of static extensions */
CONFIGURE_INITIAL_EXTENSION_TABLE, /* pointer to static extensions */
#if defined(RTEMS_MULTIPROCESSING)
diff --git a/cpukit/sapi/include/rtems/config.h b/cpukit/sapi/include/rtems/config.h
index ddcb77c..2993e70 100644
--- a/cpukit/sapi/include/rtems/config.h
+++ b/cpukit/sapi/include/rtems/config.h
@@ -237,6 +237,10 @@ typedef struct {
bool stack_allocator_avoids_work_space;
+ #ifdef RTEMS_SMP
+ bool smp_enabled;
+ #endif
uint32_t number_of_initial_extensions;
const rtems_extensions_table *User_extension_table;
@@ -360,7 +364,7 @@ extern const rtems_configuration_table Configuration;
#ifdef RTEMS_SMP
#define rtems_configuration_is_smp_enabled() \
- (rtems_configuration_get_maximum_processors() > 1)
+ (Configuration.smp_enabled)
#else
false
diff --git a/testsuites/libtests/cpuuse/system.h b/testsuites/libtests/cpuuse/system.h
index 0501d41..562f2db 100644
--- a/testsuites/libtests/cpuuse/system.h
+++ b/testsuites/libtests/cpuuse/system.h
@@ -50,6 +50,8 @@ void Task_switch(
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_DISABLE_SMP_CONFIGURATION
#include <rtems/confdefs.h>
/* global variables */
diff --git a/testsuites/libtests/rtmonuse/system.h b/testsuites/libtests/rtmonuse/system.h
index 1544f80..b7bb5f1 100644
--- a/testsuites/libtests/rtmonuse/system.h
+++ b/testsuites/libtests/rtmonuse/system.h
@@ -47,6 +47,8 @@ void Get_all_counters( void );
#define CONFIGURE_EXTRA_TASK_STACKS (20 * RTEMS_MINIMUM_STACK_SIZE)
diff --git a/testsuites/libtests/termios05/init.c b/testsuites/libtests/termios05/init.c
index 3cdf969..e9f1531 100644
--- a/testsuites/libtests/termios05/init.c
+++ b/testsuites/libtests/termios05/init.c
@@ -166,6 +166,8 @@ rtems_task Init(
#define CONFIGURE_INIT
diff --git a/testsuites/sptests/sp01/system.h b/testsuites/sptests/sp01/system.h
index a317dd9..68f8277 100644
--- a/testsuites/sptests/sp01/system.h
+++ b/testsuites/sptests/sp01/system.h
@@ -31,6 +31,8 @@ rtems_task Task_1_through_3(
#define CONFIGURE_EXTRA_TASK_STACKS (4 * RTEMS_MINIMUM_STACK_SIZE)
#define CONFIGURE_MAXIMUM_TASKS 4
diff --git a/testsuites/sptests/sp08/init.c b/testsuites/sptests/sp08/init.c
index 77e9819..2364c70 100644
--- a/testsuites/sptests/sp08/init.c
+++ b/testsuites/sptests/sp08/init.c
@@ -300,6 +300,8 @@ rtems_task Init(
/* end of file */
diff --git a/testsuites/sptests/sp14/system.h b/testsuites/sptests/sp14/system.h
index 7721366..3a63a8d 100644
--- a/testsuites/sptests/sp14/system.h
+++ b/testsuites/sptests/sp14/system.h
@@ -51,6 +51,8 @@ rtems_task Task_2(
#define CONFIGURE_EXTRA_TASK_STACKS (1 * RTEMS_MINIMUM_STACK_SIZE)
diff --git a/testsuites/sptests/sp20/system.h b/testsuites/sptests/sp20/system.h
index dfefe4b..cbc926a 100644
--- a/testsuites/sptests/sp20/system.h
+++ b/testsuites/sptests/sp20/system.h
diff --git a/testsuites/sptests/sp37/system.h b/testsuites/sptests/sp37/system.h
index 6bb47ec..67a62d2 100644
--- a/testsuites/sptests/sp37/system.h
+++ b/testsuites/sptests/sp37/system.h
@@ -39,6 +39,8 @@ rtems_task Init(
#define CONFIGURE_MAXIMUM_TASKS 2
#define CONFIGURE_MAXIMUM_TIMERS 1
/* end of include file */
diff --git a/testsuites/sptests/spcbssched01/system.h b/testsuites/sptests/spcbssched01/system.h
index 2ba1db5..813a7a0 100644
--- a/testsuites/sptests/spcbssched01/system.h
+++ b/testsuites/sptests/spcbssched01/system.h
@@ -37,6 +37,8 @@ rtems_task Task_1_through_3(
diff --git a/testsuites/sptests/spcbssched02/system.h b/testsuites/sptests/spcbssched02/system.h
index dba3d13..302b9b5 100644
--- a/testsuites/sptests/spcbssched02/system.h
+++ b/testsuites/sptests/spcbssched02/system.h
@@ -43,6 +43,8 @@ rtems_task Task_Periodic(
#define CONFIGURE_SCHEDULER_CBS
#include <rtems/rtems/clock.h>
diff --git a/testsuites/sptests/spcbssched03/system.h b/testsuites/sptests/spcbssched03/system.h
index 4ad5204..7ce4884 100644
--- a/testsuites/sptests/spcbssched03/system.h
+++ b/testsuites/sptests/spcbssched03/system.h
@@ -47,6 +47,8 @@ rtems_task Tasks_Aperiodic(
diff --git a/testsuites/sptests/spedfsched01/system.h b/testsuites/sptests/spedfsched01/system.h
index b930cb1..e673b1f 100644
--- a/testsuites/sptests/spedfsched01/system.h
+++ b/testsuites/sptests/spedfsched01/system.h
diff --git a/testsuites/sptests/spedfsched02/system.h b/testsuites/sptests/spedfsched02/system.h
index c92a398..cbdb7ad 100644
--- a/testsuites/sptests/spedfsched02/system.h
+++ b/testsuites/sptests/spedfsched02/system.h
@@ -49,6 +49,8 @@ void Get_all_counters( void );
#define CONFIGURE_SCHEDULER_EDF
diff --git a/testsuites/sptests/spedfsched03/system.h b/testsuites/sptests/spedfsched03/system.h
index 95922ae..ec5af82 100644
--- a/testsuites/sptests/spedfsched03/system.h
+++ b/testsuites/sptests/spedfsched03/system.h
diff --git a/testsuites/sptests/spfifo03/init.c b/testsuites/sptests/spfifo03/init.c
index 0fb024a..5aa4800 100644
--- a/testsuites/sptests/spfifo03/init.c
+++ b/testsuites/sptests/spfifo03/init.c
@@ -215,9 +215,9 @@ rtems_task Init(
#define CONFIGURE_MAXIMUM_BARRIERS 1
-#define CONFIGURE_INIT
#define CONFIGURE_MAXIMUM_FIFOS 1
diff --git a/testsuites/sptests/spfifo05/init.c b/testsuites/sptests/spfifo05/init.c
index 1ccdd49..a5ce313 100644
--- a/testsuites/sptests/spfifo05/init.c
+++ b/testsuites/sptests/spfifo05/init.c
@@ -270,9 +270,9 @@ rtems_task Init(
#define CONFIGURE_MAXIMUM_BARRIERS 2
diff --git a/testsuites/tmtests/tm08/system.h b/testsuites/tmtests/tm08/system.h
index 3610fe9..e6af3c1 100644
--- a/testsuites/tmtests/tm08/system.h
+++ b/testsuites/tmtests/tm08/system.h
@@ -32,6 +32,8 @@ rtems_task Init(
diff --git a/testsuites/tmtests/tm22/system.h b/testsuites/tmtests/tm22/system.h
index fa7795f..89c7138 100644
--- a/testsuites/tmtests/tm22/system.h
+++ b/testsuites/tmtests/tm22/system.h
@@ -38,6 +38,8 @@ rtems_task Init(
CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE(100, MESSAGE_SIZE )
1.8.4.5
