GCC 7.1 Released
Fri May 12 08:39:20 UTC 2017
On 12/05/17 10:35, Chris Johns wrote:
> On 12/05/2017 15:56, Sebastian Huber wrote:
>> On 11/05/17 17:29, Joel Sherrill wrote:
>>> Ok to
>>> On May 11, 2017 5:09 AM, "Sebastian Huber"
>>> <sebastian.huber at embedded-brains.de
>>> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>>>     Hello,
>>>     if someone wants to use GCC 7.1 for RTEMS 4.12, then the RSB
>>>     should be updated accordingly as soon as possible.
>>> Chris posted a patch to bump gcc and binutils. He just needs to push
>>> it.
>> I didn't see the patch. According to
> I have not posted anything.
>> contrib/download_prerequisites
>> we should use
>> gmp='gmp-6.1.0.tar.bz2'
>> mpfr='mpfr-3.1.4.tar.bz2'
>> mpc='mpc-1.0.3.tar.gz'
>> isl='isl-0.16.1.tar.bz2'
>> for GCC 7.
> I talked to Joel late his time yesterday and he is reporting increased
> code size and as a result some tests are not fitting into the target.
> Rather than head on into the change we think it is better to step back
> and visit it again after we have a release. What do you think?
A code size increase would be not an issue for me if its in the range of
a small percent range. However, we should identify this and create a GCC PR.
Gaisler suggested to use GCC 7.1. Did Gaisler observe some significant
code size changes on SPARC?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
