[PATCH] confdefs.h: Add SMP enabled field to configuration
Fri May 12 08:39:27 UTC 2017
On 12/05/2017 18:11, Sebastian Huber wrote:
> Do not use the processor count to determine if SMP is enabled.  Instead
> use a dedicated configuration option.  Enable SMP by default in SMP
> configurations.
> Add CONFIGURE_DISABLE_SMP_CONFIGURATION to all test which would fail
> otherwise.
I think adding a comment to the test explaining the reason would be good
to have.
