[PATCH] confdefs.h: Add SMP enabled field to configuration
Fri May 12 08:44:02 UTC 2017
On 12/05/17 10:39, Chris Johns wrote:
> On 12/05/2017 18:11, Sebastian Huber wrote:
>> Do not use the processor count to determine if SMP is enabled.  Instead
>> use a dedicated configuration option.  Enable SMP by default in SMP
>> configurations.
>> Add CONFIGURE_DISABLE_SMP_CONFIGURATION to all test which would fail
>> otherwise.
> I think adding a comment to the test explaining the reason would be
> good to have.
This is a new issue and not a 4.12 release blocker from my point of view:
https://devel.rtems.org/ticket/3020
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
