[PATCH] confdefs.h: Add SMP enabled field to configuration
Fri May 12 09:20:55 UTC 2017
On 12/05/17 11:15, Joel Sherrill wrote:
> On May 12, 2017 3:44 AM, "Sebastian Huber"
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     On 12/05/17 10:39, Chris Johns wrote:
>         On 12/05/2017 18:11, Sebastian Huber wrote:
>             Do not use the processor count to determine if SMP is
>             enabled.  Instead
>             use a dedicated configuration option.  Enable SMP by
>             default in SMP
>             configurations.
>             Add CONFIGURE_DISABLE_SMP_CONFIGURATION to all test which
>             would fail
>             otherwise.
>         I think adding a comment to the test explaining the reason
>         would be good to have.
>     This is a new issue and not a 4.12 release blocker from my point
>     of view:
>     https://devel.rtems.org/ticket/3020
>     <https://devel.rtems.org/ticket/3020>
> This does not address Chris' question. Whether a blocker or not, it
> needs a comment for each test.
Yes, see the new ticket. The question is when you add a comment.
> You can't add this patch without the comments before or after branching.
I don't have time to go through 35 tests to look why they don't work in
an SMP configuration at the moment. If we want to release 4.12 some time
in the future we should really identify the blocking issues, otherwise
the release will never happen.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
