[PATCH] confdefs.h: Add SMP enabled field to configuration
Fri May 12 09:39:34 UTC 2017
On 12/05/17 11:20, Sebastian Huber wrote:
> On 12/05/17 11:15, Joel Sherrill wrote:
>> On May 12, 2017 3:44 AM, "Sebastian Huber"
>> <sebastian.huber at embedded-brains.de
>> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>>     On 12/05/17 10:39, Chris Johns wrote:
>>         On 12/05/2017 18:11, Sebastian Huber wrote:
>>             Do not use the processor count to determine if SMP is
>>             enabled.  Instead
>>             use a dedicated configuration option.  Enable SMP by
>>             default in SMP
>>             configurations.
>>             Add CONFIGURE_DISABLE_SMP_CONFIGURATION to all test which
>>             would fail
>>             otherwise.
>>         I think adding a comment to the test explaining the reason
>>         would be good to have.
>>     This is a new issue and not a 4.12 release blocker from my point
>>     of view:
>>     https://devel.rtems.org/ticket/3020
>>     <https://devel.rtems.org/ticket/3020>
>> This does not address Chris' question. Whether a blocker or not, it
>> needs a comment for each test.
> Yes, see the new ticket. The question is when you add a comment.
>> You can't add this patch without the comments before or after branching.
> I don't have time to go through 35 tests to look why they don't work
> in an SMP configuration at the moment. If we want to release 4.12 some
> time in the future we should really identify the blocking issues,
> otherwise the release will never happen.
Maybe we should do this:
#warning "https://devel.rtems.org/ticket/3020"
#define CONFIGURE_DISABLE_SMP_CONFIGURATION
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
