suggested changes and bug fixes for RTEMS
Fri May 12 15:20:41 UTC 2017
Thank you Phong,
As noted by Sebastian on Trac, please use your name and real email
address in your git configuration. We need this to track the
authorship of code.
After passing review etc, the patches will be merged into rtems and be
immediately available via git-pull. We are approaching the 4.12
release, so getting these patches into shape and merging should get
your changes into 4.12 and give you a reasonably stable development
point for products.
Gedare
On Thu, May 11, 2017 at 8:02 PM, Pham, Phong <phamp at ddc-web.com> wrote:
> Hi Gedare,
> Enclosed are your requests for items 1-3.  I logged a ticket for item 4 but feel free to postpone or close the ticket.  Just curious, in general when will the committed changes (after sending you the patch like above) be available for someone to git clone the latest rtems tree?
> Phong.
> -----Original Message-----
> From: gedare at gwmail.gwu.edu [mailto:gedare at gwmail.gwu.edu] On Behalf Of Gedare Bloom
> Sent: Tuesday, May 09, 2017 12:26 PM
> To: Pham, Phong
> Cc: devel at rtems.org
> Subject: Re: suggested changes and bug fixes for RTEMS
> On Tue, May 9, 2017 at 12:16 PM, Pham, Phong <phamp at ddc-web.com> wrote:
>> Hi RTEMS Maintainers,
>> Pls. let me know which of these item # changes below (or delta within
>> a given item #) you do not wish to accommodate in the main line so
>> that I will provide it as part of my BSP.  I am porting RTEMS to IBM
>> PowerPC 750 chip; very similar to MPC750 but there are minute differences.
>> 1)      Bug: In
>> rtems\c\src\lib\libbsp\shared\src\irq-generic.c:bsp_interrupt_allocate_handler_index().
>> See attachment irq-generic.c vs. irq-generic.c.orig
> Please open a ticket on our Trac and attach a git-commit patch there or here, with "Close #xxxx." in the commit message. You can see the git-log for examples of how to format the commit message.
>> 2)      Enhancement: Add support for IBM PowerPC 750 chip in
>> rtems\c\src\lib\libcpu\powerpc\shared\include\cpuIdent.[c,h] and
>> rtems\c\src\lib\libcpu\powerpc\new-exceptions\bspsupport\ppc_exc_categ
>> ories.c
> Should be fine.
>> 3)      Bug: Missing a couple registers when DLAB is 1 in
>> rtems\c\src\libchip\serial\ns16550_p.h.  Also add a #ifndef ASM around
>> libchip/serial.h inclusion.
> Ditto on Trac.
>> 4)      Suggestion: In pci.h, there are references to BSP_pci_configuration
>> data structure which is in pci.c.  However, in this file, there are
>> also references to detect_host_bridge () in detect_raven_bridge.c.
>> For folks that are just interested in pci_read_config_dword() + its
>> brothers, all they need is to include pci.h and content for where
>> BSP_pci_configuration is defined.  The rest of the stuff in pci.c
>> should be separate.  Or in another word, data structures and #defines
>> involving with BSP_pci_configuration needs to be in separate files
>> rather all stuffed in pci.c
> Refactoring pci.c is acceptable.
>> 5)      rtems\c\src\lib\libcpu\powerpc\mpc6xx\mmu\pte121.c:triv121PgTblMap()
>> implementation only map virtual address to be the same as physical
>> address for a given address range (start + numPages).  It also assume
>> an increment of page size for a given address range.  I suggest that
>> an argument of
>> triv121PgTblMap() is needed to specify the physical address to be
>> mapped to for a given range of addresses.  Also another parameter is
>> whether or not to increment PhysAddr for each page.  Enclosed in
>> pte121.c is an implementation of triv121PgTblMapPhysAddr() where a
>> physical address is provided and it is hard coded not to increase the physical address for a given address range.
>> So APIs are needed for these requests.  Don’t know if and how much you
>> want to support me.  If not, I’ll just add whatever you’re not
>> supporting in my BSP.
> RTEMS does not have support for a non-identity mapping of virtual-physical memory. It is not clear that a non-identity mapping will work correctly, although I see no reason why it would not. You are welcome to suggest/implement improvements in this space. We have investigated some efforts to create BSP level memory management, see the ARM bsps for some ideas, and there are previous attempts to create APIs for memory management/protection, but nothing that has been mergeable. https://devel.rtems.org/wiki/Projects/MMU_Support
>> Thanks,
>> Phong.
>> PS: There are a couple more items but the first five should get things
>> rolling.
>> Notice: This e-mail and any files transmitted with it may contain Data
>> Device Corporation's privileged and proprietary information. It is
>> intended solely for the use of the individual or entity to whom it is
>> addressed. If you are not the named recipient of this transmission,
>> any disclosure, copying, distribution or reliance on the contents of
>> this message is prohibited. If you received this e-mail in error,
>> please destroy it and any attached files and notify me immediately.
> See if you can disable this notice for messages sent to the mailing list.
>> devel mailing list
>> devel at rtems.org
> Notice: This e-mail and any files transmitted with it may contain Data Device Corporation's privileged and proprietary information. It is intended solely for the use of the individual or entity to whom it is addressed. If you are not the named recipient of this transmission, any disclosure, copying, distribution or reliance on the contents of this message is prohibited. If you received this e-mail in error, please destroy it and any attached files and notify me immediately.
