[PATCH 2/2] Beagle i2c: Update Beaglebone i2c driver code
Sun May 14 13:17:57 UTC 2017
If something isn't clear from the coding conventions wiki page, please feel
free to ask.
--joel
On May 14, 2017 8:12 AM, "Sichen Zhao" <zsc19940506 at outlook.com> wrote:
> Hi Christian,
> I will read the coding conventions and modify the patch as soon as
> possible.
> Thank you
> Sichen Zhao
> *From:* devel <devel-bounces at rtems.org> on behalf of Christian Mauderer <
> christian.mauderer at embedded-brains.de>
> *Sent:* Sunday, May 14, 2017 8:42 PM
> *To:* Sichen Zhao
> *Cc:* punit vara; devel at rtems.org
> *Subject:* Re: [PATCH 2/2] Beagle i2c: Update Beaglebone i2c driver code
> Hello Sichen Zhao,
> I haven't tested the code yet. But on a first look, I noted some points
> regarding the style:
> - If I apply the patches, there are a lot of "trailing whitespace" warnings
> - There are some // comments in the code
> - Quite a number of lines is longer than 80 characters
> - There are some functions with really unnecessary blank lines like
> am335x_i2c_set_clock
> There is no unique coding style throughout RTEMS but there are some
> guidelines here:
>     https://devel.rtems.org/wiki/Developer/Coding/Conventions
> It's good style for new code to follow these conventions. Knowing that you
> will work with the libbsd too, please note that these conventions are only
> for RTEMS core system. In the libbsd, most of the code follows the
> BSD-Style.
> Kind regards
> Christian
> ----- Ursprüngliche Mail -----
> > Von: "Sichen Zhao" <1473996754 at qq.com>
> > An: devel at rtems.org, "punit vara" <punitvara at gmail.com>, "Christian
> Mauderer" <christian.mauderer at embedded-brains.de>
> > Gesendet: Samstag, 13. Mai 2017 05:52:13
> > Betreff: [PATCH 2/2] Beagle i2c: Update Beaglebone i2c driver code
> > This patch modify the i2c code for Beaglebone Black based on PV works:
> > - bbb-i2c.c: Modify the interrupt handler, transfer funciton, read
> function,
> > am335x_i2c_busbusy function etc. Add flush_fifo function
> > - include/i2c.h: Modify some macros, such as BBB_I2C_IRQ_ERROR
> > Now the i2c is working on Beaglebone Black, it can read the EEPROM
> information.
> > c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c | 378
> > c/src/lib/libbsp/arm/beagle/include/i2c.h |  11 +-
> > 2 files changed, 150 insertions(+), 239 deletions(-)
> > diff --git a/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
> > b/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
> > index 6b790e5..4d22831 100644
> > --- a/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
> > +++ b/c/src/lib/libbsp/arm/beagle/i2c/bbb-i2c.c
> > @@ -21,88 +21,8 @@
> > #include <bsp/bbb-gpio.h>
> > #include <rtems/score/assert.h>
> > -static bool am335x_i2c_pinmux(bbb_i2c_bus *bus)
> > -  bool status =true;
> > -    // We will check i2c_bus_id in am335x_i2c_bus_register
> > -    // Apart from mode and pull_up register what about SCREWCTRL &
> RXACTIVE ??
> > -  if (bus->i2c_bus_id == I2C1) {
> > -    REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_CS0) =
> (BBB_MUXMODE(MODE2) |
> > BBB_PU_EN);
> > -    REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_D1) =
> > BBB_PU_EN);
> > -    REG(AM335X_PADCONF_BASE + AM335X_CONF_UART1_TXD) =
> (BBB_MUXMODE(MODE3) |
> > BBB_PU_EN);
> > -    REG(AM335X_PADCONF_BASE + AM335X_CONF_UART1_RXD) =
> > BBB_PU_EN);
> > -  } else if (bus->i2c_bus_id == I2C2) {
> > -    REG(AM335X_PADCONF_BASE + AM335X_CONF_UART1_RTSN) =
> > BBB_PU_EN);
> > -    REG(AM335X_PADCONF_BASE + AM335X_CONF_UART1_CTSN) =
> > BBB_PU_EN);
> > -    REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_D0) =
> > BBB_PU_EN);
> > -    REG(AM335X_PADCONF_BASE + AM335X_CONF_SPI0_SCLK) =
> > BBB_PU_EN);
> > -  } else {
> > -  status = false;
> > -  return status;
> > -/* ref. Table 21-4 I2C Clock Signals */
> > - For I2C1/2
> > - Interface clock - 100MHz - CORE_LKOUTM4 / 2 - pd_per_l4ls_gclk
> > - Functional clock - 48MHz - PER_CLKOUTM2 / 4 - pd_per_ic2_fclk
> > -static void am335x_i2c1_i2c2_module_clk_config(bbb_i2c_bus *bus)
> > -/*0x2 = SW_WKUP : SW_WKUP: Start a software forced wake-up
> > -transition on the domain. */
> > -  REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKSTCTRL) |=
> > -                        AM335X_CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL_SW_WKUP;
> > -  while((REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKSTCTRL) &
> > -                        AM335X_CM_PER_L4LS_CLKSTCTRL_CLKTRCTRL) !=
> CLKTRCTRL_SW_WKUP);
> > -/* 0x2 = ENABLE : Module is explicitly enabled. Interface clock (if not
> > -used for functions) may be gated according to the clock domain
> > -state. Functional clocks are guarantied to stay present. As long as in
> > -this configuration, power domain sleep transition cannot happen.*/
> > - /* REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKCTRL) |=
> > -                        AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE;
> > -  while((REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKCTRL) &
> > -      AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE) !=
> > AM335X_CM_PER_L4LS_CLKCTRL_MODULEMODE_ENABLE);
> > -/*0x2 = ENABLE : Module is explicitly enabled. Interface clock (if not
> > -  REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C1_CLKCTRL) |=
> > -                             AM335X_CM_PER_I2C1_CLKCTRL_
> MODULEMODE_ENABLE;
> > -  while(REG((AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C1_CLKCTRL) &
> > -     AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE) !=
> > AM335X_CM_PER_I2C1_CLKCTRL_MODULEMODE_ENABLE);
> > -  REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C2_CLKCTRL) |=
> > -                             AM335X_CM_PER_I2C2_CLKCTRL_
> MODULEMODE_ENABLE;
> > -  while(REG((AM335X_CM_PER_ADDR + AM335X_CM_PER_I2C2_CLKCTRL) &
> > -     AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE) !=
> > AM335X_CM_PER_I2C2_CLKCTRL_MODULEMODE_ENABLE);
> > -  while(!(REG(AM335X_CM_PER_ADDR + AM335X_CM_PER_L4LS_CLKSTCTRL) &
> > -           (AM335X_CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_L4LS_GCLK |
> > -            AM335X_CM_PER_L4LS_CLKSTCTRL_CLKACTIVITY_I2C_FCLK)));
> > +static void flush_fifo(i2c_bus *base);
> > static void am335x_i2c0_pinmux(bbb_i2c_bus *bus)
> > @@ -303,43 +223,59 @@ static void I2C0ModuleClkConfig(void)
> >            CM_WKUP_I2C0_CLKCTRL_IDLEST));
> > -void am335x_i2c_init(bbb_i2c_bus *bus, uint32_t input_clock)
> > -  // am335x_i2c_pinmux()
> > -  // am335x_i2c1_i2c2_module_clk_config
> > static bool am335x_i2c_busbusy(volatile bbb_i2c_regs *regs)
> >   bool status;
> > +  int stat;
> > +  int timeout=I2C_TIMEOUT;
> > +   while ((stat = readw(&regs->BBB_I2C_IRQSTATUS_RAW) &
> > +    AM335X_I2C_IRQSTATUS_RAW_BB) && timeout--) {
> > +    writew(stat, &regs->BBB_I2C_IRQSTATUS);
> > +    udelay(100);
> > -  if (REG(&regs->BBB_I2C_IRQSTATUS_RAW) & AM335X_I2C_IRQSTATUS_RAW_BB)
> > +  if (timeout <= 0) {
> > +    printf("Timed out in wait_for_bb: status=%04x\n",
> > +           stat);
> > +   status = true;
> > +  else
> > -    status = true;
> > -  } else {
> > -    status = false;
> > +  writew(0xFFFF, &regs->BBB_I2C_IRQSTATUS);   /* clear delayed stuff*/
> > +   status = false;
> >   return status;
> > static void am335x_i2c_reset(bbb_i2c_bus *bus)
> >   volatile bbb_i2c_regs *regs = bus->regs;
> > -  printk("reset bus->reg is %x \n",bus->regs);
> > -  /* Disable I2C module at the time of initialization*/
> > -  /*Should I use write32 ?? I guess mmio_clear is correct choice here*/
> > -  printk("inside BBB_I2C_CON value is %x \n",&regs->BBB_I2C_CON);
> > -  mmio_clear((&regs->BBB_I2C_CON),AM335X_I2C_CON_I2C_EN);
> > -  mmio_clear((&regs->BBB_I2C_SYSC),AM335X_I2C_SYSC_AUTOIDLE);
> > -  //REG(bus->regs + AM335X_I2C_CON) &= ~(AM335X_I2C_CON_I2C_EN);
> > -  //REG(bus->regs + AM335X_I2C_SYSC) &= ~(AM335X_I2C_SYSC_AUTOIDLE);
> > -  can I clear all the interrupt here ?
> > -  mmio_write(get_reg_addr(bbb_i2c_bus->reg->AM335X_I2C_IRQ_ENABLE_CLR),
> > +   int timeout = I2C_TIMEOUT;
> > +   if (readw(&regs->BBB_I2C_CON) & I2C_CON_EN) {
> > +    writew(0, &regs->BBB_I2C_CON);
> > +    udelay(50000);
> > +  writew(0x2, &regs->BBB_I2C_SYSC); /* for ES2 after soft reset */
> > +  udelay(1000);
> > +  writew(I2C_CON_EN, &regs->BBB_I2C_CON);
> > +  while (!(readw(&regs->BBB_I2C_SYSS) & I2C_SYSS_RDONE) && timeout--) {
> > +      puts("ERROR: Timeout in soft-reset\n");
> > +      return;
> > +    udelay(1000);
> > @@ -368,7 +304,7 @@ static void am335x_i2c_next_byte(bbb_i2c_bus *bus)
> >   i2c_msg *msg;
> > -  printk("Enter next_byte\n");
> >   ++bus->msgs;
> >   --bus->msg_todo;
> > @@ -410,61 +346,26 @@ static void am335x_clean_interrupts(volatile
> bbb_i2c_regs
> > *regs)
> > static void am335x_i2c_setup_read_transfer(bbb_i2c_bus *bus, volatile
> > bbb_i2c_regs *regs, const i2c_msg *msgs, bool send_stop)
> >   volatile unsigned int no_bytes;
> > -  //am335x_i2c_masterint_enable(regs, AM335X_I2C_INT_RECV_READY);
> > -   // No of data to be transmitted at a time
> > -  REG(&regs->BBB_I2C_CNT) = 0x02;
> > -  no_bytes = REG(&regs->BBB_I2C_CNT);
> > -  // I2C Controller in Master Mode
> > -  REG(&regs->BBB_I2C_CON) = AM335X_I2C_CFG_MST_TX |
> AM335X_I2C_CON_I2C_EN |
> > AM335X_I2C_CON_START | AM335X_I2C_CON_MST;
> > -  printk("set master in transmission mode %x
> \n",REG(&regs->BBB_I2C_CON));
> > +  int status;
> > -  // Set Slave address & Master enable, bring out of reset
> > -  REG(&regs->BBB_I2C_SA) = msgs->addr;
> > -  printf("slave address : %x\n",REG(&regs->BBB_I2C_SA));
> > -  // clear status of all interrupts
> > -  am335x_clean_interrupts(regs);
> > -  printk("\n set memory address to read\n");
> > -  // transmit interrupt is enabled
> > -  am335x_i2c_masterint_enable(regs,AM335X_I2C_IRQSTATUS_XRDY);
> > -  printk("Enable transmit interrupt \n");
> > -  //start condition
> > -  REG(&regs->BBB_I2C_CON) |= AM335X_I2C_CON_START;
> > -  printk("start transmission \n");
> > -  while(am335x_i2c_busbusy(regs) == 0);
> > -  printk("bus is free \n");
> > -  printk("CNT : %x\n", no_bytes);
> > -  while(0 != no_bytes);
> > -  printk("total msg count for tranmission is zero \n");
> > -  while( !(am335x_i2c_intrawstatus(regs) &
> (AM335X_I2C_IRQSTATUS_ARDY)));
> > +    REG(&regs->BBB_I2C_CNT) = bus->current_msg_todo;
> > -  printk("Enter read transfer \n");
> > -   // No of data to be received at a time(msg_count!!)
> > -  printk("msg_todo for read is %d \n",bus->msg_todo);
> > -  REG(&regs->BBB_I2C_CNT) = bus->msg_todo;
> > -  //am335x_clean_interrupts(regs);
> >   REG(&regs->BBB_I2C_CON) = AM335X_I2C_CFG_MST_RX |
> >   AM335X_I2C_CON_MST;
> > -  printk("Set master to receiver mode %x \n", REG(&regs->BBB_I2C_CON));
> >   // receive interrupt is enabled
> >   am335x_i2c_masterint_enable(regs, AM335X_I2C_INT_RECV_READY |
> >   AM335X_I2C_INT_STOP_CONDITION);
> >   if (send_stop) {
> >     // stop condition
> > -    printk("stop to read\n");
> >     REG(&regs->BBB_I2C_CON) |= AM335X_I2C_CON_STOP;
> >   } else {
> >     // start condition
> > -    printk("start to read\n");
> > -  printk("Exit read transfer\n");
> > @@ -473,85 +374,63 @@ static void am335x_i2c_continue_read_transfer(
> > -  printk("enter continue read transfer \n");
> >   bus->current_msg_byte[bus->already_transferred] =
> REG(&regs->BBB_I2C_DATA);
> >   bus->already_transferred++;
> >   am335x_int_clear(regs,AM335X_I2C_INT_RECV_READY);
> > -  printk("clear RRDY in continue read transfer\n");
> >   if (bus->already_transferred == REG(&regs->BBB_I2C_CNT)) {
> > -    printk("continue read transfer finished \n");
> > -    //am335x_i2c_setup_read_transfer(bus,regs,false);
> >     am335x_i2c_masterint_disable(regs, AM335X_I2C_INT_RECV_READY);
> > -    printk("disable RRDY in continue read transfer\n");
> > -    printk("stop condition in continue read transfer
> > %x\n",REG(&regs->BBB_I2C_CON));
> > static void am335x_i2c_continue_write(bbb_i2c_bus *bus, volatile
> bbb_i2c_regs
> > *regs)
> > -   REG(&regs->BBB_I2C_DATA) = 0x00;
> > -   am335x_int_clear(regs, AM335X_I2C_IRQSTATUS_XRDY);
> > -   printk("clear XRDY continue write\n");
> > -   if (bus->already_transferred == REG(&regs->BBB_I2C_CNT)) {
> > -   printk("\n finished transfer \n");
> > -   am335x_i2c_masterint_disable(regs, AM335X_I2C_IRQSTATUS_XRDY);
> > -   printk("disable XRDY continue write \n");
> > -   REG(&regs->BBB_I2C_CON) |= AM335X_I2C_CON_STOP;
> > -   } else {
> > -     printk("write memory address \n");
> > -     REG(&regs->BBB_I2C_DATA) = *bus->current_msg_byte;
> > -   if (bus->already_transferred == bus->msg_todo) {
> > -     printk("finished transfer \n");
> > -   } else {
> > -     printk("remaining byte \n");
> > bus->current_msg_byte[bus->already_transferred];
> > -     printk("%s",REG(&regs->BBB_I2C_DATA));
> > -     bus->already_transferred++;
> > +  writeb(0x0,&regs->BBB_I2C_DATA);
> > +   writew(AM335X_I2C_IRQSTATUS_XRDY, &regs->BBB_I2C_IRQSTATUS);
> > -static void am335x_i2c_setup_write_transfer(bbb_i2c_bus *bus,volatile
> > bbb_i2c_regs *regs)
> > +static void am335x_i2c_setup_write_transfer(bbb_i2c_bus *bus,volatile
> > bbb_i2c_regs *regs, const i2c_msg *msgs)
> > -  printk(" \n Enter write transfer \n");
> >   // Following data count specify bytes to be transmitted
> > -  // Already cleaned during reset
> > +  REG(&regs->BBB_I2C_SA) = msgs->addr;
> >   // I2C Controller in Master transmitter Mode
> AM335X_I2C_CON_I2C_EN;
> > -  printk("enable master in transmiter mode setup write
> > +  am335x_clean_interrupts(regs);
> > -  printk("enable XRDY setup write\n");
> > +  am335x_i2c_masterint_enable(regs,AM335X_I2C_IRQSTATUS_XRDY );
> >   //start condition
> > -  printk("set start condition in setup write %x
> > -  printk("CNT in setup write : %x \n",REG(&regs->BBB_I2C_CNT));
> > -  printk("setup write msg_todo %x \n",bus->current_todo);
> > -  printk("check whether ???\n");
> > -  printk("RAW =  %x",REG(&regs->BBB_I2C_IRQSTATUS_RAW));
> > +  while(am335x_i2c_busbusy(regs)==0);
> >   while( !((am335x_i2c_intrawstatus(regs)) &
> > -  printk("exit setup write \n");
> > @@ -562,9 +441,7 @@ static void am335x_i2c_setup_transfer(bbb_i2c_bus
> *bus,
> >   bool send_stop = false;
> >   uint32_t i;
> > -  printk("Enter setup transfer\n");
> >   bus->current_todo = msgs[0].len;
> >   for (i = 1; i < msg_todo && (msgs[i].flags & I2C_M_NOSTART) != 0; ++i)
> >     bus->current_todo += msgs[i].len;
> > @@ -574,18 +451,22 @@ static void am335x_i2c_setup_transfer(bbb_i2c_bus
> *bus,
> >   REG(&bus->regs->BBB_I2C_BUF) |= AM335X_I2C_BUF_TXFIFO_CLR;
> >   REG(&bus->regs->BBB_I2C_BUF) |= AM335X_I2C_BUF_RXFIFO_CLR;
> >   am335x_i2c_set_address_size(msgs,regs);
> > -  bus->read = ((bus->read == true) ? 0:1);
> > +  bus->read = (msgs->flags & I2C_M_RD) != 0;
> >   bus->already_transferred = (bus->read == true) ? 0 : 1;
> >   if (bus->read) {
> >     if (REG(&regs->BBB_I2C_CNT) == 1) {
> >       send_stop = true;
> > -    printk("configure to read bus\n");
> >     am335x_i2c_setup_read_transfer(bus,regs,msgs,send_stop);
> >   } else {
> > -    printk("configure to write bus\n");
> > -    am335x_i2c_setup_write_transfer(bus,regs);
> > +    am335x_i2c_setup_write_transfer(bus,regs,msgs);
> > @@ -597,42 +478,45 @@ static void am335x_i2c_interrupt(void *arg)
> >   /* get status of enabled interrupts */
> >   uint32_t irqstatus = REG(&regs->BBB_I2C_IRQSTATUS);
> >   bool done = false;
> > -  printk("\n inside interrupt function \n");
> >   /* Clear all enabled interrupt except receive ready and transmit ready
> interrupt
> >   in status register */
> > -  REG(&regs->BBB_I2C_IRQSTATUS) = (irqstatus &
> ~(AM335X_I2C_IRQSTATUS_RRDY |
> > AM335X_I2C_IRQSTATUS_XRDY));
> > -  printk("\n irqstatus = %x \n",REG(&regs->BBB_I2C_IRQSTATUS));
> > +  REG(&regs->BBB_I2C_IRQSTATUS) = (irqstatus & ~(
> >   if (irqstatus & AM335X_I2C_INT_RECV_READY) {
> > -     printk("\nInside receive interrupt\n");
> > +   delay_bbb_i2c
> >     am335x_i2c_continue_read_transfer(bus, regs);
> >   if (irqstatus & AM335X_I2C_IRQSTATUS_XRDY) {
> > -    printk("\ninside transmit interrupt \n");
> >     am335x_i2c_continue_write(bus,regs);
> >   if (irqstatus & AM335X_I2C_IRQSTATUS_NACK) {
> >     done = true;
> > -    printk("inside NACK\n");
> >     am335x_i2c_masterint_disable(regs,AM335X_I2C_IRQSTATUS_NACK);
> > +  if (irqstatus & AM335X_I2C_IRQSTATUS_ARDY) {
> > +   done = true;
> > +  writew(I2C_STAT_ARDY, &regs->BBB_I2C_IRQSTATUS);
> >   if (irqstatus & AM335X_I2C_IRQSTATUS_BF) {
> >     done = true;
> > -    printk("inside BF \n ");
> >   if (done) {
> >     uint32_t err = irqstatus & BBB_I2C_IRQ_ERROR;
> > -    printk("interrupt done \n");
> >     am335x_i2c_next_byte(bus);
> > -    if (bus->msg_todo == 0 || err != 0) {
> > +    if (bus->msg_todo == 0 ) {
> >     rtems_status_code sc;
> > -    // am335x_i2c_disable_interrupts(regs);
> >     am335x_i2c_masterint_disable(regs, (AM335X_I2C_IRQSTATUS_RRDY |
> >     AM335X_I2C_IRQSTATUS_XRDY | AM335X_I2C_IRQSTATUS_BF));
> >     REG(&regs->BBB_I2C_IRQSTATUS) = err;
> > @@ -641,6 +525,7 @@ static void am335x_i2c_interrupt(void *arg)
> >     _Assert(sc == RTEMS_SUCCESSFUL);
> >     (void) sc;
> >     } else {
> >       am335x_i2c_setup_transfer(bus, regs);
> > @@ -652,7 +537,6 @@ static int am335x_i2c_transfer(i2c_bus *base,
> i2c_msg *msgs,
> > uint32_t msg_count)
> >   bbb_i2c_bus *bus = (bbb_i2c_bus *)base;
> >   volatile bbb_i2c_regs *regs;
> >   uint32_t i;
> > - printk("\n enter transfer ");
> >   rtems_task_wake_after(1);
> > @@ -668,11 +552,11 @@ static int am335x_i2c_transfer(i2c_bus *base,
> i2c_msg
> > *msgs, uint32_t msg_count)
> >   bus->msgs = &msgs[0];
> >   bus->msg_todo = msg_count;
> > -  printk("total msg = msg_count : %x \n",bus->msg_todo);
> >   bus->current_msg_todo = msgs[0].len;// current data size
> >   bus->current_msg_byte = msgs[0].buf;// current data
> > -  printk("\n current_msg_todo %x \n ",msgs[0].len);
> > -  printk("\n current_msg_byte %x \n ",msgs[0].buf);
> >   bus->task_id = rtems_task_self();
> >   regs = bus->regs;
> > @@ -688,8 +572,6 @@ static int am335x_i2c_transfer(i2c_bus *base,
> i2c_msg *msgs,
> > uint32_t msg_count)
> >     return -ETIMEDOUT;
> > -  printk("exit transfer\n");
> > -  // return bus->regs->BBB_I2C_IRQSTATUS == 0 ? 0 : -EIO;
> >   return 0;
> > @@ -699,21 +581,17 @@ static int am335x_i2c_set_clock(i2c_bus *base,
> unsigned
> > long clock)
> >   uint32_t prescaler,divider;
> > -  printk("set clock start\n");
> >   prescaler = (BBB_I2C_SYSCLK / BBB_I2C_INTERNAL_CLK) -1;
> > -  printk("PSC offset %x \n ",&regs->BBB_I2C_PSC);
> > -  printk("PSC offset %x \n", &bus->regs->BBB_I2C_PSC);
> > -  //mmio_write((&regs->BBB_I2C_PSC), prescaler);
> >   REG(&bus->regs->BBB_I2C_PSC) = prescaler;
> >   divider = BBB_I2C_INTERNAL_CLK/(2*clock);
> > -  printk("SCLL offset %x \n",&bus->regs->BBB_I2C_SCLL);
> > -  //mmio_write((&regs->BBB_I2C_SCLL), (divider - 7));
> >   REG(&bus->regs->BBB_I2C_SCLL) = (divider - 7);
> > -  //mmio_write((&regs->BBB_I2C_SCLH), (divider - 5));
> > -  printk("SCHL offset %x\n",&bus->regs->BBB_I2C_SCLH);
> >   REG(&bus->regs->BBB_I2C_SCLH) = (divider - 5);
> > -  printk("set clock end \n");
> >   return 0;
> > @@ -721,11 +599,11 @@ static void am335x_i2c_destroy(i2c_bus *base)
> >   bbb_i2c_bus *bus = (bbb_i2c_bus *) base;
> > -  printk(" starting destroy\n");
> >   sc = rtems_interrupt_handler_remove(bus->irq, am335x_i2c_interrupt,
> bus);
> >   (void)sc;
> > -  printk("end destroy\n");
> >   i2c_bus_destroy_and_free(&bus->base);
> > @@ -759,7 +637,7 @@ int am335x_i2c_bus_register(
> > // 4. configure bus speed
> >   bus->input_clock = input_clock; // By default 100KHz. Normally pass
> 100KHz as
> >   argument
> > -  printk("Before set clock \n");
> >   err = am335x_i2c_set_clock(&bus->base, I2C_BUS_CLOCK_DEFAULT);
> >   if (err != 0) {
> > @@ -771,7 +649,11 @@ int am335x_i2c_bus_register(
> >   //bring I2C out of reset
> > -   REG(&bus->regs->BBB_I2C_CON) |= AM335X_I2C_CON_I2C_EN;
> > +   udelay(1000);
> > +  flush_fifo(&bus->base);
> > +  writew(0xFFFF, &bus->regs->BBB_I2C_IRQSTATUS);
> >   // 5. Start interrupt service routine & one interrupt at a time
> >   sc  = rtems_interrupt_handler_install(
> > @@ -791,6 +673,30 @@ int am335x_i2c_bus_register(
> >   bus->base.transfer = am335x_i2c_transfer;
> >   bus->base.set_clock = am335x_i2c_set_clock;
> >   bus->base.destroy = am335x_i2c_destroy;
> > -  printk("exit register\n");
> >   return i2c_bus_register(&bus->base,bus_path);
> > +  bbb_i2c_bus *bus = (bbb_i2c_bus *) base;
> > +  volatile bbb_i2c_regs *regs = bus->regs;
> > +  int stat;
> > +   * note: if you try and read data when its not there or ready
> > +   * you get a bus error
> > +  while (1) {
> > +    stat = readw(&bus->regs->BBB_I2C_IRQSTATUS);
> > +    if (stat == I2C_STAT_RRDY) {
> > +      readb(&bus->regs->BBB_I2C_DATA);
> > +      writew(I2C_STAT_RRDY, &bus->regs->BBB_I2C_IRQSTATUS);
> > +      udelay(1000);
> > +    } else
> > +      break;
> > diff --git a/c/src/lib/libbsp/arm/beagle/include/i2c.h
> > b/c/src/lib/libbsp/arm/beagle/include/i2c.h
> > index d4a9e32..a4fcf21 100644
> > --- a/c/src/lib/libbsp/arm/beagle/include/i2c.h
> > +++ b/c/src/lib/libbsp/arm/beagle/include/i2c.h
> > @@ -132,11 +132,11 @@ extern "C" {
> > #define DISP_LINE_LEN 128
> > -#define I2C_TIMEOUT 1000
> > +#define I2C_TIMEOUT 500
> > #define I2C_BUS_MAX 3
> > -#define I2C_BASE1         (OMAP34XX_CORE_L4_IO_BASE + 0x070000)
> > +#define I2C_BASE1         (OMAP34XX_CORE_L4_IO_BASE + 0x070000)
> > //0x48000000+0x070000
> > #define I2C_DEFAULT_BASE      I2C_BASE1
> > @@ -356,7 +356,7 @@ static inline rtems_status_code beagle_i2c_read(
> >     | AM335X_I2C_IRQSTATUS_ARDY \
> >     | AM335X_I2C_IRQSTATUS_RRDY \
> >     | AM335X_I2C_IRQSTATUS_XRDY \
> > -    | AM335X_I2C_IRQSTATUS_XUDF)
> > +    | AM335X_I2C_IRQSTATUS_XUDF )
> > #define BBB_I2C_IRQ_USED \
> >   ( BBB_I2C_IRQ_ERROR \
> > @@ -378,6 +378,8 @@ static inline rtems_status_code beagle_i2c_read(
> > #define MODE2 2
> > #define MODE3 3
> > +#define delay_bbb_i2c printf("     ");
> > typedef enum {
> >   I2C0,
> >   I2C1,
> > @@ -478,6 +480,9 @@ static inline int bbb_register_i2c_2(void)
> > #ifdef __cplusplus
> > #endif /* __cplusplus */
> > 2.7.4
> > devel mailing list
> > devel at rtems.org
> embedded brains GmbH
> Christian Mauderer
> Dornierstr. 4
> D-82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> Phone: +49-89-18 94 741 - 18 <+49%2089%20189474118>
> Fax:   +49-89-18 94 741 - 08 <+49%2089%20189474108>
> PGP: Public key available on request.
> devel mailing list
> devel at rtems.org
> devel Info Page - RTEMS <http://lists.rtems.org/mailman/listinfo/devel>
> lists.rtems.org
> Developer discussions.. To see the collection of prior postings to the
> list, visit the devel Archives. Using devel: To post a message to all the
> list ...
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20170514/05aa12fc/attachment-0001.html>
