[PATCH 04/11] Add USB UGEN support for RTEMS
Kevin Kirspel
kevin-kirspel at idexx.com
Mon May 15 17:26:31 UTC 2017
freebsd/sys/dev/usb/usb_dev.c | 10 ++++++++++
rtemsbsd/include/rtems/bsd/local/opt_usb.h | 2 +-
2 files changed, 11 insertions(+), 1 deletion(-)
diff --git a/freebsd/sys/dev/usb/usb_dev.c b/freebsd/sys/dev/usb/usb_dev.c
index fe249c2..da96a99 100644
--- a/freebsd/sys/dev/usb/usb_dev.c
+++ b/freebsd/sys/dev/usb/usb_dev.c
@@ -804,9 +804,11 @@ usb_fifo_close(struct usb_fifo *f, int fflags)
/* check if a thread wants SIGIO */
if (f->async_p != NULL) {
+#ifndef __rtems__
PROC_LOCK(f->async_p);
kern_psignal(f->async_p, SIGIO);
PROC_UNLOCK(f->async_p);
+#endif /* __rtems__ */
f->async_p = NULL;
/* remove FWRITE and FREAD flags */
@@ -1025,6 +1027,7 @@ usb_ioctl_f_sub(struct usb_fifo *f, u_long cmd, void *addr,
break;
case FIOASYNC:
+#ifndef __rtems__
if (*(int *)addr) {
error = EBUSY;
@@ -1034,6 +1037,9 @@ usb_ioctl_f_sub(struct usb_fifo *f, u_long cmd, void *addr,
} else {
f->async_p = NULL;
+#else /* __rtems__ */
+ f->async_p = NULL;
break;
/* XXX this is not the most general solution */
@@ -1042,10 +1048,12 @@ usb_ioctl_f_sub(struct usb_fifo *f, u_long cmd, void *addr,
error = EINVAL;
break;
+#ifndef __rtems__
if (*(int *)addr != USB_PROC_GET_GID(f->async_p)) {
error = EPERM;
break;
break;
default:
return (ENOIOCTL);
@@ -1769,11 +1777,13 @@ usb_fifo_wakeup(struct usb_fifo *f)
selwakeup(&f->selinfo);
f->flag_isselect = 0;
+#ifndef __rtems__
static int
diff --git a/rtemsbsd/include/rtems/bsd/local/opt_usb.h b/rtemsbsd/include/rtems/bsd/local/opt_usb.h
index 7eb6148..2b7227b 100644
--- a/rtemsbsd/include/rtems/bsd/local/opt_usb.h
+++ b/rtemsbsd/include/rtems/bsd/local/opt_usb.h
@@ -1,6 +1,6 @@
#define USB_HAVE_CONDVAR 1
-#define USB_HAVE_UGEN 0
+#define USB_HAVE_UGEN 1
#define USB_HAVE_BUSDMA 1
1.9.1
