[PATCH 07/11] Add bitcount inlinesfor RTEMS. These are found in FREEBSDs types.h
Kevin Kirspel kevin-kirspel at idexx.com
Mon May 15 17:26:34 UTC 2017
 freebsd/sys/sys/bitstring.h          |   3 +
 rtemsbsd/include/machine/bitstring.h | 107 +++++++++++++++++++++++++++++++++++
 2 files changed, 110 insertions(+)
 create mode 100644 rtemsbsd/include/machine/bitstring.h
diff --git a/freebsd/sys/sys/bitstring.h b/freebsd/sys/sys/bitstring.h
index 18c9187..8fd9b25 100644
--- a/freebsd/sys/sys/bitstring.h
+++ b/freebsd/sys/sys/bitstring.h
@@ -68,6 +68,9 @@
 #endif
 #include <sys/types.h>
+#ifdef __rtems__
+#include <machine/bitstring.h>
+#endif /* __rtems__ */
 typedef	unsigned long bitstr_t;
diff --git a/rtemsbsd/include/machine/bitstring.h b/rtemsbsd/include/machine/bitstring.h
new file mode 100644
index 0000000..419cb6d
--- /dev/null
+++ b/rtemsbsd/include/machine/bitstring.h
@@ -0,0 +1,107 @@
+ * Copyright (c) 1982, 1986, 1991, 1993, 1994
+ *	The Regents of the University of California.  All rights reserved.
+ * (c) UNIX System Laboratories, Inc.
+ * All or some portions of this file are derived from material licensed
+ * to the University of California by American Telephone and Telegraph
+ * Co. or Unix System Laboratories, Inc. and are reproduced herein with
+ * the permission of UNIX System Laboratories, Inc.
+ * are met:
+ * 3. Neither the name of the University nor the names of its contributors
+ *    may be used to endorse or promote products derived from this software
+ *    without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ *	@(#)types.h	8.6 (Berkeley) 2/19/95
+ * $FreeBSD$
+#ifndef _RTEMS_BSD_MACHINE_BITSTRING_H_
+#define	_RTEMS_BSD_MACHINE_BITSTRING_H_
+#ifndef _SYS_BITSTRING_H_
+#error "the header file <sys/bitstring.h> must be included first"
+#endif
+#ifdef __POPCNT__
+#define	__bitcount64(x)	__builtin_popcountll((__uint64_t)(x))
+#define	__bitcount32(x)	__builtin_popcount((__uint32_t)(x))
+#define	__bitcount16(x)	__builtin_popcount((__uint16_t)(x))
+#define	__bitcountl(x)	__builtin_popcountl((unsigned long)(x))
+#define	__bitcount(x)	__builtin_popcount((unsigned int)(x))
+#else
+ * Population count algorithm using SWAR approach
+ * - "SIMD Within A Register".
+static __inline __uint16_t
+__bitcount16(__uint16_t _x)
+	_x = (_x & 0x5555) + ((_x & 0xaaaa) >> 1);
+	_x = (_x & 0x3333) + ((_x & 0xcccc) >> 2);
+	_x = (_x + (_x >> 4)) & 0x0f0f;
+	_x = (_x + (_x >> 8)) & 0x00ff;
+	return (_x);
+static __inline __uint32_t
+__bitcount32(__uint32_t _x)
+	_x = (_x & 0x55555555) + ((_x & 0xaaaaaaaa) >> 1);
+	_x = (_x & 0x33333333) + ((_x & 0xcccccccc) >> 2);
+	_x = (_x + (_x >> 4)) & 0x0f0f0f0f;
+	_x = (_x + (_x >> 8));
+	_x = (_x + (_x >> 16)) & 0x000000ff;
+	return (_x);
+#ifdef __LP64__
+static __inline __uint64_t
+__bitcount64(__uint64_t _x)
+	_x = (_x & 0x5555555555555555) + ((_x & 0xaaaaaaaaaaaaaaaa) >> 1);
+	_x = (_x & 0x3333333333333333) + ((_x & 0xcccccccccccccccc) >> 2);
+	_x = (_x + (_x >> 4)) & 0x0f0f0f0f0f0f0f0f;
+	_x = (_x + (_x >> 16));
+	_x = (_x + (_x >> 32)) & 0x000000ff;
+	return (_x);
+#define	__bitcountl(x)	__bitcount64((unsigned long)(x))
+#else
+	return (__bitcount32(_x >> 32) + __bitcount32(_x));
+#define	__bitcountl(x)	__bitcount32((unsigned long)(x))
+#endif
+#define	__bitcount(x)	__bitcount32((unsigned int)(x))
+#endif
+#endif /* !_RTEMS_BSD_MACHINE_BITSTRING_H_ */
1.9.1
