[PATCH 07/11] Add bitcount inlinesfor RTEMS. These are found in FREEBSDs types.h
Kirspel, Kevin Kevin-Kirspel at idexx.com
Tue May 16 13:18:24 UTC 2017
Sorry.  I pulled that header file from memory which these days is losing its effectiveness.  So, should we put the bitcount changes in sys/types.h like FREEBSD?
If so, I will submit a patch to newlib at sourceware.org.  How long does it take to get the patch reviewed by the newlib mailing list?
Kevin Kirspel
Electrical Engineer - Sr. Staff
Idexx Roswell
235 Hembree Park Drive
Roswell GA 30076
Tel: (770)-510-4444 ext. 81642
Direct: (770)-688-1642
Fax: (770)-510-4445
-----Original Message-----
From: Sebastian Huber [mailto:sebastian.huber at embedded-brains.de]
Sent: Tuesday, May 16, 2017 9:06 AM
To: Kirspel, Kevin <Kevin-Kirspel at idexx.com>; devel at rtems.org
Subject: Re: [PATCH 07/11] Add bitcount inlinesfor RTEMS. These are found in FREEBSDs types.h
On 16/05/17 14:56, Kirspel, Kevin wrote:
> Should we put this in cdefs.h like FREEBSD?
In FreeBSD the __bitcount*() functions are defined in <sys/types.h>.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
